Having trouble changing Motor Mounts! - S-10 Forum
post #1 of 25 Old 01-28-2006, 03:04 PM Thread Starter
Ground Patrol
TempoRaptor's Avatar
User is: TempoRaptor is offline
i unbolted thebolt that goes through the motor mounts but when i go to jack up the engine the whole truck wants to lift up........................ is there somebolt i am forgetting to un bolt??..............................
Ground Patrol - SoCal since 1996
"Could of had a Bentley but Id rather ride Chevy."
1999 Chevy S-10 - still in the family.
1999 Chevy C3500 Crew Cab 454 Big Block - "The Beast"
2000 VW Jetta TDI - Daily Driver - 41 MPG
post #2 of 25 Old 01-28-2006, 03:11 PM
User is: Generic0 is offline
Re: Having trouble changing Motor Mounts!
You have to disconnect the transmission mount i think, and any wires that might be tying you down.
Generic0 is offline
post #3 of 25 Old 01-28-2006, 08:23 PM
graniteguy's Avatar
User is: graniteguy is offline
It's been a while but i never unbolted anything but the mounts. There is one bolt that is hard see and even harder to get a socket on. If you get a serrated fillet knife or similar, cut the rubber off the mount. This will help a bunch to see it.
Originally Posted by 0psisdime
Whatever you do dont spray a 4.3 with stock internals 175 shot,Enless you want a few rods hanging out the side of your block.
post #4 of 25 Old 01-28-2006, 11:24 PM Thread Starter
Ground Patrol
all right i finnaly got it up and took the old ones out boy was that a pain is the @SS! Then i went to put the new ones in and it was an even BIGGER PAIN!!! I am now having trouble lining up the Long bolt to mount the new motor mounts to the frame...........any ADVICE on this??
post #5 of 25 Old 01-28-2006, 11:27 PM
rat
Got Fuel Rails?
rat's Avatar
User is: rat is offline
Send a message via AIM to rat
On my 2wd, that has a different frame than you, so this might be slightly different. I bolted the mount to the engine. The bolted the top mount to the bottom mount, then lowered the engine down untill i could get a bolt going into the frame, then i was able to get the rest started.
Rick, aim-RAT5111468
2000 4.3 auto
Custom Intake Manifold with 32lb/hr Injectors, Comp cam 260AHR, Tuner Cat Speed Density tune, Vac modulated trans with shift kit and vette servo, Bolt on's
Camshaft Tutorial-----My Truck and The Roots Blower Project ------ My Tuning Tutorial
rat is offline
post #6 of 25 Old 01-28-2006, 11:29 PM Thread Starter
Ground Patrol
I have a 2wd.......... But ive bolted the mounts to the engine already but when i lower it down i cant get the mount to the frame to line up................
post #7 of 25 Old 01-28-2006, 11:37 PM
rat
Got Fuel Rails?
rat's Avatar
Try raising and lowering corners of the truck slightly. THe frame might be twisted a little, they are really flopy on these trucks.
2000 4.3 auto
rat is offline
post #8 of 25 Old 01-28-2006, 11:55 PM Thread Starter
Ground Patrol
well i gave that a try and still isnt lineing up yet.............. Should i pry on them to get them to move? I already tryed giving the motor and shake and didnt move any so any other options?
post #9 of 25 Old 01-29-2006, 12:03 AM
VT1992S10's Avatar
User is: VT1992S10 is offline
you can always loosen the 3 bolts on the engine side, lower the engine so you can get the long bolt thru the hole and lined up, tighten the long bolt, then tighten the 3 motor side bolts. This has worked for me on both my 4x4 and when there was a 4.3 in the 2wd
1992 S-10 350 14.4 @95mph----SOLD, FML
1998 Jeep Cherokee
Originally Posted by Pageturner View Post
VT1992- Ive seen.... and heard.... your s-10 around campus.. sounds pretty stout... whats it got?
makes it worth it!
post #10 of 25 Old 01-29-2006, 01:53 AM Thread Starter
Ground Patrol
im still not having any luck................. Im going to bed and hopfully ill get it figured out tomarrow................
post #11 of 25 Old 01-29-2006, 02:02 PM
User is: bg's is offline
I believe I've read that elsewhere too. Loosen the bolts so the mounts can
move a bit, spear the long bolts into the upper and lower mounts then tighten.
bg's is offline
post #12 of 25 Old 01-29-2006, 05:29 PM Thread Starter
Ground Patrol
Well after much prying and lifting the engine up and down i was able to get the passenger side bolted up but the driver side is being a huge pain! i ve tryed everthing but it wont line up ive even tryed starting the engine and putting it in gear to put load on the engine to see if it would move the engine into place but that didnt work........................Im going to take a break and then try some more prying..............
post #13 of 25 Old 01-29-2006, 08:15 PM Thread Starter
Ground Patrol
I found the secret to sucess! 2 ratcheting tiedowns and a long 3/8 extention, put the 3/8 extention behind the motormount and use one ratchet on each side and rap it around your tire opposite the motor mount.................
post #14 of 25 Old 01-29-2006, 09:09 PM
Wow ! I've never heard of it being done like that before, but if it works and you
got your new mounts in, more power to ya..Sounds like a major PITA, and
I'm going to have to do mine soon..Wonderful.
bg's is offline
post #15 of 25 Old 01-29-2006, 09:23 PM
rat
Got Fuel Rails?
rat's Avatar
Now that you are done, i highly recomend poly mounts. They should never break again. Mine were broken, the drivers side came out in 3 pieces. My headers were hitting the frame. New mounts solved everything.
2000 4.3 auto
rat is offline
post #16 of 25 Old 01-29-2006, 09:52 PM Thread Starter
Ground Patrol
Well i sure know that next time they need to be replaced im going to get it done somewhere cause it was a huge PAIN IN THE BUTT!!!!!!!
post #17 of 25 Old 06-15-2006, 09:02 AM
Searching no more
mat1583's Avatar
User is: mat1583 is offline
Send a message via AIM to mat1583
Did you have an annoying rattling/vibration. Jon and I installed headers and a new y-pipe on my truck not long ago and now it's really rattling/vibrating when I'm at a stop.
Doin' it the right way
John 16:33
mat1583 is offline
post #18 of 25 Old 06-15-2006, 01:46 PM
Yea thats the one thing I truly hate about the poly mounts. Idle
vibration. Especially when the elec fan kicks in..Sounds and feel
nasty.
bg's is offline
post #19 of 25 Old 06-15-2006, 01:46 PM
nasty.
bg's is offline
post #20 of 25 Old 06-15-2006, 04:52 PM
rat
Got Fuel Rails?
rat's Avatar
Mine doesn't really vibrate that much(worse than stock, but still not that bad). I bumped my idle about 25rpm, and it really helped to smooth things out.
2000 4.3 auto
rat is offline
post #21 of 25 Old 06-15-2006, 05:00 PM
Searching no more
mat1583's Avatar
Well, I don't actually have poly mounts, just stock. I'm thinking the headers or y-pipe are vibrating against something somewhere. I mean it's more than just a light vibration. This is something loud and something you can feel in your feet in the cab.
John 16:33
mat1583 is offline
post #22 of 25 Old 06-15-2006, 05:04 PM
Starting from scratch...
02_Black_XBlazer's Avatar
User is: 02_Black_XBlazer is offline
What headers are you running? If they're the edelbrock, you might have to clearence the driver's side firewall a bit for the 02 sensor. A had a similiar issue to what you are descibing, and it was b/c the o2 sensor was banging against the firewall.
Pipefitter's Local 597, Chicago, IL
'97 S-10 SS (gone) ( pics- http://www.s10forum.com/forum/f3/a-l...ing-up-367228/ )
'02 Blazer Xtreme
post #23 of 25 Old 06-15-2006, 05:10 PM
Searching no more
mat1583's Avatar
Yup, edelbrock! Driver's side firewall though? The o2 sensor is on the passenger side on my truck (94 TBI). I'll check that spot to see if it's banging up against anything though. I never really thought of that spot being a culprit. It's kinda tough finding exactly where the noise is coming from.
John 16:33
mat1583 is offline
post #24 of 25 Old 06-15-2006, 05:35 PM
bvr775's Avatar
User is: bvr775 is offline
I just use a long prybar
Blue roof resident
bvr775 is offline
post #25 of 25 Old 06-15-2006, 10:49 PM
That's a good idea. I think I'll try that.
bg's is offline
