4.3 mercury marine vs standard 4.3 - S-10 Forum
post #1 of 8 Old 02-13-2010, 04:34 PM Thread Starter
bcpd_03's Avatar
User is: bcpd_03 is offline
i have a boat with a 91 4.3 merc that either has a cracked block or head.
'' the motor fill's up with watet a few minutes after leting it run.
I guess my question is whats the diference between the 2 besids the cam? Would it be safe to re-cam a 4.3 from my v8 s-10 swap it runs strong and just sitting in the shop
I WOULD RATHER BE TRIED BY 12 THAN CARRIED BY 6. THIN BLUE LINE
bcpd_03 is offline
post #2 of 8 Old 02-13-2010, 06:36 PM
goin broke but n style
S15vortecpwr's Avatar
Re: 4.3 mercury marine vs standard 4.3
I have been told some marine engine turn backwards in rotation than a normal car engine. maybe someone will chime with more marine experience.
01 GMC Noma 2.2L auto - SOLD
99 blazer 4dr 2wd - SOLD
GOIN BROKE BUT N STYLE
post #3 of 8 Old 02-13-2010, 07:55 PM
WICKED 6 RACING
disturbing V6's Avatar
User is: disturbing V6 is offline
Bottom ends are slightly different . I know they come stock studded. In 94 and 95 the 4.3L had a HD block which ran a really have casting compared to earlier marine and car blocks.
post #4 of 8 Old 02-13-2010, 07:57 PM
User is: jbirce18 is offline
no marine motors are not counter roating. that was a very slim production hickup. you should be able to swap no problem. it might not have the mech fuel pump so elect will be needed. other than that should work. cam isnt going to make that big of a diff if you dont wanna swap them
jbirce18 is offline
post #5 of 8 Old 02-13-2010, 08:21 PM
User is: poconojoe is offline
Twin I/O setups have the second motor spinning reverse rotation, to reduce cavation of the impellors. So any boat that came with twin 4.3's (if there were any) would have had one rotating in each direction.
To the OP, you need to change the head gasket to use a truck motor in a boat, unless you're only going to use it in fresh water
post #6 of 8 Old 02-13-2010, 11:27 PM
WICKED 6 RACING
There were a lot of boats that used two GM 4.3L motors but were labled as Volvo.
post #7 of 8 Old 02-14-2010, 02:27 AM Thread Starter
bcpd_03's Avatar
THANKS FOR ALL THE HELP!!! I figured that there would not be a problum swaping them out. It is a fresh water boat and I now have another project to finish befor this summer
THANKS AGAIN
bcpd_03 is offline
post #8 of 8 Old 06-04-2015, 12:06 PM
User is: Monterey is offline
How did you make out I did the same but have turned a bearing twice now
Monterey is offline
