How To: Change #3 spark plug
LinkBack (8) Thread Tools
Old 06-05-2007, 08:51 AM   #51
Insane Network Engineer
rlith's Avatar
Re: How-to change the PITA #3 spark plug
Quote: Originally Posted by evny1984
i don't diagree that but i just like it my way it's cool wasn't trying to start a fight
Oh, I know, I wasn't trying to fight either, sorry if I came off that way (shivs you in the kindey)
Just saying for the majority of people (not everyone) the intermediate shaft is the easiest. Though I guess for a lot of people that seems scary (even though it's keyed and very hard to put back on wrong...)
In the end, people will do it their own way
Old 06-27-2007, 07:29 AM   #52
Fri'chkn n wtrmeln -nom!
Zapnoma's Avatar
I had to drop the steering shaft on my '00 4.3l 2wd...theres no way in hell I could have done it otherwise.
Old 06-27-2007, 11:36 PM   #53
Unregistered User
j894's Avatar
same here. still some insist on doing it that hard way though.
Old 06-28-2007, 04:42 AM   #54
Pussy Wrangler
AK49BWL's Avatar
this thread was a life saver.. I'm rather a newbie when it comes to under-the-hood work, and I was about ready to say screw it and run past 100k miles with what I had.... then I found this. Had it all apart and back together within an hour I still took the wheels off, made it a little easier for access, which is what took the longest.. Impact wrench made it nice tho. new NGK plugs (and distro rotor and cap) and my truck runs a lot better now! thanks rlith!
Old 07-03-2007, 02:00 AM   #55
Zapnoma's Avatar
I just wanted to add, you removed the steering shaft for the front most plug on teh driver side?
Thats teh easiest one to get to on that side......its the middle plug thats blocked by my steering shaft.
Old 07-03-2007, 07:12 AM   #56
rlith's Avatar
Everyone is talking about the number 5 plug (middle drivers side) not the #1 plug
Old 07-03-2007, 02:25 PM   #57
Registered Asshole
Low99Sonoma's Avatar
Well, i bought my spark plugs and wires like a month ago and just been procrastinating and went out and throughly looked under the hood to see how to do it. And i was like hmm, there has to be a better way, so off i went to look on the forum, and of course as always, someone on here came to the rescue with tips and tricks. Im gonna do this in a bit, we shall see how long it takes front start to finish seeing as how ive never done em on my 4.3, 99 Noma. We shall see...
Old 07-03-2007, 09:00 PM   #58
Zapnoma's Avatar
Aight, just making sure.
And goddamnit, my steering wheel is off just slightly again.
Old 07-03-2007, 09:01 PM   #59
Zapnoma's Avatar
Pass side with the wheel off takes less than 10mins including time to jack up/take wheel off/change/put wheel on/jack down.
Old 07-04-2007, 04:03 AM   #60
Registered Asshole
Well, all in all it took me about 2hrs to do all the plugs, wires,and fuel filter. That time includes cigarette breaks, a few random phone calls, removing the steering, takin off the tires, and removing the airbox (cause i dropped the fuse for the fuel pump under it lmao)
I must say, my fuel pump was a WHORE!!!! The fittings had seized and i threw everything i had at it to get it off. Ended up soaking the fittings in WD40 (couldnt fidn the PB Blaster) and using vicegrips on the fitting side and a huge crescent wrench on the filter side. That thing was rusted on there. I swear the filter was one of the most time consuming, PITA general maitenance things ive ever done. But the truck runs alot better now, and i had never replaced the fuel filter, and thats probably why it was so hard to get off.
All in all, removing the steering shaft took like 2 minutes if that, and it was a great piece of advice, wouldnt have been able to do the #5 plug without it, thanks guys! And takin the tires on was no biggie but made things a hell of alot easier. SO for you people who want to argue bout takin the shaft off and/or the tires off, my advice is just do it, cause on the 4.3's it makes life alot easier.
Old 07-10-2007, 08:37 PM   #61
bmr_doc
Posts: n/a
User is:
snap on has a new socket made just for that- stock#: S9723, $30.75. it works for more stuff too, i have one in my box at the BMW dealer.
Old 07-14-2007, 11:32 AM   #62
Starting from scratch...
02_Black_XBlazer's Avatar
Wouldn't that be the #3 plug, the one the thread started over?
Old 07-16-2007, 01:23 AM   #63
I've found this thread helpful.
I hesitated doing the right bank of the engine cause it looked liked a PITA.
After removing the air box and the steering shaft I found the right bank easier than the left bank.
I had a PITA Getting the Shaft back on. A lot of wiggling and the help of a hammer.
The only thing I did different from these instructions was disconnecting my battery and wrapped the seatbelt around the steering wheel and locked the seatbelt in. IIRC if the steering shaft loses ground contact with the steering box it could deploy the airbags. I'm not sure how true this is but I did it just as a precaution.
Old 07-19-2007, 08:48 PM   #64
Biggs's Avatar
The easiest way I have found is to take off the front wheels. There are flaps you can flip up and have a great access to all 6 plugs. #3 Is hard to get due to the driveshaft being there giving you an inch to work with! I grinded a wrench so it was small enough to fit, had my buddy holding it on the socket from underneath, as I went on top to loosen. Do the same thing to get it back on.
Old 07-23-2007, 09:31 AM   #65
rlith's Avatar
Quote: Originally Posted by Carraig042
I think the easiest way is to take off the front tire and move the piece of plastic that it in the way. You will have great access to the middle and back one. This way you also get to check on your breaks, which is great.
-Brett
As had been discussed several times in this thread, that isn't the problem, the problem on most of the trucks (not all) is getting the socket on to the middle spark plug with intermediate shaft in the way. Also the above 1 minute removal makes it unnecessary to going through all the hell of jacking up the truck and then removing the wheel.
Old 07-24-2007, 12:44 AM   #66
JMew03's Avatar
get a body lift.. then you dont have to worry about disconnecting a steering shaft or taking the wheel off
Old 07-24-2007, 07:43 AM   #67
rlith's Avatar
I have a 3" body lift and I still have the issue. So now again, why don't I want to spend less than a minute removing the arm, and less than a minute putting it back on?
Old 07-28-2007, 01:06 PM   #68
Thanks, RILTH for the photos and advice.
I couldn't even get a socket onto the plug without moving the steering shaft.
This worked OK.
2001 4x4 4dr blazer 4.3l
Old 07-30-2007, 02:04 PM   #69
jimmykicker's Avatar
The first time I did this was on my friend's 95. I couldn't get the damn socket back off of the plug once I got it installed. Had to go buy a pair of Vise grips to do it (I wasn't at home). I usually just take the tire off and go at it with a swivel and a locking extension. It's not that bad once you have done it once. I also owned a 95 and currently an 01, and it was pretty straightforward and easy.
Old 08-02-2007, 10:25 PM   #70
90 f**kin 7 s f**kin 10
vespasoul's Avatar
What about the waring sticker on the shaft regarding possible actuation of the air bags if shaft is rotated while disconected?????????
Old 08-06-2007, 09:59 PM   #71
Yeahhhhhhh......
After getting the shaft disconnected, I thought 'hmmmm. what does this sticker say?'
Wiped, the grease off and my thoughts changed to 'uh oh'.
I tied it in place and prayed that nothing bad happened.
Disconnected the battery for good luck, too.
Old 08-08-2007, 05:13 AM   #72
Evil_Fingers's Avatar
Im so glad this Forum exists....because without this Forum, I would go 5150 in trying to change the Plugs from under the Hood on my truck....well anywho, I did exactly what most of the members posted in this Thread and that was by removing the Tires to get access to all the Plugs and I also have to thank God for having a friendly neighbor who happened to have the Right Socket in removing the #3 Plug without moving the Steering Rod....and now I gotta deal wit that ever annoying engine knock!
Old 08-08-2007, 12:11 PM   #73
I don't know about the second gens, but on my first gen sonoma i pulled into the garage, turned the wheels all the way to the right, grab the floor jack, jack up the driver side front wheel, (just place the jack along the frame rail under the door). jack it up, flip the dust cover, and there is the number three plug right infront of you. pull of the wire, get a 6 or 12in ext. and pull the plug.
Old 08-11-2007, 04:28 AM   #74
epiphaknee's Avatar
I have a 95 Sonoma with the 4.3L and, yes, this used to require removing the pinch bolt from the steering shaft, etc. However, the post from the mechanic is right on point.
You just access the plugs through the fender shields. It is easiest to remove the tires. But you then have a direct view of the spark plug holes. The key for me was finding a spark plug socket that was shorter than the "standard" spark plug socket. Craftsman makes a swivel and it is shorter and fits into number three with the steering shaft connected - no problem. In fact, #3 is one of the easiest with the right socket. Then, yes, you attached some long extensions. When you go to Sears just take in your typical spark plug socket and buy the swivel that is noticeably shorter.
Old 08-16-2007, 12:32 PM   #75
I agree with the original plan on here... It is the way i did mine and it tooks 3 mins to take off take out and put back in the #3 spark plug...
BTW on mine you couldn't even get the socket on the plug unless you broke it off so there is no way you could get a new one in without taking this off...
Old 08-22-2007, 02:24 PM   #76
ballinjefe22's Avatar
def not a fun job on my moms 4.3 blazer... i just swapped the 4.3 TBI into my carb'd 2.8.... life is a lot easier with the entire front clip removed. even with it on there, its easier than the plugs in my GTP... even with the wishbones off the front, there is still a lot of cuts and scrapes to get the back ones.
Old 08-23-2007, 12:28 PM   #77
2003 xtreme
socket and wrench. jacked up the suspension, lift the flap and it takes about 15min. for me it is the #1 plug not the #3 ?
Old 08-28-2007, 10:54 PM   #78
< EST 1989....>
on my first gen was simple just a 5/8 sparkplug socket w/ a 3in ex. and a reg ratchet wroked fine. Slid right under the shaft. no problems. Guess i was just lucky
Old 09-03-2007, 10:01 PM   #79
opus70's Avatar
Ok guys have you thought of looping the seat belt through the steering wheel and buckling it and slide the seat back so it locks the steering wheel in place??
Old 09-04-2007, 12:04 AM   #80
Blazin_Jason's Avatar
Yup lucky. Just did mine today and dropped the shaft.
Old 09-19-2007, 09:03 PM   #81
eric00's Avatar
long thread didnt raed all so sorry if its a repost of someone else
some will say i was wrong for doing so however i do alot of these at work.. i simply do the tune up on floor jacks doing almost all threw wheel well, for the hard #3 i simply put a peice of wood on a floor jack and jack up the motor a LITTLE using the play in motor mounts and easily remove with SP socket and open end wrench.
hope it not a repost hope it helps!
Old 10-20-2007, 03:28 PM   #82
redphoenix's Avatar
Thanks for the writeup. This worked on my GF's 95 Sonoma w/ Vortech Heads.
It could not been done without this way, jacking it up did nothing for me.
Old 11-03-2007, 04:55 PM   #83
I have the disease
blazerlow's Avatar
Wish I would have found this thread before I did my plugs. I did find a good way to change the #3 plug though. I use one of those finger ratchets and turned it with a channel locks pliers. It worked really good after about 2 hours of trying every tool combo possible.
Old 11-22-2007, 11:44 PM   #84
chevy: like a rust
therealm0rh0us's Avatar
at work i use another person and a giant prybar on teh steering shaft to change #3
works everytime on every blazer or pickup
Old 12-02-2007, 05:26 PM   #85
5-Speed Blazin
2k2indigoxtreme's Avatar
All I did with my 02 Blazer 2wd was lower the trans onto a jackstand with a block of wood, it lifted the engine and trans up about 1/4'' to 1/2'' and that was just enough to get my extension onto my swivel and sparkplug socket, too me no extra time at all just time to look for a block of wood
Old 12-08-2007, 10:54 AM   #86
im doing a full on tune up today...plugs, wires, cap, rotor, fuel filter, and a coil. my air filter is new, so im not replacing that.
i have a 94 1st gen blazer with the 4.3.
is this one of them that you have to remove the shaft? or is it only random ones?
im going to try and take this on through the wheel wells, seeing as that seems to be the most easiest way to do it i think...
Old 12-08-2007, 11:17 AM   #87
forum idiot
orangesonoma's Avatar
i used a old snap on semi deep swivel spark plug socket... no extra steps needed..
Old 12-08-2007, 05:07 PM   #88
well, im all done.
didnt get the fuel filter, seeing as everything was rusted, and i didnt want to break it off and be ****ed. so im going to let my dad help me with that this week.
but i got the front of the truck up on jackstands, pulled both front wheels, and all the plugs were staring me in the face at that point. i just got them out through the wheel wells.
the hardest part for me today was routing the wires, and getting them in order in each loom. than getting them to click back together without breaking or falling.
having big hands isnt always a good thing. lol
well, id say 2.25 hours for a tune up and an oil change and trying to do the fuelfilter also isnt too bad for a 17 year old
some good tips in this thread for sure!
thanks guys!
Old 12-18-2007, 01:13 AM   #89
Black SS
97S10SS's Avatar
I have the special Snap-On socket for the plug problem.
Do what I did, if you need spark plugs, throw on a set of JBA's at the same time
Old 12-18-2007, 11:20 PM   #90
epiphaknee's Avatar
What is the Snap-On part number for the special socket?
I would like to go to Snap-On's online catalog and take a look at it!
Thanks in advance!
Old 12-21-2007, 11:21 PM   #91
97S10TRUCK's Avatar
how big should the gap be on the spark plugs?
Old 12-23-2007, 10:15 PM   #92
i saw .045 on the sticker on the front of my truck, i think thats probably right, idk for sure though
Old 12-26-2007, 11:26 PM   #93
King Turd Polisher
89Chubby's Avatar
It was a tight fit on my '89, but not something that required any special tools when I pulled each of my plugs for examination. I didn't know steering shaft removal was necessary for some folks until I read this thread.
I just poked a 5/8" socket on there, turned it loose with an open-ended wrench on the end of the socket (I'm assuming they made the sockets hexed on the back for just these kinds of vehicles ), and once it was loose, I was able to just spin the plug out with my fingertips ... installation being the reverse of removal, of course.
As previously stated, probably just an issue for the second-gen and newer 4.3 folks, I suppose, but good to know for future reference.
Old 12-26-2007, 11:27 PM   #94
Depends on the year..I know the '96-'97 4.3s are a .60 gap.
Old 12-30-2007, 04:28 PM   #95
http://buy1.snapon.com/catalog/item....group_ID=19832
Old 12-30-2007, 04:29 PM   #96
Thanks in advance!
Sorry used wrong quote
Old 01-05-2008, 04:26 PM   #97
great forum...I just finished changing to plugs on the wifes 1996 jimmy...I started 2 weeks ago and gave up because my hands were way to big...then I found the forum and everything worked great, just like all of the tips said. Now I'll add my 2 cents about the #3 plug. I simply used and offset, boxed end wrench and a plug socket that had the wrench end to it. put the socket on, put the wrench on the end of the socket and had my nephew on top turning the wrench a little at a time while I repositioned the plug wrench. it worked great and I ddin't have to spend 30 bucks on a snap-on tool I'll only use once.
Old 01-06-2008, 12:23 AM   #98
I have taken off the steering to change 1 plug and it pissed me off, I ended up removing the small flap on both wheel wells ( no I have not had problems with debris getting in) from there you can easily put your socket on the plug and then use a boxed end wrench on the socket, works great!!
Old 01-18-2008, 11:20 PM   #99
S15jimmy's Avatar
I'd just take the wheels off, but thats just me
Old 01-21-2008, 03:47 PM   #100
I jacked mine up, pulled the tire & wheel well, and did the same as kenbo1961 (3 posts up). The socket looks something like this: http://www.professionalequipment.com...3064_thumb.jpg
LinkBacks (?)
LinkBack to this Thread: http://www.s10forum.com/forum/f107/how-to-change-3-spark-plug-224471/
Posted By For Type Date
95 s10? This thread Refback 09-26-2007 01:03 AM
ZR2 USA -> spark plug trouble This thread Refback 07-22-2007 02:31 AM
# 3 spark plug - S10PLANET.COM This thread Refback 07-16-2007 10:32 PM
# 3 spark plug - S10PLANET.COM This thread Refback 07-16-2007 12:48 PM
ZR2 USA -> spark plug trouble This thread Refback 06-01-2007 12:17 PM
ZR2 USA -> spark plug trouble This thread Refback 05-31-2007 02:47 PM
ZR2 USA -> spark plug trouble This thread Refback 05-31-2007 02:21 PM
S-10CREWCAB.COM This thread Refback 05-02-2007 09:14 AM
Page generated in 0.65082 seconds with 32 queries
[Output: 222.60 Kb. compressed to 203.70 Kb. by saving 18.90 Kb. (8.49%)]
