Can a Collapsed Lifter blow up my engine ?? - S-10 Forum
post #1 of 18 Old 01-11-2010, 09:55 PM Thread Starter
GO STEELERS !!!
LabRat116's Avatar
User is: LabRat116 is offline
Exclamation Can a Collapsed Lifter blow up my engine ??
My 99 Blazer has 132k on it and runs fairly decent.
I'm having issues getting the engine to put out heat to the heater core (see my other thread in this forum).
I decided to run the engine up a bit (80MPH 3k RPMs or so) to get the engine warmer. I did NOT work. I had done this the other week and the heater started blowing hotter.
Anyways, when I got off the highway I noticed the engine developed a loud ticking noises. It's the same speed as the valvetrain so I'm guessing a lifter crapped out when I ran up the engine.
Is it still safe to drive my truck or will a collapsed lifter blow up my engine ?
Short of ripping the engine apart, what's the best way to free up a collapsed lifter ?
post #2 of 18 Old 01-11-2010, 10:32 PM
4 wheels aren't as fun
serpentracer's Avatar
User is: serpentracer is offline
Re: Can a Collapsed Lifter blow up my engine ??
roller lifters don't collapse. they haven't used flat tappet lifters since the early 90's in most engines.
ticking lifters are quite normal for a lot of engines.
02 sonoma 4.3L auto
97 sonoma 2.2L manual
post #3 of 18 Old 01-11-2010, 11:17 PM
s10stocker's Avatar
User is: s10stocker is offline
I"m sorry but our lifters can collapse. Well its more like they can get stuck collapsed. Now to answer the original question you should be fine running your engine even if the lifter is collapsed. I however don't believe this to be the case in your situation. I would be willing to bet it is a exaust leak.
96 S10 N/A 4.3 Racetruck
97 S10 4.3 5s DD for now(will be Racetruck for sale)
02 Yamaha VMAX
94 Chevy 2500 350(was Father-in-laws R.I.P.)
07 Avalanche
It's better to remain silent and let one believe you a fool, than speak and remove all doubt.
post #4 of 18 Old 01-11-2010, 11:19 PM
Works too much!
laydout97's Avatar
User is: laydout97 is offline
A collapsed lifter can cause a dead skip. Is it skipping?
92 4.3/700r4 315k- ole red
2011 altima- daily ride
post #5 of 18 Old 01-12-2010, 06:14 AM Thread Starter
GO STEELERS !!!
LabRat116's Avatar
Not that I can tell. It still seems to run ok. It's just annoying as hell.
post #6 of 18 Old 01-12-2010, 12:08 PM
minimum wagn' it to glory
DCsdime16's Avatar
User is: DCsdime16 is offline
Well that lifter got stuck for a reason, could be an early warning sign, maybe somethings gummed up, maybe the top end isn't getting oil. DO NOT TRY I AM NOT CERTAIN, but i was wondering if maybe putting a little penetrating oil in your motor oil might free up some of the gunk? AGAIN DO NOT TRY THIS I AM NOT CERTAIN <NOT YELLING JUST WARNING> Btw, Steelers didn't make it too the play offs Cowboys are in round two!!!!!!!!
post #7 of 18 Old 01-12-2010, 01:38 PM
"factory freak"...
Crew Cab Sonoma's Avatar
try adding a few ounces of Marvel Mystery Oil to
the motor oil. MIGHT help...
95 S-10 2.2. Soon to be DD
post #8 of 18 Old 01-12-2010, 02:59 PM
Pavementnazi's Avatar
User is: Pavementnazi is offline
I had the same issue. I suspect sludge is causing the issue as I cut open my oil filter and it had a inch of sludge sitting in there.
Here's what I did: Filled my Oil with one can of Seafoam. Ran the engine for 100 miles. Change filter, used OEM GM filter, run fresh Synthetic Engine oil (5W30) Like Royal Purple or Castrol Syntec for older engines. The synthetic oil does a good job flushing the ports out of the hydro lifters. Once you motor starts ticking, I change my oil now every 2200-2500 miles. I know this is more frequent, but its stopped the lifter from ticking again for almost 6 months now.
If you continue to run the engine you will damage the hardening on the cam and the rod will fall apart...long term.
Good Luck
Tomas
2000 GMC Sonoma Step Side, 9 Gal Air Tank, Slam Spec Front Air Bags, Air Ride Technologies Air Bar Rear, 1/2 inch valves, 130 DB Train Horn, Hard Bed Cover, 4.3 V6, K&N Cold Air Intake, Xenon Headlight Swap, Chevy Extreme Wheels and XM Sat Radio, Bobbing Dash Chihuahua.
post #9 of 18 Old 01-12-2010, 06:55 PM
falcon52's Avatar
User is: falcon52 is offline
hmmm, nother idea for you... My grandpas truck (GM) was ticking, so he pulled the valve covers off and the ports where the oil circulates/drains were clogged. Wouldn't hurt to check them for sludge and gunk.
He who laughs last... thinks slowest...
96 s10 -computer tune 4.3 (for now), bagged/3 rims, tires, ss side mirrors, alpine h.u., 2 12in. Kicker XPL's, 1700 watt class D mono power akoustik amp, 2 inch cowl hood. (More to come)
low life + HIGH life = My life
falcon52 is offline
post #10 of 18 Old 01-12-2010, 07:38 PM Thread Starter
GO STEELERS !!!
LabRat116's Avatar
Angry Re: Can a Collapsed Lifter blow up my engine ??
Well....got BAD news....
It's not a sticking lifter. It's a SPUN ROD BEARING.
Now I REALLY look like the Bruiser Brody pulling his hair out (My Avatar!) !!
post #11 of 18 Old 01-12-2010, 11:08 PM
Works too much!
laydout97's Avatar
I have never heard a spun bearing tick. They will chirp like a belt squeal. How do you know that it is a spun bearing?
post #12 of 18 Old 01-12-2010, 11:18 PM
User is: fox_forma is offline
did it sound like this..............
http://www.youtube.com/watch?v=BK6M2KrylMo
post #13 of 18 Old 01-13-2010, 12:03 PM
DCsdime16's Avatar
okay so the lifter problem isn't related, its the bearing. now i get it.
post #14 of 18 Old 01-13-2010, 12:22 PM
monkeytruckin's Avatar
User is: monkeytruckin is offline
Eh thats two whole different sounds there buddy. My dad called me and told me he had a stuck lifter. I get there and he drove 50 miles on a rod knock. The lifter is a light tap and a rod is a sledge hammer hitting the block. He spun the #7 rod bearing.
post #15 of 18 Old 01-13-2010, 08:28 PM Thread Starter
GO STEELERS !!!
LabRat116's Avatar
Arrow Re: Can a Collapsed Lifter blow up my engine ??
No. That's an exhaust leak you have right there. Most likely the exhaust manifold gasket blew out.
Mine is actually more of a dull rapping noise than a tick. I've had (2) very exprienced Machinists verify that it was in fact a rod bearing noise.
post #16 of 18 Old 01-14-2010, 10:37 AM
I have a engine building book that says a collapsed lifter is actually one that has collapsed on the face where it contacts the cam lobes. not one that doesn't pump up or has broken internally.
people are using the wrong terminoligy according to this book
02 sonoma 4.3L auto
post #17 of 18 Old 01-14-2010, 10:51 AM
here's my engine with 2 spun bearings.
http://www.youtube.com/user/blue03r6#p/u/4/1NPAWF420UQ
02 sonoma 4.3L auto
post #18 of 18 Old 01-14-2010, 07:04 PM
If thats an exhaust manifold leak you just saved me a bunch of headache but I'm pretty positive something let loose in the bottom end of that motor. Keep us posted on your motor, mine should be coming out this weekend to see where it sits.
