Engine Running Rough - S-10 Forum
post #1 of 8 Old 12-02-2009, 06:21 PM Thread Starter
User is: pgreenwe is offline
This one is a head scratcher, my 97' S10 4x4 5-speed has been acting very strangely. Upon startup it runs fine, idles smoothly, no issues. But from the 1000 to 2500 RPM range it jerks and misses. After warming up however, the problem goes away and it runs smoothly for the rest of the day. We took it to a mechanic who replaced the plugs, wires, cap, rotor, and coil. This seemed to take care of it. Here is where things get really strange, about a month later it started doing it again, almost imperceptibly missing and jerking for the first 20 minutes or so of running and then going away. The jerking and missing got a little worse each day until finally, one day while driving up a hill around 40 mph with my head smacking the back window, it gave a loud backfire and shut off. It would not start back up. We had it towed to a new mechanic who replaced the coil AGAIN as well as the crank position sensor and once again the problem went away. A month later the same thing happened and we took it back to the second mechanic who tried for 2 weeks to solve the issue and was unsuccessful. He replaced the coil a third time, put in a new computer, plugs, wires, cap, rotor, checked the timing, compression tested it (i assume), and even installed an octopuss to bypass some of the fuel valves. And after all of that it was still acting like a hungover college kid. Any insight to this matter would be greatly appreciated.
pgreenwe is offline
post #2 of 8 Old 12-02-2009, 10:31 PM
Bill Wheats's Avatar
User is: Bill Wheats is offline
Re: Engine Running Rough
Dizzy gear
Dirty selinoid
vacuum leak
MAP sensor
EGR in need of cleanning
Ignition Mod
My advice: connect a vacuum gauge with about another 6' of line so you have it on the dash. Then you can at least see what is happenning when it starts to trailer hitch on you.
But that's just me. And I only believe in replacing parts because they need to be replaced or for preventive maintanance...
Yes I'm lazzy... but my vehicles start as soon as the starter turns.
Some people are like slinkies - not really good for much.
But they bring a smile to your face when pushed down the stairs.
post #3 of 8 Old 12-03-2009, 04:06 PM Thread Starter
I'll talk to my mechanic about that list, but I was just reading another thread and their issue sounds exactly like mine. Several people suggested that the distributor gear could be bad so I'll try that too. Thanks for the advice.
pgreenwe is offline
post #4 of 8 Old 12-03-2009, 06:28 PM
The list is endless, but after read about your issue I think that I'd start by looking at the coolant temp sensor ( not the engine temp sender that goes to the dash).
post #5 of 8 Old 12-04-2009, 03:08 PM Thread Starter
Yea I read that too about the coolant temp. sensor. I'm not sure if it's running rich or not, I'll ask my mechanic if the plugs are really dirty in the event that the dizzy gear isn't the problem.
pgreenwe is offline
post #6 of 8 Old 03-04-2010, 01:05 PM
tom97zr2's Avatar
User is: tom97zr2 is offline
did you fix this? mine does the same thing. please let me know thanks
1998 S10 ZR2, 2" BL and 32" tires
PICS of my old ZR2, CLICK HERE Just traded - 97 S10 ZR2 4.3L Vortech Supercharger, GMC/Envoy Conversion from 97 s10, 5" BDS Lift, 3" BL, 35" tires, 4.56 gears
tom97zr2 is offline
post #7 of 8 Old 03-20-2010, 10:23 AM
User is: nined2tsi is offline
Yeah this really gets to me. People posting problems and never coming back with a resolution. Im having an issue very similar...
1995 Chevy s10 ext cab 4x4 vortec CPI
2003 Honda CBR954RR track weapon
-It's not that some people have willpower and some don't. It's that some people are ready to change and others are not.....James Gordon
-I hear and I forget. I see and I remember. I do and I understand.....Confucius
post #8 of 8 Old 03-20-2010, 03:23 PM
tv vet's Avatar
User is: tv vet is offline
I'm also curious as to what the fix is.
Send the guy a friendly message,no harm in that.
tv vet is offline
