EGR Delete: Benefits/Drawbacks? - S-10 Forum
post #1 of 9 Old 06-07-2011, 08:19 PM Thread Starter
ComputernerdBD's Avatar
User is: ComputernerdBD is offline
Hey everyone. I keep noticing EGR delete plates for 4.3L engines on eBay and elsewhere. What exactly are the benefits or drawbacks to removing the EGR? Would it cause damage or throw the Check Engine light on? Does it improve gas mileage?
1998 GMC Jimmy 4.3L SLT
~129,000 Miles
Mods: eBay Eurotails, Spectre CAI, B&M transmission cooler, deep trans pan, interior LEDs, Posi-Lok
2007 Chevy Trailblazer 4.2L LT
~48,000 Miles
Mods: K&N CAI, trans cooler, deep trans pan, bull bars, LED spot lights/light bar, interior LEDs,
post #2 of 9 Old 06-07-2011, 08:40 PM
User is: onesickbravada is offline
Re: EGR Delete: Benefits/Drawbacks?
Does not improve gas mileage, does help keep carbon buildup out of motor.1996 or newer does not need block off plate just delete it in a tune and it will not open and no check engine light. If you use a block off plate on OBDII you will have a check engine light and have to get it turned of VIA tune so might as well just get everything deleted with a tune. You can use a block off plate to completely remove the EGR and give you a little more room is so desired...I just left mine on and deleted it through the tune as well as my kids.
OBDI you will need a block off plate and need Brian at tbichips or someone else that knows how to program chips delete it for you.
post #3 of 9 Old 06-07-2011, 08:58 PM Thread Starter
Wow. What about removing it, blocking it off, securing it and leaving it plugged into the computer? Eliminates the need for a tune, but keeps the light off?
~129,000 Miles
~48,000 Miles
post #4 of 9 Old 06-07-2011, 09:05 PM
Wont work...you will get a CEL.
post #5 of 9 Old 06-07-2011, 09:07 PM
If you have a 1996 or newer and want to delete it just get a WFM tune and have Jesse delete all the egr crap...send in your computer and it is $75 and you will get better mileage and more horse power with the tune.
post #6 of 9 Old 06-07-2011, 09:11 PM Thread Starter
It is a 1998. I will look into it. Thanks for your help.
~129,000 Miles
~48,000 Miles
post #7 of 9 Old 11-04-2011, 04:57 PM
User is: fordsmith is offline
I have remove my EGR but i didn't find any drawbacks in my car. It is running just like as before. I don't think it has down side effect of disabling the EGR valve. Some says that you will get low mileage poor car performance but nothing happened with my car. Its running nicely.
post #8 of 9 Old 11-12-2011, 12:08 AM
User is: FastEddie is offline
Wink Re: EGR Delete: Benefits/Drawbacks?
Hi everyone...new guy to the forum...with a question about the EGR delete. I have a '97 S10 (X Code VIN) 4.3 and I'm rather frustrated with the EGR system. I had a P1406 code, replaced the EGR valve, the code cleared for a time...and has now returned. Couple of questions...
Where is the DPFE Sensor (EGR Pressure sensor)?
Where is the EGR tube (my valve is mounted on top of the engine...no tube there)?
Can someone explain how I can obtain the 'EGR delete' tune?
Thanks for any help anyone can provide...
post #9 of 9 Old 11-12-2011, 02:30 AM
burned's Avatar
User is: burned is offline
Take the EGR off and clean out any carbon blockage. That code indicates your EGR pintle is stuck due to carbon.
burned is offline
