'91 S10 Blazer engine upgrades/tune up - S-10 Forum
post #1 of 8 Old 11-05-2007, 03:36 AM Thread Starter
User is: Taigrr is offline
Have an '91 blazer that i'm sort of rebuilding. Just put in a new (Refurbished...) 700R4 from Chevrolet. New radiator, brakes all around, door-hinge pins and bushing. It's comming along quickly! But, now the complicated part. What can I do in the engine? At 205,000 miles it still runs pretty strong, but there's always room for smoother and faster. Mostly looking for easily-installed parts, but some basic modification isn't a problem. Thanks alot guys!
Taigrr is offline
post #2 of 8 Old 11-05-2007, 04:27 AM
Mr. Sparkle
Onimun's Avatar
User is: Onimun is offline
Re: '91 S10 Blazer engine upgrades/tune up
Replace gaskets, Replace Drive Belt, Replace Worn Vaccum hoses, Replace Engine / Transfercase Mounts, Replace Cab Mounts, Change ALL Fluids, Replace Throttle Body Injection Sensors, Replace EGR Valve, Replace Spark Plug wires/ Replace Spark Plugs/ Replace Cap & rotor, Change Air Filter, Change Fuel filter.
Inspect Waterpump, Test Fuel Pump, Change brake Fluid ( for better brakes ), Inspect vaccum Hoses.
Should be good
You can also get some performance parts IE: Air Cleaner Assembley like K&N, Exhaust, Performance TBI, Performance Pully system, Electric Fan Conversion ( i recomend).
Onimun is offline
post #3 of 8 Old 11-05-2007, 07:32 AM
Darrylh82's Avatar
User is: Darrylh82 is offline
Do a msd 6AL box i did it on mine with 176k and no other mods and it changed the whole sound of the motor! I pulled out, matted the throttle and layed a 60ft patch definately gave the tired girl some pep. Now At 200k i dunno man its a gamble not rebuilding the motor you start upgrading and the motor goes its gonna suck. but 4.3's are strong so.... good luck!
post #4 of 8 Old 11-05-2007, 07:32 AM
Darrylh82's Avatar
post #5 of 8 Old 11-05-2007, 12:55 PM Thread Starter
All new fluids. Found some oil that still had Zinc in it. Better protection for the old dog! Electric fan is a great idea, any hints on a drop-in replacement? And K&N have so many models, but I can't find any that'll work on TBI - Or does it matter?
Taigrr is offline
post #6 of 8 Old 11-05-2007, 06:52 PM
User is: circa8890 is offline
summit has a k&n fliter kit. i forget the part number but serach by you make and model thats what i did and found it. comes with everything for like 112. plume,fliter,top cover (polished) looks like a nice kit. haven't ought it yet but i plan on soon
post #7 of 8 Old 11-05-2007, 09:11 PM Thread Starter
http://store.summitracing.com/partde...5&autoview=sku This what i'm looking for?
Taigrr is offline
post #8 of 8 Old 11-06-2007, 10:56 PM
Originally Posted by Taigrr View Post
yep i'm pretty sure my friend has a kit on his s-10 and its all the same but his has the filter top
