4.3L gas milage? - Page 2 - S-10 Forum
post #51 of 126 Old 02-17-2003, 09:11 PM
no more S10...
User is: Pewter2000LS is offline
Send a message via AIM to Pewter2000LS
I never let mine warm up much... 30 seconds-1 minute max. But I do idle for 20-30 minutes once I get to work... something I never do in the summer or fall. Guess I need to stop that and just go sit in the cafeteria...
2002 S-10 LS 2wd Indigo Blue w/ white stripes 4.3 sportside. 4/3 Belltech drop, Belltech sways, 17" Chrome Irocs, 235/45 & 255/45 Falken Ziex 512 rubber, Gibson Catback exhaust, MSD/Accel/Taylor ignition, K&N FIPK, Hypertech, March Pulleys, E-fan, CFM Tech TB Blade, JBA Headers, Extang tonneau cover, S.S. grille, SS bowtie, clear corners, smoked 3rd tail, Alpine/JBL/RF system, Silverstars, Xtreme winter wheels, Line-X spray on bedliner. ***Traded in 10-22-03***
1973 Volkswagen Beetle... project has just started
2003 Chevrolet Cavalier... stock and staying that way for a while
post #52 of 126 Old 02-17-2003, 11:45 PM
User is: wolfmangk is offline
Funny thing is....... I let my truck warm up sometimes 5 minutes, and I live in southern crapifornia... I need a timer or something that says 30 seconds. Doesn't not letting it warm up not let the oil circulate fully and causes direct metal on metal wear? I was told by my parents always to let a vehicle warm up, always.. I suppose if you drove it the day previous a little oil would be coating soem vital parts... How long does it take the oil to fully circulate through the engine?? That would be sweet juicy infromation, because that's all the time you need to let your truck warm up.
Anything said by WolfmanGK is not to be taken seriously or held against him in a court of law.
To Ricers: Your car isn't RWD. The only thing that wing spoils is your performance, and your dignity.
Really Excellent Toyota Aftermarket Racing Development
It's not a cock, it's my Glock-a gun-the one for fighting, not for fun!
post #53 of 126 Old 02-18-2003, 01:40 PM
Does anyone know the magic oil circ time? (avg)
post #54 of 126 Old 02-18-2003, 07:36 PM
mcgruff1's Avatar
User is: mcgruff1 is offline
Send a message via AIM to mcgruff1
Does anyone know how to check your O2 sensors? Theyre not throwing a code but theyre very old. I think my mileage is due to a few possible things: extended warmups, iac sensor, O2 sensor, evap canister, fp regulator. Not too sure yet.
'96 regular cab 2.2l 5-speed
mcgruff1 is offline
post #55 of 126 Old 02-18-2003, 10:42 PM
The manual suggests a visual inspection first. Normal deposits will be darker, abnormal will have pitting, and the picture it silver- ish. If it is white and gritty it may have an antifreeze leak. If it is brown, you have oil consumption. Anyway, you have to bring the engine to normal operating temperature, running the engine above 1200 RPM for two minutes. Backprobe (In other words, use your multimeter to check the voltage without severing any connections. This is very hard without damaging something. The easiest way is to use some connectors that will contact the wire and provide a metal surface to test with. This will harm some insulation, although it's not that bad. The hardest way is to find a male and female connector just like the one you are testing, and burn away the insulation (After bridging them from the M to F) at various points to test with your multimeter. I'm sure the easier way is somewhere in between lol. I'm poor, but personally it's easier for me just to replace them) With a single wire unit just ground one connection, and verify that the voltage fluctuates rapdily (May be hard to see with a digital MM, easier but less accurate with an analog/ needle type)between .40 and .60 volts. If the voltage is stabilized in the middle somewhere (or if ti fluctuates slowly) it's probably bad. If it stabilizes at either end of the range, the O2 cannot compensate for a more seriosu problem in the engine. For a heated sensor, it's the same thing, but you have to check for filament (heater) voltage as well as the .40-.60 voltage fluctuation. It's the same thing, but with a filament. You have to use a high impedance ohmmeter (ANY digital voltmeter pretty much, and most needle types), and check between the wires i list below, and verify the resistance is between 3.5-14.0 ohms.
Now, for reproducing this information, I simply ask you remove the engine from your truck, and find some way to gauge how long it takes the oil to completely circulate through the engine. I know, I know, I'm a great guy.
Obviously, I'm kidding, but if you want details with pictures, I suggest you purchase a manual for your S-10. Manuals should be one of the first things you buy for your truck. It will come in handy in the future, I guarantee!!!
The wires you need to test on the heated unit are tan and white, and purple and white. (Tan colored with a white stripe, and purple colored with a white stripe)
post #56 of 126 Old 02-19-2003, 09:23 PM
mcgruff1's Avatar
Hey wolfman, did you change your O2 sensor(s) out? If you did, did it help at all?
mcgruff1 is offline
post #57 of 126 Old 02-20-2003, 11:22 AM
User is: bluedevil is offline
Send a message via AIM to bluedevil Send a message via Yahoo to bluedevil
I get about 14 mpg. I drive mostly highway and get 240 miles per tank (18gal) S-10's get BAD gas milage.
post #58 of 126 Old 02-20-2003, 12:31 PM
Yeah I did, and also reinstalled the throttle body restrictor and cleaned the MAF. I haven't done the calcs for it yet though. They won't be good, because it rained and I got pissed off and floored it a lot (Which takes a lot of gas). I haven't replaced the post cat one just yet, I'm not sure about it.
Just did the calcs and I'm at 15.004MPG right now. MUCH better (I USED TO GET 11.9 MPG!!!), but still crappy. This is all city driving btw, though. I might replace the postcat sensor after all. They are making a difference. I have a feeling my mileage will continue to get better. Will try to get the egr mod as well. I figure the V-6 should get 25 highway at least and 18 or so city. My buddy at works has a fullsize sierra with a 305 (305 not 350) that gets 25MPG CITY!!! WTF? So, if you slap on 2 more cylinders and increase the displacement 40 some odd cubes, you get better gas mileage? HUH?
post #59 of 126 Old 02-21-2003, 03:30 AM
Weeeeeee
BadaSS_Black97's Avatar
User is: BadaSS_Black97 is offline
Send a message via AIM to BadaSS_Black97 Send a message via Yahoo to BadaSS_Black97
Mine is getting such crappy mileage right now. I'm running about 200 miles, if that, before I get to the orange. I think it's because I'm running so cold, like 140 degrees.
2006 Nissan Altima 3.5 SE 5spd tiptronic auto, fully loaded, leather, stock. 1st 1/4 mile run: 14.8 @ 94 with full tank of gas and lots of crap in the trunk
2006 Nissan Frontier king cab 4.0 V6 M6 dark metallic gray. JBA cat-back exhaust (including y-pipe) with spin tech pro street muffler... For sale $18,000
Best stock run: 15.23 @ 90 mph
Black 97 SS Stepside 4.3 GONE!!!!! best timeslip: 15.4 @ 87.8
post #60 of 126 Old 02-22-2003, 01:13 PM
User is: tketner is offline
On my 92 4dr Blazer 4.3 CPI stock with 175k my best mileage is just a shade over 17 and around 270 miles per tank. Lots of freeway helps, but in So Cal you can idle the whole way to work on the freeway so that takes it down. Plus the gas gauges are not even close to acurate. I can still show half full at 200mi and then it dives for empty after that. Any body says they get 20+ with any 4.3 doesn't know how to figure gas mileage right. These are computer controlled and they do what what they do.
tketner is offline
post #61 of 126 Old 02-22-2003, 05:50 PM
mcgruff1's Avatar
What do you have to do to replace an O2 sensor? Do you have to cut the wires or what? Im planning on goin to autozone tomorrow and buying some sensors and see if any of them do me any good, and if they dont, take them right back.
mcgruff1 is offline
post #62 of 126 Old 02-22-2003, 06:29 PM
Now own a 99 Blazer 4x4
SSsonoma43's Avatar
User is: SSsonoma43 is offline
Send a message via AIM to SSsonoma43 Send a message via Yahoo to SSsonoma43
Believe it or not.
Believe it or not. On Thursday, I did my mileage and got this. 204miles and put in 9.3 gallons. That equals 21.94 mpg. That was 95% highway driving.
Used to own a 1999 GMC SONOMA 4X4 (X) IAT mod, MAF mod, TB mod, TB spacer, 160 degree thermostat, Gibson exaust, Backyard intake, Headlight removed, Hypertech PP3, Casper TPS controller, Corvette servo, MSD coil, E-fan, ASP power pulleys, and EGR mod, 16.451@81.27
post #63 of 126 Old 02-22-2003, 06:30 PM
mcgruff1's Avatar
Way to go bro at least someone on this threads got something good to say about our trucks
mcgruff1 is offline
post #64 of 126 Old 02-22-2003, 07:32 PM
no more S10...
My best was 22.74mpg with 269.2 miles on the tank (11.8 gallons fillup). It was all highway cruising around 70. My average is around 16.2 mpg though. But yes you can get over 20 with a 4.3.
post #65 of 126 Old 02-22-2003, 07:56 PM
Roy
Urban Menace
Roy's Avatar
User is: Roy is offline
Sorry i never got specific...
I get lousy gas mialge in the city. But on the highway i get good gas mileage. Although i have an imbread cold / ram air intake. (fook'd up sounding huh)
Its a K&N fpik, with pvc / rubber housing (3"). I ran the tubes under the truck (kept them hidden for most part), they lead right up to the air fliter, but not sealed. They serve little to no purpose in the city. But when doing 75mph, all the air my truck may want is being forced right into the area of my filter. And its "cold" seeing as its from low to the ground. I think its proven, to me anyways, to be a big mod for mpg. I take my 4-wheeler all over in MI, during the summer. I noticed a diff in pwr, and mpg. Not a miricale, just subtle. And it was under $15 for "ram-air" rig-job.
I M O
2001 S-10 Reg. cab
4.3 5-Speed
K+N air filt. (otherwise stock)
Audiobahn stereo...
Roy is offline
post #66 of 126 Old 02-23-2003, 07:30 PM
xtreme11678's Avatar
User is: xtreme11678 is offline
Send a message via AIM to xtreme11678
im not to sure of the xtact milege but on my xtreme i can go about 250miles on a tank of gas, its an automatic w/ a 2.2 and i can go about 400miles on a tank of gas w/ my97 S10 witch has a 5-speed 2.2
97 S10 undergoing complete rebuild and engine swap
_____________________________________________
04 dakota now the everyday driver
post #67 of 126 Old 03-04-2003, 11:07 AM
That 3D picture dude guy
DfntPntbll's Avatar
User is: DfntPntbll is offline
Send a message via AIM to DfntPntbll Send a message via Yahoo to DfntPntbll
for a 1998 x-cab s-10 with a 4.3L V6 and 16 or so gallon tank,.. the city mileage is roughly 28 mpg and highway mileage is roughly 32 mpg.
I get about 300- 350 miles to a tank if I stay on the highway and actually use my engine like it was ment to be used (wide open),...which I do most of the time I drive.
1998 Ext. Cab S-10 4.3L bagged front/lowered 6" and rear disc
Like my 3D work? PM me for a rendering!
ASE Certified Alignment Tech
post #68 of 126 Old 03-04-2003, 12:21 PM
All my driving is city. I just put on a magnaflow muffler on my truck a few days ago. LAST ESTIMATE IS AT EXACTLY 16 MPG. Not THAT bad! Better than 11.9! I do NOT use the gas gauge. I use my Axim to jot down my mileage and exactly how much gas I put in the tank, subtract mileage and divide by gallons. I reset the comp last night for the muffler change, so I will see what i get after that. I STILL need to replace the O2 sensor post cat.
Can anyone else suggest some fuel economy increasing mods?
Fuel pressure regulator, anything... What do they cost?
post #69 of 126 Old 03-04-2003, 12:27 PM
BTW, Dfnt, Can I have your engine? Even swap.....
(Are you figuring your mileage right? Don't use the gauge, and if you skipped writing down a filling yoru mileage will go way up hehe)
post #70 of 126 Old 03-04-2003, 12:38 PM
DfntPntbll's Avatar
I tune my engine every year, get my oil changed every 3 months, replace my piston rings every 2 years or how ever often I get the chance. I also changed out my fuel pump. yes I am doing it right.
I fill my tank every 2 weeks or so and I right down the fill amount. after that I drive it untill it is about empty and I divide the amount of gas by my miles driven. every time it is around 28 city, 32 highway.
post #71 of 126 Old 03-04-2003, 05:09 PM
What does it run ($) to get the rings changed? Do you do it yourself? How difficult is it? Do you go under the crankcase, or pull the engine? Also, while you're there, why not just change out the pistons and go 20 or 30 over?
post #72 of 126 Old 03-04-2003, 05:19 PM
DfntPntbll's Avatar
I dont do it,...I take it to a local shop,...it depends on what else i need done to the truck so Im not sure on an exact price. usually sits around $400,.....and I dont replace my pistons becuase I am saving up for a 350 small block....Im just trying to keep this engine in good enough condition to sell when i get ready to.
post #73 of 126 Old 03-04-2003, 05:20 PM
DfntPntbll's Avatar
another thing,...if i tried to do engine work on my truck,....I would blow myself up,....im clueless as far as the newer engines go. i like th older 350's and 454's. CARBURATORS ALL THE WAY!!!
post #74 of 126 Old 03-04-2003, 05:26 PM
Interesting... What prompted you to change your rings? Blue smoke, anything? You just think it's a good idea? I'm willing to do a lot to get better mileage... Did you notice a big mileage increase after the rings?
post #75 of 126 Old 03-04-2003, 05:30 PM
DfntPntbll's Avatar
well,....after I started getting into the custom scene, i figured i would save up for a a bored 350, so I figured I would keep my engine in tip top shape until i did. I noticed maybe 4 or 5 miles to the gallon more,...not too much but it is worth it to me simply becuase 1 my engine now is outstanding, 2 its worth almost as much as a new 4.3, and 3 my current engine runs really nice. So i would say it is worth it if you are thinking of switching engines later.
post #76 of 126 Old 03-05-2003, 04:25 AM
96blazer's Avatar
User is: 96blazer is offline
My Blazer has 140,000 miles on it, but it still pretty good mileage on it. It gets 17 miles per gallon in heavy city traffic. And on a full tank, it'll go just over 340 miles befor it hits the red. I've done a a lot of long road trips with it. Not bad for a high-mileage Blazer.
Alot better than the 9 miles a gallon my fullsize drinks.
96blazer is offline
post #77 of 126 Old 03-05-2003, 11:02 AM
My mum's 464 Ford Econoline got 6 MPG before she sold it. Well, at least mine is better than that, right? RIGHT??!??
post #78 of 126 Old 03-05-2003, 11:44 AM
DfntPntbll's Avatar
not too bad. as far as this engine goes,...its gonna stay pretty much stock,...I WANT MY 350 SMALL BLOCK!!!!!!!!!!
post #79 of 126 Old 03-05-2003, 11:45 AM
DfntPntbll's Avatar
oh yeah,.....and traction bars,....lol
I spin my tires as it is,....it'll only get worse with a 350 in it. lol
post #80 of 126 Old 06-27-2012, 10:13 PM
Squeek's Avatar
User is: Squeek is offline
Send a message via Yahoo to Squeek
Re: 4.3L gas milage?
this is what i average too. i was getting pissed that i couldnt get any better than 18 in the city. now seeing that im one of the lucky ones to get that im a lil happier. but in MHO it should still get better milage than that
The ever changing line up...
99 4dr 2wd jimmy loaded. Still 99% stock for now
97 4dr 4wd winter blazer loaded still 100% stock for now
91 b2200 ext cab my girls truck. 98% stock for now
95 2 Dr 4wd parting out
2000 bravada parting out
2002 Bonneville stupid pos waiting for them to repo
Squeek is offline
post #81 of 126 Old 06-27-2012, 10:46 PM
User is: Atomic Citizen is offline
I get 14.6 mph when I tow a loaded 2 ton trailer into backyards and through the construction yards, but with trailer off I get 200 miles on 10 gallons, maybe better. A 1999 S10 Vin X 4x4. Recently went bumper to bumper on all electrical, found a few borderline sensors and due to a lean condition through all speeds, I found the distributor gear was the culprit. Didn't replace it with the garbage plastic base. That repair will be watched, my S10 has been feeling good since then.
post #82 of 126 Old 06-27-2012, 11:06 PM
The warm up may have been a myth back when trannys were linkage and vacuum type. They always made metal to metal sounds, but I know my electronic tranny, the control is set to a predetermined parameter when not at temperature, discounting my effort to drive the machine. I believe that e-tranny slip should always be done on warm fluid. Now a clutch vehicle, I don't believe driving off cold would be damaging. Today's tech has really changed what fluids we use.
post #83 of 126 Old 06-28-2012, 05:34 AM
User is: ranman is offline
Idling is the worst way to warm up a vehicle and it wastes gas. 5 min per day is 30 hours per year.
30 seconds of idle is way plenty to get under way. The engine warms up quicker while driving than while idling. Just don't go road racing for the first 5 minutes and you will be fine. Oil fully circulates though the engine in a matter of seconds.
ranman is offline
post #84 of 126 Old 06-28-2012, 05:58 AM
User is: 355s10 is offline
The reason for warming up is that the piston warm up and expand much more faster then the the actually block and cyl. So that being if the block is cold and the piston are hot it could rub the cyl walls there for leaving gouges, after years of abuse it could lead to poor compression etc etc etc...
I know you could say that the piston being hot is going to happen at low rpms or high rpms but i would much rather have the piston rub at 1200 rpm then 2500rpm.
355s10 is offline
post #85 of 126 Old 06-28-2012, 07:07 AM
Hardcore Lurker
User is: SloFive is offline
Check the dates
SloFive is offline
post #86 of 126 Old 06-29-2012, 01:41 PM
User is: KSZR2 is offline
Had to do some serious digging to find this thread!
KSZR2 is offline
post #87 of 126 Old 06-29-2012, 08:40 PM
Squeek's Avatar
lol i used the ever popular search the forum button
Squeek is offline
post #88 of 126 Old 06-30-2012, 01:17 AM
User is: outlaw_sonoma is offline
from full tank to 1/4 tank is about 255 miles standard cab short bed with a 4.3 non vortec. no mods just bigger tires. kicks into overdrive at 45 and its easy sailing from there.
post #89 of 126 Old 07-01-2012, 01:19 PM
User is: 96Blazer LS is offline
Originally Posted by sabbasaun View Post
Intereting, when i first bought my truck new (2001 s10, extcab 4x4), i was getting over 325 miles a tank no problem, now i can barley get 250-275 to save my life... Power is about the same, no mods, with 48,000 miles.... if i had a turbo on it or s/c i probably wouldn't care so much, ohwell..... life goes on!
My 1996 Blazer 4 dr 2 wheel drive would get 300-320 out of a tank. Now it will only get about 240-245 if lucky. The ethanol blended fuel, does not have the energy output of straight non-blended gas, therefore the gas mileage drops some.
post #90 of 126 Old 07-01-2012, 01:22 PM
Did you replace the complete distributor? I went to change my cap and rotor and there is some slop in the distributor, you can move the rotor button some.
post #91 of 126 Old 07-01-2012, 01:24 PM
Squeek's Avatar
i'm lucky if i get 220 out of a tank on mine (97 4 door 2wd with full tune up and new intake gasket)
Squeek is offline
post #92 of 126 Old 10-19-2012, 03:05 PM
User is: CapriceLT1 is offline
kudos for loving the 4.3 and doing all that work but I've been working on cars a long time. I think the rings or rebuild you do is a bit overkill. The shop must love you. Why did you do that EVERY 2 years?
post #93 of 126 Old 10-19-2012, 04:01 PM
User is: DIXIEREBEL4X4 is offline
my 01 crew cab 4wd get about 10 mpg only go about 200 miles on a tank still not sure of the gallons my tank will hold (19 or 20) the cc came with both
post #94 of 126 Old 10-19-2012, 05:11 PM
9" racing glass pack
MotorNut123's Avatar
User is: MotorNut123 is offline
I get I'd say about 20ish. Highway for me sucks too. And yea i can fill my tank with about 40 bucks. Sometimes 30. Idk what size these tanks are but they seem small, even though mine looks big
PROJECT THREAD>
http://www.s10forum.com/forum/f30/my...-piece-508137/
1995 Chevy S10 Extended Cab LS
5 speed V6 Vortec (VIN Z) 2WD
S10's FTW!
I would gladly go shove your truck into the garage of a capable mechanic
post #95 of 126 Old 10-19-2012, 05:20 PM
User is: frostystones is offline
I'm averaging 18.4mpg, my best was 21.7mpg and my worst was 16.6mpg. according to Fuelly.
post #96 of 126 Old 10-20-2012, 12:14 AM
Mine is about the same, all stock. Lucas fuel additive added every tank. Did the TB mod, had car4option CAI on but took it off (well, it broke) but i was going to switch back anyways. Its a '96 sten, 4.3 (x) auto w/3.42 rearend, 3 door step side with a bunch of tools in it. I think Im just going to get a tune from pcmforless or pcm performance like i did with my caprice. Thats what i recommend to all!! you can get an economy tune or power/economy. Good stuff
post #97 of 126 Old 10-21-2012, 03:38 AM
Better post-em.
comics22's Avatar
User is: comics22 is offline
yea my blazer is like 19-20 mostly 55mph highway but decent ammount of stoplights.
now my 4 banger s10 can get 30+ on highway trips and easy 500 miles to a tank. its great having to fill up like 6 times in an oil change haha.
i dont think the mpg makes me mad its the fact it seems i cant drive anywhere without seeing the gas gauge go down. and only lasts like 250-300 miles to a tank. im used to 300+ miles being half a tank with my truck!
comics22 is offline
post #98 of 126 Old 10-21-2012, 06:10 PM
how do you guys tell your MPG? i just guess
PROJECT THREAD>
S10's FTW!
post #99 of 126 Old 10-21-2012, 08:23 PM
MC Slide Hammer's Avatar
User is: MC Slide Hammer is offline
I add 10 gallons, set Trip meter to 0, and once I get to the same point in the gas gauge (almost empty usually), I divide by 10.
My S10 gets about 20 mpg, highway, and 15 city/mixed.
I'd love my S10 if I can get 23mpg highway and 18mpg city or mixed. LOVE IT. But not going to happen.
post #100 of 126 Old 10-21-2012, 09:18 PM
Fill your tank, and when it gets below 1/2, refill it and record how many miles you drove.
Lets say you drove 225 miles and it took 10.26 gallons to refill it.
225 divided by 10.26 = 21.93mpg
You may have to average several tank fulls to be accurate. Just try to fill up the tank the same way each time.
If you run your tank to the e mark, the mpg figure will be more accurate............ a lot depends on how you top off your tank. Just do it the same each time.
ranman is offline
