CKP Sensor Circuit High Input (P0338)any idea? where to start? - S-10 Forum
post #1 of 8 Old 05-26-2010, 06:32 AM Thread Starter
User is: tahi is offline
Send a message via AIM to tahi Send a message via Skype™ to tahi
After a lower intake gasket change I had misfire and general poor running conditions. After checking almost everything I finally could had a diagnostic tool available and the result is High Frequency on the CKP sensor (P0338).
I recon that I don't know where to start.
I know that one socket have been damaged while re-mounting the intake, could this be related to the CKP sensor?
What does mean high frequency on this sensor : faulty sensor or another trouble in the engine that is revealed by this CKP data?
Any help appreciated as I cannot use my truck for more than one month know( and spending many €uros around…)
98' Blazer LT - 4.3 l K & N Airfilter
87 Blazer Tahoe - 2.8l injection 4WD - 190000 Miles - stock rims
85' Jimmy - 2.8 l - Bodylift 2" - stock rims - 235 tires - Trush Muffler - 150000 Miles
62' Oldsmobile F85 4 door Sedan 3,5l Stock
tahi is offline
post #2 of 8 Old 05-26-2010, 12:08 PM
Sometimes I'm mean...alot
RaginInferno's Avatar
User is: RaginInferno is offline
Re: CKP Sensor Circuit High Input (P0338)any idea? where to start?
The only information I've found so far on DTC P0338 is problems that occur during start up.
It is possible that a damaged plug could cause problems, especially if the wire are in the wrong place now.
Originally Posted by Bentenn14 View Post
If I had to guess, It's gonna be one of those things that seems like a longshot that's gonna be the problem. I've almost exhausted the short-shots.
Jim
'00 Blazer 4dr 4wd, '00 S10 RCSB,'99 Blazer 2dr 4wd, '97 Southwind 35W, '03 2500HD,'02 Yukon, '00 Harley, '06 GSXR, '00 250EX, '10 RZR
post #3 of 8 Old 05-26-2010, 12:29 PM
the_coroner2002's Avatar
User is: the_coroner2002 is offline
Send a message via AIM to the_coroner2002
DTC P0338 - Shows faulty crank sensor according to gms website... hope that helps
post #4 of 8 Old 05-26-2010, 02:06 PM Thread Starter
Thanks for your informations, I'll probably change the sensor and see what's happening…another 100 bucks. For a while I had the engine that sometimes was staying stuck when I was cranking. I taught it was a faulty starter engine but in fact I guess this sensor is the true culprit.
tahi is offline
post #5 of 8 Old 05-26-2010, 03:21 PM
Originally Posted by tahi View Post
…another 100 bucks.
$50-60 US
Jim
post #6 of 8 Old 05-27-2010, 03:37 AM Thread Starter
Thanks for your help RaginInferno, I guess you should come here in France for vacation and have great time tuning my truck. We got nice beaches, good food and good party in summer lol.
Do you know where I can locate the crankshaft sensor on a 98 win W 4.3?
tahi is offline
post #7 of 8 Old 05-27-2010, 05:24 AM
terrible. take a lap.
joyride's Avatar
User is: joyride is offline
Send a message via AIM to joyride
underneath the pulleys a lil' bit on the passenger side of the block down there..pretty much right next to and/or on the timing cover
Brian
01 xtreme 4.3L 5spd 2/3 drop w/ SS front bumper|.030 over|270 comp cam|500 lift|dual valve springs|10:1 C/R|p&p heads w/ 3 angle valve job|w4me tune|shorty headers|2.25 y pipe|no cat|Spintech muffler|windage tray|LW flywheel|DF clutch|8mm wires|no ac|efan|walbro 255|MPFI upgrade|Comp Cam timing chain|ARP bolts/studs|totaled***
Now owner of a white 2002 Blazer Xtreme
http://www.youtube.com/watch?v=CO_A1IrbQNM
85 Monte Carlo SS
KCCO
joyride is offline
post #8 of 8 Old 05-27-2010, 09:42 AM
haha...last time I was there, I was in Deauville, Trouville and Saint-Gatien (Airport)... I speak a good bit of Cajun French so we could hang out!
...and yes, the Crankshaft sensor is on the bottom of the timing cover, passenger side.
Jim
