4.3 swap x engine to w type - S-10 Forum
post #1 of 19 Old 10-21-2007, 10:56 PM Thread Starter
User is: jos10 is offline
I have been the owner of a 96 s10 for 3 hours now and have been searching the forum and was unable to find any information on it. I have the x engine in it and am getting some knocking and found a w engine for sale. Is this an easy swap? What needs to be done in order to go from an x to a w type engine? Mine is a 4 wheel drive and th one i am buying is also 4 wheel drive if that helps.
thanks for your help...
jos10 is offline
post #2 of 19 Old 10-21-2007, 11:31 PM
rat
Got Fuel Rails?
rat's Avatar
User is: rat is offline
Send a message via AIM to rat
Re: 4.3 swap x engine to w type
It is the same engine if it is the same year.
If it is older don't bother.
Rick, aim-RAT5111468
2000 4.3 auto
Custom Intake Manifold with 32lb/hr Injectors, Comp cam 260AHR, Tuner Cat Speed Density tune, Vac modulated trans with shift kit and vette servo, Bolt on's
Camshaft Tutorial-----My Truck and The Roots Blower Project ------ My Tuning Tutorial
rat is offline
post #3 of 19 Old 10-21-2007, 11:48 PM Thread Starter
ok great, they are both 96's .... the only reason i was curious about this is because the person i am buying it off asked which engine i had and acted like it mattered. what is the difference if anyone knows between the x and the w...
jos10 is offline
post #4 of 19 Old 10-21-2007, 11:51 PM
rat
Got Fuel Rails?
rat's Avatar
Let the debate begin. This may get heated.
I say absolutely nothing. Programing is the same.
2000 4.3 auto
rat is offline
post #5 of 19 Old 10-21-2007, 11:53 PM
s10stocker's Avatar
User is: s10stocker is offline
Nothing if it is a 96+. A 95- would be plenty of work. Also for a engine swap don't let anyone try to tell you its worth more. If its a whole truck there are differences.
post #6 of 19 Old 10-21-2007, 11:55 PM
s10stocker's Avatar
I got your back.
post #7 of 19 Old 10-22-2007, 12:25 AM
User is: ktm841 is offline
well, i have been doing a little research about this tonight and just happened to come across this. 96-98 X/W are the same, central sequential injection. 93-95 has cfi and is a W vin.
but according to my manual (not sure if its very accurate) a W 4x4 makes 190hp , 2wd makes 180. 4x4 X series makes 180 and 2wd makes 175. the manual is for a 97 sonoma.
ktm841 is offline
post #8 of 19 Old 10-22-2007, 12:41 AM
rat
Got Fuel Rails?
rat's Avatar
Yep. I haven't really seen concreate explanations as to what is different about the engines to make different amounts of power though. Or, maybe gm thought that the 4x4's needed a couple extra horsepower to make the sale over the 2wd's.
2000 4.3 auto
rat is offline
post #9 of 19 Old 10-22-2007, 01:10 AM Thread Starter
thats great to know, thanks for your help everyone... it is good to know that the w should work fine and give me 10 extra hp.
thanks
jos10 is offline
post #10 of 19 Old 10-22-2007, 08:51 AM
s10stocker's Avatar
I still believe it has to do with the larger Y pipe dia on the 4X4. The vans and FS trucks came with 200hp. Go fugure
post #11 of 19 Old 10-22-2007, 08:07 PM
User is: johntpr is offline
is this also true for later years? Would a let's say 2003 x vin code 4.3 engine swap with no problems to a 2001 w code blazer? Would anything be different?
johntpr is offline
post #12 of 19 Old 10-22-2007, 08:08 PM
rat
Got Fuel Rails?
rat's Avatar
That may be different. They did change year to year, the big difference may be the knock sensor. And the egr.
2000 4.3 auto
rat is offline
post #13 of 19 Old 10-22-2007, 08:20 PM
But then could I just change the components from one year block to the other?
johntpr is offline
post #14 of 19 Old 10-22-2007, 08:22 PM
rat
Got Fuel Rails?
rat's Avatar
The knock sensor may be different, as i said in my last post...
2000 4.3 auto
rat is offline
post #15 of 19 Old 10-23-2007, 08:40 AM
carries a gun at work
bill 4.3l 5spd's Avatar
User is: bill 4.3l 5spd is offline
Send a message via AIM to bill 4.3l 5spd Send a message via Yahoo to bill 4.3l 5spd
effort to results wise i dont think 10hp is enough by itself to do an engine swap
post #16 of 19 Old 10-23-2007, 08:46 AM
s10stocker's Avatar
He said he was knocking.
post #17 of 19 Old 10-23-2007, 08:56 AM
96blazer's Avatar
User is: 96blazer is offline
He could have been asking if your was a 4 cylinder or the V6.
96blazer is offline
post #18 of 19 Old 10-23-2007, 04:54 PM
Sorry to highjack this post, but I'm still a bit confused. I mentioned whether let's say 2003 x vin code 4.3 engine would swap with no problems to a 2001 w code blazer?
The answer received is that the knock sensor and EGR are different. But are these just bolt on parts that can be changed from one engine to the other..or is block holes or threaded component locations different etc and this a not doable swap.
My 2001 w code 4.3 4wd Blazer looks like needs an engine and I found a low milaige 2003, but want to make sure swap will work.
johntpr is offline
post #19 of 19 Old 10-23-2007, 05:23 PM
User is: ChevyAddict is offline
why would you go through the trouble of an engine swap and not just drop a v8 in there??
