Air pump help - S-10 Forum
post #1 of 49 Old 05-13-2006, 01:51 AM Thread Starter
User is: RAPTOR_660 is offline
Air pump help
I have a bad secondary air injection system & need to replace it...Where is it located & how difficult is it to replace?
post #2 of 49 Old 05-13-2006, 10:04 AM
04Xtreme's Avatar
User is: 04Xtreme is offline
Send a message via AIM to 04Xtreme
Re: Air pump help
why do you think you have a bad system?
ASE Certified Master Technician
2004 Blazer Xtreme, Indigo Blue
2000 Silverado 2500 6.0 4L80E 2wd
1989 Camaro IROC-Z SOLD
Originally Posted by Jay Leno
It looks good but then so does putting socks down your pants: fine until you have to perform
04Xtreme is offline
post #3 of 49 Old 05-13-2006, 12:10 PM Thread Starter
Re: Air pump help
Hooked it up to a diagnostic & thats what the readout said...I ordered the parts & just looking for a little insight to make the install quicker
post #4 of 49 Old 05-13-2006, 01:52 PM
Upsetta666's Avatar
User is: Upsetta666 is offline
Re: Air pump help
What year?
post #5 of 49 Old 05-13-2006, 01:53 PM
04Xtreme's Avatar
Re: Air pump help
if its 96+,
the pump is behind the front bumper, under the rad support
make sure the check valves at the exhaust manifolds are good as well
and route the fresh air inlet hose for the pump up higher
04Xtreme is offline
post #6 of 49 Old 05-13-2006, 02:02 PM
Upsetta666's Avatar
Re: Air pump help
if its 96+,
There is an updated hose for it, to keep water from entering the system. I'm trying to find the bulletin...
post #7 of 49 Old 05-13-2006, 02:03 PM
Upsetta666's Avatar
Re: Air pump help
Subject:Check Engine Light On, DTC P0410 Set (Replace AIR Pump, Install New Hose Assembly) #04-06-04-015 - (03/22/2004)
Models:1999-2003 Chevrolet Blazer, S10
1999-2001 GMC Jimmy
1999-2003 GMC Sonoma
1999-2001 Oldsmobile Bravada
with 2.2L or 4.3L Engine (VINs 4, H, 5, W -- RPOs LN2, L43, L35)
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1480333&psdid=171&evc=sm#ss1-1480333">Condition
Some owners may comment on the check engine light being illuminated. Upon investigation, the technician may find a DTC P0410 indicating that there is a concern in the secondary air injection system.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1480333&psdid=171&evc=sm#ss2-1480333">Cause
Water may have collected in the AIR pump or the vent solenoid and frozen or corroded the pump.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1480333&psdid=171&evc=sm#ss3-1480333">Correction
Replace the AIR pump and install a new inlet hose and solenoid tube assembly using the following procedure:
  1. <LI type=1>Prep vehicle. <LI type=1>Raise vehicle on hoist. <LI type=1>Remove shield covering AIR pump. <LI type=1>Remove hose and vacuum lines from pump and solenoid. <LI type=1>Remove AIR pump inlet hose. Do not re-use. <LI type=1>Disconnect electrical connectors from pump and solenoid. <LI type=1>Remove pump mounting bolts and pump. <LI type=1>Transfer isolators from the old pump to the new pump. <LI type=1>Install new AIR pump and bolts to vehicle. Tighten
    Tighten the bolts to 17N&#183;m (12.5 lb ft)
    <LI type=1>Route new hose assembly up between engine and fender. It should come up near the area between the battery and the coolant bottle. <LI type=1>Connect new inlet hose to pump inlet. <LI type=1>Connect old outlet hose to pump outlet. <LI type=1>Connect electrical connector to pump. <LI type=1>Connect electrical connector for solenoid to connector on the new hose assembly. <LI type=1>Connect the hose with the white nipple to the vacuum source hose. <LI type=1>Connect the remaining hose to the shut off valve. <LI type=1>Install shield covering AIR pump. <LI type=1>Lower vehicle. <LI type=1>Remove coolant reservoir nut nearest the battery. <LI type=1>Route new hose assembly between the battery and the coolant reservoir with the solenoid on top. <LI type=1>Install the solenoid bracket onto the coolant reservoir stud and reinstall the nut back into the vehicle.
  2. Use a wire tie to keep the new hose assembly away from the engine. On four cylinder engines, tie to the AIR outlet hose. On six cylinder engines, tie to an available hole in the radiator fan shroud.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1480333&psdid=171&evc=sm#ss4-1480333">Parts Information
Part Number
Description
Qty
12590627
Hose Assembly - Secondary Air Injection
1
12568324
Pump, Secondary Air Injection
2001 L35
2000-2003 L43/LN2
1
12560095
1999-2000 L35
1
Parts are currently available from GMSPO.
post #8 of 49 Old 05-13-2006, 04:16 PM
Hey kids!
raider600's Avatar
User is: raider600 is offline
Send a message via AIM to raider600
Re: Air pump help
its like a $300 repair at the dealer. just get rid of its. its gay anyway.
post #9 of 49 Old 05-14-2006, 09:55 AM
Scotty doesn't know
Disco Inferno's Avatar
User is: Disco Inferno is offline
Re: Air pump help
Does anyone know how much the updated hose is? I gotta go to the dealer for some work anyway...
post #10 of 49 Old 05-14-2006, 10:05 AM
V8 Member
the_dubster98's Avatar
User is: the_dubster98 is offline
Send a message via AIM to the_dubster98 Send a message via Yahoo to the_dubster98
Re: Air pump help
when they did mine it was just regular hose... looked like 3/4'' hose and they ran it up near the computer up over everything
post #11 of 49 Old 05-15-2006, 12:27 PM Thread Starter
Re: Air pump help
The updated hose assembly is $49.12
post #12 of 49 Old 05-16-2006, 01:24 PM Thread Starter
Re: Air pump help
Has anyone else had this problem before ? Also,do I leave the wiring connected to the vacuum hose when I install it?And what do I hook the wiring & 2 smaller hoses to?
Do I leave the cap on the end of the hose?
upsetta666-The guy at the dealership gave me the paperwork for installation that you posted...Good looking out though!
post #13 of 49 Old 05-16-2006, 08:24 PM
User is: sdbecker is offline
Re: Air pump help
Since March 2005, I have had the the new hose assembly installed and about six pump replacements, (all at GM expense, thank goodness), and my SES light is still on. The dealership has been told by GM that there is no fix other than a redesigned pump, and there is no definite date for this being available. So, I have been driving around for over a year with the SES light mostly on. This is a 2001 S-10 with 44,000 miles that is in primo condition other than this pump problem. A previous entry in this thread recommended disconnecting the air pump; is this advisable/legal? What happens to me if I want to sell the truck? Can I sell it with the pump disconnected? How much does this problem reduce the market value of the truck? Thanks in advance...
sdbecker is offline
post #14 of 49 Old 05-16-2006, 08:39 PM
ChrisNJ's Avatar
User is: ChrisNJ is offline
Send a message via AIM to ChrisNJ
Re: Air pump help
Mine went south about 15k ago(@70k). replaced w/ new parts and no problems yet **knocks on wood**
2001 4.3 xtreme, auto; K&N FIPK, Bedrug, Second Skin Audio deadener, ecc stepshavers (in progress)..
ChrisNJ is offline
post #15 of 49 Old 05-17-2006, 10:17 AM
"factory freak"...
Crew Cab Sonoma's Avatar
Re: Air pump help
lots of people have problems with the air pump system on these trucks, including mine. often repatedly. i think the air intake tube should have some kind of filter on it.
it doesnt hurt the driveability or normal operation of the truck to leave it disabled, or removed and plugged, with the exception of the SES light being on.
you could have the PCM re-flashed to eliminate the air pump codes.
95 S-10 2.2. Soon to be DD
post #16 of 49 Old 05-17-2006, 01:27 PM Thread Starter
Re: Air pump help
Install tips? Anyone?
post #17 of 49 Old 05-17-2006, 07:44 PM
User is: JJmiller1 is offline
Re: Air pump help
Make sure you've got enough patience saved for those 2 check valves is all I'll say. I don't see a 30 amp maxi fuse in the pic though, you may or may not need it but it's located in a little black box between your battery and fender. disconnecting your battery for a couple hours might clear the SES, a scan tool will do it right away. The rest is easy.
Oh, I'm on my 4th pump with my 2001.
JJ
post #18 of 49 Old 06-04-2006, 07:38 PM
It WAS a Blazer
Lenny95NeoN's Avatar
User is: Lenny95NeoN is offline
Re: Air pump help
I had a problem with mine. I had to replace the check valve on the pass. side. When it went it let exhaust burn up the lil rubber elbow, the T fitting where the two sides connect, and almost some under-hood wiring.
It was a P.I.T.A. I had to remove the whole tube from the exhaust manifold. and go through several heating/cooling cycles with the blow torch, and penetrating lubricant. (iIam a pyro-maniac) But after I got it all done. I reset the s.e.s, and all has been well with it since.
1st ever time slip (in the Blazer) = 15.998 @ 85.46MPH...
Faster than my buddies sport compact that day
Driving like that is how I broke the tranny, and rear end(s)
M & G Customs <---Click here
post #19 of 49 Old 06-04-2006, 07:44 PM
V8 Member
Re: Air pump help
anybody know why the unit will set the light off for a few hundred miles then back off then back on ... inside maybe dirty or something.. would gas effect the units performance you think? seems to come on when ever i use a tank of "cheap" gas... like from cumberland farms/getty
post #20 of 49 Old 08-28-2006, 09:48 PM
User is: Paul71LT1 is offline
Question Re: Air pump help
I keep reading about bad air pumps and some about check valves and vacuum relays. What is the "failure" mode of the pump? I have the SES light on and a P0410 code on OBD II so I pulled the pump out and took it apart. There is no corrosion or damage of any kind. I hooked up a couple jumper wires to the motor and it purrs like a kitten. I will not buy a new pump when this one works just fine. I need to get the vacuum valve out next and check it for a ruptured diaphram, but it's pouring outside today and I'm not going to deal with that.
post #21 of 49 Old 08-29-2006, 09:22 AM
"factory freak"...
Re: Air pump help
not sure what you mean by "failure" mode of the pump... but a pump failure will be noted by the PCM, and a code will be set, otherwise, its buisness as usual, as far as the PCM is concerned... the engine doesnt run in any kind of "default" mode, if thats what you mean.
post #22 of 49 Old 10-09-2008, 03:53 PM
S10 Newb
drizhosszle's Avatar
User is: drizhosszle is offline
Re: Air pump help
Dang, I was told that it would cost about $410 without labor. I have an 02 s10 and they said that the 'kit' for it would, alone, cost $410.
I don't have to get mine replaced until my next emissions.... cause you need it to pass the emissions test. And yes....it is beyond gay.
post #23 of 49 Old 10-10-2008, 08:58 AM
diesel music's Avatar
User is: diesel music is offline
Re: Air pump help
Had mine done at a local shop. Total cost with a new from NAPA not rebuilt pump and a 30 amp fuse installed, $150.00.
post #24 of 49 Old 10-10-2008, 12:22 PM
No More SS
SmokeeJay's Avatar
User is: SmokeeJay is offline
Re: Air pump help
I had this problem on my 01 Blazer. Ordered a new pump off ebay for around $100.00. Before I put in the new pump, I pulled the fuse from behind the battery in the passengers side fender, 30 amp, and found that it was blown. Replaced the fuse and sold the pump on ebay. Moral to the story, check the fuse! Cheap fix. You should probably also take the pump off and clean it really well as well as spray some WD40 on it to keep water from penetrating causing the fuse to blow.
post #25 of 49 Old 12-29-2008, 10:15 PM
I dont do bolt ons
snakenet's Avatar
User is: snakenet is offline
Re: Air pump help
im gettin codes about my pump as well. mine is a 03 4cyl.
question: that little black valve under the wiper motor, is that my egr valve? or is it a manifold check valve? mines all clogged and wasnt workin right, so i pulled the valve off and used a brass plug where it was and the truck runs great now. but i have an inspection coming up and i need to pass, but when i put that thing back in the truck runs like poop...
~ 2004 Silverado - Kp6link with watts, ART LCA/UCA, HE and SS bags,3AZOB1s, Stealth valves, black with blue flames with lots of powdercoated flat black, and Panther juice 6 22s
- Gary 'Numatik' Eberle
InDePeNdEnT
snakenet is offline
post #26 of 49 Old 12-29-2008, 10:46 PM
User is: bose301s is offline
Re: Air pump help
Why did GM design this so poorly, it seems everyone is having this problem.
System:
Sub: Dayton Audio HO12 DVC Sub Amp: Vibe Audio LiteBox1 4ch Amp: Vibe Audio LiteBox4 H/U: Kenwood eXcelon KDC-X794 Front Comps: Rainbow Germanium Processor: Zapco DSP6-SL
bose301s is offline
post #27 of 49 Old 04-24-2009, 11:01 PM
JPM
User is: JPM is offline
Re: Air pump help
No wonder they are going to file bank-rupt. They need to stand by their product.Especially one as this
JPM is offline
post #28 of 49 Old 04-25-2009, 12:29 AM
abryant's Avatar
User is: abryant is offline
Re: Air pump help
hey if ya need a new one i have the whole system sitting in my gargage ripped it out of my truck for the procharger. i'll let ya have it cheap
2001 s10 4.3 ext cab 4/5 drop msd digital 6l cold air intake Mach under drive pulleys port and polished throttle body with blade mod flex lite e fans tb spacer transgo shift kit wait4me tune 3in borla X1 exhaust
abryant is offline
post #29 of 49 Old 04-27-2009, 05:52 PM
User is: MICHAEL J FROST is offline
Re: Air pump help
How much?
post #30 of 49 Old 04-27-2009, 06:10 PM
abryant's Avatar
Re: Air pump help
what they go for new 400 lets say 100 pluse shipping
abryant is offline
post #31 of 49 Old 09-07-2009, 06:19 PM
User is: mnygren is offline
Re: Air pump help- ODB Sensors
a quick question. I have a 2001 s10 that has the air pump blown. I've taken it off and confirmed it doesn't spin. Does anyone know what would happen if don't reinstall it and have the ODB reset? Does the odb monitor for some time of resistance or circuit closure? Can I throw some type of resistor coil on there and fool the ODB? What about the solenoid? Thanks for this great website and I appreciate any assistance at all.
Mike
mnygren is offline
post #32 of 49 Old 02-01-2010, 10:49 AM
muc
User is: muc is offline
Re: Air pump help
Do you still have that pump, and are the hoses with it?
muc is offline
post #33 of 49 Old 02-01-2010, 11:55 PM
Re: Air pump help
no, got a new one from Murray's ($100) and tossed the old one. Tried taking it apart for curiosity and destroyed it in anger....
mnygren is offline
post #34 of 49 Old 02-02-2010, 12:00 AM
terrible. take a lap.
joyride's Avatar
User is: joyride is offline
Send a message via AIM to joyride
Re: Air pump help
i have mine still and im bout to have my tuned computer back any day now, and when i do my motor swap ill have my air pump code taken off therefore i don't need my air pump....it throws a code right now but it's done it before...i took it apart and dried it out and the SES light went away...currently its throwing a code for the pump because i broke a hose to it but im sure it can be fixed...when i take it off and look at it, ill sell it to someone if its reusable....just might have to wait a month or so because im not sure when ill finally get down to swapping my motor in...
Brian
01 xtreme 4.3L 5spd 2/3 drop w/ SS front bumper|.030 over|270 comp cam|500 lift|dual valve springs|10:1 C/R|p&p heads w/ 3 angle valve job|w4me tune|shorty headers|2.25 y pipe|no cat|Spintech muffler|windage tray|LW flywheel|DF clutch|8mm wires|no ac|efan|walbro 255|MPFI upgrade|Comp Cam timing chain|ARP bolts/studs|totaled***
Now owner of a white 2002 Blazer Xtreme
http://www.youtube.com/watch?v=CO_A1IrbQNM
85 Monte Carlo SS
KCCO
joyride is offline
post #35 of 49 Old 02-16-2010, 06:19 PM
User is: Bradical46 is offline
Re: Air pump help
my 2001 s10 throws the code air induction malfunction. does that mean i need a new air pump. is that why my truck takes a while to start?
post #36 of 49 Old 02-16-2010, 06:20 PM
Re: Air pump help
is this the reason why my truck has a rough start up?
post #37 of 49 Old 02-16-2010, 07:02 PM
joyride's Avatar
Re: Air pump help
no, my truck runs fine with the code on. and always has
maybe you need a tune up??
Brian
85 Monte Carlo SS
KCCO
joyride is offline
post #38 of 49 Old 07-15-2010, 04:37 AM
User is: Silentbob538 is offline
Re: Air pump help
How can I get rid of it, and erase it off the computer permanently?
'91 4.3L 4x4 s-10 Blazer Sport
'87 K-5 Blazer: 4X4 with a 4" suspention lift. 1" inch body lift. Sittin on 35's.
post #39 of 49 Old 07-15-2010, 12:45 PM
joyride's Avatar
Re: Air pump help
wait4meperformance.com
you'd have to call them though to get your computer tuned.
if you can afford the downtime of not having your truck for roughly a week, then send yours in...or just buy on of theirs they tune for you, for 160.
Brian
85 Monte Carlo SS
KCCO
joyride is offline
post #40 of 49 Old 08-18-2010, 02:10 PM
capetish's Avatar
User is: capetish is offline
Re: Air pump help
I just replaced pump on my2001 v6 s10.Got the kit for $400.
includes pump new hose harness and solenoid
Took me about hour to remove old one and replace new on and i am not the fastest as this was my first one
When finished had to replace oxygen sensor sen1 bank 1
All went well
Sensor coast $130.I got away luckey
No prob.
Lot of good info on this site that is where i got my help.
Have a great day all (got parts from A C Delco)
capetish
capetish is offline
post #41 of 49 Old 08-19-2010, 02:46 AM
"factory freak"...
Re: Air pump help
the problem with replacing the pump is, eventually,
youre gonna have to do it again...
deletion/reflash is by far the best solution.
its cheaper, and only has to be done once.
plus, with the reflash, you can get the added
benefit of better fuel economy too...
post #42 of 49 Old 05-24-2011, 04:11 PM
User is: Truckowner is offline
Re: Air pump help
I was just under my truck working on something else and noticed one of the hoses from my AIR pump goes up to nowhere and is connected to nothing on the other end. It's about a foot and a half long. I get the impression from reading other posts that that's normal???
Also my engine has developed a rattling sound that sounds just like a diesel engine. Quite loud. Anybody have an idea what that could be. Sounds a bit like the sound a 350 makes when the lifters are out of adjustment.
post #43 of 49 Old 07-16-2011, 05:25 PM
User is: lowdime01 is offline
Re: Air pump help
I have been having a problem with my pump too, i just ordered a new one for $82. I took my old one out and it looks beat, I dont think it will hurt to drive around without it for a week or so.
post #44 of 49 Old 10-04-2011, 12:57 AM
User is: coyote_Jon is offline
Re: Air pump help
Hello everyone cool forum.... My pump quit working so I've been searching this forum ad learning about all the fixes for this.... So first I replaced the 30 amp maxi fuse and the check engine light went off immediately and the pumped worked for a few miles and then the fuse blew again.... So I took the pump out and apart and it had water in it... I cleaned it out and the pumped purred like a kitten so I put it back together and it keeps blowing fuses.... Could it be the solenoid? And is the solenoid that little thing mounted up between the pump and the bumper?
post #45 of 49 Old 10-04-2011, 01:08 AM
Re: Air pump help
Btw it's a 2000 2.2 litre manual 5 speed.... Don't know I it matters.... Thanx
post #46 of 49 Old 02-23-2012, 06:13 PM
User is: butthead is offline
Re: Air pump help
where can one get the chip - did it work - I have a 2001 v6 s10 with the air pump codes- and have not found the 30 amp fuse could use some info - thanks for any help
butthead is offline
post #47 of 49 Old 03-27-2012, 07:23 PM
User is: splintnote is offline
Re: Air pump help
Your gonna have to take out the battery to get to the fuse.
post #48 of 49 Old 03-27-2012, 07:25 PM
Re: Air pump help
Anyone else experience this po410 code along with a po440 code together?
post #49 of 49 Old 10-31-2012, 02:13 AM
User is: bryanhaas314 is offline
Re: Air pump help
  • I having issues with a 2000 2.2l 4 banger....yes of course the air pump. Whomever did the work before may not have done things right. Im in serious need of the wiring diagram for the vacum solenoid located on the pump bracket because it was previously missing and I have spliced the wires onto another connector donated from a washer pump motor. Perfect fit. But unsure of the hot side of the solenoid. Also if anyone can tell me which hose goes onto the inlet and outlet side of the pump would be awesome. Currently there is a hose running from the manifold over the engine into the inlet port of the pump. As of today no air was passing through the hose but the other day it was blowing fine. The outlet of the pump is blowing strong through a hose that snakes up by the battery leading to nowhere. Not sure which hoses go where and if the check valves are playing a culprit. Cleared the codes after fixing the broken connection and no light came on for 4 days. I read the ohms on the solenoid with no wires attached and it read 35 the first time moved around it hir in the 50s but rested in the 35 area after the 3rd try. PLEASE help with wiring and hose diagram.
