cleaning spectre filter..... - S-10 Forum
post #1 of 35 Old 05-18-2010, 10:13 PM Thread Starter
lwrd93's Avatar
User is: lwrd93 is offline
Send a message via AIM to lwrd93
i see they carry a diff kind of recharge kit for diff kinds of filters... can i use the k&n one on my spectre? or do i have to use the spectre kit? mine is red and looks super dirty... you can see the red on a few blades of the filter is that just the oil or the actual filter thats red? also how much oil do you use i hear some ppl putting to much on theres and messing there maf sensor up, i just replaced mine and dont wana do that!
lwrd93 is offline
post #2 of 35 Old 05-18-2010, 11:55 PM
UN-BANNED B!TCHES!!!!!
NotaDime's Avatar
User is: NotaDime is offline
Re: cleaning spectre filter.....
you can use any kit like the K&N kit, most places the K&N kit is cheaper then the spectre kit is.
make sure you let it air dry completely before oil'n it
then LIGHTLY oil it, dont soak it.
WTB cowl hood near valdosta GA NOW...
Seems like there are still a few people (Imperial, NotaDime, etc...) here that still have working brains.
Originally Posted by The Master View Post
BTW last post evar on this site. cheers and.....fock off.
Originally Posted by v8lonoma View Post
everything notadime said +1.
NotaDime is offline
post #3 of 35 Old 05-19-2010, 12:09 AM Thread Starter
lwrd93's Avatar
mine looks really dirty.. can you scrub it with a toothbrush or something? i just dont see the cleaner getting it all off, mayb ill spray it twice then let it dry and oil it. just mist the oil on all over it? like 2 pumps one close to bottom and one close to top then turn a little and 2 more until im all the way around, like 8 pumps?
lwrd93 is offline
post #4 of 35 Old 05-19-2010, 12:22 AM
Compstall's Avatar
User is: Compstall is offline
I soak my filters in a sink full of hot soapy (dish soap) water for an hour or so. I've also used a toothbrush to gently scrub. Rinse well then blow out with my air compressor and let it air dry over-night.
- Brent
'88 S10 Tahoe 4.3
'11 Mustang GT, Kona Blue, M6, 3.73, Brembo's
'08 Mazda CX-9, pretty cool for a girl car
Several Jeeps
'03 Kawalski Z1000, lots o' mods w/ a little N20 (buy it so I can fund the 5.3 install!!!!)
post #5 of 35 Old 05-19-2010, 12:26 AM
terrible. take a lap.
joyride's Avatar
User is: joyride is offline
Send a message via AIM to joyride
makes me want to clean mine out...except mines not dirty...lol
wonder what adding some orange hand cleaner to the mix would do, that some hot water and a bucket?? lol
Brian
01 xtreme 4.3L 5spd 2/3 drop w/ SS front bumper|.030 over|270 comp cam|500 lift|dual valve springs|10:1 C/R|p&p heads w/ 3 angle valve job|w4me tune|shorty headers|2.25 y pipe|no cat|Spintech muffler|windage tray|LW flywheel|DF clutch|8mm wires|no ac|efan|walbro 255|MPFI upgrade|Comp Cam timing chain|ARP bolts/studs|totaled***
Now owner of a white 2002 Blazer Xtreme
http://www.youtube.com/watch?v=CO_A1IrbQNM
85 Monte Carlo SS
KCCO
joyride is offline
post #6 of 35 Old 05-19-2010, 12:32 AM Thread Starter
lwrd93's Avatar
so you dont use a recharge kit on it at all?
lwrd93 is offline
post #7 of 35 Old 05-19-2010, 01:01 AM
Stroker Ace
frtaylor9's Avatar
User is: frtaylor9 is offline
Send a message via AIM to frtaylor9
I just soak mine down with that Blue Wolf stuff you can get from Wal-Mart or Purple Power; then let it set for about 20 min. , & spray with a water hose, works better than the cleaner in the recharge kit in IMO (you can just see the black pour out of it), but the oil in the kit is good for a lite coat after it drys.
I do think I'm gonna try Compstall's method sometime when I run out of cleaner.
2002 Chevy S10 4.3 Vortec (W) 5 Speed 2WD
Spectre CAI, Ported JANTZER TB & Mod w/Trans-Dapt Spacer, Hypertech PPIII & Stat, Flowmaster Super 44, Magnaflow Spun Cat, MSD w/Taylor wires, Billet UD Pulleys, Perma Cool E-Fan
1/4 Mile: 15.2 @ 88mph on a 2.38 60ft
post #8 of 35 Old 05-19-2010, 01:05 AM Thread Starter
lwrd93's Avatar
with a recharge kit you dont even spray it with a water hose, i dont get that how is it sopose to clean it good just by spraying stuff on it not using any pressure?
lwrd93 is offline
post #9 of 35 Old 05-19-2010, 01:10 AM
Stroker Ace
frtaylor9's Avatar
yeah that don't work, I tried that ("reading the directions") the first time I cleaned my old K&N on my TA & it, well........................I guess it works if you want your filter to be wet oily & dirty...
you pretty much have to use some type of way to rinse it out.....water hose, bath tub, sink, car wash-just be careful with the pressure on that one.
besides I think that was the older kits (they barely come with directions), all the newer K&N recharge kits tell you to use low pressure rinse.
post #10 of 35 Old 05-19-2010, 02:50 AM Thread Starter
lwrd93's Avatar
they tell you to rinse them with water? i thought you just used the cleaner and oil in the kit. also my filter was red new now its brown, does the oil make it red or is the filter really just that dirty?? i was gona get a recharge kit tomo but i think i may just put it in the tub and use the jet setting to wash it out then air dry it. then all i need is some oil?
lwrd93 is offline
post #11 of 35 Old 05-19-2010, 03:00 AM
joyride's Avatar
how long have you had your air filter? im not sure how it could get brown unless maybe you started driving your truck with the filter that wasn't dried enough or something..?
or just that spectre bullshit filter just doesn't mesh well with the K&N recharge kit, no clue on my end...
Brian
85 Monte Carlo SS
KCCO
joyride is offline
post #12 of 35 Old 05-19-2010, 03:17 AM Thread Starter
lwrd93's Avatar
it was on the truck when i got it, not sure what happened im gona try and soak it tomo in hot water and then get some kn oil.. i dont think the recharge kit is gona clean this one lol
lwrd93 is offline
post #13 of 35 Old 05-19-2010, 03:19 AM
joyride's Avatar
might be worth it just to buy a new filter...lol even though autozone wants an arm and a leg for one when on ebay you can buy the "cold air intake" kit for the same price.
Brian
85 Monte Carlo SS
KCCO
joyride is offline
post #14 of 35 Old 05-19-2010, 03:28 AM Thread Starter
lwrd93's Avatar
ya if i cant get it lookin better tomo ill get a new one..
lwrd93 is offline
post #15 of 35 Old 05-19-2010, 03:22 PM
NotaDime's Avatar
really? how much is it at "your" autozone?
and autozone has a mail in rebate right now for $10.oo off of this price, hell a cheap stp filter cost more then these do at that price.
heres a PDF link for a rebate form for you to print if you need one.
all you need is a receipt and the barcode off the box.
http://www.powerflowracing.com/rebate.pdf
NotaDime is offline
post #16 of 35 Old 05-19-2010, 07:42 PM
joyride's Avatar
haha notadime...didn't realize you were back...how awesome, i love your posts...lol im the former "vicodin" i couldnt remember my pw and email i used for the acct i made yrs ago so i made a new one not that long ago...
and for the air filter i think he is thinking of, not just the stock replacement, they want 40 bucks for it at my autozone...im not sure what the stock replacement ones are...i didnt realize spectre made a stock replacement until you posted that link either though
Brian
85 Monte Carlo SS
KCCO
joyride is offline
post #17 of 35 Old 05-19-2010, 08:49 PM
Stroker Ace
frtaylor9's Avatar
joyride....I know everyone has there own vice, but I gotta ask man...why the blue engine bro? not that it looks bad...its just different.
post #18 of 35 Old 05-19-2010, 08:58 PM
joyride's Avatar
i didn't feel like searching around for the right color paint, i just wanted something different than the "baby blue" my machinist painted it...unfortunately its "ford blue" which i should get slapped for, but it's better than what it previously was...lol...
Brian
85 Monte Carlo SS
KCCO
joyride is offline
post #19 of 35 Old 05-19-2010, 11:04 PM Thread Starter
lwrd93's Avatar
mine is not a stock drop in filter.. its a cold air intake, the cone filter. should i soak it in some soapy water and use a hair dryer to dry it? i dont have any oil though. will it hurt to wash it and dry it and not oil it right away?
lwrd93 is offline
post #20 of 35 Old 05-19-2010, 11:15 PM
A work in progress...
jasond's Avatar
User is: jasond is offline
Just spray the cleaner on the filter and let it soak. Rinse with a garden hose, and let it air dry. Don't use a hair dryer, that will shrink the cotton gauze filter media. Don't use compressed air to blow out the filter, that will blow holes in the cotton gauze media. Re-oil the filter and let it air dry again. Make sure there's no wet spots on the filter before you reinstall it. I've had a k&n drop in filter in my Grand Prix for the last 8 years, I've definitely got my moneys worth out of it.
jasond is offline
post #21 of 35 Old 05-19-2010, 11:18 PM
Compstall's Avatar
I quit buying those, I only use the oil. I used my methods on my Camaro the longest with it's long cone-style filter for almost 10 years. Never a problem.
- Brent
'88 S10 Tahoe 4.3
Several Jeeps
post #22 of 35 Old 05-19-2010, 11:37 PM Thread Starter
lwrd93's Avatar
so just soak it in a sink with hot water... and let it air dry over night? will cleaning it make it red again or is that the oil that makes it red? can i put i back on tomo after its dry without any oil?
lwrd93 is offline
post #23 of 35 Old 05-19-2010, 11:54 PM
jasond's Avatar
On the k&n filters, the oil gives it the red color. The cleaning solution removes the oil, leaving the filter the natural white cotton color. I just spray it with the cleaning solution, let it soak a bit, and rinse it out with a garden hose. If there's a lot of stuff on the filter, I'll tap it on the ground before rinsing it out. Let it air dry. I then spray it with the oil, and let it air dry again. Then reinstall. I keep a cheap paper filter to use while I have the k&n out of the car. Do not install the filter without oil, the oil is what traps the dirt. The filter will not do it's job with no oil.
jasond is offline
post #24 of 35 Old 05-20-2010, 12:05 AM
Compstall's Avatar
True 'dat. Just before installing, I also take a paper towel and blot off any excess oil from the outside of the filter.
- Brent
'88 S10 Tahoe 4.3
Several Jeeps
post #25 of 35 Old 05-20-2010, 12:12 AM
Stroker Ace
frtaylor9's Avatar
spectre filters don't use oil; the cotton gaze are red & they come that way. clean your filter (spary it with some of cleaner I mentioned earlier, let it set and rinse using the shower head or water hose & let it dry out it will still be red-put it back on the truck, DONE!!.....spectre does not require oiling. it does makes sense, oiling would trap more dirt but that's not the case with your filter, (i dunno maybe spectre sucks.)
post #26 of 35 Old 05-20-2010, 12:14 AM
jasond's Avatar
The spectre filters do use oil. I sell them on a daily basis. They use the "Accucharge" oiling system.
jasond is offline
post #27 of 35 Old 05-20-2010, 12:25 AM
Stroker Ace
frtaylor9's Avatar
damn... then why do them bastards come dry. & there whole slogan is "no greasy oils" thanks for the tip though bro.........learn something everyday on this site.
lwrd93 just go buy you a recharge kit read the directions & forget about it.
if the filters in really bad shape let it soak in hot soapy water for a few hours then go threw the cleaning process (directions supplied in the kit)...
post #28 of 35 Old 05-20-2010, 12:39 AM
jasond's Avatar
The filters come pre oiled ready to go when new. If the filter is wet or oily feeling, it's over oiled. The cotton should absorb the oil, and feel dry to the touch.
jasond is offline
post #29 of 35 Old 05-20-2010, 01:02 AM Thread Starter
lwrd93's Avatar
well its my daily driver and i already got it soaking in the tub with warm water and dish soap. and that water got nasty! but its not red as its sopose to. closest part store is about 7 miles, it will be alright to let it air dry infront of a box fan tonight. then put it on and drive to get some cleaner and oil in the morning?
lwrd93 is offline
post #30 of 35 Old 05-20-2010, 06:59 PM
jasond's Avatar
That should be fine, as long as the oil was not removed from the filter. You may want to grab a cheap paper filter to get you going while the spectre filter is out. The cleaner in the kit will remove the oil and dirt from the filter, re-oiling it will restore the red color.
jasond is offline
post #31 of 35 Old 05-21-2010, 01:49 AM Thread Starter
lwrd93's Avatar
got it cleaned and oiled!
lwrd93 is offline
post #32 of 35 Old 05-22-2010, 07:18 PM
NotaDime's Avatar
at my store, the K&N kit is like $2.oo cheaper then the spectre one....
NotaDime is offline
post #33 of 35 Old 05-22-2010, 07:37 PM Thread Starter
lwrd93's Avatar
i paid 12 bucks for the k&n kit..
lwrd93 is offline
post #34 of 35 Old 05-22-2010, 07:39 PM
joyride's Avatar
lets see what your finished product looks like. lol
Brian
85 Monte Carlo SS
KCCO
joyride is offline
post #35 of 35 Old 05-22-2010, 11:10 PM Thread Starter
lwrd93's Avatar
i forgot to take pics! but nice and red!
lwrd93 is offline
