93 dime 4.3 tbi wont start
Old 08-21-2008, 11:33 PM   #1
fah-q is on a distinguished road
i have a 1993 4.3L tbi dime..it has 170,000 miles on it and it has always ran fine other then it idles a lil rough.....i went to my friends house the other night and hung out for a few hours....when i came out to leave the truck would not start...it would crank but didnt even act like it wanted to start i could not smell any gas so i dont think the truck was flooded....i left the truck there and got a ride home....the next day i went back to have it towed put my key in the ignition and turned it to show my friend what it was doing it cranked for about 5 seconds and then started right up and ran perfectly fine.....i woke up the next morning to go to work and the only thing that i have noticed is that it takes a couple extra seconds of cranking before it starts...anyone have any ideas of what it might be?? i would be much happier if i would have had to fix something rather then going out every morning wondering if the thing is gonna start or not... the only thing that i did differant the night it would not start was turned the key to the on position and sat there for about 5 or 10 minutes without starting it...any help would be wonderful
Old 08-21-2008, 11:38 PM   #2
You got 30 minutes?
laydout97's Avatar
laydout97 is on a distinguished road
Re: 93 dime 4.3 tbi wont start
it sounds like a weak fuel pump. There is no fuel pressure test port on the tbi engines. You have to put in a guage in the return line to check fuel pressure. Yogi wil correct me/ explain more to you.
Old 08-21-2008, 11:48 PM   #3
well atleast i have somewhere to start now that makes me feel a little better....by the way like the name laydout97 its my gamertag...
Old 08-21-2008, 11:56 PM   #4
Wire Splicin Fool :-)
lesterl's Avatar
lesterl is on a distinguished road
Fuel pump relay may be bad, oil pressure sender has to see pressure before it kicks in and turns pump on, which means it will have to crank a little to fire up the pump, might listen for the pump to run with the key turned to run position (assuming relay is good should prime 3 seconds.)
Old 08-22-2008, 01:36 AM   #5
Bowtie Performance
blazerguy89's Avatar
blazerguy89 is on a distinguished road
i usually put a bridge in where the fuel filter goes and it has a fitting where u can screw ya gauge into it. you can buy them through matco tools but as expensive as they are i wouldn't recommend buying one unless u work on them alot or unless u have the extra money to spend. another way to do it is get a T- fitting and use 2 peices of rubber hose one on each side of the T-fitting going onto the lines and clamp them and put ur gauge on the T-fitting. i wouldnt recommend doing a dead head test as you really need to know more of how much pressure it has at normal flow. i could be wrong in some opinions but this is my $.02.
Old 08-22-2008, 12:59 PM   #6
Registered (Ab) User
Yogi's Avatar
Yogi is on a distinguished road
You want to test the pressure on the supply line, not the return. The return is after the regulator and the pressure will be very low or none at all.
Old 08-25-2008, 03:59 PM   #7
thanks for the opinions..it ran fine for the last few days other then having to turn the key a few times to get it started once in awhile and then all of a sudden today it died right in the middle of an intersection...that is the first time that has ever happened..i could not get it started back up...would it dying like that be caused by a faulty fuel pump also?
Old 08-25-2008, 05:42 PM   #8
Yogi's Avatar
It's possible.
Old 08-25-2008, 05:59 PM   #9
im a baller on a budget here lol..trying to figure out how much it is going to cost me to fix cant really afford to replace stuff if it is not going to fix it.. but from what i have heard fueal pump it is...any idea on how much one of those run?
Old 08-25-2008, 06:04 PM   #10
Spare Parts Pack Rat
shadow32's Avatar
shadow32 is on a distinguished road
What about the Ignition Control Module being on its way to the grave?
Old 08-25-2008, 06:06 PM   #11
Yogi's Avatar
http://www.rockauto.com/catalog/x,ca...,parttype,6256
I would get a pressure test before I spent any money on a pump. And get the ICM tested too.
Old 08-25-2008, 06:14 PM   #12
Sorry for my lack off car knowledge ...icm?
Old 08-25-2008, 06:18 PM   #13
Yogi's Avatar
Ignition Control Module.
Old 08-25-2008, 06:44 PM   #14
maybe i should go and get a manual lol or i am going to be asking alot of crazy questions
Old 08-25-2008, 09:28 PM   #15
lesterl's Avatar
WTF is a baller?
Old 08-25-2008, 09:30 PM   #16
lesterl's Avatar
Fuel pumps are around $70, get an AC DELCO pump only (spend the little extra) unless you like replacing them regularly. And replace the sock and fuel filter. Might also check the voltage/ grounds back at the pump, I would suggest checking the pressure also as previously mentioned.
Old 08-30-2008, 03:31 PM   #17
where the hell is the relay for the fuel pump at? i was also told to check this by my friend but i have no idea where it is at...and how big is the gas tank? i have been looking for pumps online and they are listing a 20 gallon pump and a 13 gallon pump which one is it?
Old 08-30-2008, 04:48 PM   #18
Yogi's Avatar
Check the option code list in the glove box and look for a code like Nxx. Take the code to the RPO Decoder sticky and look up your gas tank size. Mine was NE2 which is 18 gal.
Old 08-30-2008, 06:07 PM   #19
lesterl's Avatar
Relay should be under hood on drivers side fender?
Old 08-30-2008, 07:32 PM   #20
Yogi's Avatar
I thought it was in the glove box on a '93?
Old 08-31-2008, 12:43 AM   #21
lesterl's Avatar
Maybe it is, I was thinking the OBD1 stuff was still under the hood.
Page generated in 0.15192 seconds with 11 queries
