code help p0446 - S-10 Forum
post #1 of 16 Old 05-24-2010, 11:39 AM Thread Starter
User is: djwehr is offline
code help p0446
have a 99 gmc sonoma with 4.3l v6 that has code 0446. replaced the evap vent valve, the one near the spare tire at the rear. rest code and drove 100+ miles; filled the tank and got an additional 25 miles before code came back. can anybody shed some light on this for me?
thanks in advance
djwehr is offline
post #2 of 16 Old 05-24-2010, 11:57 AM
Sometimes I'm mean...alot
RaginInferno's Avatar
User is: RaginInferno is offline
Re: code help p0446
Originally Posted by RaginInferno View Post
****IMPORTANT****
While were on the subject...
1. How many of you, while filling your tank... stop the pump the moment it clicks off?
2. How many of you try to get to the next dollar mark or get every ounce you can into the tank?
***Hint*** #1 is what you should be doing with all newer vehicles.
In another thread I posted the questions above...your problem can be a result of #2
These valves were designed to process fuel VAPOR not raw liquid fuel.
Gasoline (liquid) destroys the valves and their components.
That's why you need to follow #1 above to avoid this happening.
Originally Posted by Bentenn14 View Post
If I had to guess, It's gonna be one of those things that seems like a longshot that's gonna be the problem. I've almost exhausted the short-shots.
Jim
'00 Blazer 4dr 4wd, '00 S10 RCSB,'99 Blazer 2dr 4wd, '97 Southwind 35W, '03 2500HD,'02 Yukon, '00 Harley, '06 GSXR, '00 250EX, '10 RZR
post #3 of 16 Old 05-24-2010, 03:15 PM Thread Starter
Re: code help p0446
i filled up to the auto shut off and no more. what else could be the problem?
djwehr is offline
post #4 of 16 Old 05-24-2010, 03:48 PM
Re: code help p0446
Many times a loose and or old gas cap can set Evap codes as well.
Do a search here using code 0446
Jim
post #5 of 16 Old 05-24-2010, 04:04 PM Thread Starter
Re: code help p0446
thanks, been following all the 0446 threads, no such luck was gonna go on a limb and try the cap. reset code and installed cap see what happens
djwehr is offline
post #6 of 16 Old 05-24-2010, 06:58 PM
User is: LeRoY DrAgOn is offline
Re: code help p0446
http://www.obd-codes.com/p0446
2002 Xtreme V6 vortech Black/Silver
post #7 of 16 Old 06-02-2010, 10:58 AM Thread Starter
Re: code help p0446
finally broke down and had it inspected by a shop. was told the Fuel Tank Pressure sensor needs to be replaced, or check the wiring. Does this make sense?
djwehr is offline
post #8 of 16 Old 06-02-2010, 11:23 AM
S10WhiteDiaMOND
S10WhiteDiaMOND's Avatar
User is: S10WhiteDiaMOND is offline
Re: code help p0446
the four components that it could be due to the end of the pinpoint
diagnostic sheet is Evap Vent Valve, Evap Vapor Canister, and Fuel Tank
Pressure Sensor, and then replacement of the VCM.
so if you already replace the vent valve, and a TECHINCAN stated its a Fuel pressure Sensor, Me being a service advisor at a dealership here in TX, thats what they get paid doing is to fix cars, then i would agree that it would be a fuel pressure sensor.
2000 Chevrolet S10 Blazer LS 2DR 101,000 miles, all Factory at this point, just purchase 5/2010
post #9 of 16 Old 07-25-2014, 08:55 PM
User is: Jazz Diamond is offline
Re: code help p0446
I also have this code I am planning on cleaning the valve first to see if that resolved the problem. My question is will this problem cause the engine to bog down on occasion or is there something else amiss. So far this the P0446 is the only code that is displaying.
post #10 of 16 Old 09-15-2014, 09:48 AM
User is: Anabolic is offline
Re: code help p0446
i'v got the same problem and will be looking into it. do you have to to drop the tank to get to the pressure sensor?
And i'v been filling the fuel literally up to the nexk so I understand this happening now.
2000 GMC Jimmy SLT 4x4
20Mpg 91 Octane 0% Ethanol
Anabolic is offline
post #11 of 16 Old 09-24-2014, 11:48 PM
Shoulda kept my ZR2...
uwwsquirrel's Avatar
User is: uwwsquirrel is offline
Re: code help p0446
Gah! The dreaded SES light... Sadly I am in the same boat - P0446 among other codes...
P0446 - Evaporative Emmission Control System Vent Control Circuit
P0441 - Evaporative Emission Control System Incorrect Purge Flow
P0101 - Mass Air Flow (MAF) sensor or circuit fault
Well I figured I'd start cheap and work my way up to more expensive parts. Today - I replaced the Purge Solenoid Valve attached to the canister, Fuel Filter, Air Filter and sprayed out the MAF with MAF cleaner.
(decided to do the throttle plate mod too since I had the air inlet off )
Got it all buttoned up - reconnected the battery - fired right up no problems...until the *&^%'n SES light came back on after about 5 minutes. Gonna scan it again tomorrow and see what comes up...
'99 S10 Reg Cab - Sold
'02 S10 ZR2 Ext Cab - Traded
'04 S10 CrewCab - Current DD
- MODS: 96 Bravada Bumper, Color Matched Grille, Bravada Shaft, NP231 swap w/console, Flaming River Steering Joint, Throttle Plate Shaved, Rear Leather Upper Door Panels.
Every time I'm in the 'For Sale' forum my bank account quietly reminds me to calm the *&#% down...
post #12 of 16 Old 09-26-2014, 11:54 PM
Re: code help p0446
Scanned it - now I have these:
P0449 - Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
P0452 - Fuel Tank Pressure Sensor Circuit Low Input Conditions
At least the MAF one is gone and I'm slowly closing in on the emissions system problem. I really don't know why I would get a 449 since i just replaced the vent valve... I'm going to do a front to back check of all the wires (make sure none of them got chaffed or damaged). Also going to try replacing the fuel tank pressure sensor next. Ill keep you all posted.
The Fuel Pressure sensor is located right on top of the fuel pump. Might be easier to simply raise the bed vice dropping the tank - I have the tiny crew cab bed so that's what I'll be doing
post #13 of 16 Old 10-03-2014, 09:44 PM
Re: code help p0446
Replaced the Fuel Pressure Sensor. Didn't help - still reading P0449 and P0452. I have absolutely no idea where to go from here - what the hell am I missing? The truck idles and drives just fine - doesn't shake or run funny. I'm running out of ideas.
I was able to get to it without dropping the tank or lifting the bed on the crew. I just removed the inner fender plastic on the driver side and it was right there. I was also able to access it by reaching it from underneath over the driveshaft.
post #14 of 16 Old 10-03-2014, 10:57 PM
Quadracer92's Avatar
User is: Quadracer92 is offline
Re: code help p0446
Check your vacuum system.
"When a man is denied the right to live the life he believes in, he has no choice but to become an outlaw"
02 Dime - 4.3, 4" rear drop, intake and exhaust
post #15 of 16 Old 10-09-2014, 07:21 PM
Re: code help p0446
Thought I'd throw out some part numbers for those of you who are having similar problems. I've got the 2004 LU3 - Vin X - 4.3L.
Chevy Parts for:
1GCDT13X34K****** S10 2004 Pickup 4WD
(vehicle options)T10643 LU3 M30
Mass Air Flow Sensor: ...........................REPAIRED
ACDelco 213-4527
GM 19207202
Fuel Tank Evap Solenoid (Vent Valve) ...REPLACED
ACDelco 214-2149
GM 25932571
Fuel Tank Evap Canister
ACDelco 215-415
GM 17113682
Fuel Filter ................................................REPLACED
ACDelco GF645
GM 19114104
Fuel Pump
ACDelco MU1767
GM 19179495
Fuel Cap .................................................REPLACED
ACDelco GT265
GM 10372865
Purge Valve ...........................................ON ORDER
ACDelco 214-640
GM 1997277
Fuel Pressure Sensor ...........................REPLACED
ACDelco 16238399
GM 16238399
Here are some useful illustrations in identifying the correct parts:
FUEL SUPPLY SYSTEM
VAPOR CANISTER LINES
INTAKE MANIFOLD & THROTTLE BODY
Here's a linkback to the **Diagnostic Trouble Codes** thread for quick reference to OBDII Codes.
It's not likely to be a vacuum leak simply because the truck runs and drives just fine - a vacuum leak anywhere would surely cause the engine to run like crap - speaking from past experiences. However, I guess I can't rule it out at this point. Maybe new intake gaskets are in order...
Hopefully once the new purge valve is installed I can clear those P0449 and P0452 codes and finally get the SES light to STAY OFF. I guess it's good to replace all these parts anyway - after all its 10+ year old truck.
post #16 of 16 Old 10-21-2014, 12:26 AM
Re: code help p0446
Still reading P0449 and P0452... Everything emissions related has been replaced -
Now "Check Gauges" light came on - overheated. Popped the hood and discovered a coolant leak somewhere near the thermostat - 1 gallon low on coolant - still have to isolate the leak.
Ordered an intake gasket kit, new thermostat, and new coolant, flush kit. - Ugh it's one thing after another! FML
Getting more motivated to yank this ungrateful 4.3 out and throw an LS1/LS6 in it.
