95 4.3 back fire - S-10 Forum
post #1 of 8 Old 04-19-2017, 04:01 PM Thread Starter
User is: 954.3 is offline
95 4.3 back fire
I have a 95 blazer with a 4.3.
It ran fine but had a tapping sound. I found a rocker arm that wasn't lubing very good so I pulled it out and cleaned it, the oil hole was almost plugged. So I pulled all of them off and cleaned all the rockers and push rods, none of the others were plugged.
I put them all back together and tightened the lifter adjustment nut down until it bottomed out, run out of threads.
Is that what you do with positive stop adjustments?
I've never adjusted positive stop before, but from what I've been told that sounds like how to adjust them.
Anyway, now it won't start back up. It turns over fine but won't start.
It will backfire loud out the intake once in a while, but that's all. Doesn't even act like it is trying to fire off other than the backfire.
I hope someone can help me figure this out.
I do appreciate the help very much.
Thank you all
954.3 is offline
post #2 of 8 Old 04-19-2017, 04:47 PM
User is: ala_frosty is offline
Re: 95 4.3 back fire
Triple-check check that you've got the spark plug wires all back on their correct positions and that the coil is firmly connected to the distributor properly.
post #3 of 8 Old 04-19-2017, 05:11 PM Thread Starter
Thanks ala_frosty,
I never did unhook the distributor wires from the plugs or the distributor.
There still the same as they were when it ran fine before taking the rocker arms off. Other than the ticking it ran fine before I took the rocker arms off and cleaned them. It's really got me puzzled.
Am I adjusting the valves right?
I just tightened the nut down untill it bottomed out in the threads. Positive stop head. It's got the studs that screw in and have a bolt head for a socket down on the head.
954.3 is offline
post #4 of 8 Old 04-20-2017, 12:56 AM
oldeerslayer's Avatar
User is: oldeerslayer is online now
Is it possible that some of the push rods weren't centered correctly on the lifters when you put the rockers back on? I'd pull them and make sure none are bent.
The more I think about this, the more I think Frosty is on the right track. Did you do both sides and not disconnect anything electrical?
post #5 of 8 Old 04-20-2017, 01:08 AM
AWD V8's Avatar
User is: AWD V8 is offline
I don't know what year the engines changed rocker arm design, what do your rockers look like?
These you tighten right down, like a bolt.
These must be tightened a certain amount while the crankshaft is in the correct position. These are easy to mess up the adjustment.
Popping through the throttle body means an intake valve is not closing (bad adjustment), or that a cylinder is firing while an intake valve is open (Wrong firing order).
It is possible that a push rod wasn't centered in the lifter, that could bend the push rod, possibly bend a valve from opening it too far, but usually the push rod just slips into the lifter when the engine rotates and then the adjustment is too loose.
Check the firing order first, that's easy.
Let us know what style of rocker arms you have.
Then a compression check or pull the valve covers off, your choice. A compression test will tell you if you have a bent valve. Pulling the rockers again to check the valve assembly/adjustment.
Usually backfiring is simply a bad valve adjustment or firing order. Usually no harm done.
AWD V8 is offline
post #6 of 8 Old 04-20-2017, 09:26 PM Thread Starter
Thanks everyone for all the help.
I think I know what is wrong, but it will be a couple days before I get time to try it. I'll let you know how it goes.
What I think is wrong is that the heads I have are not bottom stoppers. They are screw in studs but don't have the ledge on the stud for the rocker to bottom out on. So I got to readjust the lifters and try it.
They have the lifters like the bottom picture in AWD V8's post above, but I guess some of the 4.3's have that type of lifter with a ledge on the stud for bottom stop and some don't have the bottom stop, so you have to set them by doing the tdc approach.
But neither one had the lifters in the top picture in AWD V8's pictures above.
I found it out by looking at another 4.3 I have and it has the same looking rocker but has the ledge for the bottom stop.
The nut just tightens down until it stops plus 20lbs.
I'll let you know what I find out .
Thanks again.
954.3 is offline
post #7 of 8 Old 04-21-2017, 07:58 AM
If you have the lifters in the bottom picture that AWD posted, those are the venerable 1955-1995 plain old Chevy rocker arms. You have to do the traditional take out the slack +1 turn on each rocker using the TDC method. Personnaly I prefer to do them one cylinder at a time by adjusting one valve when it's opposite valve is open.
If you bottomed all them out thinking they were the newer style shown in the top picture, you need to pull and look at each pushrod to be sure they didn't get bent.
post #8 of 8 Old 04-21-2017, 11:41 AM Thread Starter
Thanks for the help oldeerslayer,
I pulled the push rods and they were all bent. so I got to replace all of them and hope it didn't bend any valves. It doesn't look like it watching them go up and down, but we'll see how it runs.
Thanks again everyone for the help. I'll get back with you in a couple days to let you know if that was the problem.
954.3 is offline
