**Diagnostic Trouble Codes**
LinkBack (4) Thread Tools
Old 02-19-2007, 10:45 AM   #51
CHANGE YOUR EMAIL ADDRESS
Rich J.'s Avatar
Re: **Diagnostic Trouble Codes**
Just re-installed my hypertech and it read code #C1269. I tried to google it to no avail. The P0155 and P0135 are O2 sensors I believe?
Old 02-21-2007, 01:03 PM   #52
Rev. Horton Heat Saves!
SA-S10's Avatar
Have you tried this site? OBD-II - On-Board Diagnostic System
Old 03-05-2007, 08:23 PM   #53
if u have the engine running when up jump term. A and B, just like to check the codes, it tells u if its open loop or closed loop. anyone know what these signals actually are
Old 03-07-2007, 03:50 PM   #54
misses truck....sometimes
never_finished92's Avatar
i just made a thread, and then saw this one...oops
P0410 - Secondary Air Injection System
thats the code i got, what could be wrong?
Old 03-07-2007, 04:27 PM   #55
roachrod's Avatar
P1345 Code
I've got an 02 blazer extreme with a P1345 code, which is camshaft and crankshaft corrilation. I replaced both the camshaft and crankshaft sensors, and the thing still throws the codes. Any ideas?
Old 03-07-2007, 04:40 PM   #56
rat
Got Fuel Rails?
rat's Avatar
Re: P1345 Code
You need to have the dealer do a crank re-learn.
You may be able to do it yourself by elongating the distributor hold down hole. But that is just guessing. Or your distributor may be off a tooth, or you may have a ton of slop in the distributor gear, or timing chain.
Old 03-10-2007, 02:04 AM   #57
ThatOneGuy's Avatar
r these just general gm codes because i didnt know any s-10 turbo diesels, glow plug codes, turbo codes, injection pump codes? just wondering
Old 03-10-2007, 02:09 AM   #58
rat
Got Fuel Rails?
rat's Avatar
These are obd2 codes, it is mostly standard. Some are manufacture specific.
OBD-II Trouble Codes
They did sell s10's with turbo diesels though, but not in this country.
Old 03-10-2007, 06:58 PM   #59
ThatOneGuy's Avatar
wow i dint no they had diesel s-10s and how can i get one??
Old 03-10-2007, 08:15 PM   #60
rat
Got Fuel Rails?
rat's Avatar
Go to south america?
Old 04-04-2007, 01:33 AM   #61
FloridaTruckScene.com
SaltyOnionBalls's Avatar
Quote: Originally Posted by ( o )( o )
P1406 auxiliary emissions controls - EGR pintle position
I just scanned my Jimmy I just bought and this was the only code that came up.
What does this mean? Do I have to replace the EGR Valve?
Need help, thanks.
Old 04-04-2007, 12:59 PM   #62
the youngest has been
tippmann243's Avatar
diesel s10's were also sold in america
Old 04-16-2007, 11:00 PM   #63
driftersdime
viper17z's Avatar
I need an explanation for a B2600 trouble code on a 03 4.3 auto.
Old 04-22-2007, 09:38 PM   #64
i've got codes 700 and 1100....what are they, i know code 700 is transmission control system..buuut what is that??? and i cant find 1100 on the chart.
Old 07-20-2007, 12:06 AM   #65
OBDII Codes is for '96 and up, right?
Old 07-20-2007, 07:49 AM   #66
96 s10ss
ewf3's Avatar
right
Old 09-15-2007, 03:54 PM   #67
///Relaxed Moderator
droppedss's Avatar
P0756 - Shift Solenoid B Performance or Stuck Off. I replaced both shift solenoids..still does it after driving it for a bit.
Old 09-24-2007, 01:41 AM   #68
Is there a way to read the code in my '88 S10 pickup?
Thanks,
Cory
Old 09-26-2007, 09:01 PM   #69
Remembering My Dad....
itscypha's Avatar
P0141 - HO2S Heater Circuit Bank 1 Sensor 2
Thats what i got in my 95 blazer... what should i do to fix this clean out the o2 sensor check the wires or just replace it?
Old 10-26-2007, 01:32 PM   #70
ok i have a 95 4x4 jimmy 4.3 has the w code motor but is the obe 2 system and im getting the codes p0700 and a p1100 i was wondering do u know what that might be i know the p0700 is Transmission Control System (MIL Request) but what is this
Old 10-30-2007, 07:15 PM   #71
2.5Dime's Avatar
I was wondering if i have one and where the aldl would be on my 91 s-10
Old 11-06-2007, 07:13 PM   #72
2.5Dime's Avatar
I got a code 22 which deals with the tps is my only option to get a new one?
Old 11-11-2007, 06:31 PM   #73
iFail
how can i tell what code i have. the only thing i can get is code 12
Old 11-30-2007, 03:28 PM   #74
mrriverajr's Avatar
My 2000 ZR2 4.3 V6 is throwing this code P0440 - Evaporative Emission Control System and I just failed inspection. What should I be looking for to fix this code? Thanks for the help.
Old 12-16-2007, 10:17 PM   #75
99 GMC Jimmy SLS
Tons of those here in Panamà, all of them by the Chevy dealer, only S10 gas were Sonoma, when the GMC dealer use to live... up to 2000... the engine was made by MWM (International) good for towing, hard work, slow as f*ck... not as much reliable... very economic... 4.3 can beat the sh+t out of them in more than thousands ways, less in economy
btw, any way to check codes manually (without scanner) for OBDII+ Jimmys? don't have scanner, and those mechanics that have, just for conecting it ask for 35+ if you are lucky, cause they think it's a SUPERHIGHTECH DEVICE...
Old 12-16-2007, 10:55 PM   #76
rat
Got Fuel Rails?
rat's Avatar
No, you need some sort of scanner. The price is coming way down on the very simple ones, like this:
http://cgi.ebay.com/ebaymotors/ENHAN...spagenameZWDVW
http://cgi.ebay.com/ebaymotors/Car-S...spagenameZWDVW
Old 12-17-2007, 12:15 AM   #77
99 GMC Jimmy SLS
Good to know, by the moment a simple one will do the job, thanks for that!
Old 12-28-2007, 01:01 PM   #78
layin20's's Avatar
I'm getting codes P0102 and P1133 what do they mean?
Old 01-22-2008, 11:38 PM   #79
~dropsicles~
94s-dime's Avatar
I have a 94 s-10 with the 4.3L engine code Z. i am getting a 35 - Idle Air Control (IAC) System code and it only comes on when my truck is idling hence the code. the problem is i have no idea what the idle air control system is and how the heck am i supposed to fix this problem? does anyone know what the IAC system is and how i can fix it??
Old 04-13-2008, 07:36 PM   #80
I have a 92 S10 Blazer. Engine runs fine until it gets warmed up, I shut down then restart. I will be driving along and it will "studder", and lose power. Check engine light will come on. When I retrieve the code it is code 41. Having a little trouble getting information on that code. On this site it says 41 is "camshaft sensor circuit" but I'm not sure the 92 has this?
Old 04-14-2008, 12:17 AM   #81
guys im getting three codes P1133, P0133,P0440 on a 97 2.2 s-10 I have taken to shop 4 times and seems they keep trying to put gaskets and seal my heads saying that it was exhaust leak and its fixed but yet I cont have problems. Is this the 02 sensor and should that solve this snowballing problem. Truck runs but low performance and seem to have low backpressure linking to a obvious exhaust leak and even sound like one but with that I am soooo confused as to how it could be a 02 sensor . Any help or advice would be great.If you could post most replies in PM that would be great
Old 05-26-2008, 09:19 PM   #82
i got a code P0446 - Evaporative Emission Control System Vent Control Circuit the guy at autozone asked if my gas cap was tight and it was should i just go out and buy a new gas cap or what should be doe fill me in i'm sick of that orange light always being on
Old 05-27-2008, 02:04 PM   #83
Registered (Ab) User
Yogi's Avatar
Yes, buy a new gas cap first - possible easy solution. If that doesn't fix it, Click here.
Old 06-02-2008, 11:42 AM   #84
Yogi's Avatar
Some more good info from another post. This applies to OBD1 vehicles when checking by the paperclip method:
Quote: Originally Posted by bg's
The ECM will flash for each digit. example code 12 would be 1 flash a delay then
2 flashes = 12. It will do this in 3 consecutive phases. 12.12.12. Then if you
have set a code for example 43 it will delay a bit after the final 12 and flash
4 flashes for the num 4 then 3 flashes for 3 quickly each time for 3 consecutive
times = code 43. Then there is a delay until either another code will be displayed. >
**** ***. **** ***. **** ***. next code or final code
If there is another code say 24 you would get 2 flashes quickly and then 4
flashes quickly 3 consecutive times. This = code 24. >
** ****. ** ****. ** ****. next code or final code.
Finally when all the codes have been flashed OR no codes are present, you
should get a final code of 55. 5 flashes quickly followed by another 5 flashed
quickly = 55 and then you've read all the codes that wereset through the ck
eng light. 55 means end of code transfer. >
***** *****. ***** *****. ***** *****. done. Have a beer and consider your options..
Simple, huh.
Old 07-02-2008, 10:30 AM   #85
2003 Chevy S-10 LS Owner
mcdanida's Avatar
Blazee, you sir, are the MAN for posting these trouble codes! Thanks so much!
Now I must figure what my SES light code is for my 2003 S-10? It came on this morning when I abruptly stopped in traffic, almost rear-ending somebody.
Any guesses out there?
Old 07-02-2008, 01:13 PM   #86
Yogi's Avatar
If it has the secondary air injection system, that would be my guess.
Old 07-02-2008, 01:24 PM   #87
mcdanida's Avatar
BINGO Yogi, the error code was P0410 - Secondary Air Injection System. Is there anything I should worry about? I've reset the SES light and the error hasn't repeated yet. Would this be common in a situation such as mine, creating maybe a false error?
Old 07-02-2008, 01:30 PM   #88
Yogi's Avatar
It's not likely a false error. Those systems have definite problems. Water accumulates and corrodes the check valve and the pump. Do an advanced search on Google for "secondary air system" on S10Forum.com and that should give you the info you need.
Old 07-03-2008, 08:41 AM   #89
mcdanida's Avatar
Yogi, while I have you here, I want to ask another question - maybe you can direct me to a better forum? Or know the answer yourself. My A/C works GREAT! Maybe too good to be honest; the vent air is pumping a very cold 39F.
There is a problem I think. The accumulator/dryer is building way too much frost, from 1/16" to 1/8" of ice. It travels into the evaporator which is covered so I'm not sure what the ice build looks like on it, I assume about the same?
I tested the pressure and it's a good 30 psi (spec is 25-44 psi). I am in a very humid and warm environment (Virginia), so condesnation is expected. I have been told I want the dryer to sweat real nice, but not freeze.
I've been told a number of diagnoses, low freon, overcharge, thermal clutch switch, etc. It is true I do not see/hear the compressor cycle or clutch engaging/disengaging, so I assume a constant "on", which makes sense to me. I also notice a "squeek" from my serpentine when A/C is on and I start moving from a complete stop - wonder if that's some type of resistance on the compressor pulley for whatever reason?
Anyway, your thoughts? Is this a "don't fix it if it ain't broken" problem?
Old 07-03-2008, 11:19 AM   #90
Yogi's Avatar
The accumulator should sweat, not freeze. Seems like a frozen accumulator would have a lower pressure than 30#. Comp. clutch should be cycling also. Definitely needs to be fixed. I would say it's a bad low pressure switch, or overcharged. I used to work on R12 systems, but I'm no expert on R134. You might try posting in the S-10 section.
Old 07-03-2008, 01:24 PM   #91
mcdanida's Avatar
Thanks Yogi, I suspected it could be the pressure switch. Question: do I have to evacuate the system in order to swap the pressure switch?
I also notice belt squeeking while A/C is running, but not while turned off, that tells me there's resistance at the clutch/compressor pulley? I'm hoping NOT to replace the compressor.
Something also funny, the system sweats PERFECTLY as it should when I run the MAX A/C? I have no problem doing that in this heat!
Old 07-03-2008, 03:07 PM   #92
Yogi's Avatar
The pressure switch is on a schrader valve (like a tire stem) so you don't have to evacuate to replace it.
Squeaking belt sounds like an overload for some reason.
It's sweating on Max A/C? I would expect that if it were freezing that it would freeze on Max A/C. When does it freeze?
Edit : We're mucking up the sticky on diagnostic trouble codes with a lot of b.s. about A/C. Why don't you start a new thread in S10 section and pm me when you do.
Old 07-04-2008, 09:40 AM   #93
mcdanida's Avatar
Yeah Yogi, I didn't mean to go off track in here, I started a new thread:
http://www.s10forum.com/forum/f137/a...-10-ls-359456/
Old 07-06-2008, 12:00 PM   #94
Wire Splicin Fool :-)
lesterl's Avatar
Yogi, I thought OBD1 flashed 12 again 3x to start over/ end the codes in memory list?
Old 07-06-2008, 02:08 PM   #95
Yogi's Avatar
The info that I copied does look suspicious. According to the list, code 55 is a faulty ECM. I'll see if I can get BG's to clarify.
Old 07-06-2008, 06:04 PM   #96
crap
bg's's Avatar
I need to give a HEADS-UP on the final code for
the code run regarding OBD-1. I stated code 55 down
was the final code. THAT IS INCORRECT. Code
12 x 3
is the START OF THE CODE STREAM
and ENDS WITH CODE 12 X 3 as the final
code
before the code stream runs again.
Sorry bout that. Didn't mean to mess anyone up.
Thanks for letting me know, Y.
Old 07-08-2008, 08:41 AM   #97
mcdanida's Avatar
I am constantly getting the following error:
It occurs everytime I begin an abrupt stop in my 2003 Chevy S-10 LS, or bogging down in a higher gear.
The SES light is beginning to annoy me and I'm tired of disconnecting neg. terminal for 20 minutes to get rid of light.
Any advice to the fix?
Old 07-08-2008, 12:50 PM   #98
Yogi's Avatar
Do a search for "Secondary air system" in titles only. That will give you plenty of info.
Old 08-14-2008, 03:26 PM   #99
code solution
hi guys i had a s10 2002 v6 extreme the s10 has the code p0155 and p0128 the p0155 is a sensor but what sensor is and where is and the oder is a tenp of coolant how i can fit this 2 problems thanks and sorry about mi englihs
Old 08-14-2008, 05:13 PM   #100
Yogi's Avatar
Re: code solution
Replace your thermostat and that may fix both codes. The sensor for P0155 is in the exhaust pipe on the passenger side, just downstream from the exhaust manifold. Click here for more info.
LinkBacks (?)
LinkBack to this Thread: http://www.s10forum.com/forum/f107/diagnostic-trouble-codes-198381/
Posted By For Type Date
Took my S-10 in to get a This thread Refback 11-22-2007 10:54 PM
ecm trouble 41 - trouble codes swicki - powered by eurekster This thread Refback 09-24-2007 11:46 PM
Banks turbocharger forums, discussion groups, banks turbocharger communities and more This thread Refback 08-13-2007 08:51 PM
SyTy/SGT - Forums - Codes and such This thread Refback 06-30-2007 08:34 PM
Page generated in 0.66901 seconds with 31 queries
[Output: 221.80 Kb. compressed to 202.89 Kb. by saving 18.91 Kb. (8.53%)]
