Distributor for 4.3 conversion to carb - S-10 Forum
post #1 of 22 Old 12-31-2003, 05:12 AM Thread Starter
User is: 87yj2NY is offline
Converting a 94 4.3 older style 12 bolt intake vortec to Carbed intake with edelbrock manifold #2111
WHat do I do with distributor? I need an HEI w/vacum advance that will work for this 4.3...any suggestions? Thanx
87yj2NY is offline
post #2 of 22 Old 01-01-2004, 06:56 AM
Lunatic
User is: Crazy J is offline
i'm not certain but i think a V8 hei distributor is the same with just a different cap/rotor.
we'll wait and see if anyone agrees with me (i'd like to know this also).
Crazy J is offline
post #3 of 22 Old 01-01-2004, 10:23 AM
mcgruff1's Avatar
User is: mcgruff1 is offline
Send a message via AIM to mcgruff1
You can use the MSD pro-billet if you want to get the msd 6a. That way its not vacuum anything, its a magnetic pickup.
'96 regular cab 2.2l 5-speed
mcgruff1 is offline
post #4 of 22 Old 01-02-2004, 01:51 PM
87s104.3's Avatar
User is: 87s104.3 is offline
I have an 85 4.3 that I just got running it was tbi I converted to carb. I used edelbrock manifold #2111 you have to get a distributor that even fire the one I got was for an 81 229 v6 I think. They did make some 85 4.3's carbed so you can get that they are in the c10 trucks some cars and vans no s10's. hope that helps
87s104.3 is offline
post #5 of 22 Old 01-02-2004, 03:14 PM
Lunatic
monte carlo's to!
Crazy J is offline
post #6 of 22 Old 01-02-2004, 10:56 PM
87s104.3's Avatar
The 85 I have is out of Monte Carlo it was tbi not sure if any was carbed in those.
87s104.3 is offline
post #7 of 22 Old 01-03-2004, 02:15 PM
User is: Dougleo is offline
You HAVE to find a 4.3L V6 Distributor. No V8 one will work. Take the cap and rotor off and have a look at the pickup coil. You'll see 8 points for a V8 and only 6 points for a V6. put a V8 one in and it'll be terribly confused... V6 distributors are easy enough to find. Just make sure it's not out of a ESC (Electronic Spark Control) truck
Dougleo is offline
post #8 of 22 Old 01-08-2004, 06:30 AM
User is: nickelsun692 is offline
I believe GM "family"has made three v6 distributors; odd fire, even fire and I believe a "semi-even fire". You need an even fire distributor and I believe (even though somebody will disagree) that Chevrolet never made an EVEN fire non-computer 4.3 distributor. However, if such a critter exist, I want one! Anybody got specifics?
post #9 of 22 Old 01-08-2004, 03:21 PM
87s104.3's Avatar
I don't know what year they started makeing the 4.3 but 1985 some was made carbed so they are non-computer. And I think all 4.3's are even fire I may be wrong.
87s104.3 is offline
post #10 of 22 Old 01-08-2004, 07:08 PM
Actually there were computer equiped cars but not really computer controled vehicles with carburators from 1980 to about 1986/87. Question boils down to: What year(s) did the 4.3 appear with carbs and distributors (if ever) and can those distributors be used/converted to traditional use. There was some really funky electronics during those years.
post #11 of 22 Old 01-08-2004, 07:30 PM
87s104.3's Avatar
1985 some was made carbed. WHAT DO YOU MEAN TRADITIONAL USE? My 4.3 was TBI I converted it to a carb I use an 1981 HEI distributor for 229 even fire v6 and I just got it running about 2 weeks ago.
87s104.3 is offline
post #12 of 22 Old 01-08-2004, 07:56 PM
By saying traditional use I ment non-computerized. All 229 engines have semi-odd fire cranks. 229's were made between 1989-84. I don't know what distributor you have but it cannot be an even fire from a 229. I ain't going to argue with you, say what you will.
post #13 of 22 Old 01-08-2004, 08:05 PM
87s104.3's Avatar
I might be wrong on the 229 but it's even fire and it runs and thats what matters. as for the traditional part I thought that was what you was meaning.
87s104.3 is offline
post #14 of 22 Old 01-11-2004, 02:44 AM
89shortbox's Avatar
User is: 89shortbox is offline
well, I posted a page on this about a year ago , words taken
right from Chevrolet Power Service Manual.
as below
Production Chev. 90 deg. v6s have been offered in 3 displace ments. In 1978 the 200 ci was introduced. In 1980 the bore was increased to yield 229 cubic inches. In 1985 , the 4.3 (262)
replaced and 229 engine. In addition to these differences in cylinder diameter, production v6/90 chev. are also distinguished by their firing sequences. All 1978-84 200ci and 229ci engines have a "semi-even" firing sequence.
The 4.3 introduced in 1985, is a true "even-fire" engine.
Finally, a heavy-duty " common pin" crankshaft was developed for racing. This is an "odd-fire".
Late model 4.3's are available with both cast iron Quadrajet and aluminum two-barrel Tbi intake manifolds.
89Short box
Current build: 406cid twin turbo blowthru carb e85
post #15 of 22 Old 01-11-2004, 02:54 AM
89shortbox's Avatar
if ya really want, just by an Msd box, then use the two wires that come off the pickup in the stock computer controlled distributor.
Use those as the pickup wire for the msd box, you wont have any advance but if you set the timing at 35 deg. and run premium, like 92-93 octane, it will start just fine. Also, gm performance says the swirl port head makes best power at 35 deg. total.
This is what I did to Lilscreamers truck, 91 4.3 block, 229 heads,
edelbrock intake , holley 600,comp roller, ran 14.91 at 92 mph.
89Short box
post #16 of 22 Old 01-13-2004, 11:49 AM
lunatic515's Avatar
User is: lunatic515 is offline
Send a message via AIM to lunatic515
I have a 4.3 hei vacuum advance distributor from 1985 from a full size truck. I got it from local parts store new, they cost around 100 bucks, but its rebuilt with new stuff, not a bad deal. If you are using a double pumper, you will have to use a lot of spacer to clear the distributor. you can also use your factory distributor if you have a hot enough motor to run with locked out timing. you just have to use an msd setup with factory style coil.
post #17 of 22 Old 01-13-2004, 04:40 PM
mcgruff1's Avatar
Hey lunatic, can you check here and see if you know the answer to any of these questions?
http://www.s10forum.com/forum/showth...threadid=80968
mcgruff1 is offline
post #18 of 22 Old 06-10-2014, 09:03 AM
Fiscally Challenged User
ammfan's Avatar
User is: ammfan is offline
Re: Distributor for 4.3 conversion to carb
Will this work?
http://www.aipelectronics.com/index....3-8l-4-3l.html
Or do I need to shell out some more...?
http://www.summitracing.com/parts/du...olet/model/c10
Restored 1987 Silverado - SOLD
Restored 1985 Corvette (with a little more muscle) SOLD
1986 Camaro Z28 (Currently Restoring)
Restored 1985 s10 (I guess I like the 80's)
1965 Buick Riviera Project (I'll get to it one day.... $$$)
ammfan is offline
post #19 of 22 Old 06-11-2014, 04:48 PM
User is: Citrus95s10 is offline
I have the set up off my 95 4.3 4 bbrl intake distributor and it all works . if your interested sell it to you cheap
post #20 of 22 Old 06-11-2014, 05:39 PM
ammfan's Avatar
That's ok, I just found a distributor on ebay with a 5 year warranty for $90. Ordered it this morning!
ammfan is offline
post #21 of 22 Old 06-11-2014, 07:50 PM
AWD V8's Avatar
User is: AWD V8 is offline
1985 Astro 4.3 was a carb engine.
AWD V8 is offline
post #22 of 22 Old 06-11-2014, 09:19 PM
Registered Hoosier
Hoosier Rick's Avatar
A friend of Mine had a carbed 229 in a first gen extended cab. It came out of a Monte Carlo he bought for $100 and drove home.
2002 rcsb, 2.2 at, 267,000 miles
1967 C10
