Coolant leak - S-10 Forum
post #1 of 13 Old 01-22-2012, 01:34 PM Thread Starter
Garbagecan Joe's Avatar
User is: Garbagecan Joe is offline
Coolant leak
Hey guys i just started having problems with my coolant the other day. I pulled up into my driveway and noticed steam coming out of the hood. I popped the hood and found coolant all over the passenger side of the frame and about three quarters of the way up the engine. At first i thought it was coolant coming out of the overflow, but that was bone dry. Now every time i drive it for more than five minutes it starts leaking coolant everywhere. I was told the thermostat might be stuck open, but i just read in a few different places that the 4.3's intake gasket sucks. Any suggestions on troubleshooting this?
97 s10 2wd, 4.3l, M/T, ext cab, party hard.
post #2 of 13 Old 01-22-2012, 01:37 PM
sam336's Avatar
User is: sam336 is offline
Re: Coolant leak
Spray the motor off and get it dry. Then pop the hood and start it and see where its coming from. It going to be hard for us to tell you where its leaking.
sam336 is offline
post #3 of 13 Old 01-22-2012, 02:22 PM Thread Starter
Re: Coolant leak
I went out and checked the engine for wet spots and then i started it up and let it run for about 15 minutes. All around the thermostat is dry, but i did notice that the edges around the front and left side of the intake manifold were wetter than when i first looked at it. The left side also had a bunch of crap along the edge of the manifold. After i turned it off it made a hissing sound for about 30 seconds if that helps any.
post #4 of 13 Old 01-22-2012, 02:32 PM
User is: aa21830 is offline
Re: Coolant leak
The corners of the LIM are what leaked first, on my '96 Sonoma. It never got so bad that it smoked under the hood, just dripped coolant. So if you've got a lower intake manifold gasket leak, you've got a pretty bad one that's probably been there awhile.
2004 Blazer ZR2
aa21830 is offline
post #5 of 13 Old 01-22-2012, 02:58 PM Thread Starter
Re: Coolant leak
I think the smoke is coming from the coolant hitting the hot engine block and the fact that its below freezing out just makes the steam show.
post #6 of 13 Old 01-22-2012, 03:47 PM Thread Starter
Re: Coolant leak
I just drove it around and got the engine temp to about 150 then pulled it into the driveway and popped the hood. Most of the steam is coming from that passenger front corner of the manifold right by the alternator. There's also alot of steam coming from underneath the alternator by the exhaust manifold, but i think thats just coolant dripping down onto the hot exhaust. I then crawled under the truck and looked for any other leaks. The engine and oil pan were steaming a little bit, but not nearly as much as in that front corner of the intake. looks like the intake gasket has gone bad. Any suggested brands for this repair? Advance auto has a couple Felpro kits, but one is $34 and the other is $80.
post #7 of 13 Old 01-22-2012, 05:05 PM
Re: Coolant leak
I used Felpro on both my '96 Sonoma and my '04 Blazer. Pretty much top-shelf quality. Here's a good article on it, if you've never done it before:
http://www.handymanlyness.com/archiv..._99_Jimmy.html
2004 Blazer ZR2
aa21830 is offline
post #8 of 13 Old 01-22-2012, 05:23 PM Thread Starter
Re: Coolant leak
Awesome thanks! My brother insists on doing this at home so it will probably be on hold until next weekend. Ill print this out just in case we get stuck.
post #9 of 13 Old 01-22-2012, 07:05 PM
goin broke but n style
S15vortecpwr's Avatar
Re: Coolant leak
also check your oil. if its milky than its deffiently the intake gskts.
thats how i got my 99 blaz so cheap. the orig owner said that 2 shoes told him he needed a motor. he didn't want to go thru that hassle.
01 GMC Noma 2.2L auto - SOLD
99 blazer 4dr 2wd - SOLD
GOIN BROKE BUT N STYLE
post #10 of 13 Old 01-23-2012, 08:45 AM
jax4x4.com
pjg1173's Avatar
User is: pjg1173 is offline
Re: Coolant leak
LOL, I think if my shoes told me I need a new motor I'd by new shoes... but we know what you mean
to the OP yes check the oil after letting it run a few min.
Bigger tires and traction adders just means you get stuck in more inaccessible places.
87 4Runner, SAS, 15" spring lift, 3" body,409 Hp chevy 355, 5.29 gears, 38.5x15.5x15" TSL's
93 S10, SAS, 12" spring lift, 4.30 gears, F/R lockers, 36x12.5x15 TSL's, many more mods
05 Silverado, 2' lift, 4" exhaust, Bully Dog programmer,
00 Jeep Grand Cherokee (Daughters)
04 Chevy Colorado ZQ8 (other Daughters) 3" drop, 235/50r17
pjg1173 is offline
post #11 of 13 Old 01-23-2012, 11:28 PM Thread Starter
Re: Coolant leak
Yea the shoes part confused me too lol. Tomorrow i'll check the oil for milkyness.
post #12 of 13 Old 01-23-2012, 11:36 PM
slamburger
koeberle04's Avatar
User is: koeberle04 is offline
Re: Coolant leak
def go with fel pro. sounds like what happened when my LIM went too. i never did one before and followed the how to on here. worked perfectly and saved money. while i was at it i did a new thermosatat cuz it was due and flushed out my cooling system of dex cool and filled with fresh green goodness. i took pics under the hood so i had a reference as to where things went, it helped me. good luck.
Neil
2000 - S10 - 2.2 - Vin 5 Flex - RCSB - Auto - 115k
post #13 of 13 Old 01-24-2012, 12:47 AM
Check your ground
556mm's Avatar
User is: 556mm is offline
Re: Coolant leak
I'd check around your water pump. That's where my leak was coming from. The idiots that owned the truck before me never took off the old gasket before they put a new one on top of it.
556mm is offline
