EGR Delete Pros/Cons - S-10 Forum
post #1 of 66 Old 04-09-2010, 05:00 PM Thread Starter
ATP
-JOE-
ATP's Avatar
User is: ATP is offline
My EGR is making my truck run like shit AGAIN. I have been reading threads all over the place about deleting the EGR with a custom plate that bolts where the EGR mounts and just stops the recirculation. I hear that it jacks up the cylinder temperature and can kill your exhaust valves or something.
If I remove the EGR, what exactly will the difference be performance wise?
What are the downfalls of doing this? Internal damage? I'm aware it will throw a code, I really don't care.
Anybody currently daily driving their truck with an EGR delete? Advice? Was it worth it? Links to plates?
Thanks a ton in advance, I can stand my truck when it runs like this, and cleaning it seems to only pay off for a few months.
94 S10 Blazer "Tahoe" 4X4
4.3L CPI Automatic 149k mi.
Blazemaster
ATP is offline
post #2 of 66 Old 04-09-2010, 05:46 PM
WICKED 6 RACING
disturbing V6's Avatar
User is: disturbing V6 is offline
Re: EGR Delete Pros/Cons
It won't hurt anything. My 92 been delete for years. On the open highway it gets a little better gas mileage beyond that nothing I can account for.
1988 S-10. Built for all out drag racing. 4.3L based 309 nitrous fed power house. Holley Dominator EFI with large amounts of dry nitrous
1.46 60ft
6.4at 112 1/8mile
10.02 at 136 1/4 mile Best MPH 136
1992 S-10 silver Sunday grocery getter.
2000 Z-R2 DD
Complete custom 309 V6 with truck build
post #3 of 66 Old 04-09-2010, 06:25 PM Thread Starter
ATP
-JOE-
ATP's Avatar
Is your truck now immune to random rough idling and stalling? That's what I want to do it for...my truck runs smooth and solid for months then out of nowhere I have the EGR "cam" at idle and the occasional stall out when slowing down.
Blazemaster
ATP is offline
post #4 of 66 Old 04-09-2010, 06:52 PM
Dig Or Die=I Die
12sws27's Avatar
User is: 12sws27 is offline
Ive had my EGR deleted and disabled in the PCM tune like a year or 2 ago. I have had no ill effects because of it. I don't think there is a down side except for causing more pollution. Some might say you'll get worse fuel mileage but I don't see how. My mileage hasn't suffered any.
As from as the pro's go.... You won't get hot filthy exhaust gases pumped into your engine. Should have less hesitation when you accelerate. You won't have to worry about the POS getting clogged up and you got a little less sh!t in the way when you're working on it.
1998 GMC Jimmy, 2dr/2wd, 4.3L auto: Wynjammer S/C @8psi, Accel 300+ ign box, Taylor 8mm wires, CFM-Tech tb blade, Trans-Go shift kit w/vette servo, cat delete, Hooker Maxflow muffler, Zexel Torsen LSD, Marine intake, 42lb/hr injectors, aeromotive stealth 340 in-tank pump, racetronix fuel pump wiring harness, AEM UEGO W/B A/F gauge, LS1 E-Fans, self tuned w/HPTuners, best 1/8th mile E.T. so far: 2.26 60' 9.55@73mph <<<6psi.
12sws27 is offline
post #5 of 66 Old 04-09-2010, 07:27 PM Thread Starter
ATP
-JOE-
ATP's Avatar
I'm going to do it. What do you guys have covering the holes? You fab something up or buy something pre fab'd?
Blazemaster
ATP is offline
post #6 of 66 Old 04-09-2010, 07:48 PM
The other "BODY" man
BobOnAir's Avatar
User is: BobOnAir is offline
Send a message via AIM to BobOnAir Send a message via MSN to BobOnAir
You can buy a plug for the intake. For the exhaust I just welded up the nut and put it back on and just made a plate and gasket for the valve.
<< Licenced Autobody & Collision guy*>>
S-10 Project
Sonoma Project.
* Money doesn't make me happy. It's the things I buy with money that make me happy *
BobOnAir is offline
post #7 of 66 Old 04-09-2010, 08:02 PM
goin broke but n style
S15vortecpwr's Avatar
just put a solid plate b/t the egr valve and the intake. Leave teh egr plugged up and the CEL wont come on. I am building one for my 94 now for the long haul. i build a plate to go b/t but it was thin and i was affraid it would not last, so i am goin thicker. My CEL never came on. just leave teh EGR plugged up.
01 GMC Noma 2.2L auto - SOLD
99 blazer 4dr 2wd - SOLD
GOIN BROKE BUT N STYLE
post #8 of 66 Old 04-10-2010, 01:13 AM Thread Starter
ATP
-JOE-
ATP's Avatar
Okay I get what you're saying, by leaving the EGR still plugged in, it wont freak out and throw a code, and by making a plate of some sort, it will keep the EGR from being used. Sounds legit. I don't have any metal working tools really, just a cheap ass dremel and JB Weld. Where would I get the proper metal and such to do this? I mean obviously the shim wouldn't have to be the same shape as the mounting area, just big enough to cover the ports and drilled so I can run the bolts through it...
Blazemaster
ATP is offline
post #9 of 66 Old 04-10-2010, 02:15 AM Thread Starter
ATP
-JOE-
ATP's Avatar
Shit, dont mean to double post
Are there any other things on the 4.3 CPI that can be deleted emissions wise? I don't care about the environment. I care about removing bullshit.
Blazemaster
ATP is offline
post #10 of 66 Old 04-10-2010, 09:04 PM
Ω Master Jedi Ω
Sound Barrier's Avatar
User is: Sound Barrier is offline
ther is a store on eBay taht sells egr block off plates and restrictor plates for the 4.3 , that is where i got my restrictor from http://stores.ebay.com/Custom-Billet-Works-Inc
post #11 of 66 Old 04-11-2010, 12:19 AM Thread Starter
ATP
-JOE-
ATP's Avatar
Ironically I just bought a plate from that eBay store a few hours ago. I figure its a killer deal considering it comes with a new gasket which I'd have to replace if I were to just clean the EGR ya know?
I'll throw a picture up of it installed when it comes.
Sounda Barrier - What are the bolt heads like? Hexagonal socket drive? I have to buy a socket for that if they are.
Blazemaster
ATP is offline
post #12 of 66 Old 04-11-2010, 03:04 PM
User is: Brad92 is offline
Thanks man!
02 GMC SIERRA RCSB 4.3 V6 Throttle blade mod, Kennedy Airbox Mod, K&N Filter, 6000K HID Highs and Lows, All On Headlight Mod, Auto Headlights Disabled, Killed the Door Chime, Resonator Capped, 265/75/16 A/Ts, Alpine HU, Pioneer Amp and Speakers, MTX Thunder 10.
97 Suburban
2004 Duramax LB7
Originally Posted by lilsonoma View Post
...Plus, I have all my teeth and I am not married to my cousin.
Brad92 is offline
post #13 of 66 Old 04-11-2010, 04:40 PM
Ω Master Jedi Ω
the restrictor had regular type bolts
i think the block off has allen bolts for it
np Brad
post #14 of 66 Old 04-11-2010, 09:02 PM Thread Starter
ATP
-JOE-
ATP's Avatar
Alright thanks man. That's prefect I have every allen size known to man from riding BMX bikes.
Blazemaster
ATP is offline
post #15 of 66 Old 04-12-2010, 04:21 PM
LadiesLoveAGuyInABowtie
01Blazed5SpdS10's Avatar
User is: 01Blazed5SpdS10 is offline
ya i got that restrictor too it helped but i still rev up to 1500 rpm at stoplights for no reason it pisses me off im wasting gas (ive alread tried everything tps, iac, maf, checked for vacuum leaks). Im thinkin about getting the full block off plate and just takin out the egr but i havent done anything with my computer i dont care if it throws a code but will my engine go into limp mode?
post #16 of 66 Old 04-12-2010, 05:46 PM
alvisoroadsters's Avatar
User is: alvisoroadsters is offline
I see smog failures for possible High NOx and missing EGR on the visual. Performance-wise there's no EGR command at idle or WOT. The EGR lowering the combustion chamber temperature allows for higher timing advance, so EGR delete will result in lower possible advance.
post #17 of 66 Old 04-15-2010, 02:56 AM Thread Starter
ATP
-JOE-
ATP's Avatar
My block off plate came in today. Ripped the EGR out completely (does throw the CEL on), and installed the plate. My truck runs buttery smooth, no sputtery acceleration or odd behavior in the lower RPM's like before. Literally solved the problems I was having SO FAR. Obviously I only got to test it for one day, so we'll see if anything comes back over the next week (could be coincidence that it is running perfect knowing these motors). I will probably extend the wiring for the EGR plug and just mount it to the firewall or something to make sure my ECM doesn't shit a brick or something.
alvisoroadsters: I do not have emissions testing in Illinois due to the year of my truck, no worries there.
Blazemaster
ATP is offline
post #18 of 66 Old 04-15-2010, 03:55 AM
terrible. take a lap.
joyride's Avatar
User is: joyride is offline
Send a message via AIM to joyride
cool, i had my egr code deleted but havent done anything about the block off plate until now, i just bought this one from that ebay company someone posted...THANKS!
Brian
01 xtreme 4.3L 5spd 2/3 drop w/ SS front bumper|.030 over|270 comp cam|500 lift|dual valve springs|10:1 C/R|p&p heads w/ 3 angle valve job|w4me tune|shorty headers|2.25 y pipe|no cat|Spintech muffler|windage tray|LW flywheel|DF clutch|8mm wires|no ac|efan|walbro 255|MPFI upgrade|Comp Cam timing chain|ARP bolts/studs|totaled***
Now owner of a white 2002 Blazer Xtreme
http://www.youtube.com/watch?v=CO_A1IrbQNM
85 Monte Carlo SS
KCCO
joyride is offline
post #19 of 66 Old 04-15-2010, 08:18 AM
Sometimes I'm mean...alot
RaginInferno's Avatar
User is: RaginInferno is offline
I left everything in place and had the EGR turned off by wait4me performance
Originally Posted by Bentenn14 View Post
If I had to guess, It's gonna be one of those things that seems like a longshot that's gonna be the problem. I've almost exhausted the short-shots.
Jim
'00 Blazer 4dr 4wd, '00 S10 RCSB,'99 Blazer 2dr 4wd, '97 Southwind 35W, '03 2500HD,'02 Yukon, '00 Harley, '06 GSXR, '00 250EX, '10 RZR
post #20 of 66 Old 04-16-2010, 02:38 AM Thread Starter
ATP
-JOE-
ATP's Avatar
So far it still is running good. However! My temp. gauge kept going from normal to max'd out and lighting the CHECK GAUGES light. But it would go back down after a minute or two, then back up. Idk if that has anything to do with it. I'm plugging the EGR in tomorrow to eliminate the CEL and see if it drives different with the plate.
Blazemaster
ATP is offline
post #21 of 66 Old 04-18-2010, 08:06 PM
joyride's Avatar
i just wanted to show everyone that ebay block off plate i bought so errrrryone has an idea of what its like and what not...15.29 was the cost of it...haha...i like it so far, and they use allen head bolts so it looks better and what not...
Brian
85 Monte Carlo SS
KCCO
joyride is offline
post #22 of 66 Old 04-21-2010, 12:20 PM
98 s10 ext cab v6 5 spd
low98ch3vy's Avatar
User is: low98ch3vy is offline
have you been driving with that motor? because i took off the pully next to the alternator and my belt would squeel soooo bad and the volts would go down.
post #23 of 66 Old 04-21-2010, 12:34 PM
joyride's Avatar
ya, i got a different belt though...mine doesn't squeak...the belt i got was 85.5 inches long.
Brian
85 Monte Carlo SS
KCCO
joyride is offline
post #24 of 66 Old 04-21-2010, 01:43 PM
93_Deuce's Avatar
User is: 93_Deuce is offline
I'm thinking of doing this on my 93 CPI as well. Can't figure out any other reason that my truck won't idle correctly.
ATP---can you post a picture of yours installed? Did it come with bolts as well?
'93 Sonoma Ext. Cab 2WD New 4.3 CPI Longblock, Hi flow cat, Dynomax Bullet Muffler, Heddman Hedders, Custom Y-pipe, 16x8 wheels, Street Performance shocks, BiXenon HID's, Clear Lenses, black euro tails, LED's all around, tint, rollpan, SS Mirrors, De-badged.
(Coming Soon - 2/3 Spindle/Block Drop, front end steering rebuild, smooth front bumper, black grille with billet, paint, e-fan, CAI, shift kit)
Member of Bravada Grills Suck Coalition
93_Deuce is offline
post #25 of 66 Old 04-21-2010, 09:17 PM
Ω Master Jedi Ω
yeah the block off plate comes with two new allen head bolts,
the restrictor plate comes with two new longer regular type bolts.
post #26 of 66 Old 04-22-2010, 09:58 AM
93_Deuce's Avatar
Thanks. I realized that after I asked. I bought the restrictor plate and didn't notice a bit of difference. Hopin' the block off plate will fix my idle issue and I'll get the code tuned out in the future.
93_Deuce is offline
post #27 of 66 Old 04-22-2010, 04:55 PM
User is: Geoff is offline
Alright so I did the marine intake manifold swap and this deletes the EGR I left it plugged in and just hanging there. I will turn it off on the computer here soon. After I turn it off in the computer I can unplug it right? Also is there anywhere else that I might need to use those restrictor plates and block off plates? Anything in the exhuast anywhere that I need to blcok off?
Geoff is offline
post #28 of 66 Old 04-22-2010, 06:52 PM
Dig Or Die=I Die
12sws27's Avatar
Yeah, there's a metal hose going from the driver side exht manifold to the intake manifold. At the time I removed mine. The parts store didn't have the right size plugs to plug the holes. So I cut off the ends of the EGR hose and made plugs out of them.
Here's some pic of where the hose goes, some pics of the EGR ends I made into plugs and a piece of aluminum I use to make a Block off plate. You don't have to make the thing the exact same shape as the EGR valve gasket. I just did out of boredom. Wasn't much going on at work that day...
12sws27 is offline
post #29 of 66 Old 04-23-2010, 11:50 AM
93_Deuce's Avatar
i'm pretty sure my CPI doesn't have anything that goes to the exhaust. Gonna have to check that out
93_Deuce is offline
post #30 of 66 Old 04-24-2010, 08:00 AM
User is: poconojoe is offline
Your CPI motor, has an heat crossover port, on the head that supplies the exhaust gas for the EGR
To the original poster,
Do you run an EGR gasket with a screen to prevent debris from getting the EGR stuck part way open?
The Con of removing it, is the the EPA can fine you $10K for tampering with the emissions control system
The Pro to removing it, is with the way OB has the country messed up, the goverment could really use the money, from your fine, and it might help out all the rest of us tax paying slaves, of the mess he created
post #31 of 66 Old 04-24-2010, 05:09 PM
93_Deuce's Avatar
That's what I thought. I noticed that when I had the intake off.
So, my point is that I don't have to worry about anything on the exhaust side. All I have to do is install the block off plate and get the computer tuned when I don't want the code anymore.
93_Deuce is offline
post #32 of 66 Old 04-24-2010, 07:50 PM
The EPA isn't gonna check under my hood. Me and the OP do not have emissions testing anyway, so who cares?
97 Suburban
2004 Duramax LB7
Brad92 is offline
post #33 of 66 Old 04-24-2010, 11:01 PM
You/re talking about 2 differant things, your state might not check emissions in your area, but the EPA is federal and nothing could stop them from checking your vehicle, if they wanted to
post #34 of 66 Old 04-24-2010, 11:39 PM
Dig Or Die=I Die
12sws27's Avatar
Yeah I can see some EPA inspector coming up to me with a search warrant to search my truck for environmental violations. LMMFAO!
12sws27 is offline
post #35 of 66 Old 04-25-2010, 12:57 PM
Yeah, technically they could, but why in the hell would they send somebody to Bleiblerville, TX, home of like 300 people, to check my stock truck?
97 Suburban
2004 Duramax LB7
Brad92 is offline
post #36 of 66 Old 04-25-2010, 01:11 PM
To justify their uselessness, that's how a bureaucracy works
PS Your truck isn't stock, they see your mods in your sig, remember big brother is watching you. Your EGR mod could be the final straw that caused the last required molecule of the ozone, protecting the earth, to be depleted, and cause the final destruction of the planet earth, as we know it. Or maybe I'll just do it, by passing wind
post #37 of 66 Old 04-25-2010, 01:33 PM
joyride's Avatar
lol...wow
Brian
85 Monte Carlo SS
KCCO
joyride is offline
post #38 of 66 Old 04-25-2010, 11:41 PM
My truck IS stock. I have really no engine mods other than a K&N filter, cut open airbox, and the throttle blade mod. Those shouldn't affect emissions. The others are just mods that make my driving experience more enjoyable.
You have know idea about the problems with diesel EGR's. They are a joke, especially on the Powerstrokes. Mine has just been messed up from the factory giving a constant CEL.
This is kinda funny...
97 Suburban
2004 Duramax LB7
Brad92 is offline
post #39 of 66 Old 05-01-2010, 03:18 PM Thread Starter
ATP
-JOE-
ATP's Avatar
If you're that worried about "big brother" go live in the woods and get off the internet. If the EPA was that eager to find me and fine me, I wouldn't even care...shit luck will find you eventually anyways.
Blazemaster
ATP is offline
post #40 of 66 Old 05-01-2010, 08:52 PM
The woods ain't no good, I live in a cave lined with aluminum foil and get my internet by piggynacking from somebody else's WiFi signal
If the EPA guys get past the bears that live in the front of the cave, they're not going to get past the vampire bats
post #41 of 66 Old 05-01-2010, 10:06 PM
What about your tinfoil hat?
97 Suburban
2004 Duramax LB7
Brad92 is offline
post #42 of 66 Old 06-18-2010, 09:58 AM
neex
User is: neex is offline
Can a plate not be cut out of aluminum and a gasket made with black high temp RTV silicone? You could likely use the bottom of a coffee can and go for years before having any sort of problems. Just a thought. You won't get any show points for a custom billet cnc'd part burried beneath a dead valve.
Mine crapped out last night and lit up my cat like a candle. I'm putting a blocker plate in today after messing with these things for years I've had enough. Screened gaskets help the most but it seems that sooner than later a cleaning, rebuild, replace, or guzzle beer, swear, and repeat will be in order.
RIP EGR.
A.
neex is offline
post #43 of 66 Old 06-18-2010, 03:48 PM
Dig Or Die=I Die
12sws27's Avatar
RIP EGR.
A.
That's all I did. Picked up a piece of scape at work, traced the gasket, then cut and drilled it. I didn't have to make it the exact shape as the gasket but work was slow so....wth right....
12sws27 is offline
post #44 of 66 Old 06-18-2010, 03:48 PM
Dig Or Die=I Die
12sws27's Avatar
Oh shoot! I already posted those pics!
12sws27 is offline
post #45 of 66 Old 07-03-2010, 12:45 AM
muddy98's Avatar
User is: muddy98 is offline
Send a message via AIM to muddy98 Send a message via Yahoo to muddy98
i have a cel and cant keep it from coming back, how can i permanently delete it, i have the blacl plate in, i have the gasket on right, i have the egr plugged on, it sucks when you're driving down the road deleting the code about every 10-15 miles
muddy98 is offline
post #46 of 66 Old 07-03-2010, 12:55 AM
joyride's Avatar
its because you have to get it deleted from the computer...go get a wait4me tune
your egr is most likely throwing a code constantly because you have it not hooked up properly since its not in the engine block due to the fact you have the egr block off plate installed...
did you also block off the big hose that runs from the exhaust manifold?? and the other end of it too...
just tune it out of your computer.
or just ignore it until you have to get emissions done.
Brian
85 Monte Carlo SS
KCCO
joyride is offline
post #47 of 66 Old 07-05-2010, 02:04 PM
Dig Or Die=I Die
12sws27's Avatar
Like Brian said. The EGR DTC has to be disabled in the trucks PCM. Getting a mail order tune will get rid of it and make your truck funner to drive.
12sws27 is offline
post #48 of 66 Old 08-09-2010, 01:30 PM
Lifted 2wd & Bodied 4x4
layinbody31's Avatar
Since I'm doing a W4M tune and a few other motor mods at the same time I'm interested in doing the EGR delete. HOWEVER, my Sonoma is an '02 and for whatever reason the description on the eBay block of plate/plugs kit says it fits '92-'01 4.3s
Is there any reason why it WOULDN'T fit my '02 4.3? I haven't actually looked at the motor to see if everything looks the same on mine as what I'm seeing in your pictures but I still thought I'd ask.
Thanks!
layinbody31 is offline
post #49 of 66 Old 08-09-2010, 01:49 PM
Ok well I answered my own question by searching a little bit farther here on the site and also looking at this picture that I found of my motor:
What I found is that '02up 4.3s DO NOT have an EGR at all, so there is no need to delete it/block it off. Saves me 40ish bucks
Now the question I have is this... behind the A/C compressor there is a valve of sorts that sticks up out of the intake manifold. It has 2 or 3 vaccuum lines going to it and it just twists into its holder. WHAT IS THIS?? I'm putting a Sanden engine driven air compressor on my 4.3 in the stock AC compressor location and my hoses coming out of the compressor are directly in line to with this valve. I can route them around it but if it is something that is not necessary (like an EGR valve) then I'd like to just get rid of it and free up the space for the air lines (which get very hot)
I'll try to get a picture tonight but any help would be appreciated. Thanks!
post #50 of 66 Old 08-09-2010, 02:29 PM
Ok, answered my own question again LOL. Found out that it is something to do with the PCV valve. If I just vent the PCV to the atmosphere can I delete this valve jobber and plug up the hole in the intake? What would I do with the vaccuum line that connects to it then?
Thanks!
