4.3 Compression
Old 09-20-2009, 10:09 PM   #1
4.3 Compression
Anyone that has checked the compression on their 4.3(preferrably 1996+), I would really appreciate knowing what the correct compression is supposed to be.
I have looked several places on the internet and even in official repair manuals and all I can find is that they are supposed to be close to each other.
I simply wanna know average psi numbers of a good 4.3.
Thanks.
Old 10-26-2009, 02:44 AM   #2
91s10blazen's Avatar
Re: 4.3 Compression
I recently did a test on my 91 4.3l v6 and it read 180psi on all 6 but I'm having trouble so my results may not be typical.
Old 10-26-2009, 11:51 AM   #3
Re: 4.3 Compression
I just did a compression test on my "X" VIN code '98 4.3 with 160k miles. The highest cylinder reading was 190, the lowest was 180 and the rest fell in between.
Old 10-26-2009, 10:30 PM   #4
Wire Splicin Fool :-)
lesterl's Avatar
Re: 4.3 Compression
Above 100 PSI is ok, the higher the better IIRC.
