dexcool flush.. - S-10 Forum
post #1 of 47 Old 01-15-2009, 01:00 AM Thread Starter
blazerxtreme18's Avatar
User is: blazerxtreme18 is offline
Send a message via AIM to blazerxtreme18
dexcool flush..
ok heres the deal ive searched countless hours on how to flush this crap out of my entire cooling system i have found alot on doing this and there are many diffrent ways but i have not found ONE DIRECT how to on doing this...i dont want this stuff in the system anymore. its time this year to flush and i need a how to please help..
post #2 of 47 Old 01-15-2009, 01:16 AM
deadbroke's Avatar
User is: deadbroke is offline
Re: dexcool flush..
i had some in my old motor it started to thicken and chunk up even after changing it a few times. finally my motor overheated and i bought a new one because of cooling problems. i personally flushed it 3 or 4 times within 3 months and it wouldn't go away.
post #3 of 47 Old 01-15-2009, 01:20 AM
Founding member of DA
pack of q tips's Avatar
User is: pack of q tips is offline
Send a message via AIM to pack of q tips
Re: dexcool flush..
buy some coolant flush treatment and read the directions on the back
usually you add that run it while its warmed up, drain it, fill with water and run it, drain that and fill it again with new coolant water mix
if its real bad you can use a couple bottles of the flush stuff and do that step multiple times
1997 bagged and bodydropped suburban
1967 volvo 122s wagon
2002 chevy s10 zr5
2014 Harley Davidson Switchback
2002 polaris edge xc 800
2009 ford fusion S daily driver
post #4 of 47 Old 01-15-2009, 01:23 AM Thread Starter
Re: dexcool flush..
see the blaze has 46K on it and ive never flushed anything and ive been reading about all this crap dexcool lately i would rather just flush it out before it gets too late..i know how to do the heater core and radiator but what about the coolant left over in the block??? ive seen a few things on here but not enough solid info to tackle it all...
post #5 of 47 Old 01-15-2009, 08:51 AM
RandomSV650's Avatar
User is: RandomSV650 is offline
Re: dexcool flush..
I just had a shop flush mine out, best way to do it IMO. Flush and fill was like 50 bucks, and the guy said the stuff was NASTY. They recommend flushing anything that has, or should have had dexacool in it because it's so bad for the motors.
post #6 of 47 Old 01-15-2009, 09:16 AM
Chip Chipperson
blazerman's Avatar
User is: blazerman is offline
Send a message via AIM to blazerman Send a message via Yahoo to blazerman
Re: dexcool flush..
ok.best way to do it.
go to local parts store.get a flush kit,made by prestone i think.it has a tee fitting in it.all you have to do is cut one of your heater hoses,insert the correct fitting in into the hoses then tighten with the provided clamps.you then proceed to hook up you standard garden hose to above mentioned fitting.turn water on.then open drain on radiator,then cranks truck.i let mine flush for a while.i also took out the thermostat just to make sure it flushed the whole system.you then turn the truck off.let water run for a few more minutes,then cut the water off.
now you unhook the garden hose and place the provided cap that is in the kit on the tee fitting.close the radiator drain.now proceed to put the correct mixture of green antifreeze/water.once it seems like it is full crank the vehicle and allow the thermostat to warm up and open.let the vehicle run without the radiator cap to allow it to "burp"(letting all the air out of the system).
this has been the best way i have found to fully flush they system.it gets all the hoses,engine passage ways,radiator and heater core.anymore questions just let me know.
Originally Posted by appstategrl View Post
The Griff was going to fight Tito Ortiz, but Tito Ortiz only fights women now.
post #7 of 47 Old 01-15-2009, 05:06 PM Thread Starter
Re: dexcool flush..
thanks blazerman yea ive seen the flush n fill kit...but the only thing i do know is to watch the pressure on the graden hose because too high pressure can fock up the heater core...and i thought that you were not supposed to use regular water to flush the block only Distilled water..??? not quite sure...
post #8 of 47 Old 01-15-2009, 05:14 PM
The Blown Blazer's Avatar
User is: The Blown Blazer is offline
Re: dexcool flush..
The water from the flush is only going to be in there temporarily, so the shit in it doesn't have the time to corrode and eat away the parts. When you refill the cooling system for long term use, then you use distilled water.
2000 black S10 Xreme auto v6 - stock on 20's "SLO S10"
2000 white S10 Xtreme auto v8 - unstock "FST S10"
post #9 of 47 Old 01-15-2009, 05:15 PM
Chip Chipperson
blazerman's Avatar
Re: dexcool flush..
beat me to it
post #10 of 47 Old 01-15-2009, 05:22 PM Thread Starter
Re: dexcool flush..
lol well thanks guys...i know that bmxbang had started a thread a while ago he had bought the Flush n Fill kit does anyone know if he got around to doin it??
post #11 of 47 Old 01-15-2009, 08:47 PM
User is: PimpingA1997Jimmy is offline
Re: dexcool flush..
I don't mean to hi jack this thread so please don't think i am
I was wondering shoudl i call the mechanic and tell him not to use dexcool when he gets the truck back togethere since he is replasing the INtake Manifold gasket ?
should i tell him to use regular preston or 50-50 and not use dexcool what should i have him use
Thanks
also do i have to worry about it being in the block still ?
or will the flush run that all out
post #12 of 47 Old 01-15-2009, 08:52 PM
Mr. Sparkle
Onimun's Avatar
User is: Onimun is offline
Re: dexcool flush..
Thanks
Chances are that they will use the green stuff by default. I have not been to any shop other then the dealer who uses dex cool. Its all personal preference. I dont mind Dex cool, it just needs to be changed every 2 years. The green stuff does not gum up like dexcool does, however it does become acidic. And it will start to eat away at aluminum peices along with gaskets.
Onimun is offline
post #13 of 47 Old 01-15-2009, 08:52 PM
Wannabe Dragger
ExtCab96S_Dime's Avatar
User is: ExtCab96S_Dime is offline
Send a message via AIM to ExtCab96S_Dime
Re: dexcool flush..
The flush and fill will get the stuff in the block out... Should anyways lol. When I brought my truck in to have it flushed I was considering asking him (my uncle owns a shop) to change it to the green coolant. I ended up not asking him, but when I got there to pick it up, he told me he changed it. He said he does it to every one that comes in there because he's seen too many problems with it.
Nick
1999 Blazer LT 4-Door, 4.3l, auto 4WD, loaded, completely stock
1992 S10 Std. Cab, Short Bed, 2.8l, manual 2WD, POS
post #14 of 47 Old 01-15-2009, 08:55 PM
Those crazy ass dogs!!!
01cherryreds10's Avatar
User is: 01cherryreds10 is offline
Re: dexcool flush..
I'd assume that shops would use Dex-Cool instead of the green stuff. Almost everyone knows that GM has their own coolant, but yeah I would give him a call and ask to put the green coolant in.
01' Ext.Cab sold and dont miss it
79' Malibu LQ4/4L70e 11.23@118 1.50 60'
07' Silverado 1500 Classic
post #15 of 47 Old 01-15-2009, 08:59 PM
Re: dexcool flush..
okay the dex cool issue was with the original stuff it has been re formualted so the newer cars dont see problems i have no problems with using it but i personally keep a bottle of preston global coolant with me it mixes with everything
2002 chevy s10 zr5
post #16 of 47 Old 01-15-2009, 09:07 PM
Local Tech
ls1s10onair's Avatar
User is: ls1s10onair is offline
Re: dexcool flush..
i usually pull the block drains out, and run water through the radiator till it comes out of the block drains as clear water
2004 Commemorative Edition Corvette
2014 Lexus IS350 F-Sport
post #17 of 47 Old 01-15-2009, 09:14 PM
Re: dexcool flush..
ok so the non dexcool the green stuff can
eat away at the gaskets wich could couse the same problem to happen again ?
and it can also ruind the radiator is that what you guys are saying but its better to use that stuff anyway ?
im confused don't understand how come the green stuff is better is the dexcool the reason i hear a slushing sound somtime or is that with all the stuff
If i plan on having the coolant system flushed every year should i just keep the dex cool ?
post #18 of 47 Old 01-15-2009, 09:16 PM
Re: dexcool flush..
so is the dexcool now a newer formula ?
or is it the same you just mean they fixed and did more work to the vehicles so they can use it now ?
post #19 of 47 Old 01-15-2009, 09:17 PM
Local Tech
Re: dexcool flush..
you have to consider coolant as a wear item...... like brake pads. green coolant is good for typically 2 years..... the dexcool is supposedly good for 5
green turns into an acid, red turns into sludge, and in some cases will turn into rock hard clumps
post #20 of 47 Old 01-15-2009, 09:23 PM
Re: dexcool flush..
Ok well im for sure going to have him flush it out and use the green stuff no dex cool dex is the red or pink stuff right ? and since i change my fluids like coolant eveyr 30k
wich is like a year and a half i should go with green
aslong as i change it and don't let it sit for a long time but have to make sure i put a sticker there that says do not use dex cool and make sure anytime it goes to shop tell them not to put dexool in it
post #21 of 47 Old 01-15-2009, 09:28 PM
Local Tech
Re: dexcool flush..
yes, yes and yes
post #22 of 47 Old 01-15-2009, 09:32 PM
Re: dexcool flush..
ok cool thanks
aso is one coolant better thent he other as in somthing for warmer weather then somthign in colder weather like if im going to spend the summer in texas where its going to be like in the 90s and 100s most the summer
is one better for warmer weather ?
post #23 of 47 Old 01-15-2009, 09:35 PM
Local Tech
Re: dexcool flush..
ok cool thanks
gm recommends slightly more than 50% water..... id recommend prestone
post #24 of 47 Old 01-15-2009, 09:49 PM
Re: dexcool flush..
GM also reccomends to fill to the hot line on the overflow tank when the engine is cold. They figured out it was better after they produced all of the vehicles that did have Dex-Cool problems, like ours.
post #25 of 47 Old 01-15-2009, 09:52 PM
Re: dexcool flush..
ok so use prestone 50-50 ?
and fill rad all the way up to the top and then fill the over flow to the hot line on the over flow right ?
post #26 of 47 Old 01-15-2009, 10:10 PM
Mr. Sparkle
Onimun's Avatar
Re: dexcool flush..
Exactly.
Onimun is offline
post #27 of 47 Old 01-16-2009, 12:32 AM Thread Starter
Re: dexcool flush..
wow i got thread jacked lolol...
post #28 of 47 Old 01-16-2009, 03:17 AM
SlamBlackSdime's Avatar
User is: SlamBlackSdime is offline
Send a message via AIM to SlamBlackSdime
Re: dexcool flush..
yeh your thread did get jacked, but it answered the question I was about to post thanks blazerextreme...I know you dont know me but I hang with rich and dave and derek and them sometimes, and heard the rear of the blazer is going down so, true??? Truck is clean , cant wait to see it fully layed out
post #29 of 47 Old 01-16-2009, 08:48 AM
Re: dexcool flush..
Hey Man im really sorry i did not mean to jack your thread i just didn't think eveyroen would want to have another thread on the same subject i hope i did not piss you off by jacking it
Ross
post #30 of 47 Old 01-16-2009, 01:31 PM Thread Starter
Re: dexcool flush..
lol word...yea never met ya wasnt around much last year...hibernated lol but im back around now...yea daves gunna be doin the back soon...i still gotta rip out the interior and whatnot for him but yea its goin down man...ill prolly end up meetin ya soon..
post #31 of 47 Old 01-16-2009, 01:32 PM Thread Starter
Re: dexcool flush..
Ross
na man not at all...everyone im sure wants to know the same thing about this crappy dex-cool sh*t
post #32 of 47 Old 01-16-2009, 01:43 PM
Re: dexcool flush..
i called the shop since he said he was not going to start on it till the weekend
i told him wait don't start yet becouse im seriously thinking about going to the dealership up the street and getting a loan for a newer vehicle
i really don't want to put anotehr dime into this headach but will if i cant get the loan
post #33 of 47 Old 01-17-2009, 12:38 AM
Wannabe Dragger
Re: dexcool flush..
I don't know if the new stuff is better, but the old stuff sucked. I don't just say that because of the gaskets it ate and whatnot, but it left deposits EVERYWHERE you could see. There were little orange pieces everywhere when I did my thermostat, inside my overflow and my radiator cap. That's the reason why I wanted mine changed.
Nick
post #34 of 47 Old 01-17-2009, 12:54 AM Thread Starter
Re: dexcool flush..
word..yea mine's still pretty clean when i put in my overflow container and took out my stock plastic one it was spotless inside so im still kinda unsure about flushing it dont know if i should go through all the trouble if its still good ya know...
post #35 of 47 Old 01-17-2009, 01:12 AM
Chip Chipperson
blazerman's Avatar
Re: dexcool flush..
either you can do it now or what till it can(probally will)cause a problem,or just go ahead and do it.saves alot of time and money.imo.i did 2 intake gaskets last year.i just dont trust the stuff after all the problems i saw when i was working at a garage
post #36 of 47 Old 01-22-2009, 11:31 PM Thread Starter
Re: dexcool flush..
yea im still thinkin about it lately we will see when it gets warmer out...
post #37 of 47 Old 01-23-2009, 01:18 AM
Re: dexcool flush..
i hardly ever see problems with it now when it first came out it was bad and people didnt know any better and were mixing green in it and obviously they wouldn't admit to doing anything wrong. keep your eye on it, just like everything else if its properly maintained it will last a long time
2002 chevy s10 zr5
post #38 of 47 Old 01-23-2009, 02:09 PM Thread Starter
Re: dexcool flush..
yea i dont know what im gunna do...we will see i geuss
post #39 of 47 Old 01-23-2009, 03:51 PM
User is: ColinMc is offline
Re: dexcool flush..
Most shops use the universal coolant that mixes with either dexcool or the green stuff...so the whole what to use after flushing is a moot point.
02 S10 Regular cab...ex NAPA delivery truck that needs some lovin...
ColinMc is offline
post #40 of 47 Old 01-23-2009, 11:01 PM
Horn if you're honkey.
4.3L5spd's Avatar
User is: 4.3L5spd is offline
Re: dexcool flush..
Changed mine to green today man was it dirty and sludgy! I just pulled my heater core hose off (make sure the heat dial is on full hot)and opened the drain on my rad poured water through the hose and though the rad then reversed it until it was clear. Then I blew them out with air cleaned my overflow and filled er up. Now the heat is hotter and the engine is cooler mmmm green...
4.3L5spd is offline
post #41 of 47 Old 01-23-2009, 11:04 PM Thread Starter
Re: dexcool flush..
nice so was it worth it ya think???
post #42 of 47 Old 01-24-2009, 06:01 AM
SS monte 350's Avatar
User is: SS monte 350 is offline
Re: dexcool flush..
changed mine over today when the intake gaskets were done, it also runs a couple degrees cooler. got to my dexcool before i had any trouble with it.
post #43 of 47 Old 01-24-2009, 10:27 AM
FUCK YOU
Wicked Mayhem's Avatar
Re: dexcool flush..
i heard if you always keep the radiator full and overflow full up to the cold mark your good with dex cool??? i had my cap off not to long ago and it looked fine in there. i got almost 71k on my blazer.. *knocks on wood* lol
Wicked Mayhem is offline
post #44 of 47 Old 01-24-2009, 07:30 PM Thread Starter
Re: dexcool flush..
yea mines still clean too when i swapped out my overflow for the billet one everything was still bright orange no crap in it but i just hit 47k before the winter...
post #45 of 47 Old 01-25-2009, 10:46 PM
4.3L5spd's Avatar
Re: dexcool flush..
Yeah I think it was worth it, I have 253,XXX kms on my truck though..
4.3L5spd is offline
post #46 of 47 Old 01-26-2009, 05:21 PM
Molon Labe
BudRacing's Avatar
User is: BudRacing is offline
Send a message via AIM to BudRacing
Re: dexcool flush..
After owning my 99 for 50k miles and roughly 5 years, I have had no problems with dexcool. I have changed the fluid twice in that time and never had a problem with sludge or other deposits.
When I bought the truck it had 103k on it. It was spotless and well-maintained.
post #47 of 47 Old 01-26-2009, 10:53 PM
A4, A5, A6, A8 ASE Cert
madscientist101's Avatar
User is: madscientist101 is offline
Send a message via AIM to madscientist101
Re: dexcool flush..
Go to your GM dealer and buy a bottle of GM Coolant flush its about $40 a bottle. Its a highly acidic. The instructions say you drain coolant, then refill with just water and the GM flush. run for about 40mins to an hour. then drain and refill with water only and run for about another 40mins to an hour. Drain and refill about 3 times with water then fill with new coolant and purge/burp the system until the fan comes on. I use that stuff at work and it works so well that it unclogs heater cores in tuaruses and sables every year.
Go big or go home,
If your American, you should buy American
If you dont have the time to do it right the first time, Then when will you have the time to do it a second time?
03 Chevy S10 Blazer 4x4 auto 4.3 V6, Specter CAI with a KN filter, Flowmaster custom exhaust, Custom TB, MSD coil, Stock tune up with Summit racing wires, TUNETIME programming for Trans and Shiftpoints. More the come in the Near future
