s-series #2?
User is:
greencactus3 is offline
first snow problems
today was the first day with snow on the ground. i was going out in the truck, and it started fine. ran fine till i got to a straight stretch, and since its the first snow ive seen in this truck, i wanted to test the brakes. so i hit the brakes hard, the abs works (i guess) and then the engine stalls. this is an automatic btw. but i was like oh well. maybe the engine's too cold still, so i crank it again but it wont start. so i floor the throttle and then crank again till it starts. but once i let the revs drop a bit, it stalls again. so i start it again by holding the throttle down, and warm the engine up for a bit keeping the revs at 2000.
once its warm, i drive it a bit, and its fine until im driving at 25, and i let go of the throttle. (no brakes yet) and then coasting, the engine speed drops down to under 500, sputters, and dies. i do this a couple times and when i give it a little more gas the engine keeps running. only when i keep the revs above 800 the engine wont stop. it being an auto, its a little complicated when i want to shift into reverse and whatnot. i go to a friends house, and he wants to see my coldair intake which i installed hmm... a week ago i guess? and i notice the filter has fallen off. not bad installation but faulty product. ill get a pic up eventually. damn cheap filter off ebay. im gonna get a k&n soon i hope. or i need to.
well anyways, i duct tape it together for now but it the engine still stalls once in a while when im hitting the brakes.
this engine has been running flawlessly until today. what's gone bad? the filter had been put together with glue and i guess the glue wasnt rated for cold temps like here. and it came apart. but even after it was put back together it still stalls... even when the engine is running temperature.
on a side note, there seems to be air leaking out from between my tire and wheel. just started today. unno why. it was fine yesterday. just started today. why? does snow have to do with it?
what's wrong with my truck now?
its a 98 4.3l with about 188k miles on it.
bone stock except for the cold air intake and i took off the rubber seal from the back of the hood. (more airflow or i was hoping)
oh and i installed an aftermarket tach which has been and still is working fine.
any reason why it should be doing this?
