94 4.3 died need help!!!
Old 06-27-2008, 07:42 PM   #1
< EST 1989....>
Project"Bag&Drag" is on a distinguished road
well my 4.3 just died on me today. and i havent had time to check spark on it, but i think it might be my spiders, b/c it died right when i parked it and aired out then i went to go start it and nothing.
Just cranks and cranks. but i didnt smell fuel and i physically felt under the injectors and they were dry.
I noticed that i poped the 25amp power/ acc. fuse, does this control the PCM at all??
cause i aired it up and it seems that i rubbed though some wires on my passenger side harness. i taped them all up and then tried to start it and nothing.
I also tryed putting some gas in the throttle to get it to pop at least, and nothing. I am going to test the spark on it tommarrow
Anyone have any ideas??
Old 06-27-2008, 07:57 PM   #2
TCossuto is an unknown quantity at this point
Re: 94 4.3 died need help!!!
test the spark and fix the wires.
Old 06-28-2008, 11:44 AM   #3
Registered (Ab) User
Yogi's Avatar
Yogi is on a distinguished road
X2
Old 06-28-2008, 04:56 PM   #4
< EST 1989....>
ok well i checked the spark today, and thires none, and checked the module on the dizzy and it was good, the cap,rotor, and the coil was replaced today.
But what gets me is that i tested to see if theirs power to the coil,and their is, i got power from all of them. all 4, the two red and white wires to the coil and then the red and white ones from the coil to the dizzy, i also noticed when i crank on it the injectors dont spray, and then when i plugged the dizz module back in they sprayed fine, only when i plugged the connection back.
Im soo puzzled right now
Old 06-28-2008, 09:41 PM   #5
Bill Wheats's Avatar
Bill Wheats is on a distinguished road
The PCM get a signal from the coils, then gives a pulsing neg voltage to the injectors to turn on.
Old 06-29-2008, 11:32 PM   #6
< EST 1989....>
So my pcm is shot?
Old 06-30-2008, 12:03 AM   #7
Why would you think that the PCM is shot?
If I read what you meant correctly, then when you disconnected the wires going to your dizzy: the injectors didn't fire - they shouldn't.
With the dizzy wires connected then the PCM sees the signal and fires your injectors.
What more could you want?
What circuit blew the fuse?
Did you test and get spark when the dizzy was connected?
Old 06-30-2008, 11:44 AM   #8
< EST 1989....>
I dont know what circut blew the fuse, it was the #7 fuse a 25amp and on the pannel it says its a power aux/ fuse?? and i didnt get spark anywhere from the coil to the dizzy at all, but i have power to the coil
Old 06-30-2008, 11:47 AM   #9
Did you try to get spark from the coil wire going to the dizzy cap yet?
Old 06-30-2008, 11:51 AM   #10
< EST 1989....>
no their is no spark any where in the system
Old 06-30-2008, 11:52 AM   #11
< EST 1989....>
yes, their is no spark
Old 06-30-2008, 11:54 AM   #12
Double post
Old 06-30-2008, 12:00 PM   #13
< EST 1989....>
so any ideas bill?
Old 06-30-2008, 12:14 PM   #14
? If you have a MAF sensor disconnect it and try again.
Pull the module and make sure that it isn't shorting out. Have it tested.
Sorry but I'm on the road...
Old 06-30-2008, 02:15 PM   #15
< EST 1989....>
the module under the dizzy, if thats the case i already had it tested it passed
Old 06-30-2008, 02:39 PM   #16
Some of the modules need to go through the tester 5 or 6 times before they show bad.
Old 06-30-2008, 02:47 PM   #17
Yogi's Avatar
I would try taking the ICM to another store to be retested - just to be sure.
Old 06-30-2008, 05:19 PM   #18
< EST 1989....>
Ok will do, or should I just get a new one
Old 06-30-2008, 07:06 PM   #19
Yogi's Avatar
No, don't do that. Just get a second opinion and go from there.
Did you replace the blown fuse? If so, is the new fuse OK?
Check your grounds. The ignition system feeds a constant 12 v. pos. to the system whenever the key is on. It makes the coil spark by connecting and disconnecting the ground side of the circuit. So you could have +12v. but no negative to complete the circuit.
Old 06-30-2008, 09:08 PM   #20
< EST 1989....>
So that means the white wire would be the ground in this case on the coil.
And the new fuse is good. I just am wondering what made the fuse blow. And what it runs/protects.
And I appreciate all the help I'm getting with my problem. This is why I love this fourm!
Old 06-30-2008, 11:00 PM   #21
The white wire from the coil is the trip (sensor) wire to the PCM that tells it to send the negitve voltage pulses to the injectors so that they will fire.
Old 07-01-2008, 02:21 PM   #22
< EST 1989....>
well i went and tested the module again, several times and it show to be good. i havent had time to check to see if the white ground wire has a good ground, but ill get to it tommarrow
Old 07-01-2008, 02:28 PM   #23
Yogi's Avatar
OK, the white wire is not a continuous ground. The pcm only grounds it when it is time to fire the coil. Check the ground strap on the back of the motor and the ground on the pcm.
Old 07-01-2008, 06:40 PM   #24
< EST 1989....>
Ok will do, what color wire is the PCM ground, and is the power for it a pink w/ black line?
Old 07-01-2008, 07:37 PM   #25
Yogi's Avatar
I'll have to see if I can find a wiring diagram. Is it CPI or TBI?
Old 07-01-2008, 09:10 PM   #26
Yogi's Avatar
Click here for a wiring diagram of a CPI motor. Go to diagram #6 for the pcm.
Old 07-01-2008, 09:27 PM   #27
sparks383iroc's Avatar
sparks383iroc is on a distinguished road
Um, possibly the pickup coil in the distributor is bad.
Old 07-01-2008, 11:36 PM   #28
That would be my first guess.
Old 07-02-2008, 10:30 AM   #29
< EST 1989....>
Ok I was told that yesterday also. I heard that its pretty hard to do also. Btw its TBI.
Old 07-02-2008, 10:57 AM   #30
You can test it with a meter. It will open and close as the dizzy turns. It basically is taking the place of points that were used in older ignition systems.
Old 07-02-2008, 11:35 AM   #31
Yogi's Avatar
I couldn't get the wiring diagram for the TBI. Sorry.
Old 07-03-2008, 06:08 PM   #32
Not a real hard job if you have pulled a distributor before. Haynes has a step by step on how to test it and how to replace. It is usually a wire that has been rubbed bare and grounded out that causes it to go bad. If I can find my pictures (and get them posted) I'll show you the wire.
Old 07-03-2008, 06:38 PM   #33
Ok, let's see if this will work.
Sorry it's so blurry, I did it with an old LowRes camera phone. If you look at the last picture, you can make out where the green wire is worn through. You can do a quick visual check to see if this has happened by pulling the cap, this wire goes from the PU coil to the Ignition Module
Old 07-10-2008, 11:24 AM   #34
< EST 1989....>
well i fixed it, i went with my gut felling and replaced the PCM, and guess what it started right up!! thanxs for all the help!!
Old 07-10-2008, 11:35 AM   #35
Yogi's Avatar
Any problems with the install? Where did you get it?
Congrats!!
