Coolant Temp Sensor Location? - S-10 Forum
post #1 of 33 Old 12-06-2007, 02:09 PM Thread Starter
User is: greatjc is offline
Question Coolant Temp Sensor Location?
Where is the coolant temperature sensor located on a '96 4.3L? I checked AutoZone's diagram, and I'm not exactly sure what I'm looking at there... http://www.autozone.com/images/cds/g...3d8018b926.gif
Also, when I attempt to change the sensor, will coolant leak out? Any tips?
greatjc is offline
post #2 of 33 Old 12-06-2007, 05:11 PM
rat
Got Fuel Rails?
rat's Avatar
User is: rat is offline
Send a message via AIM to rat
Re: Coolant Temp Sensor Location?
Front of the intake manifold, under the t-stat housing is what the pic is of.
Rick, aim-RAT5111468
2000 4.3 auto
Custom Intake Manifold with 32lb/hr Injectors, Comp cam 260AHR, Tuner Cat Speed Density tune, Vac modulated trans with shift kit and vette servo, Bolt on's
Camshaft Tutorial-----My Truck and The Roots Blower Project ------ My Tuning Tutorial
rat is offline
post #3 of 33 Old 12-06-2007, 06:29 PM
loco hombre
nater006's Avatar
User is: nater006 is offline
Send a message via AIM to nater006
I did it on my '96 a few years ago. It is directly under the t-stat housing, correct.
Some coolant may leak out, but, just have the new sensor handy. Preferably don't change it while the coolant is hot You'll lose minimal coolant.
nater006 is offline
post #4 of 33 Old 12-10-2007, 05:37 PM
Bagged
chevy power's Avatar
User is: chevy power is offline
Send a message via AIM to chevy power
I took that out once while the truck was hot, I thought it was my EGR valve. O man, what I have learned since I owned this truck. lol
post #5 of 33 Old 04-01-2008, 11:27 PM
User is: Tennted is offline
I have a 2001 S10 Blazer with an engine coolant sendor code. Where is the sensor on this vortec 4.3? I have looked everywhere. I found the gage sender on the left head. is there one sensor for both the gage and the computer?
Tennted is offline
post #6 of 33 Old 04-01-2008, 11:36 PM
rat
Got Fuel Rails?
rat's Avatar
There is only one on '98+ trucks, on the drivers side head.
2000 4.3 auto
rat is offline
post #7 of 33 Old 04-02-2008, 12:39 AM
Kicker's Avatar
User is: Kicker is offline
ya right above the middle spark plug wire.dont belive the others coolant comes out, lots of it. keep a pan under your truck.
2001 4.3 ZR2 Red, K&N cold air intake FPIK, Thrush super turbo muffler,12 inch Pioneer Shallow Mount Subwoofer
Kicker is offline
post #8 of 33 Old 04-02-2008, 11:44 AM
Registered (Ab) User
Yogi's Avatar
User is: Yogi is offline
I have a '98 (W code) and it has 2. One at the front of the intake manifold right next to the t-stat, and the second on the driver's side head.
Yogi is offline
post #9 of 33 Old 04-03-2008, 08:06 AM
NTL1991's Avatar
User is: NTL1991 is offline
On my 92 4.3 TBI, there are two coolant "sensors". One is a Coolant Temperature Sensor and the other is a Coolant Temperature Switch... The Sensor is for the Engine computers to calculate the air/fuel ratio and the Switch gives you the temp reading on the dash.
If I remember correctly, the Sensor was at the top of the engine in front of the air cleaner and the switch was down on the passenger side of the block around the spark plug area...
Nick
NTL1991 is offline
post #10 of 33 Old 04-08-2008, 02:39 PM
User is: redtruckagogogo is offline
http://www.autozone.com/servlet/UiBr...3d8018b920.jsp
post #11 of 33 Old 11-03-2008, 12:07 AM
User is: hatdrc is offline
Not to bring up an old post but I did not want to start a new thread for a similer question. I have a 97 v6 and I unpluged the one under the tstat and tested it. tested fine so I thought my gage was off but i noticed that the gage still worked. Now I did notice a single wire that was behind the intake and ran to a sensor between the 3rd and 5th spark plug. I was going to post to see if anyone knew what this was for but now im thinking it is for the temperature gage. My question is is that what it is and if so how do I test it. I have an ohm meter but it needs two wires to hook up? Can i ground one to the frame? If not just what is it? If you need pics let me know.
hatdrc is offline
post #12 of 33 Old 11-03-2008, 08:26 AM
User is: gerbsinmd is offline
The way I understand it, the one under the t-stat is used by the computer and the one in the head is used for the temp-gauge. I could be wrong, but that is what was explained to me.
post #13 of 33 Old 11-03-2008, 09:38 AM
Yogi's Avatar
Some of the 4.3s have the knock sensors in the heads too. To check, try disconnecting the wire that you think is the temp. sensor with the ignition on. The gauge should go down. Then short the wire to ground and the gauge should peg at the top of the scale.
2008 Saturn Sky Red Line Roadster
2.0L LNF Turbocharged Motor
5 Speed Manual Trans.
Custom made Blazer CAI (Click Here)
Yogi is offline
post #14 of 33 Old 11-03-2008, 10:39 PM
I will have to test this tommorrow. The question really isn't if it works but how accurate. When I check the one for the computer it is right around 250 ohms which is close to 190. But the gage only shows about 140 or so. There is only one wire so there is nothing to ground to to check the ohms. I guess it is not that important but I just like thinks to work the way they are made to.
hatdrc is offline
post #15 of 33 Old 12-28-2009, 07:16 PM
User is: SicOne is offline
bringing it back.... Which one works the gauge? I have 1 on either head.
SicOne is offline
post #16 of 33 Old 12-29-2009, 11:11 AM
93_Deuce's Avatar
User is: 93_Deuce is offline
On my 93 vin W mine is on the passenger side head. The sensor in the drivers side head is the knock sensor on mine.
The temp sensor for the computer is on the intake manifold.
'93 Sonoma Ext. Cab 2WD New 4.3 CPI Longblock, Hi flow cat, Dynomax Bullet Muffler, Heddman Hedders, Custom Y-pipe, 16x8 wheels, Street Performance shocks, BiXenon HID's, Clear Lenses, black euro tails, LED's all around, tint, rollpan, SS Mirrors, De-badged.
(Coming Soon - 2/3 Spindle/Block Drop, front end steering rebuild, smooth front bumper, black grille with billet, paint, e-fan, CAI, shift kit)
Member of Bravada Grills Suck Coalition
93_Deuce is offline
post #17 of 33 Old 10-03-2011, 11:38 PM
User is: ab7oh is offline
Hello
Is the sending unit for the gauge the same as for the computer? I have a 93 S10 Blazer 4X4 VIN W
Thank You
Richard
ab7oh is offline
post #18 of 33 Old 11-30-2011, 06:06 PM
User is: pudd750 is offline
Originally Posted by ab7oh View Post
Hello
Thank You
Richard
well shoot that was my question too - tho mines a 94 W truck
pudd750 is offline
post #19 of 33 Old 12-21-2011, 08:47 PM
timritchieblue's Avatar
User is: timritchieblue is offline
I'm a noob, just brought this home. No temp gauge? on a 94 is on the head?? For the gauge?
post #20 of 33 Old 07-02-2012, 06:05 PM
User is: sonofadocker is offline
I have SES code P1404 and the code reader book says the EGR Temperature Sensor is faulty ?
I can not find such a part listed on parts pages.
I have been changing the EGR daily after soaking each one over night in cleaners.
I get the SES light on in 10 miles of driving. When I take the EGR off the engine the plunger is NOT stuck open. It is seated in the closed position.
Help
post #21 of 33 Old 07-14-2013, 06:11 PM
User is: surfmurf is offline
As an aside topic to this question = what is the correct coolant TEMPERATURE range for a '90 4.3L Pickup? It is not in the Buyer's Manual and I cannot get an answer on-line (I keep getting referred to cooling system parts) but NO temperature numbers. I have just replaced the Water Pump and thought it should be running around 190 (the thermostat's calibration) not 30 to 60 degrees above that.
Anyone know the correct operating temperature for the 1990 4.3L?? Murf
surfmurf is offline
post #22 of 33 Old 07-14-2013, 08:54 PM
goin broke but n style
S15vortecpwr's Avatar
roughly 200-210 degrees.
01 GMC Noma 2.2L auto - SOLD
99 blazer 4dr 2wd - SOLD
GOIN BROKE BUT N STYLE
post #23 of 33 Old 05-25-2015, 05:08 PM
User is: Herb is offline
93 GMC 4.3L V6. Found 2 things that might be temp senders. The first is on top at the front. The second is on drivers side between middle and rear plugs.
Are they both temp senders? Which is the one that goes to the dash gauge? Or did I get this completely wrong?
ID:	219778   Click image for larger version
Herb is offline
post #24 of 33 Old 06-30-2015, 12:34 AM
According to Autozone:
TEMPERATURE SWITCH
1993 GMC Truck S15 2WD 4.3L CPI 6cyl
The Temperature Switch is located:
Under hood, driver side, upper engine area, below valve cover, next to the rear exhaust port, mounted in the cylinder head
COOLANT TEMPERATURE SENSOR
The Coolant Temperature Sensor is located:
Under hood, center, upper engine area, front side of engine block, mounted in water outlet
It would seem logical that the Temperature SENSOR would go to the gauge, and the temperature SWITCH would go to the computer, right?
Right? Anybody? Huh? Right?
Herb is offline
post #25 of 33 Old 06-30-2015, 12:38 AM
User is: SmokinDan is offline
The second picture with the two wire connector is the sensor for the computer. I can't remember what the sender/switch looks like year to year, but it'll be a one wire connector and it'll operate the gauge. Later years used the sensor for the gauge and computer, but I don't know when that switch was made. Is it that your gauge is not working that's prompting this question?
post #26 of 33 Old 06-30-2015, 12:45 AM
Nick
That seems backward to me. Wouldn't the sensor go to the gauge? Seems like a switch would just be in one of 2 positions, open or closed. How would a gauge get enough information from a switch to show accurate changes in temperatures? No, wait, maybe the switch is more like a digital switch, sending the gauge a stream of ones and zeros. Hmm. I dunno.
Herb is offline
post #27 of 33 Old 06-30-2015, 12:47 AM
It's because it's not a switch, is a sender labeled as a switch and parts stores don't know shit and never listen to anything they tell you ever.
post #28 of 33 Old 06-30-2015, 12:48 AM
Yes, it just stays at full cold at all times. I will do the sensor test. (Grounding the singe white wire) and report back. Thanks for the reply!
Herb is offline
post #29 of 33 Old 06-30-2015, 12:50 AM
Thanks, SmokinDan, Unfortunately I will have to wait until tomorrow to do the test. G'nite!
Herb is offline
post #30 of 33 Old 06-30-2015, 12:54 AM
Yeah, key on engine off, ground the sender wire and it should sweep the gauge.
post #31 of 33 Old 07-01-2015, 02:26 AM
User is: 93bazer is offline
I melted my CTS off twice.
Passenger side head, between the front 2 cylinders.
I also have a 1993 but the engine is from a 94 it is VIN W and it was a one wire sensor. Had to look to find one that was not 2.
I also show it in the video I did about my spark plugs. Again.. I did all but 1 (!) cylinder, from the top and without removing or loosening anything. And I probably could have got that last one the same way, but, I decided to go in through wheel well, and the result could not have been better. But I only did it for that one.. driver side rear plug.
93bazer is offline
post #32 of 33 Old 07-03-2015, 03:46 PM
OK, I did the test. The gauge did not move at all. Look's like I need to get an after market gauge. Electrical or Mechanical? Which is easier? Can I use any generic gauge/sender combo? I already have a mechanical/analog temp gauge that was for a different project. Either way, I have to drill a hole through the firewall, right?
Herb is offline
post #33 of 33 Old 07-03-2015, 04:38 PM
Personally I'd see about fixing the gauge. I hate aftermarket shit. I don't have a preference between mechanical or electrical.
