94 4.3 vortec cranks but wont fire... - S-10 Forum
post #1 of 7 Old 02-04-2010, 03:21 PM Thread Starter
User is: Tompoirier6 is offline
yesterday my truck just out of no where died on me in when i was at a red light. thought it was out of gas so we rolled it down to a station and put some in it... nothing still wont fire. then we checked to see if there was spark and there was none. i have heard that pre 96 4.3 motors dont have a Crankshaft Position Sensor. is the correct? my next move was going to look into the distributor and cap. anything else i should look into?
post #2 of 7 Old 02-04-2010, 08:43 PM
Noob
496 BB's Avatar
User is: 496 BB is offline
Re: 94 4.3 vortec cranks but wont fire...
No CPS. That was for DIS motors. See if you got power to the coil. and dist.
Could be numerous things. How many miles on it? I take it you have fuel pressure also? How did you check for spark?
496 BB is offline
post #3 of 7 Old 02-04-2010, 09:09 PM
Bill Wheats's Avatar
User is: Bill Wheats is offline
Check for spark on the coil spark plug wire.
If you have spark there but not at the plugs; suspect need for new cap and rotor.
If no spark have the ignition modual checked....
Some people are like slinkies - not really good for much.
But they bring a smile to your face when pushed down the stairs.
post #4 of 7 Old 02-18-2010, 02:49 PM
User is: 5spd94red is offline
yeah, check ign modual....
post #5 of 7 Old 02-19-2010, 07:43 PM
Cletus83's Avatar
User is: Cletus83 is offline
if u turn the key on and the lights on the dash dont come on but the engine turns over its the ignition switch not the key switch i had a 95 s10 4.3 4x4 manual trans that that happened to carried it to 2 different mechanics before they figured out what was wrong cost about 300 bucks back in 03 to fix it i think it had about a 140,000 on it when it went
Cletus83 is offline
post #6 of 7 Old 02-21-2010, 02:36 AM
Ω Master Jedi Ω
Sound Barrier's Avatar
User is: Sound Barrier is offline
very well could be the pick-up coil inside the distributor, had same issue a year or so ago
post #7 of 7 Old 03-03-2010, 10:50 AM
User is: biomed86 is offline
I had similar problem on my 93 Jimmy, the problem was ignition module, I had spark, gas, but not fire.
In these models, that modul acts as crank sensor, no crank signal came to ecm, no signal from ecm to cpi !!
about $70 for that part !
biomed86 is offline
