Location: Stratford/Grand Bend, Ontario User is: OffLine |
Changing Oil
So im doing the first oil change on my truck since i got it (never worked on these trucks before)
I found the oil pan, but theres no drain plug on it?? :/ Can anyone let me know where it is?? Thanks.. |
Got boost?
Re: Changing Oil
If you crawl under from the driver side it should be right there close to the oil filter. It's located on the side of the pan there. It's a 15mm socket.
Re: Changing Oil
I always thought that was the transmission there??
Im doing the engine oil, just to clarify. Its a 4.3 V btw |
Re: Changing Oil
Yes it is like right below the filter on the pan just a little to the right. 15mm like said before.
Re: Changing Oil
Alright i found it, I cant seem to get the filter off, its tight as hell. I cant even fit a filter wrench around it :S
4blow
Re: Changing Oil
it missey but work. take a flate head screw driver and stab in to it, that will gave you the lavaege to brake it lose.
Re: Changing Oil
Mr. Sparkle
Re: Changing Oil
Did you get the screwdriver all the way through the filter? Are you turnint it the correct way?
Re: Changing Oil
Yes i did get it all the way through, the point is theres NO room in there to turn a screwdriver. as well i am turning it the right way, towards the passenger side going counter clockwise from the driver side.
4blow
Re: Changing Oil
are you using the longest screw driver you got. that is what i use to get mine out and never have had a problem. you should need much room just to brake it lose. once you do that you shold be able to get you hand in there to get it the rest.
Re: Changing Oil
I have never used one on mine as the filters come off rather easily. But on the cutlass I had a chain wrench worked really well. It just kept crushing the damn thing down smaller and smaller until it couldn't get any smaller and the it would come out.
Re: Changing Oil
I usually use a band wrench to get them off if I can't get them with my hand. The pan is so close to the filter that you can't really get a filter wrench on it. I just can't believe we have to go this much into detail over a damn oil change.
Re: Changing Oil
Its not my fault the person before me put it on uber tight, lmao
Re: Changing Oil
LOL yeah it would have just been easier to get a band wrench. Did you get it done though. Its only been like 24 hours LOL.
Got boost?
Re: Changing Oil
That's why I use K&N oil filters. They have a nut on the bottom of the filter that uses a 1 inch socket to make it easier to tighten/untighten.
Re: Changing Oil
It would have been done, theres a mechanic coming today to do it lol. |
Got boost?
Re: Changing Oil
Re: Changing Oil
I will be putting one on the new 4.3 I'm building currently.
Re: Changing Oil
Its off, and all changed.
Lmao, thanks guys! |
