evap and egr removal
I am going to get my pcm reflashed, so I figure I might as whell get some other stuf I dont want removed also. I want to remove the 3rd oxegen sensor, the egr and the evap. Has anybody else done this?
not low, not gonna be...
Re: evap and egr removal
i have removed my 3rd O2 sensor and EGR codes removed,
kinda wish i had done the EVAP codes as well. while i have physically removed the EGR and 3rd O2 sensor, i plan to leave the EVAP canister in place and functioning. its simple, weighs almost nothing, and does allow the engine to burn fuel vapors that would otherwise be wasted. |
while the EVAP OBD diagnostic routines are a PITA,
the system itself does serve a useful function. |
not to high jack, but what about blocking off egr on 1st gen 4.3? i think my map sensor vac hose runs back there but i'd like to ditch my egr
I found a guy that will make me a full egr deletion kit for well the plate that replaces the egr valve for 43. I don't know if there is someone else out there that does cnc machine work and make a plate with the bowtie in the middle. He also can make a billet cap for the egr tube.
It a company called "Custom Billet Works Inc." on ebay if you want to take a look. Probably going to order mine soon if I can't find something cheaper. Its going to cost me probably 70 for the whole kit which is the block off plate and both plugs the one on the header and intake.
