Fast idle on a 98 4.3 Blazer ????? - S-10 Forum
post #1 of 8 Old 03-07-2005, 08:51 AM Thread Starter
pbeguy's Avatar
User is: pbeguy is offline
My engine idles fast sometimes (1100 to 1300 a lot of the time). It really concerns ms when I let off to come to a stop. After a few seconds it will settle down and stay at 600 or so. I leave it idling a lot in the summer to keep it cool on the inside.
98 4.3 185K
LB
pbeguy is offline
post #2 of 8 Old 03-07-2005, 12:11 PM
Pushrod for life!
pare_john's Avatar
User is: pare_john is offline
Send a message via AIM to pare_john Send a message via MSN to pare_john
Re: Fast idle on a 98 4.3 Blazer ?????
check the IAC it could be sticking. remeber though that if the truck has been sitting for a while it will idle higher when you first start it. Then it will eventualy come down
1992 Chevy S10, 3.1L V6 5 speed. Bored .40 over, 272 crane cam, heads ported,polished,plained. Decked block. Port matched intake.
Valve job. High compression pistons. Roller rockers. AFPR. Compression 9.5/1. 3.43 rearend. 2/2 drop. Taurus E-Fan
www.s-series.org
post #3 of 8 Old 03-07-2005, 05:30 PM
trix's Avatar
User is: trix is offline
Send a message via AIM to trix
what is IAC?
1999 Chevy S-10 Xtreme
Victory Red - 4.3L V6 Auto
Power Effects Dual Exhaust
Ebay Intake
Lead Foot
trix is offline
post #4 of 8 Old 03-07-2005, 07:23 PM Thread Starter
pbeguy's Avatar
It is my daily driver.
LB
pbeguy is offline
post #5 of 8 Old 03-07-2005, 09:30 PM
Kramerica Industries
BlazerFRS's Avatar
User is: BlazerFRS is offline
I think he just means when it's cold; not like for weeks or something.
Also the IAC stands for Idle Air Control (Or something like that) It's a valve that regulates the amount of air getting into the engine when your foot isn't on the gas. if it gets stuck, then the computer can't regulate the idle anymore, so it can stall or idle high.
1991 4.3 TBI Blazer 4x4, 5 speed
Mods:
painted DIY intake & Junkyard E-fan
Cooled Cupholder:
Mark I -Complete
Mark II - planning phase
Standard for life!!
post #6 of 8 Old 03-08-2005, 01:14 AM
Pushrod for life!
pare_john's Avatar
IAC(idle air control) like said it regulates the amount of air comming into the engine at idle.
when the engine is cole(sitting for a few hours) the idle will be higher. But it should eventually drop. does your's eventually drop?
www.s-series.org
post #7 of 8 Old 03-15-2005, 08:51 PM Thread Starter
pbeguy's Avatar
It is weird.
During the day just driving around in traffic, it will not idle down when I stop in traffic.
It will stay around 1500 till I get it stopped, then it will fall to 600.
It does it at 60 or 80 degrees.
Where is the IAC on the engine if I need to replace it?
LB
pbeguy is offline
post #8 of 8 Old 03-16-2005, 09:27 AM
User is: Jay02XBlazer is offline
Send a message via AIM to Jay02XBlazer
IAC is on the Throttle Body
