How Do You Replace Fuel Pressure Sensor? - S-10 Forum
post #1 of 5 Old 07-12-2010, 01:33 AM Thread Starter
2001 ZR2 S!O
ZR2 S10 MAN's Avatar
User is: ZR2 S10 MAN is offline
Question How Do You Replace Fuel Pressure Sensor?
I have a 2001 4,3 S10 Pickup. I need to replace the fuel tank pressure sensor. Engine Light came on with the code P0452: Evaporative Emissions System Pressure Sensor/Switch Low Input.
The first instinct is gas cap. Well i just got a new one and it didn't fix problem. I know its not gas cap because when i have around a quarter of gas left my gas gauge freaks out and starts bouncing around empty. Then the engine light comes on after ive been running it around a quarter of gas. And then it reads the same code....P0452. So it has to be the sensor, people say check wires and bblah bla but my gauge would be off all the time if it was wiring. And my gas gauge wouldn't just freak out when im running low on gas and the check engine light would come on more often. I try to keep the tank full and when i do the problem never occurs. But I also know the EVAP is connected to the overall performance of the throttle body so I would like to get this fixed and maybe improve gas mileage.
So i want to know how to change the Fuel tank pressure sensor. I was wondering if you have to take the fuel pump out. Is the sensor attached to the fuel pump? They say you have to drop gas tank to reach the sensor, well i have Zr2 suspension and i can reach this electrical harness on top of the tank with my hand and im not sure if that's the sensor. It would be nice if the sensor was separate from the fuel pump, if so i think i might be able to change it without dropping the tank.
If anyone has detailed step by step instructions on how to replace this sensor, it would be highly appreciated. If you would like to email me an answer or a url or pictures on how to, my email is and1_player547@yahoo.com
post #2 of 5 Old 07-12-2010, 02:48 PM
far2grumpy's Avatar
User is: far2grumpy is offline
Re: How Do You Replace Fuel Pressure Sensor?
I've attached service manual extract to change sensor on 02 S10 pickup. You'll note procedures say to remove the box. There are no procedures for the 01 pickup - just for 01 S10 with utility-bed and crewcab - and you drop the tank on those trucks.
It appears the sensor is held in-place by friction of at least one o-ring seal. If you can reach it - and there's clearance between the sensor and bed - I'd try to pull it free.
If you can get it out without major effort - you might try shaking and tapping the little guy against something solid and even giving it dose of MAF spray to see if it can be revived.
post #3 of 5 Old 07-13-2010, 01:54 AM Thread Starter
2001 ZR2 S!O
So theres only one wiring harness on the tank and the FPS is attatched to it?
So the sensor is just sitting right on top of the tank attatched to the top of the fuel pump? Is that what your pictures are showing? thanks
post #4 of 5 Old 07-13-2010, 10:45 AM
far2grumpy's Avatar
Should be two connectors on top fuel pump module - one (2 wire) to run pump and provide fuel tank quantity and other (3-wire) for EVAP fuel tank pressure.
I responded to your PM - can email fuel system description - it exceeds forum post limits.
post #5 of 5 Old 02-01-2016, 04:06 AM
User is: johnnylovsey is offline
I have a 2003 4.3 liter Chevrolet blazer l/s and I would like to know the same thing how to get to the evap pressure sensor hopefully without removing the gas tank don't look forward to that hopefully I can if its on top of the tank I have quite long arms and just maybe could unplug it from the harness and the Pump if that's what its plugged into on top of the tank.hopefully its easy enough to get to so I can test the wires and then hook vacuum to it to see if it's still working.
