THE Registered User
Distributor Help
Ok guys Ive got a few simple questions. First off which way does the distributor turn? Which way do I turn it to advance the timing? It should be the opposite of the way the distributor turns correct? Just so you guys know, I installed the distributor wrong when I swapped my manifold. I had my truck tuned today by Blackbear Performance and Justin told me that Im 72* retarded. He said that should be about 2 teeth off. Does that sound about right? Thanks guys.
not low, not gonna be...
Re: Distributor Help
dist. rotates clockwise. go counter-clockwise to advance.
2 teeth off sounds about right for 72 deg. at the crank. just align the balancer to timing cover marks, pull the dist. cap, and determine if its cyl. #1 or 4 thats firing. if its closer to #4, simply rotate the crank another full turn, align the marks again. in the dist. base, there is a "pointer" with a "6" on it. this marks the #1 cyl. terminal. that should be where your rotor aligns to, when the dist. is fully seated, and timed correctly. |
THE Registered User
Thats the thing, we did that. And it says that it is 2 teeth off. I dont understand why it still says its 2 teeth off and I line up that mark.
that is odd. there is a chance that the outer ring of the
harmonic balancer has slipped, giving you a false TDC reading? if its an aftermarket balancer, does the timing mark match up with the original? |
also, my stock balancer has 2 timing marks
on it,, yours probably does too. you sure youre using the right one? once i figured which mark was the true #1 TDC, i marked mine with white paint with a small artist brush. Last edited by Crew Cab Sonoma : 07-02-2009 at 02:05 PM. |
THE Registered User
Its a stock balancer. But maybe youre right about the 2 marks, I'll try that. When I pulled my manifold I never put it on TDC, I just reinstalled the dizzy the way I thought I had removed it. When it didnt run right and started to throw the codes we put it on what we thought was TDC and reinstalled the dizzy. Now cant I just advance it 2 teeth from where it is? Or is that asking for more trouble? Thanks Crew Cab.
yeah, you could give that a try. might work.
THE Registered User
Im gonna try on Saturday.
I've been having the same problem on my 2000, the distributor seems to be afew teeth off from the mark I made, but will only go in 180* apart. I cannot adjust it teeth by teeth due to that notch that will only let it go in in 2 positions 180 * apart
Will work for turbo parts
yeah, you have to remove the distributor, turn the inner shaft. To advance timing, you turn the inner shaft (cap) clockwise, not counterclockwise.
Also, when you do the TDC install, make sure you point it to the mark on the distributor and not the #1 spark plug. There should be a little triangle on it. |
Traction not found here!
The slot on the bottom of the dizzy is what turns the oil pump. You might have to use a long flat head screw driver to turn the slot in the oil pump to match the dizzy in order for it to drop in right.
I usually just turn the crank until it falls in.
THE Registered User
Wait a minute. I thought you turn it in the opposite direction to advance?
you turn the distributor housing the opposite way, but since you can't do that on the 4.3L because of the clamp, you turn the shaft.
THE Registered User
I think I got it. It runs better anyway. When I pulled the cap it was pointing at about 4 o'clock and when I reinstalled it it was at about 6 o'clock. Does that sound about right?
Is the CEL gone?
THE Registered User
So far nothing has come up since I cleared it.
THE Registered User
I guess I jinxed myself. The code came back up this morning. As soon as I started the truck. It didnt throw it at all yesterday after I played with the dizzy, but it comes on now. Guess I advanced it too far.
try to scan it again, to find out how many degrees
its off, or just find TDC, and do it by the book... if its off by just a few degrees, then its likely the Comp cam. lots of people seem to have this problem with the Comp cams... |
THE Registered User
All I have here is one of those cheap scanners. Im gonna call up my buddy and see if his shop has a scanner that can read that. Or I'll pull some strings at another local shop. Can the SOLUS or MODIS read the dizzy position?
Basically it was a little above 4 o'clock and when I turned it it ended up a little before 6 o'clock. Does that sound about right for 2 teeth? |
THE Registered User
And I never had trouble with the cam after I had it tuned by wait4me. And I've never had this code before I installed the marine intake.
retarded it more... but it shouldnt even be running at 4 teeth off... the distributor has 13 teeth, divided by 360 degrees, which makes for about 27.7 deg. per tooth, 2 teeth = 55.4 distributor degrees... double the DISTRIBUTOR degrees for CRANKSHAFT degrees. which 2 teeth would equal 110.8 degrees at the crank.... doesnt quite match up to your 72 deg. figure. did you disassemble your distributor, and maybe put your dist. gear back on 180 deg. off from where it was originally? |
#24 |
THE Registered User
I thought it had 10 teeth? And no I never disassembled it. I already did it by the book with the TDC method and that didnt help. That just retarded it.
#25 |
nope. 13. and doing by the book should have got it right,
assuming you used the correct mark on the balancer. did you look to see if your balancer has two timing marks cut into it? |
#26 |
THE Registered User
Not yet. But how could it be 72 degrees retarded if there are thirteen teeth? Im gonna play with it this afternoon. I know I advanced it too much, so I'll try retarding it a little bit, see what happens.
#27 |
thats has me puzzled as well... how is it 72 deg.
did they say if that was distributor, or crankshaft degrees??? Last edited by Crew Cab Sonoma : 07-06-2009 at 03:39 PM. |
#28 |
How much timing do these engines normally run at idle? If they normally run 15 degrees advanced then add 15 to 55.4. That gets you pretty close to the 72 that was read on the scanner.
#29 |
THE Registered User
He said from the crank if I remeber correctly.
#30 |
ideally, it should remain at zero, but i think up 4 degrees of variation is allowed before a code gets set. |
#31 |
Sounds right. I think it was 2 deg each way (+/-)
#32 |
Makes sense. But how would the ECM know the timing was off by 72 degrees? |
#33 |
THE Registered User
I dont know. But it does. I played with it some but I dont have the time or the space to set the timing correctly. Im gonna take to my buddy at a shop and have him do it.
#34 |
and camshaft (distributor) sensors, and expects them to coincide within a certain number of degrees of each other. if they fall outside of the accptable range, a code is set. this basically helps to tell the factory or mechanic that either the distributor, or the timing set wasnt aligned correctly during assembly, rebuild, or repair, or that the timing set is excessively worn, or has slipped. the cam sensor is basically used on most engines equipped with sequential fuel injection as a means of determining which cylinder is actually firing, since the crank sensor alone cant do this. the addition of a cam sensor gives the PCM the ability to know wether cyl. #1 or #4 is firing, so it can correctly arrange and time injector sequencing... |
#35 |
any new developments on this?
#36 |
THE Registered User
Not yet. Im waiting for my buddy to get a new timing light. I'll wait until I get back from my trip and have him fix her up.
