Crankshaft Position Sensor Shim? - S-10 Forum
post #1 of 9 Old 01-17-2010, 06:00 PM Thread Starter
4X4
Neil2591's Avatar
User is: Neil2591 is offline
Send a message via AIM to Neil2591 Send a message via MSN to Neil2591
Hey, I recently rebuilt my engine. I noticed one day my CKP was leaking oil from the gasket (didnt buy a new one). So I pulled it out to put on a new o ring and seen the bottom of the sensor is all cut up from rubbing, now when I was putting on my new timing cover it wasnt fitting right so I had to trim it a bit and as result it was moved up basically, so my sensor is closer now. Is there anywhere you guys know I can get a shim for my sensor so it doesnt rub? Im going to my GM dealership later this week to get the new o-ring seems the one I put in wont seal, so Ill be sure to ask them. Thanks guys.
2000 S10 4X4 V6 4.3 5SPD - Rebuilt Engine Stock, Pacesetter headers, TB Spacer, Cold Air, for now..
Neil2591 is offline
post #2 of 9 Old 01-17-2010, 07:26 PM
Sold :'(
s10xtremist's Avatar
User is: s10xtremist is offline
Re: Crankshaft Position Sensor Shim?
They actually have shims available from the dealership for this sensor. There is a TSB about the sensor being too close to the crankshaft. I'm not sure if it's from loose manufacturing tolerances, worn crank bearings, or what, but at higher RPM the crankshaft kinda vibrates a bit too much and slightly rubs the tip of the sensor. This causes a random misfire and usually a code is set. The kit has two shims and you're supposed to install one of them, test drive it, then install the second shim if there is still contact. I just installed both shims the first time and haven't had any problems since. It is recommended that you replace the damaged sensor and have a crankshaft relearn procedure done.
BTW, I'm not sure exactly where or how you trimmed your timing cover, but if the sensor was contacting the crankshaft before, it's probably gonna be even worse now. You may have to get two of the shim kits, depending on how.where you modified your timing cover. If I remember correctly, the kit is only about $6 USD.
post #3 of 9 Old 01-17-2010, 08:19 PM Thread Starter
4X4
Neil2591's Avatar
Ok thanks a lot, I'm not sure if It was rubbing before but its closer now. When I get to the dealer later I'll be sure to get 2 kits just in case. Thanks for your help.
Neil2591 is offline
post #4 of 9 Old 04-08-2013, 03:18 PM
User is: teamjj1945 is offline
Thank you guys for the info. Apparently the main bearings have become worn enough to reduce the clearance when the crank wobbles at high RPM's and puts the eratic pulse signal to the tach and causes a misfire. I made a shim from a beer can and raised the problem 500RPM's. Made another from a twelve pack box and problem solved. May need srt of bearings someday. I'm sending an oil sample to lab to determine how long I can wait.
post #5 of 9 Old 04-08-2013, 04:47 PM
burned's Avatar
User is: burned is offline
A crankshaft position sensor relearn needs to be done if the crankshaft position sensor or timing cover, are moved, removed, replaced, or disturbed in any way.
2002 Dakota, QC 4x4, 4.7L HO Intake.
1997 S10 ZR2, Ext Cab, 5 Speed (SOLD)
How to test fuel pressure and leak down <---diagnostic help
burned is offline
post #6 of 9 Old 04-08-2013, 10:53 PM
Follow thur on story. Engine ain't been worked on since new, just in service with only maybe 120,ooo miles. Mains should be good for twice that but tests will show? Sending to lab tomorow. Ol gal still running super. Thanks again for the clues!
post #7 of 9 Old 04-08-2013, 11:27 PM
Also if clearance changes occur due to wear!!!!
post #8 of 9 Old 04-09-2013, 01:37 PM
burned's Avatar
If the relearn is not done, the engine will most likely still run, but the PCM will use the "sync" data from the last relearn, which is now incorrect.
burned is offline
post #9 of 9 Old 04-09-2013, 07:29 PM
"factory freak"...
Crew Cab Sonoma's Avatar
Although probably closer to being "correct" than it was with the trigger wheel contacting the sensor...
95 S-10 2.2. Soon to be DD
