Best Brand 4.3 Intake Gaskets????? - S-10 Forum
post #1 of 14 Old 08-21-2006, 08:56 PM Thread Starter
User is: sjzs10 is offline
Question Best Brand 4.3 Intake Gaskets?????
Any info out there re: better than OEM intake gaskets for the infamous 4.3 coolent leak problem.
Hate to replace junk with junk.
Would like to know if there is a premium gasket out there.
Have a 2001 S-10 4.3 2WD.
Local shops want $500-650 for parts and labor. Don't know what gaskets they use.
Thanks
sjzs10 is offline
post #2 of 14 Old 08-21-2006, 09:37 PM
Searching no more
mat1583's Avatar
User is: mat1583 is offline
Send a message via AIM to mat1583
Re: Best Brand 4.3 Intake Gaskets?????
Thanks
Probably some of the best gaskets you could buy for your ride: http://www.raceprovenmotors.com/cart...Path=21_152_67
Victor Reinz Sy/Ty gaskets. You're looking at about $75 for just intake gaskets.
Doin' it the right way
John 16:33
mat1583 is offline
post #3 of 14 Old 08-21-2006, 09:39 PM
Gaaoooooo
MINTSICK's Avatar
User is: MINTSICK is offline
Thanks
That quote is ridiculous even the most amateur mechanic should be able to do an intake gasket job. As far as the gaskets themselves, I have used the OEM gaskets with zero problems but I believe fel-pro makes the gaskets as well.
Mat1583, while I too am a fan of victor reinz gaskets, the ones you linked will not work on 96+ 4.3's with vortec heads.
2004 Silverado Z71 ECSB - |Silver Birch Metallic|5.3|Custom Single Exhaust|Method Standards
1993 Mustang LX Hatchback - |Reef Blue|5.0 H.O.|5 Speed|MGW Short Shifter|70MM MAF|MAC Shorty Headers|Pypes O/R X|Spintech Pro Streets|3.55's|
1984 El Camino Conquista - |Black|5.0L|Comp XE262H|Holley 570|700r4 swap|2.41 open rear|
MINTSICK is offline
post #4 of 14 Old 08-21-2006, 09:40 PM
loco hombre
nater006's Avatar
User is: nater006 is offline
Send a message via AIM to nater006
Honestly, I just bought a Felpro kit from Crapzone or Advanced Auto Crap or Murrays Discount Crap or something like that. It came with the throttle body o-ring/gasket, plenum o-ring/gasket, fuel line o-rings, yadda yadda. All you need to tear it down piece by piece to the intake manifold if you want, though you can leave some of the uppers together to expedite the process. Think they were $37 or something. Under $40 with tax, either way.
Felpro has always seemed to make decent stuff in the past so figured why not?
nater006 is offline
post #5 of 14 Old 08-21-2006, 09:46 PM
loco hombre
nater006's Avatar
Mine started leaking late in the year last year and due to the weather, I called around to see and they wanted like $600-700. Places around here wanted ridiculous money too... $37 worth of gaskets, a can of carb cleaner, $10 worth of Dexcool & distrilled water, $25 worth of Mobil 1 and a filter later, it was worth the 3.5-4 hours of cold fun in early January.
nater006 is offline
post #6 of 14 Old 08-21-2006, 09:49 PM
Gaaoooooo
MINTSICK's Avatar
Originally Posted by nater006
Mine started leaking late in the year last year and due to the weather, I called around to see and they wanted like $600-700. Places around here wanted ridiculous money too... $37 worth of gaskets, a can of carb cleaner, $10 worth of Dexcool & distrilled water, and an oil change later, it was worth the 3.5-4 hours of cold fun in early January.
Oh I am quite familiar with the cold fun repair jobs, best one to date is a head gasket overhaul on a 98 dodge neon I owned for about 6 months. I completed the entire job in January with high temperatures of about 20-25 degrees in a rock driveway with no cover, the last 30% of the job included a somewhat major snowstorm! You could say I despise the cold weather jobs, but compared to what it would cost to have someone do most repairs I'll take the frost bite, busted knuckles, and overall strain and anger of cold weather wrenchin'
Edit: BTW, 1 month after the overhaul I popped the gasket again "pressure testing" my recent repair with 6700rpm powershifts and rev limiter bounces, funnest $1500 car I've owned to date!
MINTSICK is offline
post #7 of 14 Old 08-21-2006, 10:27 PM
Searching no more
mat1583's Avatar
Doh! You're right. That's why I didn't buy them along with the rebuild set. he he. whoops!
John 16:33
mat1583 is offline
post #8 of 14 Old 08-22-2006, 10:28 PM
jerseybud's Avatar
User is: jerseybud is offline
The best intake gaskets for the 1996-2003 4.3 are the:
GM revised gaskets which are green and silver and ~$48
The Fel-Pro Perma-Dry which are ~$100. You have to request Perma-dry at the counter, otherwise they give you the base grade junk.
The base grade Fel-pros are the same design as the original GM gaskets that crack and leak. I put a pair on and guess what? They cracked and leaked. I torqued them properly. No leaks with the GM REVISED intake gaskets. Its worth the extra 10 bucks to not blow your engine.
96 S-10 4x4 ext cab. 14 years and still running...
post #9 of 14 Old 08-23-2006, 12:35 PM
rob8284's Avatar
User is: rob8284 is offline
GM revised gaskets which are green and silver and ~$48...
Agreed! The gaskets are actually made out of aluminum (silver color part). You will most likely never need to replace the intake gaskets again. I did mine before they went.
2000 4.3L Jimmy- Custom FMIC Supercharger system (only 5 psi), 40 Series Flowmaster dual tails, Casper Throttle Enhancer, Custom Throttle Body, GM Zexel Torsen Differential, Taylor 8mm Spiro-Pro Series Plug Wires, Hypertech 180ΒΊ Powerstat, Magnaflow Highflow Cat, MSD 6A Ignition, C.A.T.S. OBDII Tuning Software
Cardomain
Custom Supercharger Thread Best 1/4 Mile: 14.5 @ 94 mph
rob8284 is offline
post #10 of 14 Old 08-23-2006, 07:36 PM
Daily Driver
User is: S10asmyDD is offline
Send a message via AIM to S10asmyDD
I just replaced mine with the fel-pro permadry. IIRC it was like $80.00 for the complete intake set, it also came with valve cover gaskets and the RTV for the valley. Looking at all the gaskets they seem to be very high quality. No plastic crap.
96 S-10 x-cab 4.3 5spd
post #11 of 14 Old 08-23-2006, 07:44 PM
roadlet_411's Avatar
User is: roadlet_411 is offline
Send a message via AIM to roadlet_411
is it just intake gaskets that leak primarily? anyone ever have problems with blowing a head gasket?
-jason
[02:25] <AK49BWL> I'll be damned!
[02:25] <AK49BWL> he's IRC literate to be sure.
Click on the image above to join!
post #12 of 14 Old 08-23-2006, 07:55 PM
User is: captianoats is offline
My 2 cents go to the Fel-Pro perma-dry. Their updated gaskets have all but eliminated the intake issues with this motor. Much better than the original OEM. That's what we recommend to all of our shops at work for these engines, and the rest of the GM intake blunders of the mid to late 90's.
post #13 of 14 Old 08-23-2006, 08:56 PM Thread Starter
Many thanks for all the replys.
Now the truck has not leaked for 3 days. But now that I have said that, it will have a dinner plate size puddle under it again tomorrow!!!
sjzs10 is offline
post #14 of 14 Old 08-29-2006, 08:09 PM Thread Starter
Update.
The next AM after my post on 8-23-06, there was no coolent on the driveway so I thought everything was cool. Tried to start it and it barely started. It skipped and sputtered for about 1-2 minutes. Figured I was really screwed. Assumed it was coolont in a cyl. and found a GM dealer of all places that gave me the best quote.
$480 including the upgraded aluminum gaskets.
So I let them do it. Did not have the time to do it myself.
Runs good now. No drips or coolent odor.
Really suprised me at how quickly it got into the cyl.
What a day.
sjzs10 is offline
