F$%#$ Smog Check Fail - S-10 Forum
post #1 of 11 Old 05-18-2010, 01:47 AM Thread Starter
DOINSND's Avatar
User is: DOINSND is offline
I have a 1996 Chevy S10 4X4 Blazer stock.
I cleared my codes trying to pass smog. I did it a couple of times. The same codes kept coming back. FAILED SMOG. My reader is telling me code P0134 = No activity Det Bank 1 Sensor 1. P0700 = Transmission Control System. and P1192 = PD unidentified.
The Tech at the Smog shop said change out O2 sensor before Cat. There is Three before Cat. One on drivers side, One before Y, and One before Cat. Then One behind Cat. How do you tell which one is bad. Then he said change out Cat TOO.
At $75 dollars apiece for O2 sensor's I'm trying to figure out which one out of three to change out.
Or could it be something else?
Thank's Kirk
DOINSND is offline
post #2 of 11 Old 05-18-2010, 01:48 AM
terrible. take a lap.
joyride's Avatar
User is: joyride is offline
Send a message via AIM to joyride
Re: F$%#$ Smog Check Fail
try figuring out whats wrong with the motor before wasting money on 02 sensors...
Brian
01 xtreme 4.3L 5spd 2/3 drop w/ SS front bumper|.030 over|270 comp cam|500 lift|dual valve springs|10:1 C/R|p&p heads w/ 3 angle valve job|w4me tune|shorty headers|2.25 y pipe|no cat|Spintech muffler|windage tray|LW flywheel|DF clutch|8mm wires|no ac|efan|walbro 255|MPFI upgrade|Comp Cam timing chain|ARP bolts/studs|totaled***
Now owner of a white 2002 Blazer Xtreme
http://www.youtube.com/watch?v=CO_A1IrbQNM
85 Monte Carlo SS
KCCO
joyride is offline
post #3 of 11 Old 05-18-2010, 03:36 AM
AVNCHRIS's Avatar
User is: AVNCHRIS is offline
best bet is to change all four.
AVNCHRIS is offline
post #4 of 11 Old 05-18-2010, 07:00 AM
User is: poconojoe is offline
So when you get a nail in one tire, so you tell the shop to put a patch on all four?
To the OP
Bank one sensor one is the drivers side closest to the motor
post #5 of 11 Old 05-18-2010, 09:44 AM
B4U Task Force
Rhotpursuit's Avatar
www.getgmparts.com is pretty reasonable for O2's and other fuel management parts.
U.S.C.G. "So others may live"
Apple Red 96 SS
post #6 of 11 Old 05-18-2010, 12:16 PM Thread Starter
DOINSND's Avatar
Thanks poconojoe is there anyway to test O2 sensors
DOINSND is offline
post #7 of 11 Old 05-18-2010, 02:42 PM
AVNCHRIS's Avatar
To the OP
im just saying. why change one sensor and that one senser is going to read better then the others that are used...
AVNCHRIS is offline
post #8 of 11 Old 05-18-2010, 07:36 PM
User is: cams is offline
^ what he said. If the wires running to that sensor are in good shape and not burned through or torn then replace the sensor. If the cat was bad you would get a p0420 probably but you arent so dont listen to super tech at the smog station. The P0700 and p1192 are not valid codes for your truck. (I think, what scanner are you using?)
(what he said meaning post #4. I typed this at 6 this morning and didnt send it till just now)
cams is offline
post #9 of 11 Old 05-18-2010, 08:13 PM
Dallas Anyone?????
SpiderDallas's Avatar
User is: SpiderDallas is offline
The bank 1 sensor 1 sensor is the one on your cylinder 1 side down pipe. The sensors for our vehicles are simple to get to the pig tails are actually worse to get undone then the 02 sensors.
post #10 of 11 Old 05-20-2010, 06:23 AM
94 s10 vin "W"
XeroX17's Avatar
User is: XeroX17 is offline
Send a message via AIM to XeroX17
except when the damn things wont break loose
XeroX17 is offline
post #11 of 11 Old 05-20-2010, 08:52 AM
4 wheels aren't as fun
serpentracer's Avatar
User is: serpentracer is offline
the p0134 and p0700 is but not the p1192.
these kinds of discrepencies are why the testing in ohio was stopped. the people at the tests facilities were failing cars for no real reasons. because they don't know what they are looking at etc. such as a transmission code making a car fail the smog test.
here's a site with a pretty good complete list of codes.
http://www.aa1car.com/trouble-codes/
02 sonoma 4.3L auto
97 sonoma 2.2L manual
