Blazer quit running while driving... - S-10 Forum
post #1 of 48 Old 09-06-2007, 01:50 AM Thread Starter
future Dr. Curly
Curly's Avatar
User is: Curly is offline
Send a message via AIM to Curly
I know this may be a long shot... like doing a fullback dive on 4th and 40.
Well, I was headed down the highway. All of a sudden, my engine cut off. I coasted to the side of the road, my brakes and steering got hard. The engine wont start... it acts like it is going to turn over, but wont... so its not the starter because it doesnt have the "machine gun sound."
Any idea on what could have happened? I recently crossed 100,000 miles and they recommended a dist. cap and rotor change when i had the coolant flushed. Could one of these have caused this to happen?
Jordan
Jordan
2001 Blazer Xtreme
Curly is offline
post #2 of 48 Old 09-06-2007, 03:52 AM
Mr. Sparkle
Onimun's Avatar
User is: Onimun is offline
Re: Blazer quit running while driving...
Good chance that might have been what happened. Go check the cap and rotor yourself very easy. I believe the cap comes off with 2 screws and the rotor just pops off. If those are the origional parts then they definatly need to be changed.
Onimun is offline
post #3 of 48 Old 09-06-2007, 08:36 AM
User is: davidbjordan is offline
What do you mean by seems like it wanted to turn over but wouldn't??? it's one or the other...
post #4 of 48 Old 09-06-2007, 08:44 AM Thread Starter
future Dr. Curly
Curly's Avatar
i meant that it wasnt making the "machine gun sound"... it sounded like what it normally sounds like right before it starts, but it didnt get to the point of actually starting
Best way i can describe the sound:
che che che vooom <---- normal
che che che che che che.... <---- now
Jordan
2001 Blazer Xtreme
Curly is offline
post #5 of 48 Old 09-06-2007, 08:59 AM
Usted huele como un asno
mattryanmusic's Avatar
User is: mattryanmusic is offline
Send a message via AIM to mattryanmusic
So it cranks but doesn't start?
post #6 of 48 Old 09-06-2007, 09:07 AM
PUNISHING GROUNDS
got_u_sick's Avatar
User is: got_u_sick is offline
Send a message via MSN to got_u_sick Send a message via Yahoo to got_u_sick
If your cap and rotor check out good, I can almost bet its the Ignition Module. Take your distributor cap off and its mounted on the bottom. Its a big flat simiconductor with a few wires connected to it. If you have a book for your truck it will tell you how to check it with a meter to see if its good or not. Chances are thats your problem if it was running fine then just took a shit all of the sudden.
You can check: Unplug your plug wire from the coil and put a screwdriver in it. Set it close enough to the post so it will arc when your turn the truck over. If it arcs=good. If not, coil or something in the initial firing system is bad.
Do the same with a plug wire. If there was spark on the coil, but you see no arc off the plug wire, 9 times out of 10, your ignition module is dead.
SFBD 1984 Long Bed
CLICK HERE to view my Car Domain.
CLICK HERE for my Project Thread.
CLICK HERE for the Indianapolis Meet.
post #7 of 48 Old 09-06-2007, 10:12 AM Thread Starter
future Dr. Curly
Curly's Avatar
I guess so... i've always thought of cranking as starting, but i guess they are two different things.
Jordan
2001 Blazer Xtreme
Curly is offline
post #8 of 48 Old 09-06-2007, 10:39 AM
loco hombre
nater006's Avatar
User is: nater006 is offline
Send a message via AIM to nater006
Check cap & rotor, ignition coil, and fuel pressure.
If the pump zapped, it wouldn't even try to fire since the fuel pressure wouldn't be enough to spray and even get a sputter.
I had a dist cap failure on the freeway. Truck sputtered out, stalled, steering and brakes got tough (no power steering or brake booster when the engine stalls!). Cap wasn't even that old but had a microscopic crack or similar in it which carbon traced and shorted stuff out. So, check that too.
nater006 is offline
post #9 of 48 Old 09-06-2007, 10:46 AM
__/\_____\O/___ ahh shark
rtsurfer's Avatar
User is: rtsurfer is offline
It can only be a few things, Electrical, Mechanical, Fuel
First make sure you have enough fuel in the tank. Father in law pulled this one on me. Called up car won't start. I went over there and found out he was on empty.
2nd Pull on spark plug wire, put a screwdriver in the end of the wire, and lay it on top of the motor. Now crank over the motor.(try to start it) If you see it spark Good chances are it is a Fuel Problem. No Spark it could be computer, cap, rotor or timing chain.
Did you get any Check eninge lights brfore it shut off????
rtsurfer is offline
post #10 of 48 Old 09-06-2007, 11:34 AM
Banned
User is: jimbo1145 is offline
Spray some starting fluid in the intake if it trys to start look to the fuel side of it. If not look for an Ingition problem.
post #11 of 48 Old 09-06-2007, 11:43 AM Thread Starter
future Dr. Curly
Curly's Avatar
Nope, no check engine lights.
I know someone is going to say "search button," but is there a thread telling how to change out the cap and rotor? I would like to see some pics or something... maybe something on another site. But I need to change that anyways because i've been working on getting it tuned up.
Jordan
2001 Blazer Xtreme
Curly is offline
post #12 of 48 Old 09-06-2007, 12:15 PM
loco hombre
nater006's Avatar
There are 2 torx screws (sorry, I don't remember which T-size) that hold the cap on. Label and remove the spark plug wires and coil wire from the cap. Remove the torx screws. (one in front, one in back). The cap lifts straight off. The rotor also has 2 torx screws holding it on that should be the same size as the cap ones. It's pretty easy on, easy off.
I'd recommend putting some dielectric grease in the wire boots before hooking them back up to the cap. Putting dielectric grease in the boots for the plugs is also a good move.
nater006 is offline
post #13 of 48 Old 09-06-2007, 08:35 PM
Will work for turbo parts
User is: King_Ice_Flash2 is offline
Send a message via AIM to King_Ice_Flash2 Send a message via MSN to King_Ice_Flash2 Send a message via Yahoo to King_Ice_Flash2
+1 for the PCM Same thing happened to me.
post #14 of 48 Old 09-06-2007, 08:41 PM
chesticles are fun
spaseghost's Avatar
User is: spaseghost is offline
an engine only needs 3 things, and it looks like nater has you on your way with one of the 3. easiest thing to do is check your fuses first. then double check fuel, air, and spark. then go from there and fix what you dont have.
96 ZR2 W, Auto, TB Mod, TES, FM 40, Cat Delete, K&N, HPP3, efan, egr block off, trans go, vette servos. SOLD
85 Chevy C10, 454, th400, 10 bolt open diff, 5%, 4/6 static, alpine, 16.169@84.29 no traction, untuned @ 4800 ft.
03 Mustang, 3.8L, 5spd., cai, duals, underdrives, programmer, sequential blinkers, wifes!
06 Equinox, fixed a/c door, black
Originally Posted by CouJoe56 View Post
i knew a guy at one time tried to go over 100 MPH in an s-10. he woke up the next day, boom. Herpes.
post #15 of 48 Old 09-07-2007, 04:38 PM Thread Starter
future Dr. Curly
Curly's Avatar
Ok guys. I changed the distributor cap and rotor. Didnt fix it.
I checked for a spark from the wire and I got one.
So next thing I am going to look at is if it is a fuel problem. Gonna get some starter fluid late tonight since I have to wait for friends to get off work to ride anywhere...
any other ideas?
Jordan
2001 Blazer Xtreme
Curly is offline
post #16 of 48 Old 09-07-2007, 04:40 PM
Float like a butterfly
dimerunner88's Avatar
User is: dimerunner88 is offline
Send a message via AIM to dimerunner88 Send a message via MSN to dimerunner88
is there gas in the tank?
Tom
1988 S-10 2.8/5-spd - scrapped
1992 k3500 CCLB
2002 blazer 4wd 5spd
post #17 of 48 Old 09-07-2007, 04:45 PM
don't do that screwdriver shit, just get a spark plug and put in the wire, or better yet buy a spark tester like i have and you can check spark while it running.*hooks inline and you see the voltage running through it*
Tom
1992 k3500 CCLB
post #18 of 48 Old 09-07-2007, 05:01 PM
loco hombre
nater006's Avatar
Get your hands on a fuel pressure gauge and stick it on the schraeder valve on the incoming fuel line, under the hood. If it isn't measuring 60ish with the key on, you might be looking at a pump
nater006 is offline
post #19 of 48 Old 09-07-2007, 05:19 PM Thread Starter
future Dr. Curly
Curly's Avatar
Yeah Tom, it has gas. Everyone has asked me that.
But I'm gonna get a hold of someone's fuel pressure gauge.
Jordan
2001 Blazer Xtreme
Curly is offline
post #20 of 48 Old 09-08-2007, 12:09 AM
former owner
98SS's Avatar
Location: north of Motor City ... formerly near Memphis
User is: 98SS is offline
Send a message via AIM to 98SS
Sorry to hear, man. You at school? Good luck fixing it.
- Tim -
1998 S10 LS - stock, lemon - gone
1998 S10 SS - bagged, shaved, etc. - gone
2005 Civic
2010 Equinox
98SS is offline
post #21 of 48 Old 09-08-2007, 12:42 AM
forum idiot
orangesonoma's Avatar
sounds like it is broke pretty bad... sell it to me cheap..
Brian
orangesonoma is offline
post #22 of 48 Old 09-08-2007, 12:12 PM Thread Starter
future Dr. Curly
Curly's Avatar
Thanks man. Yeah I'm at school. Thankfully my roomate has pretty much the same schedule as me, i just have to get up earlier than usual some days to catch a ride.
How about.... I'll trade you.
Jordan
2001 Blazer Xtreme
Curly is offline
post #23 of 48 Old 09-08-2007, 03:25 PM Thread Starter
future Dr. Curly
Curly's Avatar
well, ive narrowed it down to fuel related... sprayed starter fluid into the throttle body and it starts up for a little while...
does anyone know where i can get a cheap fuel pressure gauge
and if its fuel related, is there anything other than fuel pump or fuel filter that could be the problem?
Jordan
2001 Blazer Xtreme
Curly is offline
post #24 of 48 Old 09-08-2007, 04:22 PM
chesticles are fun
spaseghost's Avatar
check napa or the like for a fuel pressure gauge.
you could have a blockage in the line, but its not really all that possible. try your filter first. you can pull it off and blow some compressed air in it and put it back on and check your pressure after that. otherwise, check your pump. you could also have bad injectors too.
post #25 of 48 Old 09-09-2007, 05:11 PM Thread Starter
future Dr. Curly
Curly's Avatar
alright guys... i changed the fuel filter.... still no luck
if fuel pressure checks out fine, what should i look at?
note for those who havent read this whole thread:
so far i have changed the distributor cap and rotor, checked for spark (had one), and changed fuel filter. Spraying stater fluid in the throttle body gets it running for a few seconds.
Jordan
2001 Blazer Xtreme
Curly is offline
post #26 of 48 Old 09-09-2007, 05:52 PM
Measure the resistance of the injectors.
post #27 of 48 Old 09-09-2007, 05:54 PM Thread Starter
future Dr. Curly
Curly's Avatar
How would I go about doing that?
Jordan
2001 Blazer Xtreme
Curly is offline
post #28 of 48 Old 09-09-2007, 07:22 PM
chesticles are fun
spaseghost's Avatar
pull the electrical plug on the injectors and ohm them out.
post #29 of 48 Old 09-12-2007, 02:53 PM Thread Starter
future Dr. Curly
Curly's Avatar
alright guys... i check the fuel pressure.. it was about 10 psi. Do you just turn it to the accesory position and let the fuel pump to kick on to check it?
Also, another thing.... i called to check on the fuel pump. Told them it is a 2dr blazer 2wd. They said they have 2 different ones depending on a code that is on my factory pump. Is there a way I can find out the code without taking the the tank and fuel pump out?
Jordan
2001 Blazer Xtreme
Curly is offline
post #30 of 48 Old 09-12-2007, 03:19 PM
Son of a drag racer
BlueDime's Avatar
User is: BlueDime is offline
Don't quote me on this but isn't the fuel pressure for the newer enignes in the range of 50 psi. I have a 91 2.8 so I'm not sure on that number. I did have a similar problem that was the fuel pump put they usually go out gradually over time. The accesory position only turns on your radio and stuff I belive but if you turn the key to the on position then the pump should turn on for a second to build pressure in the line but if your getting low pressure and the pump turns on then something else is going on.
BlueDime is offline
post #31 of 48 Old 09-12-2007, 03:27 PM Thread Starter
future Dr. Curly
Curly's Avatar
Yeah I hear the pump come on for about 2 seconds and it builds a little pressure. Could the pump just not be pumping enough?
Jordan
2001 Blazer Xtreme
Curly is offline
post #32 of 48 Old 09-12-2007, 03:38 PM
Son of a drag racer
BlueDime's Avatar
It's possible. Electric motors act weird when they die. My fuel pump would get progressively worse over time and thats how they normally go out. If it was a thing where it isn't pumping enough I would check and make sure there isn't a ground problem or put a voltmeter on the wires to it and make sure its getting 12 volts. If that is the case I would have the battery checked out.
edit: If the battery is any older than 4 years I would have it replaced anyway
BlueDime is offline
post #33 of 48 Old 09-12-2007, 03:46 PM Thread Starter
future Dr. Curly
Curly's Avatar
Yeah I had the battery replaced last year. But I'll check the wires before I get into removing the gas tank.
Jordan
2001 Blazer Xtreme
Curly is offline
post #34 of 48 Old 09-12-2007, 05:21 PM
replace the pump
Tom
1992 k3500 CCLB
post #35 of 48 Old 09-12-2007, 05:27 PM Thread Starter
future Dr. Curly
Curly's Avatar
thanks man.
Jordan
2001 Blazer Xtreme
Curly is offline
post #36 of 48 Old 09-12-2007, 06:03 PM
Build them right....Mod
philntx's Avatar
User is: philntx is offline
If your FP was 10 lb, either the pump is bad or the rubber hose from the pump has a hole in it.
Either way, you'll need to drop the tank.
That motor requires 50+lbs to run. The older TBI motors ran on 9-14 lbs of pressure.
philntx is offline
post #37 of 48 Old 09-14-2007, 05:42 PM Thread Starter
future Dr. Curly
Curly's Avatar
well i got the tank dropped and drain (it was completely full, so I am not dealing with putting it back on full )
picking up the pump tomorrow and replacing it then
Jordan
2001 Blazer Xtreme
Curly is offline
post #38 of 48 Old 09-18-2007, 03:54 PM
and then? updates?
Tom
1992 k3500 CCLB
post #39 of 48 Old 09-18-2007, 04:32 PM
Mr. Sparkle
Onimun's Avatar
Yea i agree Prob the fuel pump. Keep us updated
Onimun is offline
post #40 of 48 Old 09-18-2007, 08:23 PM
94noma4.3's Avatar
User is: 94noma4.3 is offline
havin the same problem. i thought it was gonna be the fuel pump. let us no what happens
94' ext. cab Sonoma
Flowmaster exhaust
Alpine CD player, 2 Solo Baric L7 15's, Kicker 1500.1 amp
Police strobes in headlights and taillights
2/4 drop ext. mods soon to come
post #41 of 48 Old 09-18-2007, 11:27 PM Thread Starter
future Dr. Curly
Curly's Avatar
got the fuel pump in... got it running, so the fuel pump was bad
Jordan
2001 Blazer Xtreme
Curly is offline
post #42 of 48 Old 09-19-2007, 01:00 AM
Mr. Sparkle
Onimun's Avatar
glad to hear u got it working man
Onimun is offline
post #43 of 48 Old 09-19-2007, 01:02 AM Thread Starter
future Dr. Curly
Curly's Avatar
oh yeah, im glad too
Jordan
2001 Blazer Xtreme
Curly is offline
post #44 of 48 Old 09-19-2007, 01:51 PM Thread Starter
future Dr. Curly
Curly's Avatar
Son of a.... I just filled the gas tank to full and i have a leak... I guess I did not get a good seal on the pump.
Is it ok for me to drive it until it gets to about a quarter of a tank so that I can drop it again myself, or do I need to get it looked at now? I've driven it for about 5 days so far, just filled it up for the first time (was a little less than full when i got the new fuel pump on), and it leaked for a short period and has stopped now.
I'm sick of this, and I really dont have the time or desire to drop it myself right now in the middle of the week... I would probably be willing to drop it myself this weekend if I could burn some of the fuel off. So I'm debating either taking it to a shop or doing it myself this weekend.
Jordan
2001 Blazer Xtreme
Curly is offline
post #45 of 48 Old 09-19-2007, 02:12 PM
Son of a drag racer
BlueDime's Avatar
Well if its just the seal on the top of the tank then you can drive it around the problem is that you will get the worst gas mileage ever but it won't hurt anything.
BlueDime is offline
post #46 of 48 Old 09-19-2007, 02:35 PM Thread Starter
future Dr. Curly
Curly's Avatar
ok yeah, thats what im gonna do.... im gonna get the tank down to about 1/4 a tank and then take it down and redo the seal, making sure to lubricate it.
Jordan
2001 Blazer Xtreme
Curly is offline
post #47 of 48 Old 09-20-2007, 12:34 AM
99_noma's Avatar
User is: 99_noma is offline
what would you check if your fuel pump didnt even turn on when you turned your key?
ride low n drag hard
99_noma is offline
post #48 of 48 Old 09-20-2007, 01:26 AM
User is: Zygoat is offline
the fuse.
I will suck your daddys taint for 2 bucks. PM me or email me on s10planet for more information.
Zygoat is offline
