4.3L Vortec Fuel Injectors - S-10 Forum
post #1 of 11 Old 02-28-2007, 06:09 PM Thread Starter
jwykes's Avatar
User is: jwykes is offline
Send a message via MSN to jwykes
Post 4.3L Vortec Fuel Injectors
Hey there,
Does anyone know what the size is of the stock fuel injectors? and if I go to one/two/maybe even three sizes bigger would I have to reprogram my computer? also, would this increase power or do I risk causing damage, or flooding my engine? and lastly, do you guys know of a good company to get them from, prices, quality?
thanks
jwykes is offline
post #2 of 11 Old 02-28-2007, 06:18 PM
UN-BANNED B!TCHES!!!!!
NotaDime's Avatar
User is: NotaDime is offline
Re: 4.3L Vortec Fuel Injectors
what year 4.3?
WTB cowl hood near valdosta GA NOW...
Seems like there are still a few people (Imperial, NotaDime, etc...) here that still have working brains.
Originally Posted by The Master View Post
BTW last post evar on this site. cheers and.....fock off.
Originally Posted by v8lonoma View Post
everything notadime said +1.
NotaDime is offline
post #3 of 11 Old 02-28-2007, 08:45 PM Thread Starter
jwykes's Avatar
2001
jwykes is offline
post #4 of 11 Old 02-28-2007, 09:30 PM
cycle252's Avatar
User is: cycle252 is offline
There is no real easy way to upgrade the injectors for the 2001 year you would have to mod a eldebrock 2114 manifold for bousch(sp) style injectors, plus you realy dont need them unless you have some power to use them (ie. super or turbo charger).
In otherwords you probable dont need them.
My ride : 1992 half black/gray... yeah dont ask Sonoma 5.3l lm7 T70 Turbo...
I'm alot like a MSD "boost timing master"... im a boost activated retard
cycle252 is offline
post #5 of 11 Old 02-28-2007, 11:08 PM
rat
Got Fuel Rails?
rat's Avatar
User is: rat is offline
Send a message via AIM to rat
19lbs/hr at 43.5psi.
Fuel system pressure is 60psi though, so they act like 23.1lbs/hr
I run 32lb/hr injectors at 43.5 psi on the stock intake manifold, you have to push really really hard to get them through the aluminum.
Rick, aim-RAT5111468
2000 4.3 auto
Custom Intake Manifold with 32lb/hr Injectors, Comp cam 260AHR, Tuner Cat Speed Density tune, Vac modulated trans with shift kit and vette servo, Bolt on's
Camshaft Tutorial-----My Truck and The Roots Blower Project ------ My Tuning Tutorial
rat is offline
post #6 of 11 Old 03-01-2007, 12:57 AM Thread Starter
jwykes's Avatar
alright so basically if I wanted to step up a size I would go to 20lbs/hr? and would it really make a difference or would I have to match it with a better fuel pump as well?
jwykes is offline
post #7 of 11 Old 03-01-2007, 12:59 AM Thread Starter
jwykes's Avatar
alright thanks, I guess i'll just have to do some research and see what I can do. I was thinking of a super charger when I save up the cash but I was looking for something a little more right now
jwykes is offline
post #8 of 11 Old 03-01-2007, 01:28 AM
rat
Got Fuel Rails?
rat's Avatar
20lbs/hr wouldn't be worth it. I would go a minimum of 30lbs/hr, and depending on what your hp goals are will dictate how large of injector you will need.
A larger fuel pump may not be needed. I run my fuel system at 43.5 psi now, so i can pump more fuel than at 60psi. If i find my injectors can't handle my fueling i can always raise the pressure.
Also, if you didn't notice in the above picture that is completely modified. There is a ton of work to get real injectors into a 4.3
Also, don't forget about tuning. I didn't gain or loose fuel economy with the injector change. Didn't gain any power either. When i throw my roots blower onto the manifold i will have enough fuel to support the air that i expect though. This is why you change injectors, to keep the air fuel ratio in line when go go beyond what the stock fuel injectors allow.
2000 4.3 auto
rat is offline
post #9 of 11 Old 03-01-2007, 01:31 AM Thread Starter
jwykes's Avatar
oh ok, ya I noticed the pic had quite a bit in there
I guess i'm basically at the end of the cheap little things to add more power, like intakes exhausts, that kinda stuff.
I recently just did the bored throttle body and was thinking of a high flow air sensor but after that its time to get into cams, blowers, nos, that fun stuff.
thanks for the help though, i'll probly just leave the injectors alone until I need bigger ones
jwykes is offline
post #10 of 11 Old 03-01-2007, 11:47 AM
"factory freak"...
Crew Cab Sonoma's Avatar
the stock injectors are fine for you right now. you shouldnt have bothered with the bigger TB, and forget about the bigger MAF.
move the cam up to next priority... much bigger improvements than with TB/MAF combined...
either that, or install nitrous.
95 S-10 2.2. Soon to be DD
post #11 of 11 Old 03-02-2007, 01:13 AM Thread Starter
jwykes's Avatar
now i've looked into NOS a little bit, but what I have never been sure of, is it a hard install or something i can do over a weekend? and correct me if i'm wrong but until I make an engine that can handle it, would I wanna stick with like 50-150 shot so I dont burn my engine out?
and as to the cam question, what would be a good cam to research, I know of lots of cams, I have just done more work on older 350's not the newer style engines, I would probly keep it to a roller but I'm just wondering what you guys have had a lot of luck with
jwykes is offline
