4.3 Camshaft - S-10 Forum
post #1 of 71 Old 04-09-2005, 02:15 AM Thread Starter
Daves03's Avatar
User is: Daves03 is offline
Send a message via AIM to Daves03
4.3 Camshaft
Okay heres the deal I want a camshaft for my 2003 Chevy S10 with the Vortech 4.3 litre engine. No Biggie Huh? The only problem is I want it to loap so bad the truck rocks I pretty much want a race car sound. Also I have the 4L60E Automatic Transmission. Can anyone give me a suggestion on what needs to be done. Also if i change the cam will it effect the emissions part of the truck( By this I mean the SERVICE ENGINE SOON LIGHT) I dont want it BACK on.
Daves03 is offline
post #2 of 71 Old 04-09-2005, 03:06 AM
Ex V8 sonoma member...
KC'Kustom95's Avatar
User is: KC'Kustom95 is offline
Send a message via Yahoo to KC'Kustom95
Re: 4.3 Camshaft
well check out comp cams .525/.525 lift cam it will give you the sound you are after, that is what is in my budies truck and it chomps hard(u can almost count cyl's lol)
But dont count on geting a cam like that and Keeping your F.I. They are made for carb Setups
and with a carb your 4L60E wont shift out of second gear cause it works off the T.P.S.
You will need Stiffer Valve springs cause of the much higher lift of the cam
With a auto trans you will also need a stall converter so your truck will idle in gear
Hope this helps
post #3 of 71 Old 04-09-2005, 03:12 AM
stock is the new fixed up
dk_250's Avatar
User is: dk_250 is offline
Re: 4.3 Camshaft
comps 270ahr loaps slightly, there are clips on the site from members somewhere. but i doubt its racecarish.
2002 S-10 | 4.3L | 5spd | 8.5" 3.08 Posi | ZQ8 + 2/2 | LS1 rear brakes
Heads -- LS1 Brakes
dk_250 is offline
post #4 of 71 Old 04-09-2005, 03:54 AM
Damn right I'm a maniac.
PSYKO_Inc's Avatar
User is: PSYKO_Inc is offline
Re: 4.3 Camshaft
Be careful how much cam you put into that motor. I think the stock heads will max out at about .480 lift (but dont quote me on that, I'm sure Mintsick or Rat will chime in soon, and those guys know their stuff.) without needing machining, and thats with zero clearance. Zero clearance is bad... Also, too much duration, and your truck will sound mean as hell, but you will actually lose power. If your engine redlines before it can even get into that cam's powerband, what exactly is the point?
-Jay
Project Thread Picture Thread
97 S-10 Extended Cab 4.3/T56 swap/4.10 gears/W4M tune
Bagged with Alter Images 6 Link on Chevy rallys
CarPC, Audio by Peerless, Phoenix Gold, US Acoustics.
post #5 of 71 Old 04-09-2005, 09:04 AM
User is: BigDuVall is offline
Re: 4.3 Camshaft
Yeah, stock heads are .480 lift. Most likely, you'll have to get the heads machined. Comp Cams does make a 270 with a .470 lift, if you don't want to machine the heads. Clearance of .010 is better than zero.
post #6 of 71 Old 04-09-2005, 09:13 AM
Stepsider
YELLOW2002S10's Avatar
User is: YELLOW2002S10 is offline
Send a message via AIM to YELLOW2002S10
Re: 4.3 Camshaft
Hmmmm good to know I want a lil more power outta my 4.3 dime....Thanks guys
post #7 of 71 Old 04-09-2005, 11:53 AM Thread Starter
Daves03's Avatar
Re: 4.3 Camshaft
hey guys im not really after horspower i just want the old muscle car truck sound. I love my s10 and i want it to sound mean.
2003 Chevrolet S10 ZQ8 Dark Cherry Red Metallic
5"/5" Beltech DJM Drop, Nitrous Express System,
4.3 Litre Vortech V-6 Auto
Streetglow multicolor underbody lighting
10,000K purple HID system with blue halo lighting
Daves03 is offline
post #8 of 71 Old 04-09-2005, 02:29 PM
rat
Got Fuel Rails?
rat's Avatar
User is: rat is offline
Send a message via AIM to rat
Re: 4.3 Camshaft
For the lope sound you are looking for the 270AHR would do it a little. Baisicaly what will give you lope is a small lobe seperation angle, and long duration. The longer you keep the exhaust and intake open at the same time the more lope you will have. If you get an adjustable timing set you could install the cam a little retarded, and it should make it lope a little more.
I strongly recomend that you don't do this. You will probably make your truck slower by doing this. To properly do it you would have to get a stall converter, and higher gears. All of this stuff is going to kill your fuel economy by the way. It will also drive like crap on the street, because you will have zero low end torque. Crane also has some cams that are fairly wild. This isn't going to be cheep either. You would need springs, retainers, locks, cam, heads machined, gaskets, lifters maybe, rockers maybe, and computer tuning so that you don't throw an ses light. With the lope that you want the computer is going to think that it is misfireing, and it will throw an ses. The 2001 and newer trucks seem to be more prone to this. If they use the sniffer i doubt you will pass emissions with the type of cam you want.
If you call comp, they might be able to make a custom grind for you that would do this, and sound the way you want it.
If you have a manual you should go with a 266HR, or the 270AHR. Manuals can usualy take a little more duration than an automatic. If you have an automatic and want to keep the stock torque converter, then the 260AHR has good torque, drivabiltiy, and fuel economy. It makes power up to about 5000rpm. If you don't want to machine the heads a lower cost alternative would be crane. They have a 204/214 duration with .43" of lift cam that would fit without machining. It should also be good for nitrous, or a supercharger.
Rick, aim-RAT5111468
2000 4.3 auto
Custom Intake Manifold with 32lb/hr Injectors, Comp cam 260AHR, Tuner Cat Speed Density tune, Vac modulated trans with shift kit and vette servo, Bolt on's
Camshaft Tutorial-----My Truck and The Roots Blower Project ------ My Tuning Tutorial
rat is offline
post #9 of 71 Old 12-28-2008, 05:13 PM
pollard's Avatar
User is: pollard is offline
Re: 4.3 Camshaft
http://www.youtube.com/watch?v=R9dA0jTDGR4 id love for my 4.3 to sound like this
pollard is offline
post #10 of 71 Old 12-29-2008, 02:40 PM
Learn As You GO
User is: tmaxxs10 is offline
Re: 4.3 Camshaft
That truck sounds awesome. Makes me wanna just put the 4.3 in the s10 instead of v8.
1998 Black Blazer 4dr 4wd 2" BL, Tbar crank, 31" Baja Claws, Cragar Soft 8 15x7, "Cold air" intake, soon add-a-leafs
1996 Red S10 ext cab, 4 cyl, 5 spd. Under construction! Tore out 4 to make way for v8 project
tmaxxs10 is offline
post #11 of 71 Old 12-29-2008, 03:12 PM
bobfig's Avatar
User is: bobfig is offline
Re: 4.3 Camshaft
for the parts
http://www.s10forum.com/forum/f107/w...9/#post5885828
sound of the 270
http://www.s10forum.com/forum/f89/po...5/#post3341024
bobfig is offline
post #12 of 71 Old 12-29-2008, 03:17 PM
ΜΟΛΩΝ ΛΑΒΕ!
1fast4by's Avatar
User is: 1fast4by is offline
Send a message via AIM to 1fast4by
Re: 4.3 Camshaft
My 270 lopes pretty good. Its the only one I would recommend.
"The police cannot protect the citizen at this stage of our development, and they cannot even protect themselves in many cases. It is up to the private citizen to protect himself and his family, this is not only acceptable, but mandatory."
-Jeff Cooper
Ban gun free zones!
1fast4by is offline
post #13 of 71 Old 04-24-2009, 01:07 PM
User is: fatalsniper24 is offline
Send a message via AIM to fatalsniper24
Re: 4.3 Camshaft
About how long does it take to change a cam
post #14 of 71 Old 04-24-2009, 02:51 PM
Sometimes I'm mean...alot
RaginInferno's Avatar
User is: RaginInferno is offline
Re: 4.3 Camshaft
Originally Posted by rat View Post
....then the 260AHR has good torque, drivabiltiy, and fuel economy. It makes power up to about 5000rpm....
FYI, I ran a 260AHR with no other mods and it pulled all the way to 5500 before I would get out of it
Originally Posted by Bentenn14 View Post
If I had to guess, It's gonna be one of those things that seems like a longshot that's gonna be the problem. I've almost exhausted the short-shots.
Jim
'00 Blazer 4dr 4wd, '00 S10 RCSB,'99 Blazer 2dr 4wd, '97 Southwind 35W, '03 2500HD,'02 Yukon, '00 Harley, '06 GSXR, '00 250EX, '10 RZR
post #15 of 71 Old 03-04-2010, 04:31 PM
SnoMan's Avatar
User is: SnoMan is offline
Re: 4.3 Camshaft
Are there any cams like the old school RV style cams that keep power lower in the powerband? im looking for off the line power and towing power, not top end. A nice lumpy idle would be an amazing plus
'98 Chevy S10 2-Door Blazer 4.3 5-Speed 4X4 with Pioneer Head Unit, Pioneer 4 way 6.5's in the doors and Pioneer 6x9 3 ways in the back
Soon to come: -2-3 " Lift
-31" Tires -Keyless Entry
-Brush Guard
Now money needs to match ideas
SnoMan is offline
post #16 of 71 Old 03-04-2010, 04:54 PM
Got boost?
03zq8s10's Avatar
User is: 03zq8s10 is offline
Send a message via Yahoo to 03zq8s10
Re: 4.3 Camshaft
Comp 270AHR here and it has a slight lope. My exhaust clip is in the audio clip sticky. Check it out. The Comp 280HR will be too aggressive for you and you will love the sound but it's pointless unless you have all the mods to back it up.
2003 ZQ8 S-10. 4.3 Vortec Wynjammer supercharged, 36lb injectors, Richmond 4:10's w/ Auburn posi, PTC 3000 stall converter, Hughes shift kit, Jet billet servo, ported throttle body, Flex-A-Lite dual electric fans, ported Vortec heads w/valve job 2.02/1.60 , Pertronix ignition box, custom dyno tune, Competition 270 ahr, true dual exhaust ( JBA shorty ceramic headers, X pipe, no cat, 2 Spintech Pro shootouts.) 263 rwhp 298 ft lbs of torque
03zq8s10 is offline
post #17 of 71 Old 03-04-2010, 10:16 PM
SnoMan's Avatar
Re: 4.3 Camshaft
is this for my post or the guy that started this thread?
-Brush Guard
SnoMan is offline
post #18 of 71 Old 03-04-2010, 11:31 PM
Got boost?
03zq8s10's Avatar
Re: 4.3 Camshaft
OP man. I would have quoted you. It's cool though.
03zq8s10 is offline
post #19 of 71 Old 03-05-2010, 12:04 AM
Newb
97s104x4's Avatar
User is: 97s104x4 is offline
Re: 4.3 Camshaft
ok im in the same boat, so a 525/525 wont work for my 97 4.3?
im not planning on just throwing a cam in
heres my list
Head Set- Gaskets
Roller cam- which one??? and Roller lifters
Valve springs and retainers
3/8 ARP screw in studs
Roller Rockers- Help me with the brand?
Timing Chain and gears
Cam Button and retainers
High-Volume Oil pump
Machined heads
shorty headers with true duals
traction bars for wheel hop.
any suggestions/comments/critisms?
-Dave K
i'm an asshole, i know. get over it.
97s104x4 is offline
post #20 of 71 Old 03-05-2010, 12:13 AM
terrible. take a lap.
joyride's Avatar
User is: joyride is offline
Send a message via AIM to joyride
Re: 4.3 Camshaft
heres my list
Head Set- Gaskets
Machined heads
you don't need a high volume oil pump, ive got a built motor and im using a regular oil pump, high volume not needed, and 3/8 arp rocker arm studs, you're gonna have to have machine work for those...and im pretty sure you can reuse your stock lifters...
Brian
01 xtreme 4.3L 5spd 2/3 drop w/ SS front bumper|.030 over|270 comp cam|500 lift|dual valve springs|10:1 C/R|p&p heads w/ 3 angle valve job|w4me tune|shorty headers|2.25 y pipe|no cat|Spintech muffler|windage tray|LW flywheel|DF clutch|8mm wires|no ac|efan|walbro 255|MPFI upgrade|Comp Cam timing chain|ARP bolts/studs|totaled***
Now owner of a white 2002 Blazer Xtreme
http://www.youtube.com/watch?v=CO_A1IrbQNM
85 Monte Carlo SS
KCCO
joyride is offline
post #21 of 71 Old 03-05-2010, 12:46 AM
peace and big boobs to u
phantom_mia's Avatar
User is: phantom_mia is offline
Re: 4.3 Camshaft
i have the old z motor with what is basically the 266hr comp cam and on a warm day(above 70*f) at normal operating temp it tends to get a little lumpy at idle at the traffic lights
i've had it in this configuration for over 9 years it can get upwards of 21-22mpg's, and pulls very well from idle to the rev limiter
my humble $.02 worth
mike
"primer express" 91 RCSB, 4.3 z, 3713 Edelbrock intake and headers, flowmaster exhaust, comp cams 266hr cam and roller tip rockers, ported heads, 3:08 rear. boss 338's 18x8 225/45/18 f 255/55/18 r
ADVANCED FORUM SEARCH
http://www.s10forum.com/forum/search.php
opinions expressed are my humble $.02 worth
post #22 of 71 Old 03-05-2010, 10:12 AM
Newb
97s104x4's Avatar
Re: 4.3 Camshaft
but i do have the right idea correct?
and i always throw an oil pump in high mileage motors i tear apart, i realize about the studs, read an article on it this morning, and that would be nice about the lifters!
so what is the biggest cam we can go, the gives the most horsepower? im not worried about the sound, i want speed.
1997 4.3 Vin X
-Dave K
97s104x4 is offline
post #23 of 71 Old 03-05-2010, 10:38 AM
i need a paint job
s106banger's Avatar
User is: s106banger is offline
Send a message via AIM to s106banger
Re: 4.3 Camshaft
what about the beehive springs and comp 787 (i think) retainers? you can clear .525" without machine work to your heads, not to mention its a better designed valve spring.
1997 S10 266ci V6-turbo. 4l80e. 8.8. 23lbs.
10.93@122
526rwhp 531ftlbs on a mustang dyno @20lbs.
build thread-http://www.s10forum.com/forum/f11/no...r-more-481754/
2002 S10 2.2-DD 80% ZQ8 clone "TuTu Powa" w/efans. 98rwhp 111ftlbs!
post #24 of 71 Old 03-05-2010, 02:13 PM
s10stocker's Avatar
User is: s10stocker is offline
Re: 4.3 Camshaft
http://www.youtube.com/watch?v=OsE9OSm2UdE
http://www.youtube.com/watch?v=JjmfLwL3oQo
1st vid was when I was having distributer placement issues but you can hear the cam. 2nd vid was quickest pass ever in truck which is posted on fastest n/a 4.3 thread.
Now both of those was with only about .390 actual lift on the valve. The cam was ground .425/.425 but due to geometry and less than actual 1.5 ratio rockers the lift was off. Found a 7.5 inch rod was correct length to give most lift. Let me first say that lobe sep, degrees from centerline and duration at .050 give race car lope. Now believe it or not it is easier to make the 2001 and later computers work with a radical cam than the 98-00 and the 96-97s, but all can be done. No I do not drive my truck on the street, but I could if I wanted to or atleast untill it got too hot. You can have a really killer cam and only have .450 lift. Be sure to get the long slot rockers(another story). If you have ever seen a really hot LS1 or LT1 Cam or Bird with the stock ECM under the hood that is proof that stock ECMs are doing what they could do on 4.3s. I would love to do the R&D on this subject myself but I am too busy at this moment. I would find a local tuner who would put in the time of driving and recording data in order to set all of the tables correctly. The most important thing to get out of this is you don't need .500+lift to have a killer cam.
96 S10 N/A 4.3 Racetruck
97 S10 4.3 5s DD for now(will be Racetruck for sale)
02 Yamaha VMAX
94 Chevy 2500 350(was Father-in-laws R.I.P.)
07 Avalanche
It's better to remain silent and let one believe you a fool, than speak and remove all doubt.
post #25 of 71 Old 03-06-2010, 12:24 AM
Newb
97s104x4's Avatar
Re: 4.3 Camshaft
ok so i decided on 270 .510, and i love comp's cam simulator, with my planned mods i should have about 275hp motor wise, my goal is eventually 300...
-Dave K
97s104x4 is offline
post #26 of 71 Old 03-06-2010, 12:30 AM
joyride's Avatar
Re: 4.3 Camshaft
lol what mods are you doing to where the simulator says you should have 275?
Brian
85 Monte Carlo SS
KCCO
joyride is offline
post #27 of 71 Old 03-06-2010, 12:56 AM
Newb
97s104x4's Avatar
Re: 4.3 Camshaft
port and polished heads, valve job, cam, roller rockers, lifters, dual exhaust shorty headers, wiesco pistons, fluid dampener. i have a few more planned but cant remember it all, i plan on spending quite a bit, even though me and pops are doing the work, i will make a project thread when i get the parts.
it already has 175 stock right? i cant tell the difference as the 4.3 ranges from 155-200hp
1997 4.3 Vin X 4X4
-Dave K
97s104x4 is offline
post #28 of 71 Old 03-06-2010, 01:01 AM
joyride's Avatar
Re: 4.3 Camshaft
either 180 or 190 stock...the fluid dampener is gonna be pricey, along with the wiseco pistons....i almost thought about buying a set of those but decided not to...how much are you planning on spending? mines around 5400 right now, not including the cost of getting my tranny rebuilt...lol
Brian
85 Monte Carlo SS
KCCO
joyride is offline
post #29 of 71 Old 03-06-2010, 01:11 AM
Got boost?
03zq8s10's Avatar
Re: 4.3 Camshaft
Actually your truck isn't making but about 140 to the wheels stock. I was pushing 265 to the wheels with my mods in sig before the new fuel setup. I should be seeing closer to 300 to the wheels right now.
03zq8s10 is offline
post #30 of 71 Old 03-06-2010, 01:29 AM
i need a paint job
s106banger's Avatar
Re: 4.3 Camshaft
you better hurry up and get that thing on the dyno! im gonna catch up to you real fast this summer.
10.93@122
post #31 of 71 Old 03-06-2010, 02:45 AM
lsX coming soon..
94s10cpi's Avatar
User is: 94s10cpi is offline
Send a message via Yahoo to 94s10cpi
Re: 4.3 Camshaft
so if i bought this cam from this guy.. (http://www.s10forum.com/classifieds/...ct/55953/cat/6) what all would i need to do to my heads.. i will be using beehive springs.. i wanna try and keep it the price of everything low as possible.. Could i use my factory rockers and whatever else would i use and what can i now use? i've read a lot about different cam swaps but it's been awhile since i've read much and i kinda dont remember all of what i read.. but thanks guy.
1994 S10 CPI 4.10 gears
2002 S10 ZQ8 6.0 l t56 | 3.73s | SW longtubes | 2/2 drop - the daily |
94s10cpi is offline
post #32 of 71 Old 03-06-2010, 09:56 AM
Newb
97s104x4's Avatar
Re: 4.3 Camshaft
whatever it takes to get to 300 N/A.
me and my dad are doing the work so no labor, i just want to see 14's im not too picky...
-Dave K
97s104x4 is offline
post #33 of 71 Old 03-06-2010, 10:13 AM
Got boost?
03zq8s10's Avatar
Re: 4.3 Camshaft
I know!
I need to for real.
Have you gotten the injectors yet?
03zq8s10 is offline
post #34 of 71 Old 03-06-2010, 12:59 PM
joyride's Avatar
Re: 4.3 Camshaft
big custom ground cam, port and polish heads, bigger exhaust valves, probably new valves themselves, manley undercut or something, look way nicer than just having a set of stockers with a valve job, sebast19 has all this and 10:1 C/R and he has 280+ rwhp i think, not exactly 300 quite yet, his xtreme is a beast though...(youtube sebast19 and you'll see his xtreme on the dyno, at the track, running down the freeway with nos screaming, i absolutely love his truck so check it out!! i don't like the way his exhaust sounds though) lol i think he has a tci rattler harmonic balancer too, pricey. i would go with a set of total seal rings, i did...lol i forked out money for those things...im hoping with my setup i can get low 13s to mid 14s and then with a new gear change for the ass end, 373s or 390s i can hopefully be pushing 13s...my goal is 13s just because i think it'd be cool to say im doing that with a n/a v6. lol you're still gonna have to go with a big custom ground cam though to get that much power...but if you read the "fastest n/a 4.3l" thread in this section of the forum, people are pushing 13s door with the 270 cam....im hoping mine will too.
Brian
85 Monte Carlo SS
KCCO
joyride is offline
post #35 of 71 Old 03-06-2010, 01:00 PM
joyride's Avatar
Re: 4.3 Camshaft
I know!
I need to for real.
hey man, are you running true duals or an xpipe? and do you by any chance know if those spintechs, have a single in dual out muffler?? i'm still undecided on what i wanna do for an exhaust...
Brian
85 Monte Carlo SS
KCCO
joyride is offline
post #36 of 71 Old 03-06-2010, 09:03 PM
Newb
97s104x4's Avatar
Re: 4.3 Camshaft
thanks for the info bro!
-Dave K
97s104x4 is offline
post #37 of 71 Old 03-06-2010, 09:27 PM
i need a paint job
s106banger's Avatar
Re: 4.3 Camshaft
I know!
I need to for real.
i actually got a good deal on a marine intake that i couldnt pass up. so im going with that and 42lb injectors, plus i have a 270 sitting in my room, and im doing a new set of heads in my engine class right now with ls6 valve springs, a 3 angle valve job, stock size undercut valves, and light bowl work. the more i learn about heads the more i learn that i messed the ones up that are on there. also picking up hptuners this month and going to a 98 ecu. ive tossed around the idea of intercooling the jammer too
10.93@122
post #38 of 71 Old 03-07-2010, 12:41 AM
joyride's Avatar
Re: 4.3 Camshaft
np, and when i said low 13s to mid 14s...thats a pretty wide range, lol...i meant im shooting for high 13s to mid 14s at worst...i really wanna get into the 13 second range though...we'll see...
the one thing i don't like about my motor swap is how i only put in a 270 cam...if i could do it all over again id go with a bigger custom ground one...but o well. i guess it'll just be a quick parts getter for the 85 monte ss lol
Brian
85 Monte Carlo SS
KCCO
joyride is offline
post #39 of 71 Old 03-07-2010, 03:30 AM
Got boost?
03zq8s10's Avatar
Re: 4.3 Camshaft
True duals with an O/R X pipe. The X pipe makes the tone flow evenly. I have pics of my setup if you'd like to see. Yes, Spintech has a single in dual out muffler. Check out their site. I've been running the Pro shootouts for a while now and I love them. I definitely recommend Spintech.
03zq8s10 is offline
post #40 of 71 Old 03-07-2010, 03:33 AM
Got boost?
03zq8s10's Avatar
Re: 4.3 Camshaft
42lbs? Holy crap man! Also gonna be running the same cam too. Sounds like a plan. I can't wait to get back on the track and lay down some better numbers.
What's the info on the intercooled Jammer? Everytime I mention that to Al over the phone he gets all over me about it.
03zq8s10 is offline
post #41 of 71 Old 03-07-2010, 03:52 AM
joyride's Avatar
Re: 4.3 Camshaft
nice, ya i definitely might just have to give them a shot...tired of my flowmaster. lol
Brian
85 Monte Carlo SS
KCCO
joyride is offline
post #42 of 71 Old 03-07-2010, 12:55 PM
Got boost?
03zq8s10's Avatar
Re: 4.3 Camshaft
Man yeah. Spintech's sound very similar to Flowmaster at idle but reving it and driving it's louder. Also less drone inside the cab which I love. Sounds quiet inside the cab but I let a buddy of mine go up the road. My truck was out of seeing distance and I could still hear it. lol I was like no wonder I piss everyone off. haha
03zq8s10 is offline
post #43 of 71 Old 03-07-2010, 02:05 PM
WICKED 6 RACING
disturbing V6's Avatar
User is: disturbing V6 is offline
Re: 4.3 Camshaft
42LBS with the blower sounds good to me. Granted I say lets see you OD that blower to 15 to 20lbs. Hell I probably be running that on all motor. If the weather man plays nice next Saturday will be there at the track with 90 lbs of juice to tune the truck in for the first weekend of April since thats when the competition begins.
1988 S-10. Built for all out drag racing. 4.3L based 309 nitrous fed power house. Holley Dominator EFI with large amounts of dry nitrous
1.46 60ft
6.4at 112 1/8mile
10.02 at 136 1/4 mile Best MPH 136
1992 S-10 silver Sunday grocery getter.
2000 Z-R2 DD
Complete custom 309 V6 with truck build
post #44 of 71 Old 03-07-2010, 06:38 PM
i need a paint job
s106banger's Avatar
Re: 4.3 Camshaft
i cant wait to get back on the track period. lol.
i was looking at some supercharger setups for the camaros and G8's and figured a simple way of setting up an intercooler on my truck much like those setups. right now its just an idea, if i have like 250-300 bucks this summer ill pick up the stuff to do it and try it. im also thinking about buyin a smaller pulley from Al, i wanna see what my intake temps are before i start spinning the jammer faster though. i might just start saving up money for a procharger head unit, a d1sc, instead of trying to get more boost out of the wynjammer.
10.93@122
post #45 of 71 Old 03-07-2010, 07:05 PM
Got boost?
03zq8s10's Avatar
Re: 4.3 Camshaft
Me too man I'm ready. Check out my new wheel setup in the Xtreme/ZQ8 section.
I love Wynjmmer but it doesn't matter how much I have I always want more. It seems only a few guys have tried the new 36lb injector setup. It feels a lot stronger than before so I'm happy. I may ask Al about a smaller pulley as well. Now that I'm fueling mine better. Like we both stated before we're seeing as much as 10 psi on our head units. I don't know what else to do to my truck now. I want to do a 75-100 shot but don't know how it'll hold up. What do you think?
03zq8s10 is offline
post #46 of 71 Old 03-07-2010, 07:07 PM
Got boost?
03zq8s10's Avatar
Re: 4.3 Camshaft
That sounds great to me. Make sure you get a video or two!
03zq8s10 is offline
post #47 of 71 Old 03-07-2010, 11:38 PM
i need a paint job
s106banger's Avatar
Re: 4.3 Camshaft
ill check out the wheels.
we can push more boost with our head units, but at what point is the efficiency going to drop off or are we going to start ripping through bearings? boost also makes heat so your gonna need an intercooler to push it the furthest you can too.
i would start with a smaller shot and work your way up tunning it each time, you are still on the stock short.. then when you blow it up build a new motor.
10.93@122
post #48 of 71 Old 03-08-2010, 01:25 AM
ΜΟΛΩΝ ΛΑΒΕ!
1fast4by's Avatar
Re: 4.3 Camshaft
S10stocker, Mine sounds really similar to that. Mine is a custom grind Based off the 270 with .525/.525 lift and 1.6 rollers..
-Jeff Cooper
Ban gun free zones!
1fast4by is offline
post #49 of 71 Old 03-08-2010, 05:28 PM
s10stocker's Avatar
Re: 4.3 Camshaft
Next time out I will do a walk around recording since the spring change which I am sure they made the sound change unless I'm going crazy or my brain wants to hear a change. I'm running out of time before the Cajun Sports Nationals. After one fairly clean 12.40 pass at 104.91 weighing about 3040lbs the engine went stupid. Found some valve setting changed and a broken rocker arm. Originally thought it was RA flex but found I was actually hitting the studs. I opened up the holes on one set and sent off another set for Cryo. I will try the opened up set first since the Cryoed set won't be in until Friday or Monday. Depending on weather I will test Wednesday or Friday but I will race the Cajun Sports Nationals one way or another. Keep track on dragracecentral if interested.
P.S. Ever think your engine doesn't sound as good recorded or is it just me?
02 Yamaha VMAX
07 Avalanche
post #50 of 71 Old 05-19-2010, 03:49 AM
User is: BigOGreg is offline
Re: 4.3 Camshaft
i got a 2001 dime with a 4.3 what is the biggest cam (duration) and lift that you can put in a 4.3. i got a fresh block that's 0.60 over and I'm picking out a cam. i got head work done 2.02 and 1.6 valves, roller rockers, and mechanical roller lifters. trying to get higher RPM . I'm trying to use the stock computer ... does anyone know what will the factory ECU will let me adjust to. im aware that some ECUs will not let you do any adjustment beyond a certain point.
If your wondering its a budget street/strip truck
BigOGreg is offline
