cylinder won't fire. Have spark - S-10 Forum
post #1 of 3 Old 12-28-2004, 09:43 AM Thread Starter
ported Votec heads, 268H
User is: ezthere is offline
Mallory Unilight Distributor.Taylor wires.
The #6 cylinder won't fire and I have spark & Fuel
1.Swapped wires no help.
2.Swapped plug no help.
3.Swapped cap no help.
120PSi cylinder pressure. Pull the plug and ground to engine, start engine I can hear a swooshing sound coming out of the cylinder just as the plug fires.
Here's the funny thing.When I pull the #5 plug wire from the cap...{Firing order 1-6-5-4-3-2}The spark jumps from the body of the truck into the #5 spot on the cap and fires the plug.Mind you the distributor is right against the fire wall.Maybe 1\8 of an inch clearance.This is a 4runner body with the v6 shoe horned in. I will pound out the fire wall later on.
Maybe I have a ground problem?
ezthere is offline
post #2 of 3 Old 12-28-2004, 11:30 AM
One Bad Dude
badnoma's Avatar
User is: badnoma is offline
Send a message via AIM to badnoma
Re: cylinder won't fire. Have spark
Not sure how it would affect the #6 cylinder, but I'm sure that that arc from the body to the cap has something to do with it.
badnoma is offline
post #3 of 3 Old 12-28-2004, 12:26 PM Thread Starter
Well I am tinking I have #6 and #5 swapped...I will check when I get home.That would explan why the motor wont stay lite with one of the other plugs removed.
ezthere is offline
