HOW TO: Change A 4.3 Distributor...Chilton's Way... - S-10 Forum
post #1 of 40 Old 04-25-2012, 08:14 PM Thread Starter
SSRT-S10
my_nightmare's Avatar
This is a Copy of the pdf page in the Chiltons book on how to change a distributor.
I thought I would post it here if It can be useful to others...
Also I would definetly recommend not ever buying the oem plastic dizzy to replace the original one. They are prone to alot of issues. (Mostly the cap screw holes strip out extremely easy.) I reccomnd getting a good aluminum dizzy to replace it and follow the procedures below.
Here Ya go....
Removal Procedure
Caution! There are two procedures available to install the distributor.Use Installation Procedure 1 when the crankshaft has NOT been rotated from the original position.Use Installation Procedure 2 when any of the following components are removed:
The intake manifold
The cylinder head
The camshaft
The timing chain or sprockets
The complete engine
If the malfunction indicator lamp (MIL) turns on and DTC P1345 sets after installing the distributor, this indicates an incorrectly installed distributor.Engine damage or distributor damage may occur. Use Procedure 2 in order to install the distributor.
  1. Turn OFF the ignition.
  2. Remove air cleaner assembly. Refer to Air Cleaner Assembly Replacement .
  3. Remove the spark plug wires from the distributor cap. (I cant state this enough...MARK THE WIRES FOR WHAT CYLINDER THEY ARE ON USING A WHITE_OUT OR MARKER PEN!!!)
    - Twist each spark plug boot 1/2 turn.
    - Pull only on the wire boot in order to remove the wire from the distributor cap.
  4. Remove the electrical connector from the base of the distributor.
  5. Remove the 2 screws that hold the distributor cap to the housing.
  6. Discard the screws.
  7. Remove the distributor cap from the housing.
  1. Use a grease pencil in order to note the position of the rotor in relation to the distributor housing (1).
  2. Mark the distributor housing and the intake manifold with a grease pencil.
  3. Remove the mounting clamp hold down bolt.
  4. Remove the distributor.
  5. As the distributor is being removed from the engine, watch the rotor move in a counter-clockwise direction about 42 degrees. This will appear as slightly more than 1 clock position.
  6. Note the position of the rotor segment.
  7. Place a second mark on the base of the distributor (2). This will aid in achieving proper rotor alignment during the distributor installation.
  1. If installing a new distributor assembly, place 2 marks on the new distributor housing in the same location as the 2 marks on the original housing.
  2. Remove the new distributor cap, if necessary.
  3. Align the rotor with the second mark (2).
  4. Guide the distributor into the engine.
  5. Align the hole in the distributor hold-down base over the mounting hole in the intake manifold.
  6. As the distributor is being installed, observe the rotor moving in a clockwise direction about 42 degrees.
  7. Once the distributor is completely seated, the rotor segment should be aligned with the mark on the distributor base (1).
    - If the rotor segment is not aligned with the number 1 mark, the driven gear teeth and the camshaft have meshed one or more teeth out of alignment.
    - In order to correct this condition, remove the distributor and reinstall the distributor.
  8. Caution! Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
  9. Install the distributor mounting clamp bolt.
    Tighten
    Tighten the distributor clamp bolt to 25 N·m (18 lb ft).
  10. Install the distributor cap.
  11. Install 2 new distributor cap screws.
    Tighten
    Tighten the screws to 2.4 N·m (21 lb in).
  12. Install the electrical connector to the distributor.
  13. Install the spark plug wires to the distributor cap.
  14. Install the ignition coil wire.Note the correct orientation of the wire boot. Important If the malfunction indicator lamp (MIL) is turned ON after installing the distributor, and a DTC P1345 is found, the distributor has been installed incorrectly.
  15. Refer to installation procedure 2 if malfunction indicator lamp is turned ON after installing the distributor.
  1. Important Rotate the number 1 cylinder to TDC of the compression stroke. The engine front cover has 2 alignment tabs and the crankshaft balancer has 2 alignment marks (spaced 90 degrees apart) which are used for positioning number 1 piston at TDC. With the piston on the compression stroke and at top dead center, the crankshaft balancer alignment mark (1) must align with the engine front cover tab (2) and the crankshaft balancer alignment mark (4) must align with the engine front cover tab (3).
  2. Rotate the crankshaft balancer clockwise until the alignment marks on the crankshaft balancer are aligned with the tabs on the engine front cover and the number 1 piston is at top dead center of the compression stroke.
  3. Align white paint mark on the bottom stem of the distributor, and the pre-drilled indent hole in the bottom of the gear (3).
    Caution! The ignition system distributor driven gear and rotor may be installed in multiple positions. In order to avoid mistakes, mark the distributor on the following components in order to ensure the same mounting position upon reassembly:
    The distributor driven gear
    The distributor shaft
    The rotor holes
    Installing the driven gear 180 degrees out of alignment, or locating the rotor in the wrong holes, will cause a no-start condition. Premature engine wear or damage may result.
  4. With the gear in this position, the rotor segment should be positioned as shown for a V6 engine (1) or V8 engine (2).
    - The alignment will not be exact.
    - If the driven gear is installed incorrectly, the dimple will be approximately 180 degrees opposite of the rotor segment when the gear is installed in the distributor.
  5. Using a long screw driver, align the oil pump drive shaft to the drive tab of the distributor.
  6. Guide the distributor into the engine. Ensure that the spark plug towers are perpendicular to the centerline of the engine.
  7. Once the distributor is fully seated, the rotor segment should be aligned with the pointer cast into the distributor base.
    - There may be a 6 cast into this pointer, indicating that the distributor is to be used on a 6 cylinder engine or an 8, indicating that the distributor is to be used on a 8 cylinder engine.
    - If the rotor segment does not come within a few degrees of the pointer, the gear mesh between the distributor and the camshaft may be off a tooth or more.
    - If this is the case, repeat the procedure again in order to achieve proper alignment.
    Tighten
    Tighten
  14. Install the ignition coil wire.Note the correct orientation of the wire boot. Important If the MIL is turned ON after installing the distributor, and a DTC P1345 is found, the distributor has been installed incorrectly.
  15. Repeat installation procedure 2 if the malfunction indicator lamp is turned ON after installing the distributor.
Hope this helps...,
L8taz,
Allen
I hope this works on the pics this time....lol
Last edited by Sonomanclature; 04-26-2012 at 12:49 AM. Reason: Fixed pictures of original post
post #2 of 40 Old 04-25-2012, 08:31 PM
Maybe later.
tytotheler92's Avatar
Re: HOW TO: Change A 4.3 Distributor...Chilton's Way...
Pictures are not working FYI.
2016 Toyota Tacoma TRD Sport 6 speed
1985 S10 Blazer 4WD
post #3 of 40 Old 04-25-2012, 10:29 PM Thread Starter
SSRT-S10
working on that....
post #4 of 40 Old 04-25-2012, 10:57 PM Thread Starter
SSRT-S10
Hopefully it fixed..., had to extract the pics and then put them on a website of mine...
post #5 of 40 Old 04-25-2012, 11:35 PM
Mikz86TA's Avatar
User is: Mikz86TA is offline
Fixed. Thx...sticky!!
2003 S-10 ZQ8 - 262/M5 1986 Pontiac Trans Am - 355/A4
The S10 Project : http://www.s10planet.com/forum/showthread.php?t=15987
The Trans Am Project : http://www.s10planet.com/forum/showthread.php?t=15435
Mikz86TA is offline
post #6 of 40 Old 04-26-2012, 12:50 AM
Solid Axle MOD
Sonomanclature's Avatar
Edited original post with updated picture info, removed Dupe.
94 Sonoma Dana44/60 5.7L 5spd
06 Subaru Impreza
post #7 of 40 Old 04-26-2012, 01:11 AM
Slowly but eventually
98lowerednewproje's Avatar
User is: 98lowerednewproje is offline
Might want to just move it to the 4.3 section if we are gonna make it a sticky, which I am all for doing.
Procrastination has carried me this far in life, it will carry me to my grave, and hopefully put that off as well.
'98 RCSB on jack stands, waiting on me to get the 4.8 and T56 swap together, while I steal parts off of it to keep the daily going.
'99 2DR 2WD Blazer that I bought for a daily but just can't leave it alone.
post #8 of 40 Old 04-26-2012, 01:28 AM
Solid Axle MOD
thought about it but had to look to see if there was one there already, and need to get ahold of the mod there.
06 Subaru Impreza
post #9 of 40 Old 04-26-2012, 01:30 AM
Oh, I didn't mean you specifically, I figured you weren't the mod there or you would have done it yourself already.
post #10 of 40 Old 04-26-2012, 10:45 AM
Mikz86TA's Avatar
I just ordered a Skip White dizzy with alum base to replace cheap plastic stock crap. This certainly will be a nice reference!
Mikz86TA is offline
post #11 of 40 Old 04-26-2012, 08:20 PM Thread Starter
SSRT-S10
Thanks Sonomanclature !!!
Oh and by the way.., for future reference.., how does one edit their original post if it screws up like this one did ?? Or even delete the original post ? Especially if they log off and then come back later to see it messed up?
post #12 of 40 Old 05-03-2012, 09:00 PM Thread Starter
SSRT-S10
bump.... I saw someone here that wanted to know how to change a dizzy..
post #13 of 40 Old 05-09-2012, 06:52 AM
digdugsmug's Avatar
User is: digdugsmug is offline
After you get this installed properly do you have to whip out a timing light and adjust or does the computer worry about advancing/retarding (hehe) things?
91 Noma RCSB 2x4 2.5 5sp Sold
90 S10 ECSB 4x4 4.3 700R4 Sold
03 S10 ECSB 2x4 4.3 4L60E ZQ8 Current
post #14 of 40 Old 05-09-2012, 06:56 PM Thread Starter
SSRT-S10
no timing light... you use a diagnostic machine (aka scanner tool) like a modus, solus or gentec or something of that kind...anything that will show timing advance or timing retard. Some list it as cam retard.
I, Myself, use a snap-on solus to set mine. This kind of deal is pretty common if your having to pull intake or change dizzy or accidentally move the dizzy out of phase. Getting it set to +2 or down to -2 is good. 0(Zero) is the best setting.... Motor should crank with a bump of the key if all else is well.
***************UPDATE*****************
I ALSO recommend this as well....
=-> Upon removal of dizzy. Locate the hold down for dizzy. Slide it off and do the mod to it to make it where you can twist the dizzy 30 degrees in either direction. This make it EXTREMELY easy to get it dead on the mark with the scanner. The reason for this is when removing the dizzy, the oil pump shaft never will get back to where it needs to be to be "dead on" back in place. You will have to fight with it and this tip saves your blood pressure(getting mad at it) and time. <-=
I did this to my hold-down tab. I used a right angle die grinder with a coarse bit to remove just enough to make the square part twist left or right in the hold down (it was held in a vise.).
Even the aftermarket dizzys can benefit from this as well.
OR.., just buy an aftermarket chevy hold down and bolt that baby in. It wont grab as good as the factory one will.., but it will work.
post #15 of 40 Old 05-09-2012, 06:57 PM Thread Starter
SSRT-S10
Awesome.., Thanks for making it a sticky !!
post #16 of 40 Old 06-08-2012, 11:24 AM
User is: fred1948 is offline
You might want to note that the distributor doesn't go all the way back in because the slot doesn't line up with the oil pump, you will have to spin the engine over before you can tighten up the bolt on the distributor hold down.
fred1948 is offline
post #17 of 40 Old 06-08-2012, 03:10 PM
Mikz86TA's Avatar
Or long screwdriver (flat head) and a steady hand to turn it
Mikz86TA is offline
post #18 of 40 Old 08-08-2012, 04:04 PM
KingOFmoron's Avatar
User is: KingOFmoron is offline
will this work on the older 4.3?
I speak to polars bears, and to ghost,god, dead people .... he ha ha
post #19 of 40 Old 08-08-2012, 06:20 PM Thread Starter
SSRT-S10
what year model of older 4.3 motor ?
post #20 of 40 Old 08-08-2012, 06:37 PM Thread Starter
SSRT-S10
Exclamation Re: HOW TO: Change A 4.3 Distributor...Chilton's Way...
Waaay Older 4.3 model distributor removal and install ...
(I chose a 1993 model S-10 with a 4.3 for the following dizzy R&R...)
EST = Electronic Spark Timing
Non-Est - Vacumn Advance type distributor
Removal:
Except MFI-Turbo
  1. Disconnect the negative battery cable. For the 4.3L (VIN Z) engine, remove the air cleaner and hoses.
  2. Tag and disengage the electrical wiring connectors either from the distributor or from the ignition coil, whichever is applicable or easier.
  3. Remove the distributor cap (If possible, DO NOT remove the coil or spark plug wires) from the distributor and position it aside. On most 4.3L (VIN Z) engines, it will be necessary to tag and disconnect the coil wire along with the spark plug wires from 1 side (either left or right) of the engine. NOTE: On non-EST equipped vehicles, disconnect the vacuum hose from the distributor vacuum advance module.
  4. Using a crayon, chalk or a marker, make locating marks (for installation purposes) on the rotor, the distributor housing and the engine. Scribe a mark on the distributor body and the engine block showing their relationship. Mark the distributor housing to show the direction in which the rotor is pointing or otherwise matchmark the rotor with the housing.
  5. Loosen and remove the distributor hold-down bolt and clamp, then carefully lift the distributor out of the engine. Note the position of the rotor alignment mark on the housing and make a second mark on the housing to align with the rotor.
4.3L MFI-Turbo
  2. Properly drain the charge air cooler radiator.
  3. Loosen the charge air cooler clamps, then remove the ducts and hoses.
  4. Remove the charge air cooler.
  5. Detach the upper intake manifold connectors and hoses.
  6. Unfasten the bolts from the upper intake manifold, then remove the manifold.
  7. Disconnect the two screws on the sides of the distributor cap.
  8. Tag and disconnect the coil wire along with the spark plug wires from 1 side (either left or right) of the engine.
  9. Remove the distributor cap and position it aside.
  10. Using a crayon, chalk or a marker, make locating marks (for installation purposes) on the rotor, the distributor housing and the engine. Scribe a mark on the distributor body and the engine block showing their relationship. Mark the distributor housing to show the direction in which the rotor is pointing or otherwise matchmark the rotor with the housing.
  11. Loosen the remove the distributor hold-down bolt, washer and clamp, then carefully lift the distributor out of the housing and make a second mark on the housing to align with the rotor.
Installation:
Undisturbed Engine
EXCEPT MFI-TURBO
This condition exists if the engine has not been rotated while the distributor was removed.
  1. With a new O-ring on the distributor housing and the rotor aligned with the second mark on the housing, install the distributor, taking care to align the distributor body mark with the mark scribed on the engine. When fully installed, the rotor should turn and align with the first distributor housing mark and therefore point in the same direction as before removal. It may be necessary to lift the distributor and turn the rotor slightly to properly align the gears and the oil pump driveshaft.
  2. With the respective marks aligned, install the hold-down clamp and bolt finger-tight.
  3. If equipped, connect the vacuum hose to the distributor vacuum advance module.
  4. Install and secure the distributor cap.
  5. Engage the electrical connector(s) to the distributor or coil, as applicable.
  6. If removed, connect the spark plug and coil wires as noted during removal.
  7. Connect a timing light to the engine (following the manufacturer's instructions) and connect the negative battery cable. Start the engine, then check and adjust the timing, as necessary. NOTE: If removed, be sure to install the air cleaner and hoses.
  8. Turn the engine OFF and tighten the distributor clamp bolt.
  9. Start the engine and recheck the timing to verify it did not change while tightening the hold-down bolt, then stop the engine and remove the timing light.
4.3L MFI-TURBO
  1. With a new O-ring on the distributor housing and the rotor aligned with the second housing mark, install the distributor, taking care to align the distributor body mark with the mark scribed on the engine. When fully installed, the rotor should turn and align with the first distributor mark and therefore point in the same direction as before removal. It may be necessary to lift the distributor and turn the rotor slightly to properly align the gears and the oil pump driveshaft.
  2. With the marks aligned, install the hold-down clamp, washer and bolt. Tighten the bolt to 20 ft. lbs. (27 Nm).
  3. Install and secure the distributor cap.
  4. Connect the spark plug coil wires as noted during removal.
  5. Install the upper intake manifold and tighten the bolts to 17 ft. lbs. (23 Nm).
  6. Install the throttle body, cable bracket and bolts and tighten to 17 ft. lbs. (23 Nm).
  7. Attach the upper intake manifold connectors and hoses.
  8. Install the charge air cooler, then connect the cooler hoses and clamps.
  9. Connect the negative battery cable.
  10. Properly refill the charge air cooling system.
  11. Connect a timing light to the engine (following the manufacturer's instructions). Start the engine, then check and adjust the timing as necessary. Turn the engine OFF and remove the timing light.
Disturbed Engine
This condition exists when the engine has been rotated with the distributor removed.
  1. Install a new O-ring on the distributor housing.
  2. Rotate the crankshaft to position the No. 1 cylinder on the TDC of it's compression stroke. This may be determined by inserting a rag into the No. 1 spark plug hole and slowly turn the engine crankshaft. When the timing mark on the crankshaft pulley aligns with the 0mark on the timing scale and the rag is blown out by the compression, the No. 1 piston is at top-dead-center (TDC). NOTE: If you are unsure when TDC is reached, remove the valve cover and watch the rocker arms for the No. 1 cylinder. If the valves move as the crankshaft timing marker approaches the scale, the No. 1 cylinder is on its exhaust stroke. If the valves remain closed as the timing mark approaches the scale, then the No. 1 cylinder is approaching TDC of the compression stroke.
  3. Turn the rotor so that it will point to the No. 1 terminal of the distributor cap.
  4. Install the distributor into the engine block. It may be necessary to turn the rotor, a little in either direction, in order to engage the gears.
  5. Tap the starter a few times to ensure that the oil pump shaft is mated to the distributor shaft.
  6. Bring the engine to No. 1 TDC again and check to see that the rotor is indeed pointing toward the No. 1 terminal of the cap.
  7. With the respective marks aligned, install the hold-down clamp and bolt finger-tight.
  8. Install and secure the distributor cap.
  9. Engage the electrical connector(s) to the distributor and, if equipped, the vacuum advance hose.
  10. If removed, connect the spark plug and coil wires as noted during removal.
  11. Connect a timing light to the engine (following the manufacturer's instructions) and connect the negative battery cable. Start the engine, then check and adjust the timing, as necessary. NOTE: If removed, be sure to install the air cleaner and hoses.
  12. Turn the engine OFF and tighten the distributor clamp bolt.
  13. Start the engine and recheck the timing to verify it did not change while tightening the hold-down bolt, then stop the engine and remove the timing light.
post #21 of 40 Old 08-08-2012, 06:50 PM
93-94 Code W
Thanks, i was little scared,
post #22 of 40 Old 08-08-2012, 08:58 PM Thread Starter
SSRT-S10
Wow !! I cant believe I guessed it that close (before yaz last post).., to be around a 93 model so I could look it up in my chiltons place.... LOL !!! Hope it helped ya out...
l8taz,
Allen
post #23 of 40 Old 08-08-2012, 09:35 PM
l8taz,
Allen
are you magician? crystal ball? thanks.. that will help
post #24 of 40 Old 08-12-2012, 01:34 AM Thread Starter
SSRT-S10
Lol!! :d
post #25 of 40 Old 08-17-2012, 02:24 PM
Wannabe Mechanic
klturi421's Avatar
User is: klturi421 is offline
Nightmare - is there a link to where I can do the dizzy mod? I've been doing some searching just no finding.
2000 Blazer
4 Door
2 Wheel Drive
180,000 Miles
post #26 of 40 Old 08-18-2012, 12:00 AM Thread Starter
SSRT-S10
You mean the hold-down dizzy mod ? I didnt post a tutorial on it yet. But it pretty simple...
Tools needed:
die grinder
small die straight tip bit (for die grinder)
a small round chainsaw file
Do what is needed as stated above to get the dizzy completely out of the motor. Once out.., look at the hold down. Most late models 4.3 holders have a square notch that buts up closely to the square notch on the dizzy. Also notice on the holder where the bolt goes thru to make the holder do its job.
The hole is usually the part you take the die grinder to. Grind out an upside down Arc the same width as the bolt hole. Grind out to the point that it looks like it almost will go thru the edge of the metal. (NOTE: DONT go to far out on this arc.., it will fatigue the metal and make this holder useless and it will break when tightened down.) Once done.., use the round file to complete the deal out.
Now take the round file or die grinder to the square shaped part of the holder. Grind VERY LITTLE here.. test it to the dizzy to make sure the dizzy will twist 10-15 degrees either way when in square part of holder. Now bolt your dizzy back in the motor using info above and make sure to use a new dizzy gasket - felpro blue is the best. Screw bolt down but just snug the bolt.., do not tighten it yet. Dizzy should twist over 30-45 degrees nown...(I can hear ya saying it now.., "Damn.., He's good !!" ROTF!!)
Once you got it where it needs to be and engine cranks.., hook up scanner and read the cam retard. Try to get it within plus 2 or minus 2.., Dead on 0(zero) is perfect..., tighten down the dizzy and crank and retest to make definetly sure.
Once down.., your set... drink some breskis and smoke a roll or just take pride that you fixed this issue.
l8taz,
Allen
post #27 of 40 Old 11-02-2012, 03:49 AM
User is: R0adki11 is offline
Hi guys this is my first post here. My truck has been giving me heck for 2 weeks. I replaced my distributor when a refurb from Advance. Went will installation #2 as we had to start at TDC. Followed the instructions and now my engine overheated and the exhaust manifold turned a cherry red due to heat. What could've went wrong?
R0adki11 is offline
post #28 of 40 Old 11-04-2012, 09:01 PM Thread Starter
SSRT-S10
u didnt get it right there..., sounds like timing is waaay off. Sounds like about 180 degrees out to me.
re-adjust the dizzy and make sure it on the mark.
post #29 of 40 Old 03-05-2013, 03:05 AM
Mumbles's Avatar
User is: Mumbles is offline
This is EXACTLY what I was looking for! Thank you for posting up!
My father and I recently replaced the Intake Manifold Gasket on his 4.3L equipped 2002 S10 2WD, to fix its Coolant Consumption Problem. With 94K on the clock and the Factory Original Equipment still in place, we also performed a full Tune Up (Plugs, Wires, Cap & Rotor Set, and new Fuel Filter), thinking this would alleviate its Hard Starting issue as well. Upon completion, the Truck seems to be no longer loosing Antifreeze and it runs like a champ, but the Hard Start Problem remains and we now have a PO1345 Code. I'd replaced a couple of Intake Gaskets on these 4.3L's in the past without any problem, so this DTC is new to me.
I distinctly remember re-installing the Distributor. The Rotor was not pointing exactly where it had prior to its removal, although it was close. My thinking was that the Oil Pump Drive at the bottom of the Distributor meshes with the Oil Pump like a Flat Head Screwdriver: One of two ways. Either the way it came out or 180* off. I thought I couldn't f*ck it up if I was close. I guess I was wrong and I'd just gotten lucky in the past thinking "Close" is good enough.
I have a question though. Is it completely necessary to go through the entire 2nd Procedure to rectify this problem? I am certain that I know the relationship between where the Rotor was pointed when the Distributor was removed compared to where I installed it. (I need to move it one tooth counterclockwise.) Couldn't I simply remove the Distributor, adjust the Oil Pump Drive Mesh, and replace the Distributor back to its "Original" Position?
Again, thank you for posting this procedure. I've already printed it off to add to my Service Manuals in the Shop.
Mumbles is offline
post #30 of 40 Old 10-23-2013, 03:05 AM
User is: troysimons22 is offline
Hey everyone!! So i changed my distributor this weekend on my 2001 gmc sonoma. The pickup had shut down while driving. I followed this post and the truck started right up faster then ever. the truck has a bad miss under load and the check engine light was on. I ran the code and it said p0306 misfire on cylinder 6. i replced plugs wires cap and rotor at the same time. i have went back through and the rotor lines up with the 6 at tdc perfectly. the truck runs and drives just has that bad misfire. Any ideas what could be wrong
post #31 of 40 Old 03-11-2014, 08:51 AM
User is: PEEGH is offline
On the early vortec engines that have the cap where the wires come off of the top you have to unplug the single wire connector to adjust the timing. It is located under the heater box on the passenger side floorboard. Just above the carpet. Otherwise the computer will try to compensate for any movement you make on the distributor.
PEEGH is offline
post #32 of 40 Old 09-10-2014, 11:29 AM
User is: KaliDime is offline
To set to TDC do you remove the fan clutch or the pully in front of the harmonic balancer?
KaliDime is offline
post #33 of 40 Old 03-30-2015, 03:51 PM
User is: aforsberg is offline
Really helped me great sticky
post #34 of 40 Old 03-30-2015, 03:52 PM
lol my distributor cap is held on with wood screws threaded through the plastic because pops dropped the screws too many times.
post #35 of 40 Old 06-17-2015, 10:41 PM
User is: remarcable04 is offline
Ok. I'm really new to this auto repair so please bear with me. I have a 97 s10 vin w. I just bought a new distributor and dropped it in today. Well ot didn't work so well I couldent get it to seat properly so my dad said to start it from scratch and set n1 cylinder to tdc I thought I had but I was aparently wrong I think I was off by 180 and with that said how can I find tdc and don't tell me to put my finger over cylinder one and feel for compression for a few reasons. 1 my fingers are small and don't cover the entire hole I can't get my thumb in it is in a terrible place. Secondly I feel air movement with almost every roatation. Third I just want to get this done and not play guessing games anymore to see if I'm right I have removed and reinstalled my distributor over five times. The first two I got a really bad start and it choked and died last three I got a couple backfires and even one through the intake. Can anyone help me I am starting to think I bit off more than I can chew. Never done truck work like this. And I'm feeling lost and angry that I even messed with it to begin with. I do have the haynes manual but its not very specific in many things and the illustrations are terrible. I am afraid I will end up bricking my engine if I keep on this try and try some more path.
Thanks for any help.
post #36 of 40 Old 02-29-2016, 07:18 PM
User is: 4dr2kjimmy is offline
Wanted to add to this post if you have one of the cheap OBD2 Bluetooth scanners on Amazon you can check your cam retard with the free version of Car Gauge on the google play store. It has the PIDS to read it. Make sure you use the one * version.
post #37 of 40 Old 03-09-2016, 08:16 AM
User is: jeffakron is offline
Hi folks,
So, I replaced the intake manifold gaskets recently, and was wrapping up, so read the distributor install info (nicely done, thank you!).
However, I have installed it 2x and cannot get my truck to fire up (?) I have spark, and can smell gas, so not sure what is up. It does cough upon cranking, like it's out of time, but will not kick over.
I have pulled and reinstalled the distributor 2x times (just incase I did it wrong the first time) and aligned second mark, dimple on shaft, rotor on #6 after it drops in, yada yada yada.
Anything I might be missing? Like I said, I hooked a timing light up and held it from cab while cranking (no assistant) and see I am getting spark, and smell gas in exhaust . . . but wonder if something went askew in plenum when I removed it?
Advice?
Thanks,
Jeff
jeffakron
now in NY
1999 S10 ZR2
post #38 of 40 Old 04-29-2016, 10:32 AM
User is: Cleatus is offline
Originally Posted by jeffakron View Post
Hi folks,
Advice?
Thanks,
Jeff
not that it will help...but when I pulled my dist, I used the "back" of the rotor--not the terminal as the back was pointing to the firewall--use that to make the mark. If I put it back in using the terminal as my mark, I would have been 180 deg off. Not sayin you did that...but just in case...
Cleatus is offline
post #39 of 40 Old 08-28-2016, 09:32 PM
User is: observant1 is offline
to remarcable04
To change your distributor timing by 180 turn your crank 1 full rotation until the timing mark lines up again. You will have changed the distributor 180 degrees.
Keep in mind the distributor turns 180 degrees every time the crankshaft turns 360. It's a 2 to 1 ratio. Very easy if you are 180 off.
post #40 of 40 Old 11-18-2016, 10:36 AM
echardcore's Avatar
User is: echardcore is offline
Send a message via AIM to echardcore
I wanted to add this video which showed a technique that really helped me. This will help if the engine turned after the dizzy was removed.
I marked my old dizzy and removed it. I lined up the new one the same way and it dropped right in. The truck didnt start after that.
I got underneath with a socket (forget size) and a small extension, a deep socket would probably work too, and muscled the hell out of the harmonic balancer CLOCKWISE. Its really hard but im a skinny 160lb wet guy and I was able to do it without removing plugs, putting in neutral, etc. BE REALLY CAREFUL. I THINK THERES A/C LINES VERY CLOSE BY. I ALMOST SLIPPED THE RATCHET OFF AND KNOCKED INTO THEM. I carefully rotated it until the 1st mark came around and lined up with the only mark I could see on the other side from the bottom of the engine. Then I was able to see from the top that the other marks lined up too. Woot!, right? nope.
The oil pump drive shaft wasn't aligned with the dizzy so it wouldnt drop. I bought a long screwdriver to stick down the shaft but wasn't able to turn anything. Not sure why. But I didn't want to force anything. I used my camera to look down the hole and I could see no progress.
Then I found the video above. Hammering Hank describes "walking" the oil pump drive shaft using the rotor on the distributor. I was able to feel it moving little by little. Maybe like 35 degrees each time. The rotor kept getting closer to the 6 mark so I knew I was on the right track. Hit the 6, dizzy dropped. Bolts, plugs, started up rough but most likely due to ECU reset.
Hope this helps.
Balls, Lorraine!
ween
