Hard to start and STRONG smell of gas when it does - S-10 Forum
post #1 of 24 Old 03-06-2012, 02:32 PM Thread Starter
User is: mdlwate357 is offline
2000 s10 4.3 has 240k, flowmasters
About a year ago it was hard to start so I changed the fuelpump and it worked great. About 6wks ago it started being hard to start again. Instead of starting rright when I turn the key like normal, I have to "lay on the key" and pump the gas for 3-4 seconds. Then it starys but roughly and is kinda rough runnin too. I changed the fuel filter, put in irridium plugsand put in some Seafoam....no improvement. I have had my check engine light come on for the mass air flow sensor. I cleaned it and the light went off. Then it came back on a few weeks later. I noticed a hole in the cold air intake piping so I fixed that....light went off, now its back on. I just ordered a mass air flow sensor to try that, but is there anything else that it sounds like to you all ????
post #2 of 24 Old 03-06-2012, 03:30 PM
00bravadaplatinum's Avatar
User is: 00bravadaplatinum is offline
Re: Hard to start and STRONG smell of gas when it does
seems ignition related. hows the coil, cap and rotor and wires? is your mpg bad?
post #3 of 24 Old 03-06-2012, 04:13 PM
Ninja Owns Me
User is: BLKzq8noma is offline
MAybe someone passed wind?
post #4 of 24 Old 03-09-2012, 10:44 PM Thread Starter
Bought the cap, rotor and wires tonight and will install tomorrow. So this seems like the answer right ??? The smell of fuel is getting so bad I can barely stand it and it's running so rough now Im worried its gonna die on me in trafic or somewhere crazy..... If this doesnt work I'll try the coil, but aftrr that .....Im lost.....oh yeh, mass airflow sensor seemed to help....for about 5 miles or so. Then it just got worse and the check engine light came back on. What aboit a vaccume hose ? Would this be the effects of a bad vaccume ???
post #5 of 24 Old 03-09-2012, 11:24 PM
i saw what you did there!
fast68chevy's Avatar
yeah the fuel injector pipes probably are cracked leaking under the intake
does the engine oil smell like gas at all?
check fuel pressure with key on if it bleeds off pressure pretty quickly just wsitting with ign key on then you have a cracked fuel injector pipe or two its a common problem on cpi
and expensive and its one reason why i stick with the older tbi engines etc
post #6 of 24 Old 03-09-2012, 11:49 PM
superbee's Avatar
User is: superbee is offline
Send a message via AIM to superbee
Yes please do some diagnosing before throwing parts at it.
89' S10 blazer 4wd: 355, 650 dp, rpm intake, comp 282 roller cam, modified vortecs, T56 trans, 8.8 ls rear, headers, x-pipe, spintech pro street mufflers, and......AC
94 sunbird-"turbochicken"Turbo 2.0 5spd getrag swap
Tbi heads, intake,timing set, dist for sale
Blazer Video!
superbee is offline
post #7 of 24 Old 03-12-2012, 09:48 AM Thread Starter
Well I'm no mechanic, limited on tools amd time, so throwing $100 in parts at it is a better start than bringing it to the shop. Atleast I eliminated a few more things..... I replaced the coil, cap, rotor, plugs and wires with NO improvement. Also my oil cooler lines have been leaking for a while now (which is next weekends project) . There's not an oil pressure switch or something related to it that would make it hard to start ? As far as leaking fuel under the throttle body, wouldn't I have a strong smell of fuel under tje hood ? It seems to be more of a rich exhaust smell because it's not as strong under the hood. Could it possibly be the fuelpump I installed is failling ? Or maybe I didn't get something tight enough ? I'm just praying that I can resolve this without bringing it to the shop. Seems like every mechanic around here is nothing but a crook....they overcharge and under fix !
post #8 of 24 Old 03-12-2012, 10:06 AM
jax4x4.com
pjg1173's Avatar
User is: pjg1173 is offline
If the injector assembly or regulator were leaking you wouldn't smell it at the motor because its inside the intake pouring into the cylinders and getting blown out the exhaust. the fact that you have to "pump" the gas to start tells me you are putting the ecu in clear flood mode because there is too much fuel in the intake. go rent a fuel pressure gauge from an auto parts store and test fuel pressure and leakdown. this is a very common problem more than likely its the regulator leaking.
Bigger tires and traction adders just means you get stuck in more inaccessible places.
87 4Runner, SAS, 15" spring lift, 3" body,409 Hp chevy 355, 5.29 gears, 38.5x15.5x15" TSL's
93 S10, SAS, 12" spring lift, 4.30 gears, F/R lockers, 36x12.5x15 TSL's, many more mods
05 Silverado, 2' lift, 4" exhaust, Bully Dog programmer,
00 Jeep Grand Cherokee (Daughters)
04 Chevy Colorado ZQ8 (other Daughters) 3" drop, 235/50r17
pjg1173 is offline
post #9 of 24 Old 03-12-2012, 10:20 AM
fitbmx180's Avatar
User is: fitbmx180 is offline
Send a message via AIM to fitbmx180 Send a message via MSN to fitbmx180
distributor??
post #10 of 24 Old 03-12-2012, 09:31 PM Thread Starter
Something else thats strange....on a cold morning it starts right up, but only that first start of the day....dont know if that means anything....
post #11 of 24 Old 03-13-2012, 11:12 AM
jax4x4.com
pjg1173's Avatar
when an engine is cold it requires more fuel to start. more than likely fuel is puddling in your intake from regulator leaking.
pjg1173 is offline
post #12 of 24 Old 03-13-2012, 11:27 AM
burned's Avatar
User is: burned is offline
^ What he said.
To verify that, hook up a fuel pressure gauge and you will see the pressure bleeds off right away.
2002 Dakota, QC 4x4, 4.7L HO Intake.
1997 S10 ZR2, Ext Cab, 5 Speed (SOLD)
How to test fuel pressure and leak down <---diagnostic help
burned is offline
post #13 of 24 Old 03-19-2012, 09:56 PM Thread Starter
What about this..... For this whole time my check engune light has been throwing the code for "mass airflow sensor, vaccume hose".....isnt there a vaccume hose for the pressure regulator ? Could this be all from a vaccume problem ? How do I check ? I still plan on getting the pressure guage this weekend, but after reading up on the regulator the vacume thing hit me . So, could it be ??? Just a vacume hose ?
post #14 of 24 Old 03-20-2012, 11:29 AM
jax4x4.com
pjg1173's Avatar
no vac hose on the regulator. it gets is vac signal from being inside the intake plentum and usually leaks from the vac port.
pjg1173 is offline
post #15 of 24 Old 03-28-2012, 01:39 AM Thread Starter
I know you all are probably sick of me , but I ordered my spider today. Also, I have a new piece to the puzzle....oil in my coolant. Atleast I gues its oil...looks like red mud in the radiator. Flushed it today because I have no choice but to drive it to work so I wanted to get out what I could even though its still gonna come back Im sure. My oil cooler lines are leaking too lol....240,000 miles on this bad mofo !!!
post #16 of 24 Old 03-28-2012, 10:13 AM
jax4x4.com
pjg1173's Avatar
are you sure its oil and not dexsludge (dexcool). thats what it sounds like to me.
pjg1173 is offline
post #17 of 24 Old 03-28-2012, 11:21 AM
MPETESS10's Avatar
User is: MPETESS10 is offline
Send a message via AIM to MPETESS10
xeleventybillion!!!!!
I hate dexcool. as soon as my truck was out of warranty I flushed out the dex cool and switched to regular old green stuff. that was at 85k miles (ex warr) I am now at 206k with NOOOOO cooling system problems other than a failed water pump at 165k miles.
with that much sludge in your cooling system it will take a lot of flushing and probably still be problematic, but definitely look into a MAJOR FLUSH. I would consider replacing the radiator and heater core as well as the water pump, and both forward and reverse flushing the engine out. of course do this BEFORE you replace all the other parts. replace all your hoses and T-stat too.
as for your starting problem I would lean towards the spider. let us know if your new spider fixes your issues. did you buy a new conversion style or an old style
96 S10 ex cab sportside ZQ8 4.3/5spd 3.42's 207K &counting :fingerscrossed:
2011 F150 ex cab 4x4 5.0 COYOTE POWERED
post #18 of 24 Old 03-28-2012, 12:38 PM Thread Starter
Old style.....I know I know, but I have a lot to fix and with 240k on the truck. I'm not lookin' to throw a grand at it. So I found a used spider from a truck with 36k miles that was wrecked and being parted out. The spider has a 3yr/30,000 mile warranty. It was "electro-something" cleaned and tested. It looks brand new and for 90 bucks. I went ahead and orderd the pressure regulator too...another $80, plus a gasket , $30. Im looking for a good price on a new radiator now. My oil cooler lines are cheap to fix, but it still all ads up. I JUST changed the coil, rotor, cap, plugs, wires, fuel pump, fuel filter, 4 new tires, alternator, control arm bushings, stabilizer and pitman arms. So while I know it is stupid to tear i to the intake only to replace using used parts, but saving that $200 just seemed like the way to go at the time.....honestly though, I think just trying to convince myself because I know better.
post #19 of 24 Old 03-29-2012, 10:29 AM
MPETESS10's Avatar
so you spent 200 bux for a USED old style injector spider?
I hate to tell ya this but you just wasted a bunch of money.
Rockauto has new style injectors from DELPHI (aka OEM supplier) for $219 and it comes with a new mounting bracket, new FPR, and gasket.
what you bought will hopefully fix your problems though
post #20 of 24 Old 03-29-2012, 06:01 PM Thread Starter
No, I SAVED $200. Online I found a new one for $289....I got mine for 80 bucks.
post #21 of 24 Old 03-30-2012, 12:22 AM
MPETESS10's Avatar
90 spider
+80 regulator
+30 gasket
by my math that equals 200 unless I am misunderstanding something here.
I paid $226 for everything you just mentioned and its brand new and a new style and its OEM parts.
am I missing something here?
post #22 of 24 Old 03-31-2012, 08:17 AM Thread Starter
Really ??? Rockauto shows 263.79 for a remanufactuered syder injector kit for the 2000 4.3. Anyway...my truck is running great again and that's all that matters. Who got the best deal on their parts ??? Well I guess you did. Thanks for all of y'alls help....withoit this site I'd probably be curled up into an ass ball in some dark room sucking my thumb by now lol....
post #23 of 24 Old 04-02-2012, 11:44 AM
MPETESS10's Avatar
RELAX MAN, I am just tryin to help you get the right part AND the most for your money.
the price you saw is a reman OLD style injector and the $236 price INCLUDES a core charge of $85 that you would be refunded if you sent in your leaky injector. which would give you a purchase price of $152 for said reman inj.
directly above that part on rockauto is "standard motor products FJ503" for $219.79
and above that is delphi FJ10565 and it is priced at 218.79. it is the OE part manufactured by the same company that makes the ACDELCO part that is the last part on the page for 377.79
the delphi part is the one I bought. it has a brand new regulator, it comes with the gasket needed, as well as the new bracket required for install.
post #24 of 24 Old 04-03-2012, 12:33 AM
User is: vinx is offline
Just had the same problem. Hard to start. I did a fuel and vacuum diagnostic with a loner tool from the local parts store. Pressure build good but after shut down quick leak down. I pulled the upper intake plenum and on the driver side intake back by the fire wall was clean due to gas leak. Bad fuel pressure regulator. I'm installing a new spider as the truck has 360k and I don't want to have to do this again.
New spider
vinx is offline
