cost of replacing intake manifold gaskets - S-10 Forum
post #1 of 16 Old 12-21-2010, 07:44 PM Thread Starter
User is: pgd55 is offline
My 2003 s-10 has over 125,000 miles and just recently it has been leaking antifreeze, I brought it into my mechanic and he says that the intake manifold gaskets are bad and need replacing. He wants to replace the thermostat while the engine is apart which is smart but his quote for the job is $350 labor and $150 parts. I AM SUPPLYING THE OIL AND FILTER AND THE ANTIFREEZE SO THAT MEANS HE IS CHARGING ME $150 FOR A THERMOSTAT AND A INTAKE MANIFOLD GASKET SET. I think this is a little outrageous what do you guys think? I know I should do it myself but it is 20 degrees outside and I am limited physically. I just had all the u-joints on the drive shaft replaced, 2 cv joints and 1 joint and had the driveshaft balanced. This cost me over $400. It seems like everytime they work on my truck it is at least $400. Before this I had all the brakes replaced including the rear drums and that cost me $700. This truck better last me another 10 years.
pgd55 is offline
post #2 of 16 Old 12-21-2010, 08:58 PM
Wire Splicin Fool :-)
lesterl's Avatar
User is: lesterl is offline
Re: cost of replacing intake manifold gaskets
RockAuto has Felpro PermaDry Plus Intake Manifold gasket set for $59
FEL-PRO Part # MS98002T PermaDryPlus®; Set
Valve cover gskts. & valve cover grommets incl.; Upper set incl. int. manifold gskts. incl.
lesterl is offline
post #3 of 16 Old 12-21-2010, 09:58 PM
User is: saab9k is offline
It is a 3.5 to 4 hr job, go figure
2004 S10 ZR5
saab9k is offline
post #4 of 16 Old 12-21-2010, 10:10 PM
goin broke but n style
S15vortecpwr's Avatar
i bought my complete intake gasket kit from advance auto for 35 bucks. Fel-pro brand. It came with the gskts and all necessary rubber o-rings to the upper intake.
I did the one on my 99 blazer in about 7 hours, But i completely disasembled the intake and acid dipped it to remove all carbon and replaced all rubber seals. this was also pulling the dist about 4 times b4 getting it set back in right for the cel to go out. this was also my first set. on a cust car i think i could do it start to finish in about 3 hours.
A t-stat cost about 10 bucks from advance auto.
01 GMC Noma 2.2L auto - SOLD
99 blazer 4dr 2wd - SOLD
GOIN BROKE BUT N STYLE
post #5 of 16 Old 12-21-2010, 10:21 PM Thread Starter
Thanks for the info I am going to have a little talk with ACE the mechanic before he screws me at XMAS time because we all know that little Timmy needs that wooden leg.
pgd55 is offline
post #6 of 16 Old 12-21-2010, 11:01 PM
User is: MrSpeedyBob is offline
I am a mechanic, so looking at this from his perspective I would like to point out a few things...
1. Shops mark up the parts they sell you. They have to in order to stay in business and honestly they add value to them by covering the extra labor to replace them again if they are faulty. If the gaskets you bought at Advance fail Advance will not cover the labor to replace them again. A good mechanic will.
2. The shop needs to make a certain amount of money on the job for it to be worth their time to do it. If you are supplying fluids and what-not then the shop is not able to mark them up as they otherwise would. They are adding mark-up to your estimate so that your job is at least as profitable as whatever else they could be doing with that time / shop space.
3. ALL good, reputable, shops add a certain amount of "Oh Shit!" room in their estimates. If they think the job could be done for $300 they should quote you $400. If something goes wrong they have a $100 cushion to work with without having to call you and ask for more money after it's torn down. If nothing goes wrong and you get a bill for $100 less then expected you are happy.
It is also possible that your guy is a little shady. Dishonest mechanics do exist but they are not nearly as prolific as people think they are.
post #7 of 16 Old 12-21-2010, 11:03 PM
badmofo529's Avatar
User is: badmofo529 is offline
your brakes cost you 700!!! wtf thats expensive. mine cost me like 150 with drums (done myself) and i had the shop up the road do all my brake lines for 250. so i think your mechanic is screwing you royally
post #8 of 16 Old 12-22-2010, 12:04 AM
lesterl's Avatar
I would use the upgraded steel backed rubber intake gaskets so the job doesnt have to be done again in a while when the new plastic carrier gaskets crack and leak.
lesterl is offline
post #9 of 16 Old 03-02-2011, 06:02 AM
LuCiFeRsHaL0
LuCiFeRsHaL0's Avatar
User is: LuCiFeRsHaL0 is offline
Well im having a similar problem minus the shady mechanic. I have a 2.2 2003 s10. When i start it up it will stay idle half the time then the other half it sputters then dies. While its running i get white steam from the exhaust and a particular kind of smell. I just replaced the thermostat and radiator but its leaking while sitting and driving. When i am driving it will only blow hot air when im pressing on the gas. When i let off or use the cruise it blows cold air. I have been driving my gfs ford f150 and i am really fn sick of driving it. Any help would be most appreciated. Oh and my brakes were like 150 took me just over an hour.
Thanks peeps
jd.
post #10 of 16 Old 03-02-2011, 11:22 AM
User is: onesickbravada is offline
Our local GM dealer wants $450 to do the job but it includes updated gaskets, oil/filter change, Change thermostat, radiator flush and fill.
I am seriously thinking about having them do it just for the simple fact that the job comes with a warranty, if it leaks again it is their problem, if a check engine light is on when they are done it is their problem, if it don't run right when done it is their problem.
Any work I have had done by them in the past has always been top notch and never had another problem as far as what they fixed. The biggest bonus is I stay nice and warm while they do it.
But on the other hand some reasons why I am thinking about doing it myself is when it comes time to scrape the old gasket off I will know it is done right and not in a hurry and don't have to worry about crap being dropped into my motor, I can also clean the throttle body, replace any thing else I see while doing the job such as PCV valve, Vacuum hoses, ect. I can thoroughly clean the intake, replace all gaskets, upper intake, valve covers, ect. I can use oil and filter of my choice, I always run Amsoil SSO 0w30 and Amsoil AEO filter.
It's a catch 22 and I am kinda torn on what to do...money is not an issue but if they drop a chunk of shit down in my motor while doing it because they are in a hurry that will be an issue.
post #11 of 16 Old 03-02-2011, 06:26 PM
terrible. take a lap.
joyride's Avatar
User is: joyride is offline
Send a message via AIM to joyride
I've done it a few times. It's not all that bad. You can work at your own pace, and make sure nothing goes wrong by being in a hurry. I'd rather have peace of mind and saving some money at the same time over someone else working on it.
Brian
01 xtreme 4.3L 5spd 2/3 drop w/ SS front bumper|.030 over|270 comp cam|500 lift|dual valve springs|10:1 C/R|p&p heads w/ 3 angle valve job|w4me tune|shorty headers|2.25 y pipe|no cat|Spintech muffler|windage tray|LW flywheel|DF clutch|8mm wires|no ac|efan|walbro 255|MPFI upgrade|Comp Cam timing chain|ARP bolts/studs|totaled***
Now owner of a white 2002 Blazer Xtreme
http://www.youtube.com/watch?v=CO_A1IrbQNM
85 Monte Carlo SS
KCCO
joyride is offline
post #12 of 16 Old 03-03-2011, 11:07 PM
lesterl's Avatar
Thanks peeps
jd.
Dude, this is the 4.3l V6 forum.... could have a cracked head tho, or a blown HG....
lesterl is offline
post #13 of 16 Old 01-25-2016, 06:03 PM
User is: Crane Operator is offline
I have purchased the intake gasket set with valve cover gaskets and new intake bolts thermostat new radiator and cap plus all hoses for around $220. from RockAuto. That is shipping and all. Hopefully this weekend will be better than last and i can get those parts put on !!
post #14 of 16 Old 01-25-2016, 06:17 PM
Poo
User is: Poo is offline
You really do get what you pay for. Go cheap and hope it works or go GM dealer and know it is good. I hated cheap people but I am now retired.
Poo is offline
post #15 of 16 Old 01-26-2016, 06:11 PM
burned's Avatar
User is: burned is offline
You guys do know this thread is from 5 years ago?
Going to the dealer does not guarantee its going to be good. The factory gaskets are plastic and fail due to expansion and contraction. By going with the upgraded Fel-Pro set (metal) you will never have to do it again.
The intake bolts do not need to be changed. Clean them up with a wire wheel and use Loctite blue.
2002 Dakota, QC 4x4, 4.7L HO Intake.
1997 S10 ZR2, Ext Cab, 5 Speed (SOLD)
How to test fuel pressure and leak down <---diagnostic help
burned is offline
post #16 of 16 Old 01-27-2016, 06:38 PM
Jay72's Avatar
User is: Jay72 is offline
I don't know who brought this post back from 2010 but I had some thoughts after reading it.
The op didn't say anything about how the shop that quoted him planned on removing the coolant from the oil. His supplied oil and filter might be step one and used 5 minutes and thrown away. And theres way more to it than whats been said.
Don't like the price go somewhere else. The shop thats going to charge $200 for the job is shady IMO. These shops should have a pricing chart or something. Ranging from done properly to thrown back together.
I'm in a repair business, I hate people that want everything for nothing, and there are plenty out there.
It's simple, if you don't like the price move along. If no one gives you a price you like, guess you're shit outta luck.
Jay72 is offline
