Driveability Issue
Old 10-20-2009, 06:27 PM   #1
Driveability Issue
I have a friend with a 99 Blazer 4 door 2wd. When starting off from a stop it jerks and eventually when up to speed its runs fine also the tach jumps. This is what I am told is going on I have not had a chance to look at it, the check engine light is on as well. I thought it may be fuel pressure regulator, fuel injector issue. Anyone ever had this happen to them?
Old 10-20-2009, 06:53 PM   #2
Knowledge is power.
s10pimpin209's Avatar
Re: Driveability Issue
get the codes checked. thats a good start.
Old 10-20-2009, 07:05 PM   #3
where's my chippy?
lee-mill's Avatar
prolly a gummed up injector, id run seafoam throw it first, see if that helps
Old 10-20-2009, 10:29 PM   #4
Yeah, I am going to check the codes for him, but thought I would ask if this has happened to anyone else. There have been a number of sensors replaced from the person he purchased the truck from. Before my friend bought the truck, it was checked at the dealership. The dealer said they would have to remove the manifold and look at things, about $700-$800. He bought the truck at a reduced price with the issue and looking to get it fixed now.
Old 11-05-2009, 05:45 PM   #5
The engine code shows to be a P0420 - Catalyst System Efficiency Below Threshold (Bank 1). The cat has been replaced with a aftermarket cat, but the o2 sensors are original. Could the o2 sensors be defective? Which o2 sensor is considered to be bank 1
Old 11-05-2009, 05:50 PM   #6
The tach jumps erratically, is there a fix for this?
Old 11-06-2009, 01:13 AM   #7
take the truck to a tranny shop i have a 2000 gmc seira and they have the same tranny and s10s the 4l60e. it would act up and when i would be driving down the road the tach would jump up and down and it would not shift right some tranny shops will check it out for little or no cost... i do not feel that a faulty o2 sensor would do that or a cat.. there is only 2 o2 sensors on that truck one pre cat and one post cat. my brother owns a blazer same year model too and that is how his o2 sensors are set up. hope this helps you
Old 11-06-2009, 01:29 AM   #8
95tahoelt's Avatar
there are 3- O2 sensors bank 1, bank 2 and 1 after the cat.
sounds like a ground issue to me or dist. cap..
Old 11-06-2009, 01:48 AM   #9
Former S10 enthusiast
01cherryreds10's Avatar
Does it take a while for it to start? Possibly be a bad CKP if it is doing that with the tach and runs rough from a stop. For the injectors you can push nitrogen through the spider to clean them. That's if the shop has access. Do you have access to a scan tool that will display engine data?
Old 11-06-2009, 02:56 PM   #10
well it it is a misfire problem caused by the fuel injectors or somthing with the ignition system the check engine light would flash indicating a severe misfire. is the check engine light flashing??? also i know that if there is something wrong with the tranny it can have the same symptoms that he is explaining thats what my 2000 gmc seira would do and it is not an uncommon problem with the 4l60e trans it is not the best trans in the world.
Old 11-16-2009, 05:29 PM   #11
I will have to ask my friend, the guy that owns the truck. I looked under to the hood and looked as if the plug wires are new and distributor cab looked to be replaced, but never know what previous owner put in with out taking it all back out and looking at it. The check engine light does not flash, just get code: 0420 Catalyst System Efficiency Below Threshold Bank 1. Just that code alone doesn't make since with the jerking. The jerking from take off from stop is worse when the weather is warm outside. I was going to suggest to do plugs, cap, wires and rotor, just to make sure the previous owner didn't put in cheap plugs, or crack a plug when installing it. Start with the basics at least to eliminate the simple stuff.
Old 11-16-2009, 07:08 PM   #12
SpiderDallas's Avatar
Well I looked up the code for you on identifix and it says that the cat is bad. Usually a P0420 code means a bad cat. Hope you get it fixed just figured I would help out.
Old 11-16-2009, 08:31 PM   #13
Bill Wheats's Avatar
Before you start replacing parts like the CAT, I would recomend running some seafoam through the gas (not in the oil) and connecting a vacuum gauge with enough vac line to make it into the dash.
Post your results....
Old 11-16-2009, 08:42 PM   #14
I'm just posting up what the code means. Sorry just trying to help out.
Old 11-16-2009, 09:15 PM   #15
You got it right, but you have to remember that the codes only point to a direction. You still need to use your senses and trouble shooting techniques to solve the cause.
Old 11-16-2009, 09:25 PM   #16
Check the cat and see if it is clogged?
Old 11-16-2009, 09:43 PM   #17
The vacuum gauge will check it real quick, and you don't have to pull the exhuast....
Also the cat may just be getting plugged with fuel, which means once the cause is taken care of the CAT will clean up while driving....
But feel free to do what you want.
Page generated in 0.57827 seconds with 31 queries
[Output: 92.66 Kb. compressed to 85.74 Kb. by saving 6.92 Kb. (7.47%)]
