How do you adjust the tps - S-10 Forum
post #1 of 17 Old 02-02-2009, 02:28 PM Thread Starter
NEVER2LOW
BusinessMan_24's Avatar
User is: BusinessMan_24 is offline
Send a message via AIM to BusinessMan_24 Send a message via MSN to BusinessMan_24 Send a message via Yahoo to BusinessMan_24
How do you adjust the volts for the tps? I have a brand new holley oem tbi. I'll post a pic of it later.
Insane Kustoms Car Club
www.insanekustomscc.com
Rides:
1995 Chevy S10 (Mini Truck) --- 1991 Nissan NX2000 (Tuner)
1999 Dodge Caravan (Daily Driver)
post #2 of 17 Old 02-02-2009, 03:01 PM
Good Bye SonomaST
91sonomast's Avatar
User is: 91sonomast is offline
Send a message via Yahoo to 91sonomast
Re: How do you adjust the tps
what do you mean? are you using the stock TPS? whats wrong with it? im lost, explain and we can help more. cant adjust a TPS sensor as far as i know, you can replace them
1998 Dodge Dakota, 2wd ECSB, 318, M1 2bbl intake, 52mm TB, Taurus fan, Ford injectors, MP PCM, MPP mid-length headers and full exhaust, Hooker Aerochamber, DJM 3/5 drop. Put back to stock and sold
2001 Grand Cherokee 4.0L, it's so SLOW!!!
1991 SonomaST, WAS SOLD, reacquired and rusting away.
Originally Posted by 99 BUCKET View Post
I will get off at some point.
post #3 of 17 Old 02-02-2009, 07:26 PM
Banned
User is: 4x4zr2GA is offline
Send a message via AIM to 4x4zr2GA
the ones on our trucks arent adjustable like say on a fox body mustang or rx7... our basically just get replaced, no adjustments.
4x4zr2GA is offline
post #4 of 17 Old 02-02-2009, 08:33 PM
Will work for turbo parts
User is: King_Ice_Flash2 is offline
Send a message via AIM to King_Ice_Flash2 Send a message via MSN to King_Ice_Flash2 Send a message via Yahoo to King_Ice_Flash2
TPS reset:
with key ON engine OFF - unplug the TPS for 30 seconds
turn key OFF - plug TPS back in
This won't help if the voltage range for your throttle position sensor is different.
2003 S10 Long Bed 4.3L ZQ8 + 2/3 drop, Caltracs, rear disk conversion, 7" dual diaphragm booster, 255/50/R16 Falken ZE-512, MPFI converted 2114, 48LB Racetronix injectors, eBay RS BOV, Accel 60115 distributor, Aeromotive FPR, Corbeau Forza seats, Mach headers, 2.5" front mount intercooler, Innovative turbo, Precision Industries Vigilante 3,000 RPM torque converter, EFILive COS3 tune.
post #5 of 17 Old 02-02-2009, 08:43 PM
Unregistered User
j894's Avatar
User is: j894 is offline
You don't adjust them because there was anything necessarily wrong with them, it was to set more or less "calibrate" the TPS and set it right at the voltage for closed throttle, so when opened the PCM would respond quicker. People do the mod more or less to compensate for the tolerance in how the TPS mounts, because it might not be right at 0% throttle. To do this you would have to modify the TPS screw holes, and check the closed voltage with a mutimeter while adjusting it to the correct voltage... but its only for older trucks.
Newer OBD2 trucks throttle position is set by the PCM software, it starts out at 0% automatically, no adjustment is needed.
'01 Blazer, 5sp, 4x4
Retired: 1993 Chevy S-10 Blazer - 4x4,4.3L,CPI, auto
-Cardomain-
j894 is offline
post #6 of 17 Old 02-02-2009, 08:56 PM
LIL-ZUKI's Avatar
User is: LIL-ZUKI is offline
just make sure your throttle body is clean and CAN close to 0% throttle.
LIL-ZUKI is offline
post #7 of 17 Old 02-02-2009, 10:04 PM Thread Starter
NEVER2LOW
Sorry I didn't have enough time earlier to post up all the details. Its a brand new Holley oem style TBI which came with a new tps on it. In the instructions it says to adjust the tps to .65 volts but it does not say how.
There is a screw holding on the gold bracket which turns when you give it throttle. I'm wondering if losening that screw and moving the gold bracket a bit and retightening will change the volts.
Rides:
post #8 of 17 Old 02-02-2009, 10:07 PM Thread Starter
NEVER2LOW
Its a 92 4.3 ecu so it should be OBD1
Rides:
post #9 of 17 Old 02-03-2009, 06:10 PM
s10stocker's Avatar
User is: s10stocker is offline
Just give it a try. Did one on a 91 350 in a fullsize years back and it was close. If not unplug it and check it with the TB closed.(ohm meter) Then either find someone with a 95 or older S10 with the TB and ask them to read theirs. If not get one of the HAYES or CHILTON manuals manuals and do some reading.
96 S10 N/A 4.3 Racetruck
97 S10 4.3 5s DD for now(will be Racetruck for sale)
02 Yamaha VMAX
94 Chevy 2500 350(was Father-in-laws R.I.P.)
07 Avalanche
It's better to remain silent and let one believe you a fool, than speak and remove all doubt.
post #10 of 17 Old 02-03-2009, 10:12 PM
Wire Splicin Fool :-)
lesterl's Avatar
User is: lesterl is offline
might be able to bend the gold tab a bit, usually on the adjustable tps you loosen the two screws holding it on and twist the unit then tighten the screws.
lesterl is offline
post #11 of 17 Old 02-03-2009, 10:32 PM
Overhead Console Expert
Raven's Avatar
User is: Raven is offline
Send a message via AIM to Raven
on second gens they can be adjusted let me find the thread....
http://www.s10planet.com/forum/showthread.php?t=608
1999 S10 4.3L Zr2
Overhead Console Dude
Raven is offline
post #12 of 17 Old 02-03-2009, 11:02 PM
Unregistered User
j894's Avatar
any cars TPS could be made to be adjusted, but on 2nd gens its not necessary
-Cardomain-
j894 is offline
post #13 of 17 Old 08-18-2009, 08:54 PM
User is: 4.3tbi is offline
i got an 88 gmc jimmy 4.3l i just put on a new tps how to i check the volts someone got a step by step to what to do to set it right
4.3tbi is offline
post #14 of 17 Old 08-21-2009, 09:33 PM
Jesper's Avatar
User is: Jesper is offline
Not my write up,but found this on anothere forum :
Adjust your TPS and I.A.C. on your TBI / MPFI
Authored by: Jay Vessels
Tools needed:
* Torx bits or drivers (T-10, T-15, maybe more depending on the application)
* Voltmeter (digital is best, but a really accurate analog will work)
* Tachometer (the one in the vehicle will work fine if equipped)
* Wrenches and an awl (various sizes, only if the idle speed hasn’t ever been set)
Theory of Operation – (lengthy)
A common myth about fuel injected vehicles is that the idle speed is fixed and cannot be adjusted. This isn’t quite true; there is a setting. It's called minimum air, which is adjustable on TBI and MPFI vehicles. This setting sets the lowest-possible idle speed for the vehicle. The ECM uses the IAC (idle air controller) to raise the idle speed from this adjustment. So, while the exact idle speed isn’t really adjustable, the minimum idle speed is.
Why adjust the idle speed? Isn’t the ECM supposed to do that? Yes it does and it does do a good job, but has to have a starting point. That starting point is called minimum air, or the smallest amount of air allowed to enter the engine with the throttle closed. The ECM can only add air to that minimum setting. If that setting is too high, the ECM can’t slow the engine down to an acceptable idle. If the setting is too low, the ECM may not be able to keep the engine running under certain conditions.
Another reason to adjust minimum air is if there has been some repairs to the fuel system. If the throttle body has been removed (i.e. rebuilt or cleaned) or the TPS (throttle position sensor) has been replaced or otherwise disturbed (i.e. loosened the mounting screws unintentionally -- it happens) then minimum air should be adjusted. Any changes that could affect idle speed or idle quality, like performance upgrades or replacing leaking vacuum lines, should be followed by setting minimum air.
This adjustment, once learned, only takes a few minutes. It rarely has to be adjusted, but it takes so little time to check (and adjust, if needed) that there’s no reason not to do so.
Checking & Adjustment Instructions
To establish minimum air, the idle speed must be set first. The idle speed screw is sealed with a cap from the factory. This should be removed by removing the throttle body and using an awl to pry the plug off. If this seems scary, have it done. It’s not difficult but it’s not worth risking damage to the throttle body or human flesh to remove the plug. Once the plug has been removed, reinstall the throttle body.
Assuming the idle speed screw is accessible and the throttle body is installed, jumper pins A&B on the ALDL (Assembly Line Data Link) connector under the dash. Pins A&B are on the upper-right-hand side. These are the same two pins to jumper to read codes from the ECM. Now turn the key on (the Check Engine light should be lit) and leave the key on for at least 30 seconds. The computer will extend the IAC plunger all the way out to allow adjustment of the idle speed.
After the 30 second wait, unplug the IAC (square 4-pin connector on the throttle body) WHILE THE KEY IS STILL ON. This prevents the ECM from adjusting the idle speed while you make your adjustments.
Block the drive wheels, set the emergency brake, and start the engine. Set the idle speed by adjusting the idle speed screw. The engine should be at operating temperature for this. The exact setting is on the emissions label on the radiator shroud, but in general, the idle speed should be about 500 RPM in Drive, 700 in Park / Neutral, or if you have a manual transmission, somewhere between 600-800 RPM. Remember that the truck is running during this adjustment, so stay clear of the fan, and make sure it can’t roll or otherwise be put into gear while this is done.
Once the minimum idle speed is set, turn the engine off, reconnect the IAC, and remove the jumper from the ALDL connector. The TPS minimum voltage must now be set. Turning the idle-speed screw may have moved the TPS idle voltage away from the specification, so it should be adjusted next.
Connect a voltmeter between pins A (usually dark blue) and B (usually black, or black/pink) of the TPS, and turn the key on. Don’t start the engine. Loosen the two torx screws holding the TPS in place, but don’t remove them. Rotate the TPS until the voltmeter reads between 0.45 and 0.55 volts, with 0.50 being ideal. Tighten the mounting screws (carefully, they thread into soft aluminum) and re-check the voltage to make sure it’s still within range.
That’s it. After the procedure is done once, it’s easy to remember and do. I hope this helps.
A worthwhile adjustment I think.
Mine measured .546 volts at idle and 4.45 volts wide open throttle. The reading for idle should be .8 or less and the reading for WOT should be at least 4.5 volts.
I used a drill to file the holes for counter clockwise adjustment.
I now have .747 volts at idle and 4.62 volts at WOT
Chevrolet Blazer LT 1995
Jesper is offline
post #15 of 17 Old 08-23-2009, 12:20 AM
28Hz
03S-dime_xtreme's Avatar
User is: 03S-dime_xtreme is offline
thats bad ass im gonna try that tomorrow
post #16 of 17 Old 08-24-2009, 01:18 PM
"factory freak"...
Crew Cab Sonoma's Avatar
most of the 80's model GM TPS sensors were adjustable.
by the very early 90's, most were non-adjustable.
GM redesigned the software to accept a wider variable range
for the idle position, and the computer would quickly learn,
and use whatever voltage (within reason) as its std. reference.
the early TPS sensors had slotted mounting holes, and using a
scan tool was the quickest way to set them.
once idle position was within acceptable range, you would
hold the throttle wide open to make sure the WOT minimum
voltage was being achieved, if not, re-adjust until you
got both right...
95 S-10 2.2. Soon to be DD
post #17 of 17 Old 10-27-2009, 12:11 AM
trucky's Avatar
User is: trucky is offline
so can this be done on an OBDII? Or will the computer correct it like stated above?
---===<<< 2001 Xtreme X-Cab 4.3 W.I.P.>>>===---
Ported & Polished Throttle Body / Polished MAF / Modded Air Box / Dual E-Fan Installed / '93 Jeep Grand Cherokee Steering Mod / New Front KYB MonoMax Drop Shocks
trucky is offline
