92' 4.3 TBI Timing Marks / Degrees - S-10 Forum
post #1 of 12 Old 01-04-2011, 04:51 PM Thread Starter
User is: sdimedanrider is offline
The timing marks on my engine are just like the image attached: I am having trouble finding a diagram or book that references the proper 0degree mark on timing marks that look like they do on my truck. Take a look at the image please and let me know if I have the degrees properly referenced for timing to 0 degrees.
post #2 of 12 Old 01-04-2011, 05:12 PM
User is: bg's is offline
Re: 92' 4.3 TBI Timing Marks / Degrees
Looks good to me. The deepest notch where you have "0" indicated
is just that, "0". The second line on the harmonic balancer is the
one you want to use when the timing interrupt wire is disconnected.
I have a 92 as well.
bg's is offline
post #3 of 12 Old 01-04-2011, 05:19 PM Thread Starter
Yeah I'm pretty sure I have the timing thing down I just needed to make sure what zero actually was since everything is rusted out. Thanx for the reply!
post #4 of 12 Old 01-04-2011, 05:38 PM
Sorry about that. I didn't mean to infer you didn't. Some have
an issue with the two makes on the balancer. Good luck with
your project !
bg's is offline
post #5 of 12 Old 01-04-2011, 05:48 PM
i saw what you did there!
fast68chevy's Avatar
yep many or most 4,3L balancers have two identical lines on them so watch ouy for that
almost positive the second one around clockwise around it is the TDC #1 firing position one
i forgot again for sure though, its been a while again..
and when you set the actual ign timing unplug the wire or spark module on firewall or intake bracket
set to zero of course
post #6 of 12 Old 01-05-2011, 01:05 AM
Doctorvettte's Avatar
User is: Doctorvettte is offline
Send a message via Yahoo to Doctorvettte
On my 94 there are numbers stamped on that tab, do ya think if you used a wire toothbrush or screwdriver and cleaned up the tab that there might be some on yours.. ?
BTW, the EST wire you need to unplug on the "92 I looked at yesterday was under the passenger floormat all the way up at the top next to the heater box.
A Brown wire with a square black connection to unplug.
Tomorrow I'm going my my pals house who has a clean "92, I'll look at his for ya.
you guys say there are 2 lines on the Harmonic Balancer ?
Can you chalk both and time it with whichever one shows up under the light ?
DrVette
post #7 of 12 Old 01-05-2011, 12:14 PM
Iroc-10's Avatar
User is: Iroc-10 is offline
My balancer only has 1 line, however on each rotation of the engine, it can be top dead center or bottom dead center. It has to be set to top dead center, with the pickup pulling from spark plug #1.
You really only need to worry about top dead center if you had the dist pulled out, other wise if you mark the balancer, connect to #1 and pull the advance wire, you should be good to go. I don't think you'll find 2 different marks on the balancer. I have never seen that.
Maybe Fall of '16 Turbonetics TC78
Currently Running:
6.0 / Ported 799 heads/ LJMS Stg2 cam
Yank SS3600
1994 SS S-10 Project CorectionSS LS swap-Running!
http://www.s10forum.com/forum/f213/p...tionss-495456/
1988 S-10 W/ Iroc Package, Screamin' Yellow -SOLD!
Iroc-10 is offline
post #8 of 12 Old 01-05-2011, 07:57 PM
Wire Splicin Fool :-)
lesterl's Avatar
User is: lesterl is offline
My 88 Astro had 2 marks about 1cm apart IIRC.....
lesterl is offline
post #9 of 12 Old 03-25-2012, 08:11 PM
User is: jared10130 is offline
I'm having some serious issues on my 99 Jimmy just built the motors bottom end and it is acting like the timing is out but I followed the book #4 is up timing marks are perfect but when I turn the key the motor is sluggish and doesn't wont to crank any suggestions
post #10 of 12 Old 03-26-2012, 02:22 PM
jax4x4.com
pjg1173's Avatar
User is: pjg1173 is offline
#4 is up???
Bigger tires and traction adders just means you get stuck in more inaccessible places.
87 4Runner, SAS, 15" spring lift, 3" body,409 Hp chevy 355, 5.29 gears, 38.5x15.5x15" TSL's
93 S10, SAS, 12" spring lift, 4.30 gears, F/R lockers, 36x12.5x15 TSL's, many more mods
05 Silverado, 2' lift, 4" exhaust, Bully Dog programmer,
00 Jeep Grand Cherokee (Daughters)
04 Chevy Colorado ZQ8 (other Daughters) 3" drop, 235/50r17
pjg1173 is offline
post #11 of 12 Old 06-09-2013, 09:31 PM
User is: dh56 is offline
ok so, assuming that you used the hanes manual which suggests you go with #4 at TDC look again it also says that the timing marks on the balancer which should be 2 of them, one is for cyl #1 and one is cyl #4. as for the sluggish crank, make sure that your torque value on your valve rockers is not too high.
dh56 is offline
post #12 of 12 Old 06-09-2013, 09:54 PM
goin broke but n style
S15vortecpwr's Avatar
http://www.s10forum.com/forum/f107/h...ns-way-494798/
01 GMC Noma 2.2L auto - SOLD
99 blazer 4dr 2wd - SOLD
GOIN BROKE BUT N STYLE
