A/C ORIFICE TUBE LOCATION. please help!! - S-10 Forum
Old 04-22-2008, 11:34 AM   #1
Exclamation A/C ORIFICE TUBE LOCATION. please help!!
I'm at school right now doing my a/c lab, and I wanted to replace my orifice tube, but it's not where I thought it would be. I thought it would be near the condenser under the battery tray. It's a 96 GMC Sonoma, X engine, 4x4.
PLEASE HELP!
Old 04-22-2008, 11:34 AM   #2
Re: A/C ORIFICE TUBE LOCATION. please help!!
Mitchell on demand has been no help, also....
Old 04-22-2008, 11:43 AM   #3
Registered (Ab) User
Yogi's Avatar
My '98 only has 2 joints in the HP line. 1 under the battery and 1 at the condenser inlet. Got to be one of the 2. I would've expected under the battery too. If it's not there then it has to be at the condenser inlet.
Good luck!
Old 04-22-2008, 11:44 AM   #4
it's not in either of the two lines coming from the condenser, and I just found it's in the evaporator....
Old 04-22-2008, 11:48 AM   #5
Yogi's Avatar
HOLY COW! I meant to say evap. and put cond. instead. So sorry! Hope I didn't cause you any extra work.
Old 04-22-2008, 01:05 PM   #6
it's cool, man, the condenser was where I looked first. But now I know it's at the evaporater.... still a PITA
Old 04-22-2008, 01:09 PM   #7
Yogi's Avatar
That's good!
Good luck in school!
Old 04-22-2008, 10:19 PM   #8
Molon Labe
BudRacing's Avatar
Where is the evaporator? Is it behind the black plastic under the hood? Or is it behind the dash. I'm going to replace my orifice tube when I rebuild my A/C and would like to know where it is beforehand.
Old 04-22-2008, 11:46 PM   #9
Yogi's Avatar
It's behind the black plastic. Got that aluminum cylinder (accumulator - drier) hanging off of it.
Old 04-23-2008, 12:25 AM   #10
Molon Labe
BudRacing's Avatar
So do I have to remove the black plastic?
Old 04-23-2008, 09:53 AM   #11
Yogi's Avatar
No. The orifice tube is located in the high pressure line where the line enters the evaporator.
There are 2 tubes on the evap.: a 3/4" line at the top with the aluminum cylinder (accumulator - drier), and a 3/8" line at the bottom. The orifice tube is located in the 3/8" line at the tubing joint where it enters the evap.
Be sure to replace the accumulator - drier anytime you open the system too.
Old 04-23-2008, 10:04 AM   #12
Molon Labe
BudRacing's Avatar
Got it, thanks. I actually ordered those parts last weekend and they should be here today (including a new drier). A replacement orifice tube was only $2.
Old 04-23-2008, 10:06 AM   #13
Molon Labe
BudRacing's Avatar
Is that it^^? Where the brass fitting is going into the black plastic?
Old 04-23-2008, 10:12 AM   #14
Yogi's Avatar
Yes, that's it. Not very accessible, huh! Good luck on getting it out!
Old 06-08-2008, 12:18 PM   #15
AwesomeO's Avatar
what size are the bolts to get it apart?
Old 06-08-2008, 12:22 PM   #16
Outlaws's Avatar
All the GMs I have seen with that are 32mm and.......I want to say 24mm.
Old 06-08-2008, 12:27 PM   #17
AwesomeO's Avatar
Thanks
Old 06-08-2008, 10:11 PM   #18
Molon Labe
BudRacing's Avatar
Yeah, that sounds right. To get the orifice tube out take a pair of needle nosed pliers and stick it in there, pinch, and pull out.
Old 06-08-2008, 10:19 PM   #19
Works too much!
laydout97's Avatar
heres a tip, take the drier off of the evaporator. you will have more working room. also if its too hard to get both wrenches in there, you can use a 6in. cresent wrench. I had to change them on a 96 blazer and a 98 s10 both 4.3s
Old 06-08-2008, 11:35 PM   #20
Molon Labe
BudRacing's Avatar
While room was limited.. I didn't really have a problem getting a 10" crescent wrench down there with enough room to break it loose.
Old 06-09-2008, 12:20 AM   #21
AwesomeO's Avatar
thanks..im going to take it out one day this week.
