Common s10 problems - S-10 Forum
post #1 of 126 Old 10-12-2005, 10:16 AM Thread Starter
cdnuser's Avatar
User is: cdnuser is offline
Common s10 problems
What are some of the most common problems with s10s? (I have a 96 2wd).
My mechanic informed me they have a problem with coolant getting into the engine and distroying your cam and other internal components (if I remember correctly).
What are some things I should keep an eye on?
Thanks
cdnuser is offline
post #2 of 126 Old 10-12-2005, 10:22 AM
Nitto1320 M O D
guhman2002's Avatar
User is: guhman2002 is offline
Send a message via AIM to guhman2002
Re: Common s10 problems
He may have been talking about siameze cylinders.
2003 GMC Sonoma 4.3 AUTO 4X4 [Daily]
1997 S10 2WD 5 Speed. .030 over, Forged Dome Pistons, 2.02 1.60 1996 vortec heads ported/polished, comp 280, 125 shot, Carbed. [5 Speed Now, Need Clutch Soon]
Myspace
post #3 of 126 Old 10-12-2005, 10:29 AM
It Has Been Awakened
Cruznsten's Avatar
User is: Cruznsten is offline
94-97 2.2L head gaskets were really shitty.
--Tyler
98 S-10 5/6 Drop, Shaved Bed, '59 Caddy Tails, Blacked out front end
88 S-10, the work beater!
1979 Datsun 620 King Cab, NO BRAKES!! Future Badass
post #4 of 126 Old 10-12-2005, 11:01 AM
rat
Got Fuel Rails?
rat's Avatar
User is: rat is offline
Send a message via AIM to rat
He was talking about the plastic intake manifold gaskets, they have a tendency to leak after a while. Sometimes they leak to the outside of the engine, sometimes internaly. For the most part these are farily reliable vehicles. I have not had any problems that left me stranded in the last 40K miles, at 100K now.
Rick, aim-RAT5111468
2000 4.3 auto
Custom Intake Manifold with 32lb/hr Injectors, Comp cam 260AHR, Tuner Cat Speed Density tune, Vac modulated trans with shift kit and vette servo, Bolt on's
Camshaft Tutorial-----My Truck and The Roots Blower Project ------ My Tuning Tutorial
rat is offline
post #5 of 126 Old 10-12-2005, 11:06 AM
Bread makes me poop
fscott20's Avatar
User is: fscott20 is offline
windshield wipers. that's my only problem.
Scott S.
fscott20 is offline
post #6 of 126 Old 10-12-2005, 11:06 AM
ROD TWISTIN MEMBER
dropped94's Avatar
User is: dropped94 is offline
Send a message via AIM to dropped94
mine has been kickin for 275,000 on mostly all stock parts
~Charlie~
PRO DIME DROPPER
^^^CLICK FOR PICS
the bitterness of poor quality lasts long after the sweetness of low cost has faded
post #7 of 126 Old 10-12-2005, 11:10 AM
Cruznsten's Avatar
oh yeah, the 94-97 fourbangers SOME of the time have HORRIBLE lifter chatter. mine was so bad that it sounded like a diesel
--Tyler
post #8 of 126 Old 10-12-2005, 11:15 AM
no more S10
NCarolina910's Avatar
User is: NCarolina910 is offline
Send a message via AIM to NCarolina910
I have had no major problems with either of my 4.3 V6's. They're good motors!
Bryan
1964 Impala 333cid 4-speed | 1992 S10 4x4 4.3L | 2002 Impala 3.4L
post #9 of 126 Old 10-12-2005, 11:17 AM
bodydropped on 22s!
JMew03's Avatar
User is: JMew03 is offline
Send a message via AIM to JMew03 Send a message via Yahoo to JMew03
mine has been good to me.
JMew03 is offline
post #10 of 126 Old 10-12-2005, 01:55 PM
User is: tom3 is offline
Fuel pump/gas gauge. Coolant leakage or turning brown eventually turning to mud. Engine noise. AC compressors. Ignition switches. Not a lot of problems actually. Beats the heck out the newer stuff I see these days.
tom3 is offline
post #11 of 126 Old 10-12-2005, 01:56 PM
Tacklin Fuel
BLACKBOWTIESS10's Avatar
User is: BLACKBOWTIESS10 is offline
My lifter clatter like a mother when it's warming up or has been sitting for an hour after warming up. I have a trans problem or torque converter problem. I have a little vibration all of a sudden. It's at 45K with regular oil changes. I am probably lemon in the bunch but these dealerships are pissing me off. They have 2 more tries to fix it and then I'm going after them.
Also, the damn cab pops and creeks. It's not an engine thing but G damnit everything is starting to bother me. I do like my truck very much though.
2001 S-10 ZQ8 auto
Vette servo, 1-2 accumulator spring, blackcatcustom gauges. Custom floor mats,and grill
Flowmaster 50 series, CRMB Y pipe, minus pre-cat, 180*stat, Cut OEM airbox, Easton posi 3.42, blazer f/brakes, Wait4Me PCM tune
Helper Air Bags 2,500lbs each and compressor
Panasonic, Alpine amp, Fosgate HX2 10", polk momo
post #12 of 126 Old 10-12-2005, 02:34 PM
the youngest has been
tippmann243's Avatar
User is: tippmann243 is offline
that would be the timing chain tensioner, not a lifter
-mark
89 s10 blazer 5.7 vortec/t56 0411 pcm powered
03 zr2 s10 with some mods
post #13 of 126 Old 10-12-2005, 02:37 PM
rat
Got Fuel Rails?
rat's Avatar
Most don't have a tensioner. There was a dealer fix that installed one, but they wore out quick.
2000 4.3 auto
rat is offline
post #14 of 126 Old 10-12-2005, 09:33 PM
then what did i change on the 2.2 i worked on, i could of swore it was the tensioner and an updated oil oraface
-mark
post #15 of 126 Old 10-12-2005, 09:44 PM
rat
Got Fuel Rails?
rat's Avatar
The 2.2 is a compleatly different animal. The 4.3's are cam in block, just like a 350 small block. The gears are only 6 inches apart. No need for a tensioner.
I just peaked at the haynes manual, and i see what you are talking about on the 2.2. The 4.3 tensioner was a joke compared to that thing. It was a nylon thing that wore out in short order. I know my 2000 4.3 doesn't have one, a 2002 that i worked on didn't have one. The 4.3 is also considerably more skinny that that thing.
2000 4.3 auto
rat is offline
post #16 of 126 Old 10-13-2005, 08:55 AM
i was working on a 96 2.2 if that makes a difference
-mark
post #17 of 126 Old 10-13-2005, 10:13 PM
Scotty doesn't know
Disco Inferno's Avatar
User is: Disco Inferno is offline
yeah, lots of creaks, third door rattles like a bastard. From what I can tell, from reading this site, keep your shit maintained and it will run for a long time.
post #18 of 126 Old 10-13-2005, 11:44 PM
gadget73's Avatar
User is: gadget73 is offline
My biggest annoyance is the crappy plastic latch on the sliding rear window, the big plastic thing on the passenger side rear squeaks and rattles, and the door has gotten tweaked a little so the seal isn't quite right. It now makes a slight air noise that bugs me. My uncle mostly fixed the door by grabbing ahold of it and twisting it, so its better than it was.
Other minor BS, the chrome on the grille directly forward of the joint between the hood and fenders is all shot, the armrest on the passenger door randomly pops off. Its been replaced, the original one was broken but the area it hooks into is damaged so it doesn't quite stay properly. The screws have come out of the exterior door handle, but there are holes with plugs you can just pop out to fix this pretty easily.
As far as mechanical stuff, I had a water pump go around 120k, the transmission started to go around 128 and finally gave out totally at 141k, the AC compressor gave around 125k (front seal, and I suspect a clogged orifice tube). I also had the well known 4.3 fuel pressure regulator failure. Otherwise, its been pretty darn reliable. I've had it nearly 5 years, put some 60k hard miles before it started giving me any trouble. I plan to fix this one, and I'd buy another one.
1996 S10 LS extended cab 2wd
green over silver
bone stock 4.3 / overbuilt transmission w/ Vette servos and all the good stuff.
sport suspension steering box
gadget73 is offline
post #19 of 126 Old 10-14-2005, 01:11 AM
GMC99's Avatar
User is: GMC99 is offline
Send a message via AIM to GMC99
Damn loud ass whining fuel pumps on some......
99 GMC Sonoma SLS 4.3L Vortec
GMC99 is offline
post #20 of 126 Old 10-14-2005, 07:10 AM
Scotty doesn't know
Mine's loud.
post #21 of 126 Old 10-14-2005, 06:28 PM
'02 S10
S10Stix's Avatar
User is: S10Stix is offline
Send a message via AIM to S10Stix
Fuel pumps and Fuel Level Sensor. Lower Intake Gasket. And a lot of other maintence things that will go wrong just like any other car. If you keep it well maintain and stay on top of problems that develop, you will have a great truck for a long time down the road.
4.3L V6, Chrome Rims, Flowmaster, Clear Corners, and Much More
S10Stix is offline
post #22 of 126 Old 10-14-2005, 06:29 PM
'02 S10
S10Stix's Avatar
By the way if your fuel pump is loud it means it's about to go out. It could be months it could be days. When it won't start hit the tank with a rubber mallet and hope it will start.
S10Stix is offline
post #23 of 126 Old 10-14-2005, 09:41 PM
Getting back in the game.
Fast_Lo96's Avatar
User is: Fast_Lo96 is offline
Send a message via AIM to Fast_Lo96
the a/c compressors suck, if yours goes out DO NOT buy a reman., buy a new one that has straps holding the back cap and front cap together, the factory one has a faulty cap on the back that wiggles loose and leaks horribly. the hazard light switch has a tendancy to break on 95-97 w/cruise and cause the blinkers not to work right. The blinker clicker is in a whorible location where you gotta take the bottom of the dash off. tailgate makes a whorible squeak. clutch safety switch went bad on mine...thats about it so far
When the lights drop...The bullshit stops
post #24 of 126 Old 10-14-2005, 09:44 PM
Fast_Lo96's Avatar
great truck though, i just got rid of an 00 bmw 3 series and the reason i got rid of it is because of stupid factory problems, had it for 3 months, maybe it was a lemon but from now on its strictly chevy...i love my 4.3
post #25 of 126 Old 10-15-2005, 12:48 AM
User is: mbowrsax06 is offline
only real problem i have is my tranny slipping but the truck has 150k on it and towed a tractor daily with the previous owner
post #26 of 126 Old 10-15-2005, 02:33 AM
User is: Rob454 is offline
On mine the fuel pump went bad. I thought it was the CPI injector but it was the fuel pump. Of course I didnt really get it figured till after i replaced it but no biggie since the stock one was leaking anyway and probably shoudl be replaced so I have a whole new fuel system. Other than that I replaced a alternator and the basic wear out stuff. i had new tires installed 1x, new shocks 1x and brakes 2x. its a 95 with a 4.3 and its really been a great vehicle. It has 107 000 miles on it and it still looks brand new.
The only major repair was the fuel problem. the Clutch on the AC is a little noisy so Ill probably be replacing that also sometime soon but Im not too worried cause the truck sits a lot now its basically a 3rd vehicle
Rob
Rob454 is offline
post #27 of 126 Old 10-15-2005, 09:44 AM
Scotty doesn't know
Um...every S10 I've heard has that stupid high pitch whine to it. So I guess all of our fuel pumps are going
post #28 of 126 Old 10-04-2009, 02:05 AM
bmxzach's Avatar
User is: bmxzach is offline
Send a message via MSN to bmxzach
hey guys, thinking of buying a 1987 2.8L 2WD s10, needs exhaust and "the sending unit is shot"
he is including an extra gas tank with the pump in it, should it be fine? any known problems with fuel pumps? i read that they tend to screw over. any help would be appreciated, thanks!
bmxzach is offline
post #29 of 126 Old 10-04-2009, 06:38 AM
diesel music's Avatar
User is: diesel music is offline
My serpentine belt wont quit squealing. Should I replace the truck with an older one ?
post #30 of 126 Old 12-08-2010, 12:53 PM
User is: MJ1227M is offline
Lightbulb Re: Common s10 problems
I have a '99 extended cab 4x4 (LS) with the 4.3. I bought the truck about 1 1/2 yrs ago and ever since summer my belt has been squealing...My dad has been an aircraft mechanic/technical diagnostics his entire life and between him and I we still have not fixed this damn belt.
1. Bought a new Duralast belt from Autozone (cheap belt)--> still squealing
2. replaced: tensioner pulley, idler pulley, alternator (was bad anyway)--> still squealing...
3. replaced: water pump, harmonic balancer, another new belt (Duralast)-->still @#?!*%# squealing!! (at this point we thought a pulley was out of alignment but apparently was not)
4. Replaced: fan clutch, bought a Gates belt this time (~$45)--> STILL SQUEALING!!!!
5. The only thing left to replace is the power-steering or A/C compressor and I'm thinking it is the power-steering pump. Because when the vehicle is stopped, the squealing lightens up a little but when I turn the wheel it screams like a bat out of hell.
I have seriously never ever heard of someone having this much trouble with a stupid squealing serpentine belt. I think my truck is cursed but if not, I am just another example that the 4.3 has a tendency for squealing.
After talking with a master-mechanic and a couple other people about the issue, we found out that the 4.3 in this year range have a tremendous load being run on the belt in general, and especially if your A/C is turned on. Sometimes if you just upgrade to a better belt like a Goodyear Gatorback or something like this, it might stop the problem. Some other common problems that we found out about:
-Low power-steering fluid (puts more of a load on the belt if low)
-A/C clutch pulley bearings commonly go out on the S-10s
-Tensioner pulley is a common problem and about a 5 minute fix...
-fan clutch could be worn out which increases the load on the belt
--A manager at our local parts store told us that he had a van with the 4.3 and the pulleys were out of alignment. (A good way to tell if your pulleys are out of alignment: inspect each pulley for build-up of rubber shavings, if you notice anything, remove the belt and check each side for wear which very well could indicate that misalignment is the problem.
-If you are still having problems finding out exactly where the squealing is coming from, you can buy a cheap mechanic's stethoscope and while the engine is running (carefully) try to get somewhat close to each pulley to see if the sound gets any louder (watch out for the fan, it'll get ya). If you, (like me) still cannot find the problem, I recommend that you either buy earplugs, blast the radio while driving, go completely insane, or, most importantly, talk dirty to the belt because this will make you feel a little better.
MJ1227M is offline
post #31 of 126 Old 12-08-2010, 02:11 PM
User is: 03 zr2 2010 is offline
I agree with the GOODYEAR Gatorback belt. I had the same problem with a 98 ZR2. Did same thing you did, replaced everything and still squealed. I read somewhere about the GOODYEAR belt, so I bought one and put it on. 3 Years later and still no more squealing!!! Go to GOODYEAR website and see where they are sold near you, and get you one. I think it only cost me $39.00. Part # for 4.3 with air is 4060960. Good luck. Eric
post #32 of 126 Old 12-08-2010, 07:27 PM
Flight Recorder's Avatar
User is: Flight Recorder is offline
the only problem i have is that the fan is really loud when i first start it and until i get to second gear. i plan to fix that with an electric fan though...
post #33 of 126 Old 12-08-2010, 10:00 PM
snm
User is: snm is offline
take care of it..drive it easy...and it'll take care of you...
snm is offline
post #34 of 126 Old 12-08-2010, 10:03 PM
I didn't build it for you
Dogsofjune's Avatar
User is: Dogsofjune is offline
Common problem? They are slow......
Doesn't play well with the ignorant.
New project
My 2003 Turbo 4.3l SyTy wannabe Build
post #35 of 126 Old 12-08-2010, 10:24 PM
Slowly but eventually
98lowerednewproje's Avatar
User is: 98lowerednewproje is offline
I love both my S-10 and my wife's Jimmy, they each have their qwerks, but other than the normal little things that go bad, not a lot of issues.
Procrastination has carried me this far in life, it will carry me to my grave, and hopefully put that off as well.
'98 RCSB on jack stands, waiting on me to get the 4.8 and T56 swap together, while I steal parts off of it to keep the daily going.
'99 2DR 2WD Blazer that I bought for a daily but just can't leave it alone.
post #36 of 126 Old 12-08-2010, 10:27 PM
User is: mikealp123 is offline
i have a 98 4x4 the front wheel bearings suck i have put on 2 left and 2 right all 4 mind you are from diffrent companys tring to find the best one no luck yet though the 94 4x4 i had last went 269,xxx miles on factory bearings anybody know if i could use that style looking at them only diffrence i see is the abs gear is external and i unplugged mine anyways .other than that s10's rock you cant beat them
post #37 of 126 Old 12-08-2010, 10:57 PM
User is: NachesValleyElect is offline
I have had 3 Blazer/Jimmys..
My 91 4.3 I drove the snot...out of and it wouldn't die. sold it at 204000 miles and didnt put but about 800 into it in 8 years and 125000 miles.. didn't even change oil like I should have and only changed plugs once.
My biggest complaint on it was the door hinges and electronic dash.
I got a 96 Jimmy that I really liked.. The fuel pump quit and a wheel bearing went out.. all and all it gave me no problems..
Now I got a 2000 Blazer and have had some small issues..
wipers are crap, heater flapper system is crap, my belt squeaked and I just replaced it, and now I have this funky sputtering at 3000 rpm..
I think its the last one for me.. Soon as I get this fixed its for sale. If I don't get it fixed I am ripping it apart and parting it out..
post #38 of 126 Old 12-11-2010, 12:59 AM
meyers2211's Avatar
User is: meyers2211 is offline
Send a message via AIM to meyers2211
MAKE SURE you get a decent quality fan, a cheap ebay electric fan won't do. Typical mechanical fans draw power but boy do they pull air lol. I've ran several dif setups and found the larger the electric fan motor and bettter brands are required. Think about, sitting in traffic on a hot summer day and how much warm air you have to pull to keep the a/c and motor cool. When the engine bay temps are climbing.
even worse, try and keep a engine bay cool with turbo piping under it. I need a huge radiator and adequate fan to cool it now.
To the OP, lower intake manifold gaskets are very common, mine blew 5k miles ago, since I'm going that far I'm changing the water pump and the cracked radiator all in one shot.
If you are over 100k:
Fuel pumps are common
Lower intake manifold as mentioned by many
post #39 of 126 Old 12-12-2010, 01:31 AM
1-32 INF
armymansS10's Avatar
User is: armymansS10 is offline
Send a message via AIM to armymansS10
my transmission crapped out around 50K, serp belt corroded. (Northern Truck) other then that, nada.
1996 Chevrolet S10
Quote: Originally Posted by GeorgesBlazah
"Hey Bob!"
"Yeah Leroy?"
"Remember that faggot in the Monte Carlo?"
"Hell Yeah I do, he looked like he sucked harder than a Shamwow"
post #40 of 126 Old 02-15-2011, 09:43 PM
User is: kibbles223 is offline
on my '96 4.3L 4x4 the sending unit is bad so the fuel gauge is past full and at 1/2 full when it's empty.
post #41 of 126 Old 02-15-2011, 09:58 PM
My '96 just hit 150,000 miles on 2/14/11 and the only thing i've ran into was a slight grinding noise under the cab (driver side, near the converter).
post #42 of 126 Old 02-16-2011, 07:13 PM
Bold as Love
Harry Canyon's Avatar
User is: Harry Canyon is offline
Lower Intake Gaskets, Fuel Pump, Fuel Filter.
1998 S10 4.3/Auto daily driver.
1984 S15 2.2 Diesel.
1988 S10 2.5 5-speed lowered 4/4.
post #43 of 126 Old 02-16-2011, 10:00 PM
User is: rockwell is offline
1997 sonoma 160,000 now 5th gear went out at 110,000 slave started acting up at 130,000 still have both problems but constantly slave is getting worse especially with cold weather. radiator cracked at 120,000 cam sensor 135,000 crank sensor160,000 (last night) timing belt at 105,000 had to get all new cylinder head pistons 115,000 blew plug #2 out of new head 120,000plug #1 blew out 137,000 #4 155,000#3 dam aluminum head new head all full of helicoils. fuel gauge at 144,000 then fuel pressure was 64 psi now at 160,000 37 lbs still runs but when i get on it it misses and in the mornings its hard to start.
rockwell is offline
post #44 of 126 Old 02-16-2011, 10:01 PM
surprisingly it still holds 60 psi oil pressure at idle and around 70 psi doing 65 (only have 4th gear Maybe why)
rockwell is offline
post #45 of 126 Old 02-22-2011, 01:59 AM
User is: coors628 is offline
mine has a weird clicking under the dash that speeds up with engine rpm.
coors628 is offline
post #46 of 126 Old 02-22-2011, 05:22 PM
Bold as Love
Exhaust donut gasket.
Mine does the same thing, its like an audio tachometer.
post #47 of 126 Old 02-22-2011, 11:56 PM
could be cus last time i serviced the trans I had to cheat the header pipe out of the way with a ratchet strap but then again its always done that. my exhaust is super short and comes out right behind the cab consists of the stock y pipe and a glass pack. It sounds pretty good and I havnt seen any negative effects in gas mileage or horsepower despite having no backpressure.
coors628 is offline
post #48 of 126 Old 10-06-2011, 05:03 PM
User is: Theripper is offline
when i start my s10 and the engine is cool it runs grate but when it warms up the oil pressure drops 1/4 way and i looes pick up. it eat up gas prety good what the hell's wrong i know my bareings are good no blue smoke out the tail pipe netheir. the teputer is at 100 and stays there the fuel tac somtimes is wrong but i dont think thats why i dont have picup speed when it warms up. i need help
post #49 of 126 Old 10-08-2011, 02:10 PM
Sounds like two different problems here. The oil pressure is probably due to age/mileage, normal in an older truck. The other deal points to a bad thermostat in the cooling system. When the engine doesn't heat up right it screws up the computer control. I'd start with that.
tom3 is offline
post #50 of 126 Old 10-10-2011, 08:57 PM
User is: bdubs is offline
I just bought my 03 ZQ8 and I only have a few minor complaints
1) the third door handle is a pile of you know what
2) the P0442 SES code (gas cap)
3) a clunking in the steering when the wheel is at full lock
4) a whining that changes with RPM...doesn't do it all the time
bdubs is offline
