4.3 engine removal - S-10 Forum
post #1 of 9 Old 03-29-2009, 05:28 PM Thread Starter
User is: you6no6me6 is offline
Question 4.3 engine removal
i'm stuck guys i have a 1997 s10 4.3 i've taken evry bolt loose to get this thing out and now i'm stuck the oil pan hit's the front diff i've heard a few logical answers like lifing body so i don't have to talk the axel down but i'm lookin for someone who has done this with better luck than me that can tell me the easiest way to remove it my engine is all loose and ready to pull i have it held up by hoist right now and cant wiggle it anyway to get it up and out the trans is seperated the oil pan is less than inch away from the diff if i lift on it it hits anyone know how to do this?
thank you
post #2 of 9 Old 03-30-2009, 12:07 AM
T_WEST99's Avatar
User is: T_WEST99 is offline
Re: 4.3 engine removal
When i changed my motor in my 99 i had a hell of a time too but mine is 2x4 and i pulled my tranny out with it. People told me i had to remove my front end and pull it straight out bc the motor and tranny wouldnt clear, but i said the hell with that and did it my way, i have take a head bolt out and the passenger side close to the back for one lift point and then went cross ways to the front of the motor and use a intake bolt, once i got it loose i had to get under the truck and pull down on the butt of the tranny hard to while someone was at the fire wall watching not to dent it and then had another buddy operating the hoist with three people and sum wiggling it will come out, but if u cant get it then may wanna try the removing the front end hope that helped good luck to u
T_WEST99 is offline
post #3 of 9 Old 03-30-2009, 08:55 AM
User is: gerbsinmd is offline
on a 4x4 you must take the engine by itself. When I did it I spent 2 days trying to get it out with the trans and every extra piece attached that I could, but when I decided that it just wouldn't come out. I took the trans off, the torque converter off the engine and left it with the trans, took off the passenger side exhaust manifold, intake manifold and distributor, and starter, ( you need the starter out to get at the torque converter bolts) and lifted it almost straight up. Then it was out in no time.
Don't try to take the engine out with anything else attached to it unless you want to unbolt the body and lift the body 6 - 8 inches.
It goes in the same way, nothing but the flexplate attached to the back of the motor. I set the engine in and had it bolted to the trans etc in less than 2 hours by myself. It took a few more hours to put the intake and exhaust and wire it back up.
post #4 of 9 Old 03-30-2009, 09:00 AM
truefire04's Avatar
User is: truefire04 is offline
i gues the 4x4 and the 4x2 is diffrent i pulled the motor and trans when i pulled my motor, but i have the 4x2....i had to pritty much turn the motor almost vertical, to get it out and i took the hole front end off the truck....but had to do that because of the 5.7l that i put in it.....and had to mod the core support for the rad.
post #5 of 9 Old 03-30-2009, 07:17 PM Thread Starter
thanx for you help guys i actually ended up taking a few body mount bolts out and lifted the cab less than an inch and i was able to get it just pass the front diff and came out so easy so i left eh cab on jackstands and the new motor practiacally fell into place thanx again for help
post #6 of 9 Old 12-28-2014, 02:02 AM
User is: rtmartin is offline
I am currently pulling the engine out of my 2002 chevy blazer, going in I knew I would have to remove the trans, so I went ahead and pulled the transfer case and then got all the trans bolts out, and have removed the starter and took the three torque converter bolts out and thought I could just wiggle, push and pull a bit to get the thing out like I have with other transmissions but I was mistaken, couldn't even get a slight crack to form so I could get a screw driver or something in there to try to create a bigger gap. Just wanted to see if anyone had come across some tricks to solve this problem.
rtmartin is offline
post #7 of 9 Old 12-28-2014, 11:37 AM
AWD V8's Avatar
User is: AWD V8 is offline
6 bolts on the bell housing.
2 support rods, one on each side of the bell housing.
Are the above done?
AWD V8 is offline
post #8 of 9 Old 12-28-2014, 12:01 PM
I have the bell housing bolts out. are the support rods not molded into the engine? can they be hammered out
rtmartin is offline
post #9 of 9 Old 12-28-2014, 12:09 PM
And I have seen where people have
said there are 8 bolts.
rtmartin is offline
