HOW TO Increase gas mileage - Page 2 - S-10 Forum
post #51 of 64 Old 07-09-2004, 06:55 PM
MPETESS10's Avatar
User is: MPETESS10 is offline
Send a message via AIM to MPETESS10
Re: HOW TO Increase gas mileage
Originally Posted by Crew Cab Sonoma
a friend on mine tried that in Atlanta, he passed the code check, until the inspector noticed the telltale, typical non-catalyst stench coming from his exhaust pipes...so they demanded he pass the sniffer test too... he failed...and he was told he would have to pass another sniffer test in order to pass again...regardless of where in ATL he went to have it checked...
well if I end up in that scenario I guess I will just have to get another cat and put it on there but in the mean time I am not gonna worry about it
I only have to do emmissions testing every 2 years and its only 6 bolts and 2 gaskets to remove my cat/straight pipe and swap em around
of course right now my truck is too low to be tested at all so they just give me an exemption for 2 years and that was back in may or june (cant remember) but well see how things go in 2 years
96 S10 ex cab sportside ZQ8 4.3/5spd 3.42's 207K &counting :fingerscrossed:
2011 F150 ex cab 4x4 5.0 COYOTE POWERED
post #52 of 64 Old 07-09-2004, 07:17 PM
"factory freak"...
Crew Cab Sonoma's Avatar
too low to be tested?
95 S-10 2.2. Soon to be DD
post #53 of 64 Old 07-10-2004, 12:37 PM
MPETESS10's Avatar
yes
at MD emissions stations you have to drive over the rollers to get to the spot where they do the diagnostic tests and the sniff tests
my truck sits too low to make it over the rollers and they are too wrried about damaging something on the customers vehicle
it happens way too much already as it is so they are paranoid about it
which is fine because I cant stand it when other people drive my truck anyway because I am to worried about something getting messed up
there is only one other person that has driven my truck since I put in the manual valve body 700r4
and the only reason I let him is because he was the one who helped me put it in and his race car has a manual valvebody tranny so i know he knows what to do/how to drive it
post #54 of 64 Old 09-02-2004, 11:23 PM
User is: Generic0 is offline
How dose an restrictor in the egr line work and how do i do it? would the computer get mad it i pluged the tube completly?
Generic0 is offline
post #55 of 64 Old 09-02-2004, 11:38 PM
Quad-Turbocharged Blazer
nystateofmind27's Avatar
User is: nystateofmind27 is offline
Send a message via AIM to nystateofmind27
Reduce Weight! Stop carrying a trunkful of junk around. Maintain proper tire pressure. Don't stop on the gas, rather just let the acceleration build up until the required speed then ease off the pedal. Homemade intake is a must. It should cost around $50 max. Keep throttle body and sensors clean with tb cleaner. Don't go over 65 mph highway and try to maintain a constant speed.
post #56 of 64 Old 09-02-2004, 11:40 PM
You also have to remember, EPA ratings for a blazer are something like 17/21. If you are somewhere in the middle in mixed driving, you are getting excellent mpg and are very unlikely to see much better gas milage.
post #57 of 64 Old 09-03-2004, 12:52 AM
loco hombre
nater006's Avatar
User is: nater006 is offline
Send a message via AIM to nater006
E-fan was my best mod, mileage-wise. Can't wait to see what the pulleys do.
nater006 is offline
post #58 of 64 Old 09-03-2004, 03:28 AM
"factory freak"...
hey Nate, when you installing them? youve had them in your sig. for a long time....
post #59 of 64 Old 09-03-2004, 03:55 AM
"factory freak"...
crap, double post....
post #60 of 64 Old 09-03-2004, 01:25 PM
User is: Lander215 is offline
I have a '94 Blazer with CPI, 148,500 miles and am getting 21mpg in mixed driving.
Bought it with 100k on it and haven't touched the O2 sensor (I did just find it however, because it was rattling!). I'm guessing since my mileage is so good that I'm better off leaving it alone (the O2 sensor that is), correct?
I did get tired of cleaning the EGR valve and bought a new one last year. Also had to put a fuel filter on it after it stalled out with my wife and kids. Beyond that, just normal maintenance does the trick. And I love the no payments thing as well! lol
post #61 of 64 Old 09-03-2004, 02:55 PM
Clean N' Dark
BlazerLT's Avatar
User is: BlazerLT is offline
Originally Posted by jjrambo
thanks now as soon as i get the cast off my arm i can finally do the mod. been waiting t do it for a while.
EGR MOD does nothing for fuel economy.
Check out this link for good factual information with no biased opinions:
http://www.autoshop101.com/forms/h61.pdf
1995 Blazer LT 4 Door 4x4
4.3L CPI Vortec
Ravin Z55 Performance Muffler
K&N FIPK Gen2 Cold Air Intake
BlazerLT is offline
post #62 of 64 Old 09-03-2004, 04:53 PM
loco hombre
nater006's Avatar
haven't had much time between school and work... I have the Crane HI6 sitting here, and the March 3-piece set. was considering sending it back for the 2-piece but.. the money's spent so its not a biggie Going to get them on this fall, for sure, just have been busy as hell...
Guess my "can't wait to see what the pulleys do" should have been worded... "can't wait till I have more time and ambition to put the things on"
nater006 is offline
post #63 of 64 Old 09-03-2004, 06:50 PM
Got Snow?
s10eric's Avatar
User is: s10eric is offline
Send a message via AIM to s10eric Send a message via Yahoo to s10eric
I did the TB plate mod (took off the butterfly) and haven't had any problems, nor with the descreened MAF. The TB plate definitely was a disappointment. The modified air box is awesome (don't waste 200-300 on a intake). Gears are the best idea though and are next on my list. Just my 2 cents.
'03 V6 -- Summit White X-Cab -- Homemade Air Intake -- Descreened MAF -- TB Spacer -- Modified TB Plate -- Magnaflow Exhaust -- B&M Electronic Shift Improver -- 180* Thermostat -- Fabtech Lift Spindles -- 30" BFG ATs on Axis Regulators with Silver Ring -- Much more to come...
s10eric is offline
post #64 of 64 Old 09-04-2004, 08:07 AM
"factory freak"...
i know what you mean all too well....
