Belt squeak will not stop! - S-10 Forum
post #1 of 23 Old 01-09-2011, 01:09 PM Thread Starter
User is: 249mx is offline
Hi, I am seeing if anyone else has had the same belt squeak problems as I am having. First, I replaced the idler pully because the bearings were shot, then I replaced the belt twice. The first time I replaced it, it stopped squeaking for about a week then started again, so i took it off cleaned the belt with soap and water and hit all of my pullies with an air chuck to get off whatever debris i could... but it continued to squeak. Finally i went to advance got the most expensive belt i could and it stopped the squeak, but now after two weeks it is squeaking again. any advice would be appreciated. thanks! and i also checked all my pullies and they all feel tight??
1999 s-10 LS 4.3l vortec H.O., extra cab short bed, thrush glass pack, intake.
249mx is offline
post #2 of 23 Old 01-09-2011, 02:57 PM
User is: crash55 is offline
Re: Belt squeak will not stop!
squirt some armorall on it
crash55 is offline
post #3 of 23 Old 01-09-2011, 03:01 PM
s-series #2?
greencactus3's Avatar
User is: greencactus3 is offline
is your belt too long?
post #4 of 23 Old 01-09-2011, 03:27 PM
User is: dnasty88 is offline
sounds like faulty belt tensioner
dnasty88 is offline
post #5 of 23 Old 01-09-2011, 04:51 PM
jman85's Avatar
User is: jman85 is offline
quote=dnasty88;7281766]sounds like faulty belt tensioner[/quote]
X2
1985 gmc s15 4x4 high sierra 5 speed 2.8l reg cab short box 3 inch body lift SOLD
1991 gmc jimmy 2 door 4.3l auto 4x4 lifted 2 inches on air SOLD
highly modded 97 dodge diesel 4wd 5 speed fully loaded making 450hp and 28mpg.
93 sle 4wd 4 door jimmy
jman85 is offline
post #6 of 23 Old 01-09-2011, 05:02 PM
superbee's Avatar
User is: superbee is offline
Send a message via AIM to superbee
sounds like it needs a v8
89' S10 blazer 4wd: 355, 650 dp, rpm intake, comp 282 roller cam, modified vortecs, T56 trans, 8.8 ls rear, headers, x-pipe, spintech pro street mufflers, and......AC
94 sunbird-"turbochicken"Turbo 2.0 5spd getrag swap
Tbi heads, intake,timing set, dist for sale
Blazer Video!
superbee is offline
post #7 of 23 Old 01-09-2011, 11:53 PM Thread Starter
the belt tensioner was replaced not too long ago, maybe about a year? I guess i can try that,but like i said when i replace the belt it stops, but its like after it gets used for a little it squeaks again. Thanks for the help
249mx is offline
post #8 of 23 Old 01-09-2011, 11:56 PM Thread Starter
Shouldn't be, i have tried both brands of belts that my truck calls for from advance and they went on there like a normal belt should.
249mx is offline
post #9 of 23 Old 01-10-2011, 11:17 AM
User is: 03 zr2 2010 is offline
had the same problem on a 98 ZR2. Tried everything to stop it. Replace the belt with a GOODYEAR GATORBACK belt and the squeel will stop. Part number for a 4.3 with air is #4060960. Go to Goodyear website and see where they are sold near you.
post #10 of 23 Old 01-10-2011, 11:36 AM
GM
GM's Avatar
User is: GM is offline
Send a message via AIM to GM
^ yea I was going to suggest the gator back as well. I've had good luck with them.
GM is offline
post #11 of 23 Old 01-10-2011, 07:21 PM
Belts DO stretch over time. even a week, they will stretch. The tensioner compensates for this slack. Springs strech over time. If the tensioner spring is weak or stretched, then its time to replace. Theyre relatively cheap and easy, i'd try it, if not bring it back lol.
I had this happen with a 91 cadillac seville, replaced tensioner again, solved issue. come to think of it, same with my dodge ram...
dnasty88 is offline
post #12 of 23 Old 01-11-2011, 02:06 AM
black92 4.3's Avatar
User is: black92 4.3 is offline
mine wont stop squeakin also might try changing the tensioner
1992 4.3 ex cab s10 SOLD.
now 1996 ex cab 4.3. cai, magnaflow with cutout, 33mm front swaybar, hellwig rear sway bar, 2/3 drop , GM roll pan, camaro RS rims, center console shifter, blazer front
1998 trans am bolt ons with cam SOLD
1995 camaro- full exhaust, intake, gears, spray.
post #13 of 23 Old 01-11-2011, 04:29 AM
Toms97dime's Avatar
User is: Toms97dime is offline
check ur ac pully. best thing to do is pinpoint where the sound is coming from. with the vehicle running take a long screwdriver and use it as stethoscope if you dont have one. place it on all pulleys and to the front of your ear to listen to the bearings, if it doesnt sound smooth then theres you problem.
post #14 of 23 Old 01-11-2011, 05:17 AM
i saw what you did there!
fast68chevy's Avatar
we always use a wooden bromstick handle to listne for sounds etc in parts
or anything wooden like that
works great
put right on the ear to hear that exact thing you put the other end on
hear squeaks or bad bearings or pumps or clacking or anything very well
my 4.3L has a pretty bad constant belt dqueal issue that developed very recently
i tried another alternator and tensioner and all that stuff and its no better
just gonna live with it until maybe i get a nice belt ofr it possibly some day maybe
probably not though and it seems to only really do it when its very cold, like right now
post #15 of 23 Old 01-11-2011, 07:30 AM
f150dailydragger's Avatar
User is: f150dailydragger is offline
hold a candle to the one of the pullies or inside of the blet. its worked for me in the past.
post #16 of 23 Old 01-11-2011, 07:32 AM
belt*
post #17 of 23 Old 01-12-2011, 03:45 PM Thread Starter
Thanks for the tips, first I will change the tensioner in the next couple weeks or so when i get time. then if that doesn't solve it i guess i will try the Good Year belt. I will try to let you know how it goes.
249mx is offline
post #18 of 23 Old 01-13-2011, 08:14 AM
User is: stickballer 9 is offline
Re: Engine Squeak
All kidding aside. i had an obnoxious squeal , at first thought it was the altenator pully. lucky for me i had replaced it last summer so it was under warantee so i replaced that.. still squealing. changed the idler pulley... still squealing. installed a new tensioner..... still squealing ... returned the $25 tensioner... so I took off the belt washed it in my slop sink with dish soap and hot water... scrubbed the hell out of it.... let it drip dry..... than scuffed it up with a piece of sandpaper...... put it back on .....SQUEAL WAS GONE....AMAZING... i really thout it was a BS idea to simply wash it but it worked like a charm, I am expecting a gatorback to come in the mail this week.$25 from summit racing but now i might return it because it seems like i wont need it. cant explain how or why it worked but it did.
post #19 of 23 Old 01-13-2011, 10:23 PM Thread Starter
@stickballer9, thanks for the help. i just did it about 2 hours ago and drove about 20 miles and it wasnt squeakin... but i will see if it comes back.
249mx is offline
post #20 of 23 Old 01-14-2011, 12:40 PM
Molon Labe
BudRacing's Avatar
User is: BudRacing is offline
Send a message via AIM to BudRacing
If it goes away after changing or cleaning the belt, then it's the belt and not pulleys or tensioners. Hope that solution worked for you.
If I didn't think it were the belt I would ask what brand of tensioner you used. Sometimes the cheaper brands don't hold up like they should.
post #21 of 23 Old 01-14-2011, 02:25 PM
Truckin'
LeSabreUltra's Avatar
User is: LeSabreUltra is offline
I had the same problem. Replaced my OLD Gatorback belt with what should have been a quality NAPA belt and developed a squeak within a month. Thought it might be the idler so I replaced it. Tensioner was a brand new AC Delco unit. Put a new Gatorback on it and the squeak stopped. I guess our belt systems are a little picky. Sucks that Autozones in many (or all) locations don't carry Gatorback anymore, I had to order mine online.
Personal luxury truck in the making. 4.3 V6, leather, wood, HID projectors, sound, sound dampening and insulation.
Proving that S10s can be a refined ride!
post #22 of 23 Old 01-22-2011, 04:27 PM Thread Starter
well the squeak is back... next im going to replace the tensioner pulley and buying a gatorback after i put that on if it doesnt stop the squeak. If that does not work i have lost hope.
249mx is offline
post #23 of 23 Old 01-22-2011, 04:29 PM
superbee's Avatar
Road flare.
Blazer Video!
superbee is offline
