Fuel Tank Pressure Sensor Problem - S-10 Forum
post #1 of 13 Old 01-09-2009, 07:05 PM Thread Starter
User is: punisher83 is offline
i have just rplaced the fuel pump on my 98 s-10. now the check engine light comes on. when i get the diagnostics done on it it says that there is a pressure sensor problem. has anyone else had this problem and if so what could it be? and aslo were is the location of this sensor. please help
post #2 of 13 Old 01-09-2009, 07:20 PM
Will work for turbo parts
User is: King_Ice_Flash2 is offline
Send a message via AIM to King_Ice_Flash2 Send a message via MSN to King_Ice_Flash2 Send a message via Yahoo to King_Ice_Flash2
Re: Fuel Tank Pressure Sensor Problem
The pressure sensor is located on the top of the gas tank. What is the code number?
2003 S10 Long Bed 4.3L ZQ8 + 2/3 drop, Caltracs, rear disk conversion, 7" dual diaphragm booster, 255/50/R16 Falken ZE-512, MPFI converted 2114, 48LB Racetronix injectors, eBay RS BOV, Accel 60115 distributor, Aeromotive FPR, Corbeau Forza seats, Mach headers, 2.5" front mount intercooler, Innovative turbo, Precision Industries Vigilante 3,000 RPM torque converter, EFILive COS3 tune.
post #3 of 13 Old 04-09-2009, 12:19 AM
~02DIME~'s Avatar
User is: ~02DIME~ is offline
I'm getting a p0452. evap low pressure. and my gas gauge stays on low fuel. could this sensor cause this?
{Mike}
02 S-10, 4.3 Ext. Cab. ZQ8 + 2/3 drop. SS mirrors, Noma hood, Clear headlights and signals, SS Gen 4 valance, 18" KMC Stealths, Shaved. Needs bags!
07 F-150 Lariat - Daily
~02DIME~ is offline
post #4 of 13 Old 04-09-2009, 01:16 AM
leaking gas cap, evap vent solenoid, evap purge solenoid, leaking fitting, leaking tank, leaking line, or plugged evap line are also possibilities. If there isn't something obviously wrong with it, take it somewhere to get smoked.
post #5 of 13 Old 04-09-2009, 08:48 AM
Been around the block
CatDaddy52's Avatar
User is: CatDaddy52 is offline
....or bad electrical connection!!
post #6 of 13 Old 04-09-2009, 08:19 PM
I finally got blown
99xtrm's Avatar
User is: 99xtrm is offline
isnt the pressure sensor on the very top of the fuel pump itself maybe they pinched the o-ring where the pump seats to the tank causing an evap leak. You could undo the bolts holding the bed on and start the pass side bolts a couple of threads and prop the bed up with a 2x4 and check the electrical connections and get to the pump to check the o-ring.
best time of 13.9 looking for 12's. Pics and vids https://myspace.com/270507651
99xtrm is offline
post #7 of 13 Old 04-14-2009, 07:49 PM
~02DIME~'s Avatar
P0452 - Evaporative Emission Control System Pressure Sensor Low Input
thats the definintion of my code.... where are these sensors on the truck. It has to be a sensor, gauge was working mint one night, next morning its stuck on low fuel and ses light comes on
{Mike}
~02DIME~ is offline
post #8 of 13 Old 04-15-2009, 09:31 AM
Benoitmusic's Avatar
User is: Benoitmusic is offline
I had a simular problem and a new wire harness connector to the pump solved that.
post #9 of 13 Old 04-15-2009, 07:24 PM
~02DIME~'s Avatar
I'm pulling a p0449 now as well as p0452. wheres my evap vent/solenoid?
{Mike}
~02DIME~ is offline
post #10 of 13 Old 04-15-2009, 09:09 PM
It only quit once...today
Anothersutherner's Avatar
User is: Anothersutherner is offline
Send a message via AIM to Anothersutherner
A bad pressure sensor has it's own code. I put a airtex pump on mine and two weeks later the sensor quit, but I swapped it off the stock pump i removed and have had no more problems. An evap code is something completely different.
2001 Chevy S-10 extended cab 2WD
mobile HAM / EM. Comm station
1995 Chevy Suburban 4x4
wife's truck
post #11 of 13 Old 04-15-2009, 09:18 PM
~02DIME~'s Avatar
but if the vent or solenoid is stuck open couldn't that cause low pressure?
{Mike}
~02DIME~ is offline
post #12 of 13 Old 04-15-2009, 09:23 PM
yes it can, but that is not a bad sensor, that is a sensor doing its job alerting to a problem in the evap system.
wife's truck
post #13 of 13 Old 04-16-2009, 09:15 AM
"factory freak"...
Crew Cab Sonoma's Avatar
the PURGE solenoid is located on the pass. side
rear intake manifold.
the "VENT" solenoid is probably located above the
rear axle housing. it has about a half inch hose attached
to it, which leads back to the EVAP canister.
this solenoid is normally open, but is commanded shut by the
PCM once in a while to test the system to make sure its
airtight.
any other time, the tank, and EVAP canister should be at
ambient atmospheric pressure.
once the VENT is shut, the PURGE is opened briefly,
and the PCM uses the tank MAP sensor to monitor for a
slight pressure drop.
both solenoids can be bench tested for proper function,
by applying 12V to the terminnals and lisening for the "click"
they make when functioning properly.
without power applied, the PURGE sol. is normally closed,
and the VENT sol. is normally open.
95 S-10 2.2. Soon to be DD
