97 s10 wont crank
Old 08-21-2008, 08:53 PM   #1
Flat Out Fabricator
MiniTuckin''s Avatar
MiniTuckin' is on a distinguished road
97 s10 wont crank
Hey guys just installed my a/c bypass pulley and i'm getting fire and fuel just wont crank. You can spray some starting fluid and it fires right up like nothing is wrong. Am i missing a wire or somethin? Or is my spider fukked?
Old 08-21-2008, 10:10 PM   #2
You got 30 minutes?
laydout97's Avatar
laydout97 is on a distinguished road
Re: 97 s10 wont crank
if it is starting off starting fluid, then you don't have sufficient fuel. Check fuel pressure.
Old 08-21-2008, 10:50 PM   #3
MikeInCtown is on a distinguished road
FYI, when you say it won't crank, that means the starter won't turn the engine. From the sound of your post, it is cranking fine. You need to check the fuel system for proper pressure before anything else as the engine will run at lower pressures than it takes to start it.
Unfortunately I had this problem on Monday. Hadn't used the truck in 5 days. Went to start it and no fire. Sprayed starting fluid and perfect start that day and every start until last night when I get no crank at all.
Now that I think about it, I'd better check the ground for the battery and engine.
Page generated in 0.08979 seconds with 11 queries
